Data Sheet
SML-21 Series
2012 0805) ( 2.0×1.25mm t=0.8mm) ( Features ・ Abundant color variations with diverse luminous intensity types
Color Type
V W
U M
D P
Y
Specifications
Part No.
■ SML-212VT ■ SML-210VT ■ SML-212U2T(A) ■ SML-211UT ■ SML-212DT ■ SML-211DT ■ SML-210DT ■ SML-212WT(A) ■ SML-211WT ■ SML-212YT ■ SML-211YT ■ SML-210YT ■ SML-210MT
Absolute Maximum Ratings (Ta=25℃) Electrical and Optical Characteristics (Ta=25℃) Emitting Power Chip Forward Voltage VF Reverse Current IR Dominant Wavelength λD Luminous Intensity IV Forward Peak Forward Reverse Operating Storage Structure Color Dissipation Current Current Voltage Temperature Temperature Max. Min.*3 Typ. Max.*3 Min. Typ. PD(mW) IF(mA) IFP(mA) VR(V) Topr(℃) Tstg(℃) Typ.(V) IF(mA) (μA) VR(V) (nm) (nm) (nm) IF(mA) (mcd) (mcd) IF(mA) AIGaInP 75 30 2.05 22 63 on GaAs 60*1 4 -30 to +85 -40 to +85 100 4 625 630 635 GaAsP 70 25 1.4 4 20 20 20 on GaP 2 Red 5 -40 to +100 -40 to +100 10 5 611 615 619 71 140 75 30 100*2 AIGaInP on GaAs Orange GaAsP on GaP 44 75 44 70 75 AIGaInP on GaAs 44 Yellow 75 44 GaAsP on GaP GaP Yellowish Green Green 70 25 2.2 557 560 563 1.4 4 *1:Duty1/5, 200Hz / *2:Duty1/10, 1kHz / *3:Reference 20 30 20 25 30 20 30 20 60*1 4 -30 to +85 -40 to +85 2.1 20 567 570 573 20 100*2 2 5 -40 to +100 -40 to +100 1.8 2.05 1.8 2 20 2 100 4 2.2 3.6 6.3 16 20 584 587 590 20 10 5 587 590 593 2 20 2 1.4 22 1.4 4 63 4 2 20 2 20 112 224 60*1 4 -30 to +85 -40 to +85 1.8 2 1.8 2.05 2 20 100 4 602 605 608 2 0.9 2.2 2.5 6.3 20 2 615 620 625 2 20 0.9 25 2.5 63 2 20
■ SML-210PT
Dimensions
2.0 1.4
Recommended Solder Pattern Viewing Angle
SML-21 Series
Angular Displacement (deg) Directivity (deg)
X Y
X’ Y’
20° 30° 40° 50°
10°
0°
10°
20° 30° 40° 50° 60° 70° 80°
20° 30° 40°
10°
0°
10°
1.1
1.25
50° 60° 70° 80° 90° 100 50 0 50
60° 70°
1.25
80° 90° 100 50 0 50
Cathode mark
90° 100
90° 100
RELATIVE LUMINOUS INTENSITY (%) RELATIVE INTENSITY (%)
0.25
0.8
1.2 Terminal
Tolerance : ±0.1 (unit : mm)
(unit : mm)
www.rohm.com
© 2010 ROHM Co., Ltd. All rights reserved.
