T1610
T1610
    STMICROELECTRONICS(意法半导体)
    T1610 - 16 A Snubberless™, logic level and standard Triacs - STMicroelectronics
T1610 数据手册
BTA16, BTB16 T1610, T1635 16 A Snubberless™, logic level and standard Triacs Features ■ ■ ■ ■ ■ ■ ■ A2 Medium current Triac G Low thermal resistance with clip bonding Low thermal resistance insulation ceramic for insulated BTA High commutation (4Q) or very high commutation (3Q) capability BTA series UL1557 certified (File ref: 81734) RoHS ( 2002/95/EC) compliant Insulated tab (BTA series, rated at 2500 VRMS) A1 A2 G A1 A2 D2PAK T1610G T1635G A2 Applications ■ Snubberless versions (BTA/BTB...W and T1635) especially recommended for use on inductive loads, because of their high commutation performances On/off or phase angle function in applications such as static relays, light dimmers and appliance motor speed controllers A1 A2 G A1 A2 G ■ TO-220AB insulated BTA16 TO-220AB BTB16 Description Available either in through-hole or surface-mount packages, the BTA16, BTB16, T1610 and T1635 Triacs series are suitable for general purpose mains power AC switching. Table 1. Symbol IT(RMS) VDRM/VRRM Device summary Parameter On-state rms current Repetitive peak off-state voltage BTA16 (1) 16 600/800 35/50 10 25/50 BTB16 16 600/800 35/50 10 25/50 T1610 16 600/800 10 T1635 16 600/800 35 - IGT (Snubberless) Triggering gate current IGT (logic level) IGT (standard) 1. Insulated Triggering gate current Triggering gate current TM: Snubberless is a trademark of STMicroelectronics March 2010 Doc ID 7471 Rev 9 1/10 www.st.com 10 Characteristics BTA16, BTB16, T1610, T1635 1 Characteristics Table 2. Symbol Absolute maximum ratings Parameter D2PAK / TO-220AB TO-220AB insulated F = 50 Hz F = 60 Hz tp = 10 ms Tj = 125 °C Tj = 25 °C Tj = 125 °C Tj = 125 °C Tc = 100 °C 16 Tc = 86 °C t = 20 ms t = 16.7 ms 160 A 168 144 50 VDRM/VRRM + 100 4 1 -40 to + 150 -40 to + 125 Value Unit IT(RMS) On-state rms current (full sine wave) A ITSM I²t dI/dt VDSM/ VRSM IGM PG(AV) Tstg Tj Non repetitive surge peak on-state current (full cycle, Tj initial = 25 °C) I²t value for fusing A ²s A/µs V A W Critical rate of rise of on-state current F = 120 Hz IG = 2 x IGT , tr ≤ 100 ns Non repetitive surge peak off-state voltage Peak gate current Average gate power dissipation Storage temperature range Maximum operating junction temperature tp = 10 ms tp = 20 µs Table 3. Electrical characteristics (Tj = 25 °C, unless otherwise specified) Snubberless and logic level (3 quadrants) BTA16 / BTB16 Test conditions Quadrant I - II - III I - II - III I - II - III Max. Max. Min. Max. I - III Max. II Tj = 125 °C Min. 30 40 8.5 Min. 3.0 60 500 8.5 30 40 8.5 3.0 60 500 8.5 80 1000 14 A/ms V/µs 15 25 35 50 T1610 T1635 SW CW 35 BW 50 mA V V 35 50 50 70 mA mA 10 35 10 1.3 0.2 15 25 Unit Symbol IGT (1) VGT VGD IH (2) IL dV/dt (2) VD = 12 V RL = 33 Ω VD = VDRM RL = 3.3 kΩ Tj = 125 °C IT = 500 mA IG = 1.2 IGT VD = 67 %VDRM gate open (dV/dt)c = 0.1 V/µs Tj = 125 °C (dI/dt)c (2) (dV/dt)c = 10 V/µs Without snubber Tj = 125 °C Tj = 125 °C 1. Minimum IGT is guaranted at 5% of IGT max 2. For both polarities of A2 referenced to A1 2/10 Doc ID 7471 Rev 9 BTA16, BTB16, T1610, T1635 Table 4. Characteristics Electrical characteristics (Tj = 25 °C, unless otherwise specified) standard (4 quadrants) BTA16 / BTB16 Test conditions Quadrant C B 50 100 1.3 0.2 25 40 Max. II Tj = 125 °C Tj = 125 °C Min. Min. 80 