WML-D12P8WT86P
WML-D12P8WT86P
    ROHM(罗姆)
    WML-D12P8WT86P - Original device technology enables high brightness and high reliability - Rohm
WML-D12P8WT86P 数据手册
Data Sheet SML-D1 Series EXCELEDTM 1608 0603) ( 1.6×0.8mm t=0.55mm) ( Features ・ riginal device technology enables high brightness O and high reliability Color Type V M U P D HB Y Specifications Part No. ■ SML-D12V8W ■ SML-D12U8W ■ SML-D12D8W ■ SML-D12Y8W ■ SML-D12M8W ■ SML-D12P8W ■ SMLD12HBC7W Absolute Maximum Ratings (Ta=25℃) Electrical and Optical Characteristics (Ta=25℃) Chip Emitting Power Forward Voltage VF Reverse Current IR Dominant Wavelength λD Luminous Intensity IV Forward Peak Forward Reverse Operating Storage Structure Color Dissipation Current Current Voltage Temperature Temperature Typ. Min.*2 Typ. Max.*2 Max. Min. Typ. PD(mW) IF(mA) IFP(mA) VR(V) Topr(℃) Tstg(℃) (V) IF(mA) (μA) VR(V) (nm) (nm) (nm) IF(mA) (mcd) (mcd) IF(mA) Red Red AIGaInP on GaAs Orange Yellow Yellowish Green Green InGaN Pink 78 2.9 5 5 54 2.2 20 4 625 615 602 587 569 557 630 620 605 590 572 560 635 625 608 593 575 563 5 20 16 25 40 25 10 2.5 9.0 40 63 100 63 25 6.3 22 5 20 20 100*1 5 -40 to +85 -40 to +100 10 (x, y) (0.47, 0.25) *1:Duty1/10, 1kHz / *2:Reference Dimensions 1.6 1.2 Recommended Solder Pattern Viewing Angle SML-D1 series X Y 0.8 60° 70° 40° 50° 30° 20° 10° 0° 10° 20° 30° X’ Y’ 40° 50° 60° 70° 80° 60° 70° 80° 90° 100 50° 40° 30° 20° 10° 0° 10° 20° 30° 40° 50° 60° 70° 80° 0.8 0.5 0.8 R0.15 80° 90° 100 50 0 50 RELATIVE INTENSITY (%) RELATIVE INTENSITY (%) 90° 100 RELATIVE INTENSITY (%) RELATIVE INTENSITY (%) 50 0 50 90° 100 0.55 0.18 0.85 0.8 X-Y SMLD12HBC7W 0.8 40° 50° 60° 30° 20° 10° 0° 10° 20° 30° X’ Y’ 0.65 40° 50° 60° 70° 80° 60° 70° 80° 90° 100 50° 40° 30° 20° 10° 0° 10° 20° 30° 40° 50° 60° 70° 80° Cathode mark Terminal 70° 80° Tolerance : ±0.1 (unit : mm) 90° 100 (unit : mm) RELATIVE RELATIVE INTENSITY (%) INTENSITY (%) 50 0 50 90° 100 RELATIVE RELATIVE INTENSITY (%) INTENSITY (%) 50 0 50 90° 100 EXCELEDTM is ROHME's pending trademark. © 2011 ROHM Co., Ltd. All rights reserved. www.rohm.com 1/3 2011.05 - Rev.B SML-D1 Series Electrical Characteristics Curves Forward Current-Forward Voltage 100 Ta=25°C ■ ■ ■ FORWARD CURRENT:IF (mA) ■SML-D12V8W ■SML-D12U8W ■SML-D12Y8W ■SML-D12M8W ■SML-D12P8W ■SML-D12D8W ■ ■SMLD12HBC7W 10 1 1.0 1.5 2.0 2.5 3.0 FORWARD VOLTAGE:VF (V) Luminous Intensity-Atmosphere Temperature 1.6 RELATIVE LUMINOUS INTENSITY (a.u.) 1.4 1.2 1.0 0.8 0.6 0.4 -40 IF=20mA ■ RELATIVE LUMINOUS INTENSITY (a.u.) ■SML-D12V8W ■SML-D12U8W ■SML-D12D8W ■SML-D12Y8W ■SML-D12M8W ■SML-D12P8W 1.6 1.4 1.2 1.0 0.8 0.6 0.4 -40 IF=5mA ■ ■SMLD12HBC7W -20 0 20 40 60 80 100 ATMOSPHERE TEMPERATURE:Ta (°C) ATMOSPHERE TEMPERATURE:Ta (°C) -20 0 20 40 60 80 100 Luminous Intensity-Forward Current 1.2 Ta=25°C ■ ■ ■ RELATIVE LUMINOUS INTENSITY (a.u.) 1.0 0.8 0.6 0.4 0.2 0 RELATIVE LUMINOUS INTENSITY (a.u.) ■SML-D12V8W ■SML-D12U8W ■SML-D12D8W ■SML-D12Y8W ■SML-D12M8W ■SML-D12P8W 4.0 Ta=25°C ■ ■SMLD12HBC7W 3.0 2.0 1.0 0 5 10 15 20 25 0 FORWARD CURRENT:IF (mA) 0 FORWARD CURRENT:IF (mA) 5 10 