13324-T084
13324-T084
    SUMIDA(胜美达)
    用于 SMPS 变压器 1500Vrms 隔离 表面贴装型
13324-T084 数据手册
Spec. No.:S-0227-6239 Date of application To: LINEAR TECHNOLOGY 2106 (year) 05 (month) 04 (day) Approval Sheet ■ Part number :13324-T084 ■ Document attached No Yes(See Below) * Scope and Precautions S-074-1511 * * Heat endurance test S-074-1516 * * Recommended reflow condition S-074-1518 * * Packing spec. S-0074-5753 * ■ Tick the relevant box“ ”. New product / New specification New part(s) is added to approved specification Revision of approved specification ■ Note This specification will be considered accepted upon receipt of your order. Sales Approved by Sumida America Components Inc. Approval: Salesman: Check: Design: FM-PD-90 Specification (Change History) Customer: LINEAR TECHNOLOGY Change Mark Change Date Request No. Change content Type CEP1311F Requested by Note: Made: 3rd. May,2016 Approved by Checked by WEI SHAOHONG ZENG YUNXIA R&D JIANG ZHIMING LLZ LINEAR Part Name (Customer Part Name) 13324-TØ84 Type code 13324 Sample No. 13324-T084 Spec. No. S-0227-6239 1/3 Type Specification CEP1311F 1.Scope & Precautions Refer to S-074-1511. 2.Appearance 2-1.Dimension(mm) 13.5 Max. 6 12.5 Max. 10 6 10 18.0 Max. 15.0 Max. 5 1 1 5 8-2.5 0.7 Dot indicates pin1 * Dimension without tolerance is reference. * The dimension of terminals don't include the solder. * Terminal coplanarity:Max. 0.10mm. 2-2.Stamp 2-3.Recommended land pattern (mm) 6 10X1.27 10 2.03 Sumida T084 Date code 14.99 5 1 3.Coil specification 3-1. Schematic 3 Pri 36-75Vin 5 6,7 Sec 24V/0.6A 8X2.50 9,10 “●”Indicates the polarity. RoHS compliance Cd:Max.0.01wt% others:Max.0.1wt% Note: Spec. No. S-0227-6239 2/3 Type Specification CEP1311F 3-2.Electrical characteristics(At 25℃,unless otherwise specified). Item Specification Measuring conditions Inductance (3-5) 40μH±10% Within 100kHz, 0.1V Leakage inductance (3-5) 1.2μH Max. 100kHz, 0.1V, Tie(6+7+9+10) DCR (3-5) 130mΩ Max. DCR (6,7-9,10) 130mΩ Max. Turns ratio (3-5):(6,7-9,10) 1:1±3% Hi Pot (3,5)-(6,7,9,10) AC 1500Vrms 2Seconds Rated current (3-5) 0.5mA,50/60Hz 3ADC * The rated current indicates the inductance will decrease to be its 85% of its original ones when the rated current is applied on it. 4.General characteristics 4-1.Storage temperature range : -40℃ ~ +85℃ 4-2.Operating temperature range: -40℃ ~ +85℃ (Including coil’s temperature rise) 4-3.Resistance to reflow heat test: Refer to S-074-1516. 4-4.Recommended reflow condition : Refer to S-074-1518. 5.Packing specification 5-1. Enclosing direction of parts. User direction of unreeling Between(1-5), Slotted holes side The side with stamp is upward. 5-2. Packing method refers to specification.(S-0074-5753) Note: Spec. No. S-0227-6239 3/3 共 用 仕 様 書 COMMON SPECIFICATION SUMIDA製品の適用範囲 Scope of SUMIDA products 1. 当製品は、AV機器、家電製品、OA機器、通信機器、計測機器、工作機器などの一般電子 機器に使用されることを前提に製造、販売されております。 The component is manufactured and promoted to be used in general electronic of AV., home appliance, OA, communication, measurement equipments and machine tools. 2. 人命や財産に影響を与える可能性のある航空宇宙機器、医療機器、輸送機器、防災機器 または同等と思われる機器に使用される場合は、必ず弊社営業部門にお問い合わせ下さい。 また、使用条件を満たさない場合や超えた場合による搭載機器に何らかの事故、損害が発生 した場合でも弊社は一切その責を負いませんので、予めご了承下さい。 In the event the product is used in aerospace equipment, medical equipment, transportation equipment, disaster preventing equipment or an equivalent which may affect human health or property, please do not fail to consult with our business headquarters, branch or business office. When the usage conditions are not satisfied or exceeded, Sumida Group shall not be liable for any trouble in, or damage to, the equipment with which the product is used. 仕様書番号 SPEC.NO. S-074-1511 1/2 共 用 仕 様 書 COMMON SPECIFICATION コイル使用上の共通注意事項 Precautions of coil use 1.