1.25
1.1
1/2
2010.05 - Rev.A
SML-21 Series
Electrical Characteristics Curves Forward Current-Forward Voltage
Ta=25°C
100
FORWARD CURRENT:IF (mA)
10
10
■SML-212VT ■SML-212DT ■SML-212YT ■SML-212U2T(A) ■SML-212WT(A)
100
Ta=25°C
■SML-211UT ■SML-211DT ■SML-211WT ■SML-211YT
Ta=25°C
100
■SML-210VT ■SML-210DT ■SML-210YT ■SML-210MT ■SML-210PT
10
1
1 1.5
2.0
2.5
0.1 1.5
2.0
2.5
1 1.5
2.0
2.5
FORWARD VOLTAGE:VF (V)
Luminous Intensity-Atmosphere Temperature
1.6 RELATIVE LUMINOUS INTENSITY (a.u.) 1.4 1.2 1.0 0.8 0.6 0.4 -40 IF=20mA
1.6
IF=2mA
1.6 1.4 1.2 1.0 0.8 0.6 0.4 -40
IF=20mA
-20
60
80
100
-20
60
80
100
-20
60
80
100
ATMOSPHERE TEMPERATURE:Ta (°C)
Luminous Intensity-Forward Current
1.5
Ta=25°C
10 8 6 4 2 0 0 5 10 15 20
1.0
12
Ta=25°C
1.5
Ta=25°C
1.0
0.5
0.5
0 0 5 10 15 20
0.0 0 5 10 15 20 25
Derating
MAXIMUM FORWARD CURRENT:IF (mA) MAXIMUM FORWARD CURRENT:IF (mA) MAXIMUM FORWARD CURRENT:IF (mA)
40
30
30
30
10
10
0 -40
-20
60
80
100
0 -40
-20
60
80
100
0 -40
-20
60
80
100
AMBIENT TEMPERATURE:Ta (°C)
www.rohm.com
2/2
2010.05 - Rev.A
Notice
Notes
No copying or reproduction of this document, in part or in whole, is permitted without the consent of ROHM Co.,Ltd. The content specified herein is subject to change for improvement without notice. The content specified herein is for the purpose of introducing ROHM's products (hereinafter "Products"). If you wish to use any such Product, please be sure to refer to the specifications, which can be obtained from ROHM upon request. Examples of application circuits, circuit constants and any other information contained herein illustrate the standard usage and operations of the Products. The peripheral conditions must be taken into account when designing circuits for mass production. Great care was taken in ensuring the accuracy of the information specified in this document. However, should you incur any damage arising from any inaccuracy or misprint of such information, ROHM shall bear no responsibility for such damage. The technical information specified herein is intended only to show the typical functions of and examples of application circuits for the Products. ROHM does not grant you, explicitly or implicitly, any license to use or exercise intellectual property or other rights held by ROHM and other parties. ROHM shall bear no responsibility whatsoever for any dispute arising from the use of such technical information. The Products specified in this document are intended to be used with general-use electronic equipment or devices (such as audio visual equipment, office-automation equipment, communication devices, electronic appliances and amusement devices). The Products specified in this document are not designed to be radiation tolerant. While ROHM always makes efforts to enhance the quality and reliability of its Products, a Product may fail or malfunction for a variety of reasons. Please be sure to implement in your equipment using the Products safety measures to guard against the possibility of physical injury, fire or any other damage caused in the event of the failure of any Product, such as derating, redundancy, fire control and fail-safe designs. ROHM shall bear no responsibility whatsoever for your use of any Product outside of the prescribed scope or not in accordance with the instruction manual. The Products are not designed or manufactured to be used with any equipment, device or system which requires an extremely high level of reliability the failure or malfunction of which may result in a direct threat to human life or create a risk of human injury (such as a medical instrument, transportation equipment, aerospace machinery, nuclear-reactor controller, fuelcontroller or other safety device). ROHM shall bear no responsibility in any way for use of any of the Products for the above special purposes. If a Product is intended to be used for any such special purpose, please contact a ROHM sales representative before purchasing. If you intend to export or ship overseas any Product or technology specified herein that may be controlled under the Foreign Exchange and the Foreign Trade Law, you will be required to obtain a license or permit under the Law.
Thank you for your accessing to ROHM product informations. More detail product informations and catalogs are available, please contact us.
ROHM Customer Support System
http://www.rohm.com/contact/
www.rohm.com © 2010 ROHM Co., Ltd. All rights reserved.
R1010A
很抱歉,暂时无法提供与“SML-212VT”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 5+0.79958
- 50+0.6322
- 150+0.54851
- 国内价格
- 5+0.78165
- 50+0.62632
- 600+0.62006
- 1200+0.60766
- 3000+0.58943
- 国内价格
- 5+0.5588
- 50+0.45002
- 600+0.35486
- 1200+0.34954
- 3000+0.32222
- 国内价格
- 5+0.63533
- 50+0.49774
- 150+0.42895
- 国内价格
- 10+0.48688
- 100+0.38818
- 600+0.3843
- 1200+0.37661
- 3000+0.36531
- 国内价格
- 1+0.78401
- 30+0.75601
- 100+0.72801
- 500+0.67201
- 1000+0.64401
- 2000+0.62721
