495-77298-KIT
495-77298-KIT
    TDK(东电化)
    铁氧体圆盘和板 工具箱
495-77298-KIT 数据手册
ER23/5/13 Ferrite core Series/Type: Ordering code: B66482 B66482G0000X608 Date: Version: 2017-07-25 2 Content of header bars 1 and 2 of data sheet will be automatically entered in headers and footers! Please fill in the table and then change the color to "white". This ensures that the table disappears (invisible) for the customer PDF. Don't change formatting when entering or pasting text in the table and don't add any cell or line in and to it! Identification/Classification 1 ER23/5/13 (header 1 + top left bar): Identification/Classification 2 Ferrite core (header 2 + bottom left header bar): Ordering code: (top right header bar) B66482G0000X608 Series/Type: (bottom right header bar) B66482 Preliminary data (optional): Department: SMP MAG D Date: 2017-07-25 Version: 2  EPCOS AG 2017. Reproduction, publication and dissemination of this publication, enclosures hereto and the information contained therein without EPCOS' prior express consent is prohibited. EPCOS AG is a TDK Group Company. ER23/5/13 Ferrite core B66482G0000X608 B66482 Magnetic characteristics (per set) l/A le Ae Amin Ve = = = = = 0.648 mm 32.6 mm 2 50.3 mm 2 50 mm 3 1640 mm -1 Approx. weight 3.9 g/pc Type of delivery In pieces Packing Standard Styrofoam tray (size 200 mm x 300 mm) 1) Material AL value nH PC200 1400 +30/-20% µe Pvmax W/Set Ordering code 720 < 0.5 (1000 kHz, 50 mT, 100 °C) B66482G0000X608 < 0.65 (2000 kHz, 30 mT, 100 °C) 1650 +30/-20% 2) 850 < 0.7 (1000 kHz, 50 mT, 100 °C) 2) < 1.55 (2000 kHz, 30 mT, 100 °C) 1) 2) Measurement Parameter: 10 kHz, 0.25 mT, 100 turns, room temperature. AL value is measured acc. to IEC62044-2. An appropriate wringing of cores with polished surface is used to improve reproducibility of the measurement. (It is recommended to rub the mating surfaces themselves six times in a circular or elliptic arc that matches the core profile before measuring AL value). 2) Magnetised (magnetised in DC field strength H = 200 A/m for 10 s) Material PC200 is not suitable for applications with strong magnetic fields above 80 A/m. With respect to power loss characteristics, customer should assure that there is no overheating in an application. For information only SMP MAG D Please read Cautions and warnings and Important notes at the end of this document. 2017-07-25 Page 2 of 5 ER23/5/13 Ferrite core B66482G0000X608 B66482 Cautions and warnings Mechanical stress and mounting Ferrite cores have to meet mechanical requirements during assembling and for a growing number of applications. Since ferrites are ceramic materials one has to be aware of the special behavior under mechanical load. As valid for any ceramic material, ferrite cores are brittle and sensitive to any shock, fast temperature changing or tensile load. Especially high cooling rates under ultrasonic cleaning and high static or cyclic loads can cause cracks or failure of the ferrite cores. For detailed information see data book, chapter “General - Definitions, 8.1”. Effects of core combination on AL value Stresses in the core affect not only the mechanical but also the magnetic properties. It is apparent that the initial permeability is dependent on the stress state of the core. The higher the stresses are in the core, the lower is the value for the initial permeability. Thus the embedding medium should have the greatest possible elasticity. For detailed information see data book, chapter “General - Definitions, 8.1”. Heating up Ferrites can run hot during operation at higher flux densities and higher frequencies. NiZn-materials The magnetic properties of NiZn-materials can change irreversible in high magnetic fields. Ferrite Accessories EPCOS ferrite accessories have been designed and evaluated only in combination with EPCOS ferrite cores. EPCOS explicitly points out that EPCOS ferrite accessories or EPCOS ferrite cores may not be compatible with those of other manufacturers. Any such combination requires prior testing by the customer and will be at the customer‘s own risk. EPCOS assumes no warranty or reliability for the combination of EPCOS ferrite accessories with cores and other accessories from any other manufacturer. Processing remarks The start of the winding process should be soft. Else the flanges may be destroyed. – Too strong winding forces may blast the flanges or squeeze the tube that the cores can not be mounted any more. – Too long soldering time at high temperature (>300 °C) may effect coplanarity or pin arrangement. – Not following the processing notes for soldering of the J-leg terminals may cause solderability problems at the transformer because of pollution with Sn oxyde of the tin bath or burned insulation of the wire. For detailed information see chapter “Processing notes”, section 2.2. – The dimensions of the hole arrangement have fixed values and should be understood as a recommendation for drilling the printed circuit board. For dimensioning the pins, the group of holes can only be seen under certain conditions, as they fit into the given hole arrangement. To avoid problems when mounting the transformer, the manufacturing tolerances for positioning the customers’ drilling process must be considered by increasing the hole diameter. SMP MAG D Please read Cautions and warnings and Important notes at the end of this document. 