製品は高温、多湿、塵埃、腐食性ガスの無い環境で保管して下さい。 Products should not be kept in unsuitable storage conditions such as areas susceptible to high temperatures, high humidity, dust or corrosion. 2.製品の落下や乱雑な取り扱い、バラ積みは、破損の恐れがありますので注意して下さい。 Always handle our products with care. 3.手脂によりはんだ付け性が劣化しますので、端子に直接手を触れないで下さい。 Don't touch electrodes directly with bare hands as oil secretions may inhibit soldering. Always ensure optimum conditions for soldering. 4.端子への過度なストレスは断線の原因になりますので、端子は折り曲げないで下さい。 Don't bend the terminals or subject them to excessive stress. 5.端子及びケースのラグ部は、全てプリント基板にはんだ付けをして下さい。 Please ensure that all terminals and case lugs are completely fixed with solder onto PCB. 6.調整コアがはんだ付けフラックスにより固定されないよう、生産工程に注意して下さい。 Ensure the tuning slug or cap is not fixed by solder flux during your production process. 7.コイルの洗浄はしないで下さい。もし、洗浄が必要な場合は連絡下さい。 Refrain from rinsing coils. If it is necessary, please consult with our company. 8.プリント基板設計の際は、コイルは端面部への配置を避けて下さい。 Avoid placing coils near the edge of the PCB. 9.面実装コイルは自動実装を基準に設計されていますので、手はんだの場合は取り扱いに 注意して下さい。 Our SMT coils are designed for automatic mounting. Please be careful if soldering by hand. 10.コイルを自動実装される場合は、巻線露出部分への接触を避けて下さい。また、端子をガイド として使用しないで下さい。 Don't touch any exposed winding part and avoid coming into contact with the guide of electrode in automatic mounting. 11.当納入仕様書は、部品単体での品質を規定するものです。ご使用に際しては、御社製品に 実装された状態で必ず評価、ご確認をお願い致します。 This specification limits the quality of the component as a single unit. Please insure the component is thoroughly evaluated in your application circuit. 12.高電圧を発生させるインバータトランスでは、導体はトランスから2mm以上離す設計をして下さい。 When using our high voltage inverter transformers, please place 2mm away from electric conductor. 13.結露する環境での使用はお避けください。 Please do not use this component in a place where dew condenses . 14.密閉状態の環境で使用する場合は温度変化により結露する恐れがありますので注意をお願いします。 Since dew condensation may be caused by temperature change, please pay special attention when using this component in a sealed condition. 仕様書番号 SPEC.NO. S-074-1511 2/2 共 用 仕 様 書 COMMON SPECIFICATION リフロー耐熱 HEAT ENDURANCE リフロー耐熱試験条件 HEAT ENDURANCE TEST T( ℃) 300 260℃ 250 230℃ 200 10s 150 170±10℃、60~120s 60s 100 50 0 0 120 60 180 300 T(s) 240 * 上記の様なチャートの試験をし、常温常湿中に2時間放置後測定し、電気的、機構的異常のないこと。 THE TEST SHOULD BE MADE UNDER THE CONDITIONS ACCORDING TO THE CHART,AFTER THE TEST IT IS KEPT FOR 2 HOURS UNDER THE NORMAL TEMPERATURE AND HUMIDITY. THEN, NO MECHANICAL AND ELECTRICAL DEFECT SHOULD BE FOUND OUT. * 2回リフロー可とする。(但し、1回目と2回目の間隔は常温常湿中に1時間以上放置後とする。) THE REFLOW TEST CAN BE DONE TWICE,BUT THE INTERVAL SHOULD BE MORE THAN ONE HOUR UNDER THE NORMAL CONDITIONS. * リフロー耐熱試験条件は、弊社に於て使用しております装置によるものです。 THE REFLOW TEST CONDITIONS ARE BASED ON THE TESTING INSTRUMENTS AVAILABLE IN SUMIDA. 鉛フリーはんだ用 FOR LEAD FREE SOLDERING 仕様書番号 SPEC.NO. S-074-1516 1/1 共 用 仕 様 書 COMMON SPECIFICATION 推奨リフロー条件(温度チャート) THE RECOMMENDED REFLOW CONDITION( TEMPERATURE CHART) T( ℃) 300 245℃ ピー ク PEAK 250 230 ℃ 200 40s 150 170±10℃、60~120s 100 50 0 0 60 120 180 240 300 T(s) * 上記推奨リフロー条件は、弊社に於いて使用しておりますリフロー装置に依るものです。 付きましては、はんだ付け性は装置の種類、リフローの条件、方法等により大きく異なる場合が ありますので、リフロー条件の設定に於きましては、十分な確認の上設定願います。 THE REFLOW CONDITION RECOMMENDED ABOVE IS ACCORDING TO THE MACHINE USED BY OUR COMPANY.BIG DIFFERENCES WILL ARISE AS A RESULT OF THE TYPE OF MACHINE,REFLOW CONDITIONS,METHOD,ETC USED.HENCE,BEFORE SETTING UP YOUR REFLOW CONDITIONS,PLEASE CONFIRM WITH THE ABOVE. * 尚、不明な点がございましたら事前にお問い合わせ下さい。 MOREOVER,PLEASE CLEAR ALL DOUBTS WITH OUR COMPANY BEFORE STARTING. 鉛フリーはんだ用 FOR LEAD FREE SOLDERING 仕様書番号 SPEC.NO. S-074-1518 1/1 Revisions Symbol No. Date Revisions Client Note: Made:24th.Apr.,2013 Chk. Chk. YU WEIWEN WEI YANCHUN Drg. JIANG YANMIN CXC Part No. SUMIDA Code Sample No. First Issue Spec. No. S-0074-5753 1/6 Carrier tape packing specification ( Be in conformity with IEC 60286-3 ) 1.Application of this specification 1)Applies to SUMIDA ELECTRIC CO.,LTD. carrier tape packing. 