ACH32C-333-T
ACH32C-333-T
    TDK(东电化)
    FILTER-3P_3216(METRIC)
    FILTER LC(T) 0.033UF SMD
ACH32C-333-T 数据手册
E M C C o m p o n e n t s July 2013 3-terminal Filters For power line ACH series ACH32C ACH3218 [1206 inch]* [1207 inch] * Dimensions Code JIS[EIA] (2/9) E M C C o m p o n e n t s REMINDERS FOR USING THESE PRODUCTS Before using these products, be sure to request the delivery specifications. SAFETY REMINDERS Please pay sufficient attention to the warnings for safe designing when using these products. REMINDERS The storage period is less than 12 months. Be sure to follow the storage conditions (Temperature: 5 to 40°C, Humidity: 10 to 75% RH or less). If the storage period elapses, the soldering of the terminal electrodes may deteriorate. Do not use or store in locations where there are conditions such as gas corrosion (salt, acid, alkali, etc.). Before soldering, be sure to preheat components. The preheating temperature should be set so that the temperature difference between the solder temperature and chip temperature does not exceed 150°C. Soldering corrections after mounting should be within the range of the conditions determined in the specifications. If overheated, a short circuit, performance deterioration, or lifespan shortening may occur. When embedding a printed circuit board where a chip is mounted to a set, be sure that residual stress is not given to the chip due to the overall distortion of the printed circuit board and partial distortion such as at screw tightening portions. Self heating (temperature increase) occurs when the power is turned ON, so the tolerance should be sufficient for the set thermal design. Carefully lay out the coil for the circuit board design of the non-magnetic shield type. A malfunction may occur due to magnetic interference. Use a wrist band to discharge static electricity in your body through the grounding wire. Do not expose the products to magnets or magnetic fields. Do not use for a purpose outside of the contents regulated in the delivery specifications. The products listed on this catalog are intended for use in general electronic equipment (AV equipment, telecommunications equipment, home appliances, amusement equipment, computer equipment, personal equipment, office equipment, measurement equipment, industrial robots) under a normal operation and use condition. The products are not designed or warranted to meet the requirements of the applications listed below, whose performance and/or quality require a more stringent level of safety or reliability, or whose failure, malfunction or trouble could cause serious damage to society, person or property. If you intend to use the products in the applications listed below or if you have special requirements exceeding the range or conditions set forth in the each catalog, please contact us. (1) Aerospace/Aviation equipment (2) Transportation equipment (cars, electric trains, ships, etc.) (3) Medical equipment (4) Power-generation control equipment (5) Atomic energy-related equipment (6) Seabed equipment (7) Transportation control equipment (8) Public information-processing equipment (9) Military equipment (10) Electric heating apparatus, burning equipment (11) Disaster prevention/crime prevention equipment (12) Safety equipment (13) Other applications that are not considered general-purpose applications When designing your equipment even for general-purpose applications, you are kindly requested to take into consideration securing protection circuit/device or providing backup circuits in your equipment. 