Data Sheet
SML-M1 Series
20125 0805) ( 2.0×1.25mm t=0.8mm) ( Features ・ Compact LED with reflector ・ Die is located at the center of the package,achieving equivalent distribution of light emission. ・ New emitting color,including the pastel colors available upon request.
HB GB CB AB SB
Warm White
Specifications
Part No.
■ SML-M13VT ■ SML-M13UT ■ SML-M13DT ■ SML-M13YT ■ SML-M13MT ■ SML-M13PT ■ SMLM12BC7T ■ SMLM12WBC7W
Absolute Maximum Ratings (Ta=25℃) Electrical and Optical Characteristics (Ta=25℃) Chip Emitting Power Forward Voltage VF Reverse Current IR Dominant Wavelength λD Luminous Intensity IV Forward Peak Forward Reverse Operating Storage Structure Color Dissipation Current Current Voltage Temperature Temperature Typ. Min.*2 Typ. Max.*2 Max. Min. Typ. PD(mW) IF(mA) IFP(mA) VR(V) Topr(℃) Tstg(℃) (V) IF(mA) (μA) VR(V) (nm) (nm) (nm) IF(mA) (mcd) (mcd) IF(mA) Red Orange Yellow Yellowish Green Green InGaN Blue White 68 63 25 100* 30 20 -30 to +85 -40 to +100
1
625 2.0 -40 to +85 5 -40 to +100 2.2 100 10 20*1 10 5 615 602 587 569 557 5*1 465
630 620 605 590 572 560 470
635 625 608 593 575 563 475 5 20
40 63 100 25 6.3 56
75 120 200 160 45 16 36 100 5 20
AlGaInP on GaAs
66
2.9
(x, y) (0.30, 0.30)
*1: Duty1/10 1KHz *2: Reference
Dimensions
2.0 1.25 0.8
Recommended Solder Pattern Viewing Angle
1.1
1.25
Cathode mark
Through hole
X–Y
X’–Y’
Directivity (deg)
30° 20° 10° 0° 10° 20° 30°
1.1
Same for both directions 50°
40°
40° 50° 60° 70° 80°
60° 70°
0.9
1.25
80° 90° 100 50 0 50
Terminal
1.0
Unit : mm Tolerance : ±0.2
RELATIVE INTENSITY (%)
90° 100
Curve direction
Unit : mm
© 2011 ROHM Co., Ltd. All rights reserved.
www.rohm.com
1/3
2011.05 - Rev.B
SML-M1 Series
Electrical Characteristics Curves Forward Current-Forward Voltage
100
Ta=25°C
FORWARD CURRENT:IF (mA)
10
■SML-M13VT ■SML-M13UT ■SML-M13DT ■SML-M13YT ■SML-M13MT ■SML-M13PT
100
■SMLM12BC7T
■ SMLM12WBC7W
10
1.0 1.5
FORWARD VOLTAGE:VF (V)
2.0
2.5
1.0 2.8
2.9
3.0
3.1
3.2
Luminous Intensity-Atmosphere Temperature
1.6 RELATIVE LUMINOUS INTENSITY (a.u.) 1.4 1.2 1.0 0.8 0.6 0.4 -40 IF=20mA
1.6 1.4 1.2 1 0.8 0.6 0.4 -40
IF=5mA
■SMLM12BC7T
■ SMLM12WBC7W
-20
60
80
100
ATMOSPHERE TEMPERATURE:Ta (°C)
-20
60
80
100
Luminous Intensity-Forward Current
1.4 1.2 1.0 0.8 0.6 0.4 0.2 0.0 0 5 10 15 20 25 30
Ta=25°C
4
Ta=25°C
■SMLM12BC7T
■ SMLM12WBC7W
3
2
1
10
15
Derating
MAXIMUM FORWARD CURRENT:IF (mA) MAXIMUM FORWARD CURRENT:IF (mA)
40
Ta=25°C
30
30
■SMLM12BC7T
■ SMLM12WBC7W
10
0 -40
-20
60
80
100
AMBIENT TEMPERATURE:Ta (°C)
0 -40
-20
60
80
100
www.rohm.com
2/3
2011.05 - Rev.B
SML-M1 Series
Rank Reference of Brightness Red (V, U)
Luminous K L M Intensity Package size(mm) Height(mm) (mcd) 4.0 to 6.3 6.3 to 10 10 to 16
N 16 to 25
P 25 to 40
Q
R
S
T
U
V
(Ta=25˚C, IF=20mA) W X
40 to 63 63 to 100 100 to 160 160 to 250 250 to 400 400 to 630 630 to 1000 1000 to 1600 SML-M13VT SML-M13UT
Small LEDs 20125 with reflector
0.8
Orange (D)
(Ta=25˚C, IF=20mA) Luminous K L M N P Q R S T U V W X Intensity Package size(mm) Height(mm) (mcd) 4.0 to 6.3 6.3 to 10 10 to 16 16 to 25 25 to 40 40 to 63 63 to 100 100 to 160 160 to 250 250 to 400 400 to 630 630 to 1000 1000 to 1600 0.8 SML-M13DT