2017-07-25 Page 3 of 5 ER23/5/13 Ferrite core B66482G0000X608 B66482 Display of ordering codes for EPCOS products The ordering code for one and the same EPCOS product can be represented differently in data sheets, data books, other publications, on the EPCOS website, or in order-related documents such as shipping notes, order confirmations and product labels. The varying representations of the ordering codes are due to different processes employed and do not affect the specifications of the respective products. Detailed information can be found on the Internet under www.epcos.com/orderingcodes SMP MAG D Please read Cautions and warnings and Important notes at the end of this document. 2017-07-25 Page 4 of 5 Important notes The following applies to all products named in this publication: 1. Some parts of this publication contain statements about the suitability of our products for certain areas of application. These statements are based on our knowledge of typical requirements that are often placed on our products in the areas of application concerned. We nevertheless expressly point out that such statements cannot be regarded as binding statements about the suitability of our products for a particular customer application. As a rule, EPCOS is either unfamiliar with individual customer applications or less familiar with them than the customers themselves. For these reasons, it is always ultimately incumbent on the customer to check and decide whether an EPCOS product with the properties described in the product specification is suitable for use in a particular customer application. 2. We also point out that in individual cases, a malfunction of electronic components or failure before the end of their usual service life cannot be completely ruled out in the current state of the art, even if they are operated as specified. In customer applications requiring a very high level of operational safety and especially in customer applications in which the malfunction or failure of an electronic component could endanger human life or health (e.g. in accident prevention or life-saving systems), it must therefore be ensured by means of suitable design of the customer application or other action taken by the customer (e.g. installation of protective circuitry or redundancy) that no injury or damage is sustained by third parties in the event of malfunction or failure of an electronic component. 3. The warnings, cautions and product-specific notes must be observed. 4. In order to satisfy certain technical requirements, some of the products described in this publication may contain substances subject to restrictions in certain jurisdictions (e.g. because they are classed as hazardous). Useful information on this will be found in our Material Data Sheets on the Internet (www.epcos.com/material). Should you have any more detailed questions, please contact our sales offices. 5. We constantly strive to improve our products. Consequently, the products described in this publication may change from time to time. The same is true of the corresponding product specifications. Please check therefore to what extent product descriptions and specifications contained in this publication are still applicable before or when you place an order. We also reserve the right to discontinue production and delivery of products. Consequently, we cannot guarantee that all products named in this publication will always be available. The aforementioned does not apply in the case of individual agreements deviating from the foregoing for customer-specific products. 6. Unless otherwise agreed in individual contracts, all orders are subject to the current version of the “General Terms of Delivery for Products and Services in the Electrical Industry” published by the German Electrical and Electronics Industry Association (ZVEI). 7. The trade names EPCOS, CeraCharge, CeraDiode, CeraLink, CeraPad, CeraPlas, CSMP, CTVS, DeltaCap, DigiSiMic, ExoCore, FilterCap, FormFit, LeaXield, MiniBlue, MiniCell, MKD, MKK, MotorCap, PCC, PhaseCap, PhaseCube, PhaseMod, PhiCap, PowerHap, PQSine, PQvar, SIFERRIT, SIFI, SIKOREL, SilverCap, SIMDAD, SiMic, SIMID, SineFormer, SIOV, ThermoFuse, WindCap are trademarks registered or pending in Europe and in other countries. Further information will be found on the Internet at www.epcos.com/trademarks. Page 5 of 5
495-77298-KIT 价格&库存
很抱歉,暂时无法提供与“495-77298-KIT”相匹配的价格&库存,您可以联系我们找货
495-77298-KIT
  • 1+663.058651+85.78434
  • 10+575.8416010+74.50048
  • 25+544.3000525+70.41974
  • 50+532.1860450+68.85247
库存:7
