SML-011VTT86A
SML-011VTT86A
    ROHM(罗姆)
    发光二极管/LED 红色 1208 630nm 63mcd
SML-011VTT86A 数据手册
SML-010x/011x Series      ■Features • Reflector type (3.0×2.0mm, t=1.3mm) • Reflector improved the concentration of viewing angle and luminous intensity to the front direction Data Sheet ■Outline ■Size Color Type 3020 (1208) 3.0×2.0mm (t=1.3mm) V U D Y M P ■Dimensions ■Recommended Solder Pattern 3.0 1.3 0.3 0.5 1.6 2.0 1.6 2.3 +0.2 -0.1 1.45 Through Hole Cathode Index 1.5 1.45 2-R0.3 1.7 PCB Bonding Direction Tolerance : ±0.2 ■Moisture sensitivity level(MSL) : (unit : mm) (unit : mm) Electrode 1.6 Level 3 ■Specifications Absolute Maximum Ratings (Ta=25ºC) Part No. Emitting Power Forward Peak Forward Reverse Chip Structure Dissipation SML-010VT Red SML-010DT Orange SML-010MT SML-010PT Yellow Typ. Current Current Voltage PD(mW) IF(mA) IFP(mA) VR(V) GaAsP Forward Voltage VF Topr(ºC) Tstg(ºC) (V) IF VR Min. (V) (nm) (nm) (nm) (mA) (mcd) (mcd) (mA) 10 25 60*1 4 -30〜+85 -40〜+85 2.1 2.2 100 Green - 4 20 Typ. Max. 650 - 610 - 3.6 10 - 2.2 6.3 - 570 - - 555 - Red - 630 - - 611 - - 590 - - 639 - - 611 - - 590 - Yellow Red SML-011DT(A) Orange SML-011YT(A) Yellow 75 30 100*2 5 -40〜+100 -40〜+100 2.0 10 10 5 20 10 IF 6.3 585 Orange AlGaInP 2.2 Typ. - SML-011DT SML-011VT(A) Min. - SML-011UT SML-011YT IF Luminous Intensity IV Max. 2.0 70 Peak Wavelength λP (mA) (μA) Yellow Green GaP Reverse Current IR Operating Temp. Storage Temp. Color SML-010YT Electrical and Optical Characteristics (Ta=25ºC) 5.6 25 2.2 6.3 22 63 14 28 22.4 45 20 10 11.2 22.4 *1: Duty1/5 pulse width 1ms *2 : Duty1/10 1kHz ________________________________________________________ www.rohm.co.jp 1/11 ©2020 ROHM Co., Ltd. All rights reserved 2020.4 - Rev.002 [SML-010x/011x series] [Data Sheet]      ■Electrical Characteristics Curves Reference Fig.2 Luminous Intensity      Atmosphere Temperature 100 FORWARD CURRENT : IF [mA] SML-010VT SML-010DT SML-010YT SML-010MT SML-010PT Ta=25ºC 10 1 1 1.2 1.4 1.6 1.8 2 2.2 2.4 2.6 2.8 3 RELATIVE LUMINOUS INTENSITY [a.u.] Fig.1 Forward Current - Forward Voltages FORWARD VOLTAGE : VF [V] SML-010VT SML-010DT SML-010YT SML-010MT SML-010PT 0.9 0.6 0.3 5 10 15 20 FORWARD CURRENT : IF [mA] 25 MAXIMUM FORWARD CURRENT : [mA] RELATIVE LUMINOUS INTENSITY Ta=25ºC 0 1.4 1.2 1 0.8 SML-010VT SML-010DT SML-010YT SML-010MT SML-010PT 0.6 0.4 -40 -30 -20 -10 0 10 20 30 40 50 60 70 80 90 100 Fig.4 Derating 1.5 0 IF=20mA ATMOSPHERE TEMPERATURE : Ta [ºC] Fig.3 Luminous Intensity - Forward Current 1.2 1.6 30 28 26 24 22 20 18 16 14 12 10 SML-010VT SML-010DT SML-010YT SML-010MT SML-010PT 8 6 4 2 0 -40 -20 0 20 40 60 80 100 AMBIENT TEMPERATURE : Ta [ºC] ________________________________________________________ www.rohm.co.jp 2/11 ©2020 ROHM Co., Ltd. All rights reserved 2020.4 - Rev.002 [SML-010x/011x series] [Data Sheet]      ■Electrical Characteristics Curves Reference Fig.2 Luminous Intensity      Atmosphere Temperature RELATIVE LUMINOUS INTENSITY [a.u.] Fig.1 Forward Current - Forward Voltages FORWARD CURRENT : IF [mA] 100 Ta=25ºC SML-011UT SML-011DT SML-011YT 10 1 1.0 1.5 2.0 2.5 3.0 1.6 1.2 1.0 0.8 0.6 0.4 0.2 2.0 Ta=25ºC SML-011UT SML-011DT SML-011YT 1.5 1.0 0.5 5 10 15 20 25 FORWARD CURRENT : IF [mA] -40 -30 -20 -10 0 10 20 30 40 50 60 70 80 90 100 Fig.4 Derating 30 MAXIMUM FORWARD CURRENT : [mA] RELATIVE LUMINOUS INTENSITY Fig.3 Luminous