200 5 120 400 10 V/µs V/µs 50 60 mA mA V V mA I - II - III IV ALL VD = VDRM RL = 3.3 kΩ Tj = 125 °C IT = 500 mA I - III - IV IG = 1.2 IGT ALL 25 50 Unit Symbol IGT (1) VGT VGD IH (2) IL VD = 12 V RL = 33 Ω Max. Max. Min. Max. dV/dt (2) VD = 67 %VDRM gate open (dV/dt)c (2) (dI/dt)c = 7 A/ms 1. Minimum IGT is guaranted at 5% of IGT max 2. For both polarities of A2 referenced to A1 Table 5. Symbol VT (2) Vto (2) Rd (2) IDRM IRRM Static characteristics Test conditions ITM = 22.5 A tp = 380 µs Tj = 25 °C Tj = 125 °C Tj = 125 °C Tj = 25 °C Tj = 125 °C Max. Max. Max. Max. 2 mA Value 1.55 0.85 25 5 Unit V V mΩ µA Threshold voltage Dynamic resistance VDRM = VRRM Table 6. Symbol Rth(j-c) Thermal resistance Parameter D2PAK / TO-220AB Junction to case (AC) TO-220AB insulated S(1) = 1 cm² D2PAK 2.1 45 °C/W 60 Value 1.2 °C/W Unit Rth(j-a) Junction to ambient TO-220AB / TO-220AB insulated 1. S = Copper surface under tab Doc ID 7471 Rev 9 3/10 Characteristics BTA16, BTB16, T1610, T1635 Figure 1. P(W) 20 18 16 14 12 10 8 6 4 2 0 0 2 Maximum power dissipation versus Figure 2. on-state rms current (full cycle) IT(RMS)(A) 18 16 14 On-state rms current versus case temperature (full cycle) BTB / T16 BTA 12 10 8 6 4 IT(RMS)(A) 4 6 8 10 12 14 16 2 0 0 25 50 TC(°C) 75 100 125 Figure 3. IT(RMS)(A) 4.0 On-state rms current versus ambient temperature (full cycle) Figure 4. Relative variation of thermal impedance versus pulse duration K=[Zth/Rth] 1E+0 D PAK (S=1cm2) 2 printed circuit board FR4, copper thickness: 35 µm 3.5 3.0 2.5 2.0 1.5 1.0 0.5 0.0 0 25 50 Zth(j-c) Zth(j-a) 1E-1 TC(°C) 75 100 125 1E-2 1E-3 1E-2 1E-1 tp(s) 1E+0 1E+1 1E+2 5E+2 Figure 5. ITM(A) 200 100 Tj max. Vto = 0.85V Rd = 25 mΩ On-state characteristics (maximum values) Figure 6. Surge peak on-state current versus number of cycles ITSM(A) 180 160 140 t=20ms Tj = Tj max. 120 100 Tj = 25°C. Non repetitive Tj initial=25°C One cycle 10 80 60 40 Repetitive TC=85°C VTM(V) 1 0.5 1.0 1.5 2.0 2.5 3.0 3.5 4.0 4.5 5.0 20 0 1 10 Number of cycles 100 1000 4/10 Doc ID 7471 Rev 9 BTA16, BTB16, T1610, T1635 Characteristics Figure 7. Non-repetitive surge peak on-state Figure 8. current for a sinusoidal 2 2 Relative variation of gate trigger current ITSM(A), I t (A s) 3000 Tj initial=25°C dI/dt limitation: 50A/µs IGT,IH,IL[Tj] / IGT,IH,IL[Tj=25°C] 2.5 holding current and latching current versus junction temperature (typical values) 2.0 IGT 1000 ITSM 1.5 IH & IL 1.0 I2t 0.5 2 100 pulse with width tp < 10 ms and corresponding value of I t 0.01 0.10 1.00 tp(ms) 10.00 Tj(°C) 0.0 -40 -20 0 20 40 60 80 100 120 140 Figure 9. Relative variation of critical rate of decrease of main current versus (dV/dt)c (typical values) Figure 10. Relative variation of critical rate of decrease of main current versus (dV/dt)c (typical values) (dI/dt)c [Tj] / (dI/dt)c [Tj specified] 6 Standard types (dI/dt)c [(dV/dt)c] / Specified (dI/dt)c 2.0 Snubberless and Logic level types 1.8 1.6 B C SW 5 4 3 2 1 1.4 1.2 1.0 0.8 0.6 T1635/CW/BW (dV/dt)c (V/µs) 0.4 0.1 1.0 10.0 100.0 0 0 25 50 Tj(°C) 75 100 125 Figure 11. D2PAK thermal resistance junction to ambient versus copper surface under tab (printed circuit board FR4, copper thickness: 35 µm) Rth(j-a)(°C/W) 80 70 60 50 D2PAK 40 30 20 10 S(cm²) 0 0 4 8 12 16 20 24 28 32 36 40 Doc ID 7471 Rev 9 5/10 Ordering information BTA16, BTB16, T1610, T1635 2 Ordering information Figure 12. Ordering information scheme (BTA16 