Data Sheet
SML-R1 Series
PICOLEDTM-side
16115 0604) ( 1.6×1.15mm t=0.2mm) ( Features ・ Ultra compact, thin side-view type LED ・ Ultra low height package t=0.2mm
Color Type
V M
U P
D B
Y WB
Specifications
Part No.
■ SML-R12V8T ■ SML-R12U8T ■ SML-R12D8T ■ SML-R12Y8T ■ SML-R12M8T ■ SML-R12P8T ■ SMLR13BDT ■ SMLR13WBDW
Absolute Maximum Ratings (Ta=25℃) Electrical and Optical Characteristics (Ta=25℃) Chip Emitting Power Forward Voltage VF Reverse Current IR Dominant Wavelength λD Luminous Intensity IV Forward Peak Forward Reverse Operating Storage Structure Color Dissipation Current Current Voltage Temperature Temperature Max. Min.*2 Typ. Max.*2 Min. Typ. PD(mW) IF(mA) IFP(mA) VR(V) Topr(℃) Tstg(℃) Typ.(V) IF(mA) (μA) VR(V) (nm) (nm) (nm) IF(mA) (mcd) (mcd) IF(mA) Red Orange Yellow Yellowish Green Green InGaN Blue White 66 78 3.0 5 625 615 54 20 100*1 5 -40 to +85 -40 to +100 2.2 20 10 5 602 587 569 557 465 630 620 605 590 572 560 470 635 625 608 593 575 563 475 5 20 16 25 40 25 10 2.5 14 56 40 63 100 63 25 6.3 36 110 5 20
AIGaInP on GaAs
(x, y) (0.30, 0.30)
*1:Duty1/10, 1kHz /*2:Reference
Dimensions
1.6 0.2+0.05 -0.02 1.2
Recommended Solder Pattern Viewing Angle
1.2
X-Y
SML-R12□8T Series
SCANNING ANGLE (deg)
30° 40° 50° 60° 70° 80° 90° 100 50 0 50 20° 10° 0° 10° 20°
Directivity (deg)
X’ - Y’
Directivity (deg)
20° 10° 0° 10° 20°
30°
30°
40° 50° 60° 70° 80°
0.68
1.15
0.9
3.3
RELATIVE INTENSITY (%)
RELATIVE INTENSITY (%) RELATIVE INTENSITY (%)
50
90° 100
X-Y
SCANNING ANGLE (deg) Directivity (deg)
30° 40° 50° 60° 20° 10° 0° 10° 20° 30°
SMLR13BDT / SMLR13WBDW
X’ - Y’
Directivity (deg)
20° 10° 0° 10° 20°
30°
40° 50° 60° 70° 80° 50 0 50 90° 100
60° 70° 80° 90° 100 50°
40°
70°
Cathode mark
1.1
80°
Tolerance : ±0.1 (unit : mm)
(unit : mm)
90° 100
50
90° 100
*PICOLEDTM is ROHM's pending trademark.
© 2011 ROHM Co., Ltd. All rights reserved.
www.rohm.com
1/3
2011.05 - Rev.B
SML-R1 Series
Electrical Characteristics Curves Forward Current-Forward Voltage
100
Ta=25°C
FORWARD CURRENT:IF (mA)
10
■SML-R12V8T ■SML-R12U8T ■SML-R12D8T ■SML-R12Y8T ■SML-R12M8T ■SML-R12P8T
100
Ta=25°C
10
1 1.0
1.5
2.0
2.5
3.0
1 2.0
2.5
3.0
3.5
4.0
FORWARD VOLTAGE:VF (V)
Luminous Intensity-Atmosphere Temperature
1.6 RELATIVE LUMINOUS INTENSITY (a.u.) 1.4 1.2 1.0 0.8 0.6 0.4 -40 IF=20mA
1.6 1.4 1.2 1.0 0.8 0.6 0.4 -40
IF=5mA
-20
60
80
100
-20
60
80
100
ATMOSPHERE TEMPERATURE:Ta (°C)
Luminous Intensity-Forward Current
1.2
Ta=25°C
1.0 0.8 0.6 0.4 0.2 0
4.0
Ta=25°C
3.0
2.0
1.0
10
15
10
15
PEAK FORWARD CURRENT:IF (mA)
Derating
MAXIMUM FORWARD CURRENT: (mA)
30
MAXIMUM FORWARD CURRENT:IF (mA)
30 25 20 15 10 5 0 -40
10
0 -40
-20
60
80
100
-20
60
80
100
AMBIENT TEMPERATURE:Ta (°C)
www.rohm.com
2/3
2011.05 - Rev.B
SML-R1 Series
Rank Reference of Brightness Red (V, U)
Package size(mm) Side View 16115 Chip LEDs
Luminous Intensity (mcd) Height(mm)
G
H
J
K
L 6.3 to 10
M 10 to 16
N 16 to 25
P
Q
R
S 100 to 160
T 160 to 250
U 250 to 400
V
(Ta=25˚C, IF=20mA) W X 630 to 1000 1000 to 1600
1.0 to 1.6 1.6 to 2.5 2.5 to 4.0 4.0 to 6.3
0.2
25 to 40 40 to 63 63 to 100 SML-R12V8T SML-R12U8T
400 to 630
Orange (D)
G 1.0 to 1.6
H 1.6 to 2.5
J 2.5 to 4.0
K 4.0 to 6.3