Intensity - Forward Current 0 SML-011UT SML-011DT SML-011YT ATMOSPHERE TEMPERATURE : Ta [ºC] FORWARD VOLTAGE : VF [V] 0.0 IF=20mA 1.4 40 SML-011UT SML-011DT SML-011YT 30 20 10 0 -40 -30 -20 -10 0 10 20 30 40 50 60 70 80 90 100 AMBIENT TEMPERATURE : Ta [ºC] ________________________________________________________ www.rohm.co.jp 3/11 ©2020 ROHM Co., Ltd. All rights reserved 2020.4 - Rev.002 [SML-010x/011x series] [Data Sheet]      ■Electrical Characteristics Curves Reference Fig.2 Luminous Intensity      Atmosphere Temperature RELATIVE LUMINOUS INTENSITY [a.u.] Fig.1 Forward Current - Forward Voltages FORWARD CURRENT : IF [mA] 100 Ta=25ºC SML-011VT(A) SML-011DT(A) SML-011YT(A) 10 1 1.0 1.5 2.0 2.5 3.0 RELATIVE LUMINOUS INTENSITY 3.0 Ta=25ºC 2.0 1.0 0 5 10 15 20 25 FORWARD CURRENT : IF [mA] 1.2 1.0 0.8 0.6 0.4 0.2 SML-011VT(A) SML-011DT(A) SML-011YT(A) -40 -30 -20 -10 0 10 20 30 40 50 60 70 80 90 100 Fig.4 Derating 30 MAXIMUM FORWARD CURRENT : [mA] Fig.3 Luminous Intensity - Forward Current 0.0 IF=10mA 1.4 ATMOSPHERE TEMPERATURE : Ta [ºC] FORWARD VOLTAGE : VF [V] SML-011VT(A) SML-011DT(A) SML-011YT(A) 1.6 40 SML-011VT(A) SML-011DT(A) SML-011YT(A) 30 20 10 0 -40 -30 -20 -10 0 10 20 30 40 50 60 70 80 90 100110 AMBIENT TEMPERATURE : Ta [ºC] ________________________________________________________ www.rohm.co.jp 4/11 ©2020 ROHM Co., Ltd. All rights reserved 2020.4 - Rev.002 [SML-010/011 series] [Data Sheet]      ■Viewing Angle Reference SCANNING ANGLE (deg) X - Y スキャン方向 (Scanning Direction) SCANNING ANGLE (deg) SML-010/ 011 series 0 10 10 20 20 30 30 40 40 50 50 60 60 70 70 80 90 100 X 80 50 0 50 RELATIVE INTENSITY (%) 90 100 Y RELATIVE INTENSITY (%) ________________________________________________________ www.rohm.co.jp 5/11 ©2020 ROHM Co., Ltd. All rights reserved 2020.4 - Rev.002 [SML-010x/011x series] [Data Sheet]      ■Rank Reference of Brightness* *Measurement tolerance:±10% Red(V,U) Rank Iv (mcd) SML-010VT Rank Iv (mcd) SML-011UT (Ta=25ºC, IF=20mA) J K L M N P Q R S T U V 2.5〜4.0 4.0〜6.3 6.3〜10 10〜16 16〜25 25〜40 40〜63 63〜100 100〜160 160〜250 250〜400 400〜630 J K L M 9〜18 2.2〜4.5 3.6〜7.1 5.6〜11 N P Q R S T U V 14〜28 22〜45 36〜71 56〜110 90〜180 140〜280 220〜450 360〜710 W X 630〜1000 1000〜1600 W X 560〜1100 900〜1800 (Ta=25ºC, IF=10mA) Rank Iv (mcd) AG AH 9.0〜11.2 11.2〜14 SML-011VT(A) AJ 14〜18 AK AL AM AN 18 〜22.4 22.4〜28 28〜35.5 35.5〜45 AP AQ AR AS AT AU AV AW AX AY AZ 45〜56 56〜71 71〜90 90〜112 112〜140 140〜180 180〜224 224〜280 280〜355 355〜450 450〜560 ∗Please note that the brightness of some products may fall between ranks (half rank) Orange(D) Rank Iv (mcd) SML-010DT Rank Iv (mcd) SML-011DT Rank Iv (mcd) (Ta=25ºC, IF=20mA) J K L M N P Q R S T U V 2.5〜4.0 4.0〜6.3 6.3〜10 10〜16 16〜25 25〜40 40〜63 63〜100 100〜160 160〜250 250〜400 400〜630 J K L M 9〜18 2.2〜4.5 3.6〜7.1 5.6〜11 N P Q R S T U V 14〜28 22〜45 36〜71 56〜110 90〜180 140〜280 220〜450 360〜710 W X 630〜1000 1000〜1600 W X 560〜1100 900〜1800 (Ta=25ºC, IF=10mA) AG AH 9.0〜11.2 11.2〜14 SML-011DT(A) AJ 14〜18 AK AL AM AN 18 〜22.4 22.4〜28 28〜35.5 35.5〜45 AP AQ AR AS AT AU AV AW AX AY AZ 45〜56 56〜71 71〜90 90〜112 112〜140 140〜180 180〜224 224〜280 280〜355 355〜450 450〜560 ∗Please note that the brightness of some products may fall between ranks (half rank) Yellow(Y) Rank Iv (mcd) SML-010YT Rank Iv (mcd) SML-011YT Rank Iv (mcd) (Ta=25ºC, IF=20mA) J K L M N P Q R S T U V 2.5〜4.0 