and BTB16 series) BT A 16 - 600 BW RG TRIAC series Insulation A = insulated B = non insulated Current 16 = 16 A Voltage 600 = 600 V 800 = 800 V Sensitivity and type B = 50 mA Standard C = 25 mA Standard SW = 10 mA Logic Level Packing mode RG = Tube BW = 50 mA Snubberless CW = 35 mA Snubberless Figure 13. Ordering information scheme (T16 series) T 16 35 - 600 G (-TR) TRIAC series Current 16 = 16 A Sensitivity 10 = 10 mA 35 = 35 mA Voltage 600 = 600 V 800 = 800 V Package 2 G = D PAK Packing mode Blank = Tube -TR = Tape and reel Table 7. Product selector Device(1) Voltage (xxx) Sensitivity 600 V 800 V X X X X X X 50 mA 50 mA 25 mA 35 mA 10 mA 10 mA 35 mA Standard Snubberless Standard Snubberless Logic level Logic level Snubberless TO-220AB TO-220AB TO-220AB TO-220AB TO-220AB D2PAK D2PAK X X X X X X X Type Package BTA/BTB16-xxxB BTA/BTB16-xxxBW BTA/BTB16-xxxC BTA/BTB16-xxxCW BTA/BTB16-xxxSW T1610-xxxG T1635-xxxG 1. BTB: non insulated TO-220AB package 6/10 Doc ID 7471 Rev 9 BTA16, BTB16, T1610, T1635 Package information 3 Package information ● ● Epoxy meets UL94, V0 Recommended torque value: 0.4 to 0.6 N·m In order to meet environmental requirements, ST offers these devices in different grades of ECOPACK® packages, depending on their level of environmental compliance. ECOPACK® specifications, grade definitions and product status are available at: www.st.com. ECOPACK® is an ST trademark. Table 8. D2PAK dimensions Dimensions Ref. Millimeters Min. A A E L2 Inches Min. 0.169 0.098 0.001 0.027 0.048 0.055 Typ. Max. 0.181 0.106 0.009 0.037 Typ. Max. 4.60 2.69 0.23 0.93 4.30 2.49 0.03 0.70 1.25 0.45 1.21 8.95 10.00 4.88 15.00 1.27 1.40 0.40 0° 1.40 A1 C2 A2 B D L L3 A1 B2 C C2 B2 B G A2 2mm min. FLAT ZONE C R 0.60 1.36 9.35 0.017 0.047 0.352 0.024 0.054 0.368 0.405 0.208 0.624 0.055 0.069 0.016 D E G L 10.28 0.393 5.28 0.192 15.85 0.590 1.40 1.75 0.050 0.055 V2 L2 L3 R V2 8° 0° 8° Figure 14. Footprint (dimensions in mm) 16.90 10.30 1.30 5.08 8.90 3.70 Doc ID 7471 Rev 9 7/10 Package information Table 9. BTA16, BTB16, T1610, T1635 TO-220AB (non-insulated and insulated) dimensions Dimensions Ref. Millimeters Min. A B ØI L b2 C Inches Min. Typ. Max. 0.625 0.147 Typ. Max. 15.20 3.75 13.00 10.00 0.61 1.23 4.40 0.49 2.40 2.40 6.20 3.75 15.90 0.598 a1 a2 B b1 14.00 0.511 10.40 0.393 0.88 1.32 4.60 0.70 2.72 2.70 6.60 3.85 0.024 0.048 0.173 0.019 0.094 0.094 0.244 0.147 0.551 0.409 0.034 0.051 0.181 0.027 0.107 0.106 0.259 0.151 A b2 C l3 a1 l2 c2 c1 c2 a2 e F M b1 e c ØI I4 L l2 l3 M 15.80 16.40 16.80 0.622 0.646 0.661 2.65 1.14 1.14 2.60 2.95 1.70 1.70 0.104 0.044 0.044 0.102 0.116 0.066 0.066 8/10 Doc ID 7471 Rev 9 BTA16, BTB16, T1610, T1635 Ordering information 4 Ordering information Table 10. Ordering information Marking(1) BTA16xxxyz BTB16xxxyz T1610xxxG T1635xxxG T1635xxxG D2PAK 1.5 g Package TO-220AB TO-220AB Weight 2.3 g 2.3 g Base qty 50 50 1000 50 1000 Delivery mode Tube Tube Tape and reel Tube Tape and reel Order code(1) BTA16-xxxyzRG BTB16-xxxyzRG T1610-xxxG-TR T1635-xxxG T1635-xxxG-TR 1. xxx = voltage, y = sensitivity, z = type 5 Revision history Table 11. Date Oct-2002 13-Feb-2006 03-Jul-2009 11-Mar-2010 Document revision history Revision 6A 7 8 9 Last update. TO-220AB delivery mode changed from bulk to tube. ECOPACK statement added. Added part number T1610. Updated value for VDSM/VRSM in Table 2. Updated temperature in Table 2 from 15 °C to 86 °C. Changes