L 6.3 to 10
M 10 to 16
N 16 to 25
P 25 to 40
Q 40 to 63
R 63 to 100
S 100 to 160
T 160 to 250
U 250 to 400
V
400 to 630
0.2
SML-R12D8T
Yellow (Y)
G
H
J
K
L 6.3 to 10
M 10 to 16
N 16 to 25
P 25 to 40
Q 40 to 63
R 63 to 100
S 100 to 160
T 160 to 250
U 250 to 400
V
400 to 630
0.2
SML-R12Y8T
Green (M, P)
Package size(mm) Side View Chip LEDs 16115
F
G
H
J
K
L 6.3 to 10
M 10 to 16
N
P
Q 40 to 63
R 63 to 100
S 100 to 160
T 160 to 250
U 250 to 400
V
(Ta=25˚C, IF=20mA) W X 630 to 1000 1000 to 1800
0.63 to 1.0 1.0 to 1.6 1.6 to 2.5 2.5 to 4.0 4.0 to 6.3
0.2
16 to 25 25 to 40 SML-R12M8T
400 to 630
SML-R12P8T
Blue (B)
G 0.9 to 1.4
H 1.4 to 2.2
J 2.2 to 3.6
K 3.6 to 5.6
L 5.6 to 9.0
M 9 to 14
N 14 to 22
P 22 to 36
Q 36 to 56
R 56 to 90
S 90 to 140
T 140 to 220
U 220 to 360
(Ta=25˚C, IF=5mA) V W 360 to 560 560 to 900
0.2
SMLR13BDT
White (WB)
Luminous Package Intensity size (mcd) (mm) Height(mm)
P 25 to 36
Q 36 to 56
R 56 to 90
S 90 to 140
T 140 to 220
U 220 to 360
Side View Chip LEDs
1810
0.2
SMLR13WBDW
Part No. Construction
∗ “−” will be taken out for emitting color W/B/E series. Special Code will be applied for Emitting color W/B/E series. Chromaticity rank(for white LED)
SML
Series name
R12M
Package name Chip Type Emitting Color
T
Resin Color
T86
Taping Specifications
P
Rank sign (Brightness Rank)∗
2 3
High Brightness Type Ultra High Brightness Type
V Red:630nm U Red:620nm D Orange:605nm Y Yellow:587(590)nm M Yellowish-Green:572nm B Blue:470nm WB White P Green:560nm
T
Transparent Colorless
T86 Cathode at sprocket hole side T87 Reverse of T86 1
For white LED, cathode at sprocket hole side
W MilkyWhite
∗ Concerning the Brightness rank • Please refer to the rank chart above for luminous intensity classification. • Part name is individual for each rank. • When shipped as sample, the part name will be a representative part name. General products are free of ranks. Please contact sales if rank appointment is needed.
Packing Specification
ROHM LED products are being shipped with desiccant (silica gel) concluded in moisture-proof bags. Pasting the moisture sensitive label on the outer surface of the moisture-proof bags or enclosing the humidity indication card inside the bag is available upon request. Please contact the nearest sales office or distributer if necessary.
www.rohm.com
3/3
2011.05 - Rev.B
Notice
Notes
Thank you for your accessing to ROHM product informations. More detail product informations and catalogs are available, please contact us.
ROHM Customer Support System
http://www.rohm.com/contact/
www.rohm.com © 2011 ROHM Co., Ltd. All rights reserved.
R1120A
很抱歉,暂时无法提供与“SML-R13VWT86P”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 5+0.79958
- 50+0.6322
- 150+0.54851
- 国内价格
- 5+0.78165
- 50+0.62632
- 600+0.62006
- 1200+0.60766
- 3000+0.58943
- 国内价格
- 5+0.54341
- 50+0.43434
- 600+0.33879
- 1200+0.33371
- 3000+0.30605
- 国内价格
- 5+0.63533
- 50+0.49774
- 150+0.42895
- 国内价格
- 1+0.78401
- 30+0.75601
- 100+0.72801
- 500+0.67201
- 1000+0.64401
- 2000+0.62721
- 国内价格
- 5+0.96236
- 50+0.93962
- 600+0.93022
- 1200+0.91162
- 3000+0.88427
- 国内价格
- 10+0.48688
- 100+0.38818
- 600+0.30175
- 1200+0.29722
- 3000+0.27205
