445-174586-KIT
445-174586-KIT
    TDK(东电化)
    MMZ1005 AUTO KIT
445-174586-KIT 数据手册
MMZ1005 Series Ferrite Bead Kit Automotive Grade Ferrite Chip Bead Kit The TDK MMZ1005 Series ferrite chip beads are used to suppress noise in signal line circuits. They are effective at reducing noise simply by being placed into the circuit in series. Multilayer chip beads consist of ferrite material and a conductive paste layered together. Static characteristics of a chip bead are typically described as the impedance value Z at a frequency of 100MHz. While several different chip beads could provide the same impedance value at 100MHz, it is important to look at their individual frequency characteristics to determine which bead will work best for the circuit within the required frequency range. TDK offers several material types which provide various frequency characteristics for the MMZ1005 series chip beads. Automotive Features  AEC-Q200 Qualified  Noise reduction solution for general signal line  Various frequency characteristics with different materials  Countermeasures from general signals to high-speed signals  Conforms to RoHS directive, halogen free, & compatible with lead-free soldering General Signal Line  Standard operating temperature range of –55°C to +125°C  Storage temperature range of –55°C to +125°C (after PC board mounting) Datasheet Applications  ECUs  Powertrains  Body Controls  Car Multimedia (Telematics) MMZ1005 Series Automotive Chip Bead Kit Includes: Case Size: 1005 (1.0x0.5mm) Impedance Range: 10-1800Ω (±25%) Current Rating: 100-550mA Kit contains 260 pieces total—10 pieces per value Now Available at: 445-174586-KIT-ND Click the links above for ordering information. MMZ1005 Series Automotive Chip Bead Kit Includes: Digi‐Key Part Number  TDK Part Number  Case Size Impedance Value  Tol  445‐174586‐KIT‐ND  MMZ1005B800CTD25  MMZ1005B121CTD25  MMZ1005B601CTD25  MMZ1005S800CTD25  MMZ1005S121CTD25  MMZ1005S241CTD25  MMZ1005S601CTD25  MMZ1005S102CTD25  MMZ1005Y400CTD25  MMZ1005Y121CTD25  MMZ1005Y241CTD25  MMZ1005Y301CTD25  MMZ1005Y471CTD25  MMZ1005Y601CTD25  MMZ1005Y102CTD25  MMZ1005Y152CTD25  MMZ1005Y182CTD25  MMZ1005D100CTD25  MMZ1005D220CTD25  MMZ1005D330CTD25  MMZ1005D680CTD25  MMZ1005D121CTD25  MMZ1005D241CTD25  MMZ1005F330CTD25  MMZ1005F470CTD25  MMZ1005F560CTD25  1005, Bead, 80Ω±25%  1005, Bead, 120Ω±25%  1005, Bead, 600Ω±25%  1005, Bead, 80Ω±25%  1005, Bead, 120Ω±25%  1005, Bead, 240Ω±25%  1005, Bead, 600Ω±25%  1005, Bead, 1000Ω±25%  1005, Bead, 40Ω±25%  1005, Bead, 120Ω±25%  1005, Bead, 240Ω±25%  1005, Bead, 300Ω±25%  1005, Bead, 470Ω±25%  1005, Bead, 600Ω±25%  1005, Bead, 1000Ω±25%  1005, Bead, 1500Ω±25%  1005, Bead, 1800Ω±25%  1005, Bead, 10Ω±5Ω  1005, Bead, 22Ω±25%  1005, Bead, 33Ω±25%  1005, Bead, 68Ω±25%  1005, Bead, 120Ω±25%  1005, Bead, 240Ω±25%  1005, Bead, 33Ω±25%  1005, Bead, 47Ω±25%  1005, Bead, 56Ω±25%
445-174586-KIT 价格&库存
很抱歉,暂时无法提供与“445-174586-KIT”相匹配的价格&库存,您可以联系我们找货