15 20 Derating ■ MAXIMUM FORWARD CURRENT:IF(mA) 30 20 MAXIMUM FORWARD CURRENT:IF (mA) ■SML-D12V8W ■SML-D12U8W ■SML-D12Y8W ■SML-D12M8W ■SML-D12P8W ■SML-D12D8W ■ 30 ■SMLD12HBC7W 20 10 10 0 -40 -20 0 20 40 60 80 100 0 -40 -20 0 20 40 60 80 100 AMBIENT TEMPERATURE:Ta (°C) AMBIENT TEMPERATURE:Ta (°C) © 2011 ROHM Co., Ltd. All rights reserved. www.rohm.com 2/3 2011.05 - Rev.B SML-D1 Series Rank Reference of Brightness Red (V, U) Luminous H J K L M Intensity Package size(mm) Height(mm) (mcd) 1.6 to 2.5 2.5 to 4.0 4.0 to 6.3 6.3 to 10 10 to 16 N 16 to 25 P 25 to 40 Q R S (Ta=25˚C, IF=20mA) T U 40 to 63 63 to 100 100 to 160 160 to 250 250 to 400 Mini-mold Chip LEDs 1608 0.55 SML-D12V8W SML-D12U8W Orange (D) Luminous H J K L M Intensity Package size(mm) Height(mm) (mcd) 1.6 to 2.5 2.5 to 4.0 4.0 to 6.3 6.3 to 10 10 to 16 N 16 to 25 P 25 to 40 Q R S (Ta=25˚C, IF=20mA) T U 40 to 63 63 to 100 100 to 160 160 to 250 250 to 400 SML-D12D8W Mini-mold Chip LEDs 1608 0.55 Yellow (Y) Luminous H J K L M Intensity Package size(mm) Height(mm) (mcd) 1.6 to 2.5 2.5 to 4.0 4.0 to 6.3 6.3 to 10 10 to 16 N 16 to 25 P 25 to 40 Q R S (Ta=25˚C, IF=20mA) T U 40 to 63 63 to 100 100 to 160 160 to 250 250 to 400 SML-D12Y8W Mini-mold Chip LEDs 1608 0.55 Green (M, P) Luminous H J K L M Intensity Package size(mm) Height(mm) (mcd) 1.6 to 2.5 2.5 to 4.0 4.0 to 6.3 6.3 to 10 10 to 16 N 16 to 25 P 25 to 40 Q R S (Ta=25˚C, IF=20mA) T U 40 to 63 63 to 100 100 to 160 160 to 250 250 to 400 Mini-mold Chip LEDs 1608 0.55 SML-D12P8W SML-D12M8W Part No. Construction ∗ “−” will be taken out for emitting color Pink series. Chip Special Code SML Series name D12 Package type Chip Type M8W Emitting Color Resin Color T86 Taping Specifications P Rank sign (Brightness Rank)∗ 2 High Brightness Type V Red:630nm W MilkyWhite T86 Cathode at sprocket hole side T87 Reverse of T86 1 For white LED, cathode at sprocket hole side U Red:620nm D Orange:605nm Y Yellow:587(590)nm M Yellowish-Green:572nm HB Pink P Green:560nm ∗ Concerning the Brightness rank • Please refer to the rank chart above for luminous intensity classification. • Part name is individual for each rank. • When shipped as sample, the part name will be a representative part name. General products are free of ranks. Please contact sales if rank appointment is needed. Packing Specification ROHM LED products are being shipped with desiccant (silica gel) concluded in moisture-proof bags. Pasting the moisture sensitive label on the outer surface of the moisture-proof bags or enclosing the humidity indication card inside the bag is available upon request. Please contact the nearest sales office or distributer if necessary. © 2011 ROHM Co., Ltd. All rights reserved. www.rohm.com 3/3 2011.05 - Rev.B Notice Notes Thank you for your accessing to ROHM product informations. More detail product informations and catalogs are available, please contact us. ROHM Customer Support System http://www.rohm.com/contact/ www.rohm.com © 2011 ROHM Co., Ltd. All rights reserved. R1120A
WML-D12P8WT86P 价格&库存
很抱歉,暂时无法提供与“WML-D12P8WT86P”相匹配的价格&库存,您可以联系我们找货
