2176-T060
2176-T060
    SUMIDA(胜美达)
    2176-T060 - IFT Coils < Pin Type: PG Series> - Sumida Corporation
2176-T060 数据手册
IFT Coils < Pin Type: PG Series> Type: PG78 /FM, PG78/AM, PG78/SW, PG78/MW ◆ Product Description ・7.6×7.6mm Max.(L×W), 8.7mm Max. Height. ・Inductance:1~820µH. ・Operating frequency:20MHz Max. ・In addition to the reference versions of parameters shown here, custom designs are available to meet your exact requirements. ◆ Feature ・Variable shielded type. ・FM,AM,SW,MW types are available. ・Internally assembled condenser is available. ・Ideally used in Radio (FM, AM,SW,MW),TV. Transceiver ・RoHS Compliance ◆ Dimensions (mm) 1.0±0.15 3.5±0.3 7.5 +0.1 φ0.5-0.05 4.5±0.15 8.2±0.5 ±0.5 3.0 4.5±0.15 7.3±0.3 * Dimension does not include solder used on coil. * Pin pitch shall be measured at the root of terminal. * Dimension without tolerance are approx. ◆ Connection (Bottom View) ④S ③ ② S① ④ S③ S② ④ ③ ② ③ ② ⑥ ① ⑥S S① ⑥ S① PG78/FM “S” is winding start PG78/AM PG78/SW PG78/MW Please refer to the sales offices on our website for a representative near you w ww.sumida.com 7.3±0.3 ④S ⑥ 1/1 IFT Coils < Pin Type: PG Series> Type: PG78 /FM, PG78/AM, PG78/SW, PG78/MW ◆ Specification (PG78/FM) (Part No. 2176-T060) (1-3) Using frequency Unloaded Qu Capacity (Int.) 10.7MHz±1% 60 Min. 100pF±10% Measuring Condition Variable 10.7MHz Ext stray capacity 0pF between (1-3) at measuring. ◆ Specification (PG78/AM) (Part No. S0975881) Item Frequency Unloaded Qu Capacity (INT.) (1-3) 455kHz±2% Variable 50 Min. 180pF±10% Measuring Conditions 455kHz ◆ Specification (PG78/SW) (Part No. 2178-T044) Item Inductance Unloaded Qu (1-3) 110µH ± 4% Variable 40 Min. Measuring Conditions 2.52MHz 2.52MHz ◆ Specification (P-7GB/MW) (Part No. 2177-T074) Item Inductance Unloaded Qu (1-3) 400μH± 5% Variable Measuring Condition 796KHz 796KHz 55 Min. Please refer to the sales offices on our website for a representative near you w ww.sumida.com 2/2
2176-T060 价格&库存
很抱歉,暂时无法提供与“2176-T060”相匹配的价格&库存,您可以联系我们找货
