IFT COILS < Pin Type: PG Series>
Type: PG57/FM , PG57/AM, PG57/SW , PG57/MW
◆ Product Description
・6.1×6.1mm Max.(L×W), 8.0mm Max. Height. ・Inductance:1~820µH. ・Operating frequency:20MHz Max. ・In addition to the reference versions of parameters shown here, custom designs are available to meet your exact requirements.
◆ Feature
・Variable shielded type. ・FM,AM,SW,MW types are available ・RoHS Compliance
◆ Dimensions (mm)
0 .8 ± 0 .1 +0 . 1 φ 0. 4 -0 . 05 2 . 8 ± 0 .3 6.0
M A X . 8 .0
±0.3 2.8
3 .5 ± 0 . 2 5 .8 ± 0 . 3
* Dimension does not include solder used on coil. * Pin pitch should be measured at the root of terminal. * Dimensions without tolerance are approx. ◆Connection (Bottom View)
③ S② S①
PG57/FM
④S
③ ②
④S
S③ S②
④S
③ ②
3. 5 ± 0. 2
5. 8 ± 0. 3
④
⑥
S①
PG57/AM
⑥
①
PG57/SW
⑥
S①
PG57/MW
⑥
“S” is winding start.
Please refer to the sales offices on our website for a representative near you w ww.sumida.com
1/1
◆Specification (PG57/FM)
(Part No. : 3151-T028)
(1−3) 10.7MHz±2% 45 Min 56pF±10% Variable 10.7 MHz
Item Frequency Unloaded Qu Capacity (Int.)
Measuring Condition
Ext stray capacity 3pF between (1-3) at measuring.
◆Specification (PG57/AM)
(Part No. : 3150-T043)
(1−3) 450kHz± 2% Variable 30 Min. 180pF±10% 450kHz
Measuring Condition
◆Specification (PG57/SW)
(Part No.: 3153-T013)
(1−3) 10MHz 10μH±4% Variable 7.96MHz 7.96 MHz
Item Using frequency Inductance Unloaded Qu
Measuring Condition
50 Min
◆Specification (PG57/MW)
(Part No. : 3152-T023)
(1−3) 660μH±5% Variable
Item Inductance Unloaded Qu
Measuring Condition
796kHz 796kHz
65 Min
2/2
很抱歉,暂时无法提供与“3150-T043”相匹配的价格&库存,您可以联系我们找货