4.0〜6.3 6.3〜10 10〜16 16〜25 25〜40 40〜63 63〜100 100〜160 160〜250 250〜400 400〜630 J K L M 9〜18 2.2〜4.5 3.6〜7.1 5.6〜11 N P Q R S T U V 14〜28 22〜45 36〜71 56〜110 90〜180 140〜280 220〜450 360〜710 W X 630〜1000 1000〜1600 W X 560〜1100 900〜1800 (Ta=25ºC, IF=10mA) AG AH 9.0〜11.2 11.2〜14 SML-011YT(A) AJ 14〜18 AK AL AM AN 18 〜22.4 22.4〜28 28〜35.5 35.5〜45 AP AQ AR AS AT AU AV AW AX AY AZ 45〜56 56〜71 71〜90 90〜112 112〜140 140〜180 180〜224 224〜280 280〜355 355〜450 450〜560 ∗Please note that the brightness of some products may fall between ranks (half rank) Yellow Green/Green(M,P) Rank Iv (mcd) SML-010MT SML-010PT J K L (Ta=25ºC, IF=20mA) M N P Q R S T U V 2.5〜4.0 4.0〜6.3 6.3〜10 10〜16 16〜25 25〜40 40〜63 63〜100 100〜160 160〜250 250〜400 400〜630 W X 630〜1000 1000〜1600 ________________________________________________________ www.rohm.co.jp 6/11 ©2020 ROHM Co., Ltd. All rights reserved 2020.4 - Rev.002 [SML-010x/011x series] [Data Sheet]      1.75 ±0.1 ■Taping(T86) ±0.1 4 2 ±0.05 φ1.5 +0.1 0 8.0 5.5 0~0.5 3.4 3.5 ±0.05 Cathode index 2.4 ±0.1 1.6 0 +1 0 φ60 φ180 -3 φ13 11.4 ±1 Unit:mm Packing quantity 2,500pcs/reel Note)Tolerance is within ±0.2mm unless Pull direction otherwise specified. ■Part No. Construction *"-"will be taken out for emitting color Special Code will be applied for Chromaticity rank Rank sign WB/B/E series. Emitting color WB/B/E series. (for white LED) (Brightness Rank)* S M L - Series name SML Chip LED 0 1 0 Package Type Chip type D T Emitting Color Resin Color 6 0 Standard Type V Red T 1 Low Current Type U Red W Milky White D1 1.6x0.8 t=0.55mm 2 High Brightness type U2 Red B H1 3 D Orange 2.0x1.25 t=0.8mm 4 Y3 Yellow Y2 Yellow Y Yellow 7 W Yellow 8 M2 Yellowish green 01 3.0x2.0 t=1.3mm 5 3.5x2.8 t=1.9mm 6 A1 1.6x1.15 t=0.55mm 3.4x1.25 t=1.1mm 81/82 Ultra High Brightness type K1 4.5x2.0 t=0.6mm M Yellowish green S1 3.2x1.6 t=1.85mm F Green P2 1.0x1.0 t=0.2mm P Green 52 1.3x1.5 t=0.6mm E Green P34 1.0x1.0 t=0.2mm B Blue P36 1.5x1.0 t=0.2mm WB White VN 3.5x2.8 t=0.6mm T Phototransistors RGB 01 3.0x1.5 t=2.2mm Red/Green/Blue K Taping Specification E1 1.6x0.8 t=0.36mm Z1/ZN Chip LED 8 P1 1.0x0.6 t=0.2mm M1 SCM T Transparent Colorless T86 Cathode at sprocket hole side(the top) Black *Concerning the Brightness rank. *Please refer to the rank chart above for luminous intensity classification. *Part name is individual for each rank. *When shipped as sample,the part name will be a representative part name. General products are free of ranks. Please contact sales if rank appointment is needed. ■Packing Specification Complying with IPC/JEDEC J-STD-033. ________________________________________________________ www.rohm.co.jp 7/11 ©2020 ROHM Co., Ltd. All rights reserved 2020.4 - Rev.002 [SML-010x/011x series]      [Data Sheet] ■Precaution (Surface Mount Device) 1.Storage If the product is heated during the reflow under the condition of hygroscopic state, it may vaporize and expand which will influence the performance of the product. Therefore, the package is waterproof. Please use the product following the conditions: ・Using Conditions Classification Temperature Humidity Expiration Date Remark Within 1 year ①Before using 5〜30℃ 30〜70%RH Storage with waterproof package from Receiving ②After opening Please storing in the airtight container 5〜30℃ Below 70%RH Within 168h package with our desiccant (silica gel) ・Baking Bake the