IFT Coils < Pin Type: PG Series>
Type: PG78 /FM, PG78/AM, PG78/SW, PG78/MW
◆ Product Description
・7.6×7.6mm Max.(L×W), 8.7mm Max. Height. ・Inductance:1~820µH. ・Operating frequency:20MHz Max. ・In addition to the reference versions of parameters shown here, custom designs are available to meet your exact requirements.
◆ Feature
・Variable shielded type. ・FM,AM,SW,MW types are available. ・Internally assembled condenser is available. ・Ideally used in Radio (FM, AM,SW,MW),TV. Transceiver ・RoHS Compliance
◆ Dimensions (mm)
1.0±0.15
3.5±0.3
7.5
+0.1 φ0.5-0.05
4.5±0.15
8.2±0.5
±0.5 3.0
4.5±0.15 7.3±0.3
* Dimension does not include solder used on coil. * Pin pitch shall be measured at the root of terminal. * Dimension without tolerance are approx. ◆ Connection (Bottom View)
④S
③ ②
S①
④
S③ S②
④
③ ②
③ ②
⑥
①
⑥S
S①
⑥
S①
PG78/FM “S” is winding start
PG78/AM
PG78/SW
PG78/MW
Please refer to the sales offices on our website for a representative near you w ww.sumida.com
7.3±0.3
④S ⑥
1/1
◆ Specification (PG78/FM) (Part No. 2176-T060)
(1-3) Using frequency Unloaded Qu Capacity (Int.)
10.7MHz±1% 60 Min. 100pF±10%
Measuring Condition Variable
10.7MHz
Ext stray capacity 0pF between (1-3) at measuring.
◆ Specification (PG78/AM) (Part No. S0975881)
Item Frequency Unloaded Qu Capacity (INT.)
(1-3) 455kHz±2% Variable 50 Min. 180pF±10%
Measuring Conditions
455kHz
◆ Specification (PG78/SW) (Part No. 2178-T044)
Item Inductance Unloaded Qu
(1-3) 110µH ± 4% Variable 40 Min.
Measuring Conditions 2.52MHz 2.52MHz
◆ Specification (P-7GB/MW) (Part No. 2177-T074)
(1-3)
400μH± 5% Variable
Measuring Condition 796KHz 796KHz
55 Min.
2/2
很抱歉,暂时无法提供与“2178-T044”相匹配的价格&库存,您可以联系我们找货