Small LEDs with reflector 20125
Yellow (Y)
(Ta=25˚C, IF=20mA) Luminous K L M N P Q R S T U V W X Intensity Package size(mm) Height(mm) (mcd) 4.0 to 6.3 6.3 to 10 10 to 16 16 to 25 25 to 40 40 to 63 63 to 100 100 to 160 160 to 250 250 to 400 400 to 630 630 to 1000 1000 to 1600 0.8 SML-M13YT
Green (M, P)
(Ta=25˚C, IF=20mA) Luminous K L M N P Q R S T U V W X Intensity Package size(mm) Height(mm) (mcd) 4.0 to 6.3 6.3 to 10 10 to 16 16 to 25 25 to 40 40 to 63 63 to 100 100 to 160 160 to 250 250 to 400 400 to 630 630 to 1000 1000 to 1800 0.8 SML-M13PT SML-M13MT
Blue (B)
Package Intensity size (mcd) (mm) Height(mm)
Luminous
K L M 3.6 to 5.6 5.6 to 9.0 9 to 14
0.8
(Ta=25˚C, IF=5mA) N P Q R S T U V W 14 to 22 22 to 36 36 to 56 56 to 90 90 to 140 140 to 220 220 to 360 360 to 560 560 to 900 SMLM12BC7T
White (WB)
Luminous
P 25 to 36
0.8
(Ta=25˚C, IF=5mA) Q R S T U V W 36 to 56 56 to 90 90 to 140 140 to 220 220 to 360 360 to 560 560 to 900 SMLM12WBC7W
Part No. Construction
∗ “−” will be taken out for emitting color W/B/E series. Special Code will be applied for Emitting color W/B/E series. Chromaticity rank(for white LED)
SML
Series name
M12
Package name Chip Type
M
Emitting Color
T
Resin Color
T86
Taping Specifications
P
Rank sign (Brightness Rank)∗
2 3
High Brightness Type Ultra High Brightness Type
V
Red:630nm
T W
Transparent Colorless MilkyWhite
T86 Cathode at sprocket hole side T87 Reverse of T86 1
For white LED, cathode at sprocket hole side
U Red:620nm D Orange:605nm M Yellowish-Green:572nm P Green:560nm B Blue:470nm WB White Y
Yellow:587(590)nm
∗ Concerning the Brightness rank • Please refer to the rank chart above for luminous intensity classification. • Part name is individual for each rank. • When shipped as sample, the part name will be a representative part name. General products are free of ranks. Please contact sales if rank appointment is needed.
Packing Specification
ROHM LED products are being shipped with desiccant (silica gel) concluded in moisture-proof bags. Pasting the moisture sensitive label on the outer surface of the moisture-proof bags or enclosing the humidity indication card inside the bag is available upon request. Please contact the nearest sales office or distributer if necessary.
www.rohm.com
3/3
2011.05 - Rev.B
Notice
Notes
Thank you for your accessing to ROHM product informations. More detail product informations and catalogs are available, please contact us.
ROHM Customer Support System
http://www.rohm.com/contact/
www.rohm.com © 2011 ROHM Co., Ltd. All rights reserved.
R1120A
很抱歉,暂时无法提供与“SML-M13BTT86P”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 5+0.63533
- 50+0.49774
- 150+0.42895
- 国内价格
- 5+0.5588
- 50+0.45002
- 600+0.35486
- 1200+0.34954
- 3000+0.32222
- 国内价格
- 10+0.48688
- 100+0.38818
- 600+0.3843
- 1200+0.37661
- 3000+0.36531
- 国内价格
- 10+0.35442
- 100+0.2773
- 600+0.27453
- 1200+0.26904
- 3000+0.26097
- 国内价格
- 5+0.78165
- 50+0.62632
- 600+0.62006
- 1200+0.60766
- 3000+0.58943
