DC COMMON MODE CHOKE COIL
Type: CPFC74
◆ Product Description
・9.5×5.7mm Max.(L×W), 5.1mm Max. Height .
◆ Feature
・Ideally used in CAN BUS ,AV,OA equipment.
・RoHS Compliance
1.3±0.1
2.54±0.15
◆ Dimensions (mm)
5.5±0.2
0.15
7.0±0.2
6.4±0.2
9.5 MAX.
5.08 MAX.
* Dimension does not include solder used on coil.
◆ Land Pattern (mm)
◆ Schematics (Bottom)
1.8
1.6
②
③
③
①
④
2.54
or
①
6.7
②
④
MARK OF POLARITY
MARK OF POLARITY
9.9
◆ Specification (For CAN bus)
Insulation
Impedance (Ω)
Resistance
(L1,L2 Parallel)
(MΩ)(Coil-Coil)
(10~100MHz)
(DC80V 1min)
Withstanding
Voltage (coil-coil)
(5sec)
D.C.R. (Ω)
(1-2)at 20℃
(3-4) short
Part Name.
Stamp
CPFC74NP-CB1ØM4
C10M
1000 MIN.
100 MIN.
200V DC
0.6 MAX.
CPFC74NP-CBØ8M6
C08M
800 MIN.
100 MIN.
200V DC
0.5 MAX.
※ D.C.R. is measured by 2 lines as series because impedance will be deteriorated when D.C.R. is
measured by 1 line.
Please refer to the sales offices on our website for a representative near you
www.sumida.com
1/2
Type: CPFC74
◆ Specification (For Power supply)
Part Name.
Impedance (Ω)
Stamp (L1,L2 Parallel)
CPFC74NP-PS1ØH2A15
P15H
CPFC74NP-PSØ2H2A2Ø
P20H
CPFC74NP-PSØ3H2A25
P25H
CPFC74NP-PSØ1H2A3Ø
P30H
700 MIN.
(100 MHz)
200 MIN.
(20~300MHz)
300 MIN.
(160 MHz)
100 MIN.
Insulation
Resistance
(MΩ)(Coil-Coil)
(DC100V 1min.)
Withstanding
Voltage
(Coil-Coil)
(5sec)
D.C.R. (mΩ)
(1-2)at 20℃
(3-4) Short
※2
Rated
Current
(1-2)(A)
(3-4) Short
※1
10 MIN.
D.C.125V
120
1.5
10 MIN.
D.C.125V
120
2.0
10 MIN.
D.C.125V
120
2.5
10 MIN.
D.C.125V
60
3.0
※1: Rated current: The DC current at which the temperature rise is △t=40℃.(Ta=20℃).
※2: D.C.R is measured by 2 lines as series because impedance will be deteriorated when D.C.R. is
measured by 1 line.
www.sumida.com
2/2
很抱歉,暂时无法提供与“CPFC74NP-4251-T093”相匹配的价格&库存,您可以联系我们找货
