NTC thermistors for temperature measurement
NTC Probes
Series/Type:
Ordering code:
M703/10k/A47
B57703M0103A047
Date:
Version:
2015-06-22
1
Content of header bars 1 and 2 of data sheet will be automatically entered in headers and footers! Please fill in the
table and then change the color to "white". This ensures that the table disappears (invisible) for the customer PDF.
Don't change formatting when entering or pasting text in the table and don't add any cell or line in and to it!
Identification/Classification 1
(header 1 + top left header bar):
Identification/Classification 2
(header 2 + bottom left header bar):
NTC Probes
Ordering code: (top right header bar)
B57703M0103A047
Series/Type: (top right header bar)
M703/10k/A47
Preliminary data (optional):
(if necessary)
Department:
SEN NTC PD
Date:
2015-06-22
Version:
1
EPCOS AG 2015. Reproduction, publication and dissemination of this publication, enclosures hereto and the information
contained therein without EPCOS' prior express consent is prohibited.
EPCOS AG is a TDK Group Company.
NTC Probes
B57703M0103A047
M703/10k/A47
Application
High accuracy
surface
temperature
measurement e.g
heatsink
Dimensions in mm
Materials:
No. Item
1
2
3
4
5
6
7
8
Material
Property
Thermistor
Potting
Ring Tongue
Shrinktube
Shrinktube
Wire
Ceramic
Epoxy
Brass with tinned plated
Polyolefin
Polyolefin
Stranded copper with silver plated,
PTFE insulation
Crimp contact Phosphor bronze
with tin plated
Plug Housing PA 6
Remarks
EPCOS NTC
Black
Black
Black
AWG 28 (19x0.07)
Blue
JST SXH-002T-P0.6
JST XHP-2
Natural
JST connector is specified for a maximum temperature of 85°C
Ratings and characteristics
Climatic Category (IEC 60068-1)
(test without voltage)
Lower category temperature
Upper category temperature
: 25/125/56
[°C] : -25
[°C] : 125 *
Rated resistance RN // Tolerance
Rated temperature
RN
TN
[Ω // %] : 10000 // ± 3
[°C] : 25
B-value : B(25/100) // Tolerance
R/T-Curve no. // R25
BN
[K // %] : 3988 // ± 1
[n // Ω] : 8016 // 10000
SEN NTC PD
Please read Cautions and warnings and
Important notes at the end of this document.
2015-06-22
Page 2 of 7
NTC Probes
B57703M0103A047
M703/10k/A47
Max. power rating at 25°C
P25
[mW] : 150
Dissipation factor (in air)
Thermal time constant (in air)
Heat capacity
δth
τa
Cth
[mW/K] : approx. 3 **
[s] : approx. 50 **
[mJ/K]: approx. 150 **
Voltage proof // Time
Vis
[Vac] : 2700 // 1sec
Remark:
* Up to 150°C for max 30 minutes
** Typical values, depends on mounting situation
Delivery mode
Bulk
NTC Resistance Temperature Curve
R/T-Curve
R at 25°C
Temp. [°C]
-20
-15
-10
-5
10
15
30
35
40
45
50
55
60
65
8016 / A01
10000 [Ohm]
R Nom [Ω]
97070
72929
55330
42315
32650
25388
19900
15708
12490
10000
8057
6531
5327
4369
3603
2986
2488
2083
B(25/100)
Rn at 25°C
R Min [Ω]
91801
69193
52658
40391
31254
24369
19152
15156
12081
9700
7793
6304
5130
4199
3456
2859
2377
1987
SEN NTC PD
R Max [Ω]
[Ω]
102339
76665
58002
44239
34046
26406
20648
16260
12899
10300
8321
6759
5524
4539
3750
3114
2599
2180
3988[K] ± 1 [%]
10000 [Ohm] ± 3 [%]
∆R [±%]
5.4
5.1
4.8
4.5
4.3
4.0
3.8
3.5
3.3
3.0
3.3
3.5
3.7
3.9
4.1
4.3
4.5
4.6
2015-06-22
Page 3 of 7
NTC Probes
70
75
80
85
90
95
100
105
110
115
120
125
130
135
140
145
150
1752
1481
1258
1072
917.7
788.5
680.0
588.6
511.2
445.4
389.3
341.7
300.9
265.4
234.8
208.3
185.3
1668
1408
1193
1016
867.7
744.4
641.0
554.0
480.4
418.0
364.8
319.8
281.2
247.8
218.9
194.0
172.3
B57703M0103A047
M703/10k/A47
1836
1555
1323
1129
967.7
832.6
719.0
623.2
542.0
472.8
413.8
363.6
320.6
283.1
250.7
222.7
198.3
4.8
5.0
5.1
5.3
5.4
5.6
5.7
5.9
6.0
6.2
6.3
6.4
6.5
6.7
6.8
6.9
7.0
Reliability Data
Test
Test conditions
∆R25/R25
Remarks
(typical)
Storage in dry
Heat
Storage at upper category temperature
Temperature: 125°C; Duration: 1000 h
很抱歉,暂时无法提供与“495-77559-KIT”相匹配的价格&库存,您可以联系我们找货