product in case of below: ①The expiration date is passed. ②The color of 5% and 10% on humidity indicator card is not green. (Even if the product is before expiration date.) ・Baking Conditions Temperature Time Humidity 60±3℃ 12〜24h Below 20%RH ・Bake products in reel. ・Reel and embossed tape are easy to be deformed when baking, Remark so please try not to apply stress on it. ・Recommend bake once. 2.Application Methods 2-1.Precaution for Drive System and Off Mode Design the circuit without the electric load exceeding the ABSOLUTE MAXIMUM RATING that applies on the products. If drive by constant voltage, it may cause current deviation of the LED and result in deviation of luminous intensity, so we recommend to drive by constant current. (Deviation of VF Value will cause deviation of current in LED.) Furthermore, for off mode, please do not apply voltage neither forward nor reverse. Especially, for the products with the Ag-paste used in the die bonding, there’s high possibility to cause electro migration and result in function failure. 2-2.About Derating  It is considered that derating characteristics will not result in LED chip's electrical destruction. Even within the derating, the reliability and luminous life can be affected depending on operating conditions and ambient environment. So we would be appreciate it if you can confirm with your application again. 2-3.About product life Depending on operating conditions and environment(applied current, ambient temperature and humidity, corrosive gas), decreasing of luminosity and change of chromaticity may occur even within the specification conditions. Please contact our sales office if you use it for the following applications. ①It requires long luminosity life ②It is always lit 2-4.Applied Stress on Product No resin hardening agent such as filler is used in the sealing resin of the product. Therefore, please pay attention to the overstress on it which may influence its reliability. 2-5.Usage The Product is LED. We are not responsible for the usage as the diode such as Protection Chip, Rectifier, Switching and so on. ________________________________________________________ www.rohm.co.jp 8/11 ©2020 ROHM Co., Ltd. All rights reserved 2020.4 - Rev.002 [SML-010x/011x series]      [Data Sheet] 3.Others 3-1.Surrounding Gas Notice that if it is stored under the condition of acid gas (chlorine gas, sulfured gas) or alkali gas (ammonia), it may result in low soldering ability (caused by the change in quality of the plating surface ) or optical characteristics changes (light intensity, chrominance) and change in quality of cause die bonding (Ag-paste) materials. All of the above will function failure of the products. Therefore, please pay attention to the storage environment for mounted product (concern the generated gas of the surrounding parts of the products and the atmospheric environment). 3-2.Electrostatic Damage The product is part of semiconductor and electrostatic sensitive, there’s high possibility to be damaged by the electrostatic discharge. Please take appropriate measures to avoid the static electricity from human body and earthing of production equipment. Especially, InGaN type LEDs have lower resistance value of electrostatic discharge and it is recommended to introduce the ESD protection circuit. The resistance values of electrostatic discharge (actual values) vary with products, therefore, please call our Sales staffs for inquiries. 