Doc ID 7471 Rev 9 9/10 BTA16, BTB16, T1610, T1635 Please Read Carefully: Information in this document is provided solely in connection with ST products. STMicroelectronics NV and its subsidiaries (“ST”) reserve the right to make changes, corrections, modifications or improvements, to this document, and the products and services described herein at any time, without notice. All ST products are sold pursuant to ST’s terms and conditions of sale. Purchasers are solely responsible for the choice, selection and use of the ST products and services described herein, and ST assumes no liability whatsoever relating to the choice, selection or use of the ST products and services described herein. No license, express or implied, by estoppel or otherwise, to any intellectual property rights is granted under this document. If any part of this document refers to any third party products or services it shall not be deemed a license grant by ST for the use of such third party products or services, or any intellectual property contained therein or considered as a warranty covering the use in any manner whatsoever of such third party products or services or any intellectual property contained therein. UNLESS OTHERWISE SET FORTH IN ST’S TERMS AND CONDITIONS OF SALE ST DISCLAIMS ANY EXPRESS OR IMPLIED WARRANTY WITH RESPECT TO THE USE AND/OR SALE OF ST PRODUCTS INCLUDING WITHOUT LIMITATION IMPLIED WARRANTIES OF MERCHANTABILITY, FITNESS FOR A PARTICULAR PURPOSE (AND THEIR EQUIVALENTS UNDER THE LAWS OF ANY JURISDICTION), OR INFRINGEMENT OF ANY PATENT, COPYRIGHT OR OTHER INTELLECTUAL PROPERTY RIGHT. UNLESS EXPRESSLY APPROVED IN WRITING BY AN AUTHORIZED ST REPRESENTATIVE, ST PRODUCTS ARE NOT RECOMMENDED, AUTHORIZED OR WARRANTED FOR USE IN MILITARY, AIR CRAFT, SPACE, LIFE SAVING, OR LIFE SUSTAINING APPLICATIONS, NOR IN PRODUCTS OR SYSTEMS WHERE FAILURE OR MALFUNCTION MAY RESULT IN PERSONAL INJURY, DEATH, OR SEVERE PROPERTY OR ENVIRONMENTAL DAMAGE. ST PRODUCTS WHICH ARE NOT SPECIFIED AS "AUTOMOTIVE GRADE" MAY ONLY BE USED IN AUTOMOTIVE APPLICATIONS AT USER’S OWN RISK. Resale of ST products with provisions different from the statements and/or technical features set forth in this document shall immediately void any warranty granted by ST for the ST product or service described herein and shall not create or extend in any manner whatsoever, any liability of ST. ST and the ST logo are trademarks or registered trademarks of ST in various countries. Information in this document supersedes and replaces all information previously supplied. The ST logo is a registered trademark of STMicroelectronics. All other names are the property of their respective owners. © 2010 STMicroelectronics - All rights reserved STMicroelectronics group of companies Australia - Belgium - Brazil - Canada - China - Czech Republic - Finland - France - Germany - Hong Kong - India - Israel - Italy - Japan Malaysia - Malta - Morocco - Philippines - Singapore - Spain - Sweden - Switzerland - United Kingdom - United States of America www.st.com 10/10 Doc ID 7471 Rev 9
T1610
1. 物料型号:型号为ATMEGA16U2-AU,是一款基于AVR增强型8位微控制器。
2. 器件简介:ATMEGA16U2-AU是一款低功耗、高性能的CMOS 8位AVR微控制器,适用于许多嵌入式系统和工业控制应用。
3. 引脚分配:该芯片有32个引脚,包括电源引脚、地引脚、复位引脚、I/O引脚等。
4. 参数特性:工作电压为1.8-5.5V,最大工作频率为16MHz,内置8KB的SRAM和512KB的闪存。
5. 功能详解:具有多种通信接口,如USB、UART、SPI等,支持多种外设功能,如ADC、定时器、PWM等。
6. 应用信息:广泛应用于USB通信、工业控制、医疗设备等领域。
T1610 价格&库存
很抱歉,暂时无法提供与“T1610”相匹配的价格&库存,您可以联系我们找货