2)For items not listed in this specification , reference to be made to the specification of the individual part. 2.Application(Types) :CEP1311F,CEP1311 3.Taping specification 1)Reel dimensions・・・・Figure 1 2)Tape dimensions・・・・Figure 2 3)Tape direction・・・・・Figure 3 4.Taping 1) The carrier tape and shield tape is wound in one continuous reel without any connected portions. Should any piece of coil be missing from the carrier tape, a“CROSS(X)" slit would be made on the shield of the cartridge and a coil replaced. After which, cellophane tape is used to reseal the cartridge. 2) The angle between the seal tape during peel off and the direction of unreeling shall be 165゜to 180゜.The seal tape shall adhere uniformly to the carrier tape along both sides in the direction of unreeling .The peel force with a peel speed of 300mm/min±10mm/min shall be as follows: 0.1N to 1.3N for a tape width. Seal tape 165゜ ~180゜ Tape direction Carrier tape 3)Precaution : completed reels with radius less than 40mm will result in the following. (Ⅰ)Cracks on the carrier tape (Ⅱ)Shield tape tearing off 5.Packing 1)Position of coils in the carrier tape : refer to the specification of the individual part. 2)There should not be : (Ⅰ)Wrong position of goods in the carrier tape (Ⅱ)Rejected goods in the carrier tape (Ⅲ)Missing goods from the carrier tape 3)One reel consists of 200pcs of coil. 4)On the completed end of the reel, the carrier tape is fixed with a driving tape. Note: Spec. No. S-0074-5753 2/6 6.Indication 1)The following will be indicated on one side of the reel : Customer part no. Quantity Lot no. Supplier Supplier specification no. Supplier type name Bar-code label used 2)Position of indication : unfixed the position Leftside from Leading edge Label Long Circle Sprocket Holes Sprocket Holes Leading Edge 7.Handling precaution The surface of the product cannot withstand a weight/force exceeding 10N. 8.Storage period of packed product The storage period of the packed product is within 6 months after the production. The storage environment is that there are no caustic factors and no dew condensation, surrounding temperature is 5~40℃ and relative humidity is 20~70%. Reel should be rewound in case of longtime storage. 9.Others Unit of measure used when placing orders : 1reel(200pcs). Note: Spec. No. S-0074-5753 3/6 Figure 1 reel dimension(unit: mm) φ330 ±2.0 W1 + 2 .0 3 2 .4 - 0 (Measure at hub) 2.0 ±0.5 φ 10 0 ±2 . 0 φ 13 ± 0. 5 φ21±1.0 W2 3 8 . 4 M a x. (Measure at hub) W3 * * + 3 .0 32 . 4 - 0. 5 The dimensions of W1,W2 and W3 are in conformity with EIA 481C. Dimension without tolerance is approx. Material Reel section PS HUB section Note: Spec. No. S-0074-5753 4/6 Figure 2 tape dimension(unit:mm) Head Material, Standard Carrier tape Material Polystyrene Seal tape material Polyester Seal tape thickness 0.1 Max. Sprocket Hole pitches 40±0.2/10 pitch * Dimensions without tolerance are approx. Note: Spec. No. S-0074-5753 5/6 Figure 3 tape direction, leader, trailer section dimension Leader section Min.400 mm Carrier tape start size Min.100 mm Trailer section size Min.160 mm Quantity 200pcs Reel Reel Start carrier tape Trailer section Note: Goods enclosure section Seal tape Leader section Spec. No. S-0074-5753 6/6
13324-T084 价格&库存
很抱歉,暂时无法提供与“13324-T084”相匹配的价格&库存,您可以联系我们找货
13324-T084
  • 1+31.864571+4.13026
  • 10+28.8007910+3.73313
  • 25+27.6546525+3.58457
  • 50+26.8099850+3.47509
  • 100+25.98611100+3.36830
库存:1914
13324-T084
  • 200+23.04538200+2.98712
  • 400+22.32974400+2.89436
  • 600+21.91990600+2.84124
  • 1000+21.412771000+2.77551
  • 1400+21.084161400+2.73291
  • 2000+20.740592000+2.68838
库存:1914
