(1/2) 001-01 / 20030823 / e9613_acf.fm
EMC Components
ACF Series ACF321825, 451832 Types
3-Terminal Filters for Signal Line and DC Power Line SMD
FEATURES • The ACF series are T-type EMC filters incorporating ferrite chip beads and multilayer ceramic chip capacitors. • The external structure consists entirely of ferrite, enabling these parts to achieve superior attenuation characteristics despite their extremely compact dimensions. ACF321825 TYPE SHAPES AND DIMENSIONS/CIRCUIT DIAGRAM
3.2± 0.3 Terminal electrode
• Because they can be mounted on edge, the ACF series are ideal for high-density circuit configurations. • Available for reflow soldering.
RECOMMENDED PC BOARD PATTERN REFLOW SOLDERING
2.5±0.25
2
0.6
0.35 Ferrite GND terminal
GND 2
No polarity
1.94
0.3
1
3
Insulation resin
1
3
1.8±0.2
1.4
0.6 2.2
1.4
Resist Land pattern Dimensions in mm
ELECTRICAL CHARACTERISTICS
Part No. ACF321825-223-T ACF321825-103-T ACF321825-682-T ACF321825-472-T ACF321825-332-T ACF321825-222-T ACF321825-152-T ACF321825-102-T ACF321825-681-T ACF321825-471-T ACF321825-331-T ACF321825-221-T ACF321825-151-T ACF321825-101-T ACF321825-680-T ACF321825-470-T ACF321825-330-T ACF321825-220-T Maximum attenuation frequency (MHz) 17 27 37 45 55 65 80 100 120 145 165 200 240 300 370 450 530 650 25dB attenuation frequency range (MHz) 11 to 55 17 to 60 22 to 75 30 to 85 37 to 90 45 to 105 60 to 115 80 to 140 95 to 150 120 to 180 130 to 210 170 to 250 205 to 280 265 to 340 340 to 420 420 to 500 500 to 600 600 to 700 Rated voltage Edc Rated current (V)max. (mA)max. 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 300 300 300 300 300 300 300 300 300 300 300 300 300 300 300 300 300 300 DC resistance (Ω)max. [Terminal No.1 to 3] 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 Insulation resistance (M Ω)min. [Terminal No.1 to 2/No.2 to 3] 1000 1000 1000 1000 1000 1000 1000 1000 1000 1000 1000 1000 1000 1000 1000 1000 1000 1000
TYPICAL ELECTRICAL CHARACTERISTICS ATTENUATION vs. FREQUENCY CHARACTERISTICS
MEASURING CIRCUIT
S.G. 50Ω ACF Series L.M.
Attenuation (dB)
22
3
10
3
68 47 33 222
40
50
1
3
10
30 100 Frequency (MHz)
300
1000
• All specifications are subject to change without notice.
50Ω
10
0 22 0 33 0 47 0 681 101 151 22 1 331 471 2 68 2 15 10 2 22
(2/2) 001-01 / 20030823 / e9613_acf.fm
EMC Components
ACF451832 TYPE SHAPES AND DIMENSIONS/CIRCUIT DIAGRAM
4.5 ± 0.4
3
3.2 ± 0.3
Terminal electrode
1
0.4
1 2 1
3
Insulation resin
GND 2
No polarity
1.94
1.8 ± 0.2
1.75
Dimensions in mm
1 3.5
Resist Land pattern
1.75
Dimensions in mm
Part No. ACF451832-333-T ACF451832-223-T ACF451832-153-T ACF451832-103-T ACF451832-682-T ACF451832-472-T ACF451832-332-T ACF451832-222-T ACF451832-152-T ACF451832-102-T ACF451832-681-T ACF451832-471-T ACF451832-331-T ACF451832-221-T ACF451832-151-T ACF451832-101-T ACF451832-680-T ACF451832-470-T ACF451832-330-T ACF451832-220-T Maximum attenuation frequency (MHz) 12 15 18 23 35 40 50 60 75 90 105 125 150 190 230 280 340 410 500 600 25dB attenuation frequency range (MHz) 7 to 60 9 to 65 11 to 70 15 to 75 20 to 85 25 to 95 35 to 100 40 to 110 50 to 130 65 to 150 75 to 160 95 to 180 115 to 205 150 to 250 190 to 290 235 to 335 295 to 395 360 to 460 450 to 550 550 to 650 Rated voltage Edc Rated current (V)max. (mA)max. 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 300 300 300 300 300 300 300 300 300 300 300 300 300 300 300 300 300 300 300 300 DC resistance (Ω)max. [Terminal No.1 to 3] 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 Insulation resistance (M Ω)min. [Terminal No.1 to 2/No.2 to 3] 1000 1000 1000 1000 1000 1000 1000 1000 1000 1000 1000 1000 1000 1000 1000 1000 1000 1000 1000 1000
0 10 Attenuation(dB) 20 30 40 50 60
22 15 10 68 47 33 22 3 3 3 2222 33 3
MEASURING CIRCUIT
S.G. 50Ω 50Ω ACF Series L.M.
1 101 151 31 3 22 1 1 68 47 2 2 15 10
0 22 0 330 680 47
1
3
10
300
1000
很抱歉,暂时无法提供与“ACF321825-152-T”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+2.1976
- 30+2.1156
- 100+1.9516
- 500+1.7876
- 1000+1.7056