3-3. Electromagnetic Wave Applications with strong electromagnetic wave such as, IH cooker, will influence the reliability of LED, therefore please evaluate before using it. ________________________________________________________ www.rohm.co.jp 9/11 ©2020 ROHM Co., Ltd. All rights reserved 2020.4 - Rev.002 [SML-010x/011x series] [Data Sheet]      4.Mounting 4-1. Soldering ・No resin hardening agent such as filler is used in the sealing resin of the product. Therefore, resin expansion and moisture absorption at humidity will cause heat stress during soldering process and finally has bad influence on the product’s reliability. ・The product is not guaranteed for flow soldering. ・Do not expose the product in the environment of high temperature (over 100℃) or rapid temperature shift (within 3℃/sec. of temperature gradient) during the flow soldering of surrounding parts. In case of carrying out flow soldering of surrounding parts without recommended conditions, please contact us for inquiries. ・Please set appropriate reflow temperature based on our product usage conditions and specification. ・The max for reflowing is 2 times, please finish the second reflow soldering and flow soldering with other parts within the usage limitation after open the moistureproof package. ・Compare with N2 reflow, during air reflow, because of the heat and surrounding conditions, it may cause the discoloration of the resin. ・For our product that has no solder resist, because of its solder amount and soldering conditions,  one of its specific characteristics is that solder will penetrate into LED. Thus, there's high possibility that will influence its reliability.Therefore, please be informed, concerning it before using it. 4-2. Automatic Mounting 4-2-1. Suction nozzle Excessive load may cause damage inside the LED product, so select an optimal suction nozzle according to the material and shape of the LED product. 4-2-2. Mini Package (Smaller than 1608 size) ・Vibration may result in low mounting rate since it will cause the static electricity of product and adhere to top cover tape. Therefore, the magnet should be set on parts feeder cassette of the mounter to control the product stabilization. In addition, it is recommended to set ionizer to prevent electrostatic charge. 4-3. Mounting Location The stress like bending stress of circuit board dividing after mounting, may cause LED package crack or damage of LED internal junction, therefore, please concern the mounting direction and position to avoid bending or screwing with great stress of the circuit board. Stress strength according to he mounting position: A>B>C>D 4―4. Mechanical Stress after Mounting The mechanical stress may damage the LED after Circuit Mounting, so please pay attention to the touch on product. 4-5.Soldering Pattern for Recommendation We recommend the soldering pattern that shows on the right. It will be different according to mounting situation of circuit board, therefore, please concern before designing. ※The product has adopted the electrode structure that it should solder with back electrode of the product. Thus, please be informed that the shape of electrode pin of solder fillet formation is not guaranteed. The through hole on electrode surface is for conduction of front  and rear electrodes but not for formation of solder fillet. 1.6mm 1.45mm 1.5mm 1.45mm PCB Bonding Direction ________________________________________________________ www.rohm.co.jp 10/11 ©2020 ROHM Co., Ltd. All rights reserved 2020.4 - Rev.002 [SML-010x/011x series] [Data Sheet]      4-6.Reflow Profile For reflow profile, please refer to the conditions below:(※) ■Meaning of marks, Conditions Mark Tsmax Tsmin ts TL tL TP tP ΔTR/Δt ΔTD/Δt Meanings Maximum of pre-heating temperature Minimum of pre-heating temperature Time from Tsmin to Tsmax Reference temperature Retention time for TL Peak temperature Time for peak temperature Temperature rising rate Temperature decreasing rate Conditions 180℃ 140℃ Over 60sec. 210〜250℃ Within 40sec. 250℃(Max) Within 10sec. Under 3℃/sec. Over -3℃/sec. ※Above conditions are for reference. Therefore, evaluate by customer’s own circuit boards and reflow furnaces before using, because stress from circuit boards and temperature variations of reflow furnaces vary by customer’s own conditions. 4-7.Attention Points in Soldering Operation This product was developed as a surface mount LED especially suitable for reflow soldering. So reflow soldering is recommended. In case of implementing manual soldering, please take care of following points. ①SOLDER USED Sn-Cu,Sn-Ag-Cu,Sn-Ag-Bi-Cu ②HAND SOLDERING CONDITION LED products do not contain reinforcement material such as a glass fillers. So thermal stress by soldering greatly influence its reliability. Please keep following points for manual soldering. ITEM a) b) RECOMMENDED CONDITION Condition ) Temp. of iron top less than 400℃ within 3 sec. Heating method Heating on PCB pattern, not direct to the LED. (Fig-1) Handling after Please handle after the part temp. soldering goes down to room temp. Fig-1 SOLDERING IRON SOLDERING LAND 4-8.Cleaning after Soldering Please follow the conditions below if the cleaning is necessary after soldering. Solvent We recommend to use alcohols solvent such as, isopropyl alcohols Temperature Under 30℃ within 3 minutes Ultrasonic Cleaning 15W/Below 1 liter (capacity of tank) Drying Under 100℃ within 3 minutes ________________________________________________________ www.rohm.co.jp 11/11 ©2020 ROHM Co., Ltd. All rights reserved 2020.4 - Rev.002
SML-011VTT86A 价格&库存
很抱歉,暂时无法提供与“SML-011VTT86A”相匹配的价格&库存,您可以联系我们找货
SML-011VTT86A
    • 1+1.486431+0.19323
    • 300+1.07353300+0.13956
    • 500+0.99095500+0.12882
    • 1000+0.990951000+0.12882
    • 4000+0.908374000+0.11809
    • 5000+0.908375000+0.11809
    • 10000+0.9083710000+0.11809
    库存:1320
    SML-011VTT86A
    • 1+4.588151+0.59645
    • 10+3.1498210+0.40947
    • 100+2.25705100+0.29341
    • 500+1.85649500+0.24134
    • 1000+1.724681000+0.22421
    库存:2500
    SML-011VTT86A
      • 1+1.25129
      • 200+0.49929
      • 500+0.48266
      • 1000+0.47434
      SML-011VTT86A
      • 5+4.53243
      • 10+3.12050
      • 100+2.24249
      • 500+1.85094
      • 1000+1.72043
      库存:317
      SML-011VTT86A
      • 5+4.53243
      • 10+3.12050
      • 100+2.24249
      • 500+1.85094
      • 1000+1.72043
      库存:317
      SML-011VTT86A
      • 2500+1.580182500+0.20542
      • 5000+1.489885000+0.19368
      • 7500+1.443557500+0.18766
      • 12500+1.3912212500+0.18086
      • 17500+1.3600917500+0.17681
      • 25000+1.3297325000+0.17286
      库存:2500