001-01 / 20130722 / e9611_ach.fm (3/9) E M C C o m p o n e n t s 3-terminal Filters Product compatible with RoHS directive Halogen-free Compatible with lead-free solders For power line Overview of the ACH Series FEATURES T-type EMC filter that can be used for high-current circuits. Achieve excellent attenuation characteristics by using it for circuits with stable grounds. Does not require mounting space due to vertical mounting design, making it perfect for high-density circuits. Guaranteed temperature range is –40 to +125°C, so it can be used under severe environmental conditions. Use this product under reflow soldering conditions. APPLICATION HE devices (TVs, VTRs, CD players, electronic musical instruments, PCs, etc.) OA equipment (Computers, terminals, facsimiles, etc.) FA equipment (Robots, NC machine tools, process controllers, etc.) AE equipment (Car navigation systems, ECUs, etc.) ACH32C cannot be used for ECUs. PART NUMBER CONSTRUCTION ACH32C ACH Series name 32C - L×W×T Dimensions (mm) 32C 3.2×1.6×2.1 103 - Capacitance (pF) 100 10 103 10000 T 001 Packaging style Internal code T Taping ACH3218 ACH Series name 3218 - L×W×T Dimensions (mm) 3218 3.2×1.8×2.5 223 - Capacitance (pF) 223 22000 T □□□ Packaging style Internal code T Taping OPERATING TEMPERATURE RANGE, PACKAGE QUANTITY, PRODUCT WEIGHT Temperature range Operating Storage temperature temperature (°C) (°C) ACH32C –40 to +125 –40 to +125 ACH3218 –40 to +125 –40 to +125 The Storage temperature range is for after the circuit board is mounted. Type Package quantity Individual weight (pieces/reel) 2,000 1,000 (mg) 70 70 RoHS Directive Compliant Product: See the following for more details related to RoHS Directive compliant products. http://www.tdk.co.jp/rohs/ Halogen-free: Indicates that Cl content is less than 900ppm, Br content is less than 900ppm, and that the total Cl and Br content is less than 1500ppm. • All specifications are subject to change without notice. 001-01 / 20130722 / e9611_ach.fm (4/9) E M C C o m p o n e n t s Overview of the ACH Series RECOMMENDED REFLOW PROFILE Preheating Soldering Natural cooling Peak T: Temperature T4 T3 T2 T3 t3 T1 t1 t2 t: Time Preheating Temp. T1 T2 150°C 180°C Time t1 60 to 120s Soldering Temp. Time T3 t2 230°C 30 to 60s Peak Temp. T4 250 to 260°C Time t3 10s max. • All specifications are subject to change without notice. 001-01 / 20130722 / e9611_ach.fm (5/9) E M C C o m p o n e n t s ACH series ACH32C Type SHAPE & DIMENSIONS 2.1±0.2 1.6±0.2 3.2 ± 0.2 1 3 0.1 2 Dimensions in mm RECOMMENDED LAND PATTERN CIRCUIT DIAGRAM 4.2 0.6 1.0 3 1 GND 2 0.5 2.6 1.0 • No polarity Dimensions in mm • All specifications are subject to change without notice. 001-01 / 20130722 / e9611_ach.fm (6/9) E M C C o m p o n e n t s ACH series ACH32C Type ELECTRICAL CHARACTERISTICS CHARACTERISTICS SPECIFICATION TABLE Rated voltage (V)max. Rated current (A)max. Insulation resistance (M: )min. DC resistance (m: )max. 50 50 50 50 50 50 50 50 50 50 6 6 6 6 6 6 6 6 6 6 100 100 100 100 100 100 100 100 100 100 2 2 2 2 2 2 2 2 2 2 ○ Measurement equipment Measurement item Product No. Insertion loss E5071B DC resistance 4338A Insulation resistance 4339A * Equivalent measurement equipment may be used. Guaranteed insertion loss (dB) –15 –15 –15 –20 –20 –25 –25 –25 –25 –25 Guaranteed frequency Part No. bandwidth (MHz) 2000 to 6000 ACH32C-100-T001 1300 to 2500 ACH32C-220-T001 650 to 2500 ACH32C-470-T001 450 to 1300 ACH32C-101-T001 200 to 800 ACH32C-331-T001 100 to 350 ACH32C-102-T001 55 to 300 ACH32C-222-T001 30 to 200 ACH32C-103-T001 10 to 300 ACH32C-333-T001 3.5 to 200 ACH32C-104-T001 Manufacturer Agilent Technologies Agilent Technologies Agilent Technologies INSERTION LOSS VS. FREQUENCY CHARACTERISTICS 0 10 Insertion loss (dB) 20 30 220 100 470 101 40 331 50 102 104 60 103 222 333 70 80 1 10 100 Frequency (MHz) 1000 10000 ○ Measurement equipment Product No. Manufacturer E5071B Agilent Technologies * Equivalent measurement equipment may be used. • All specifications are subject to change without notice. 001-01 / 20130722 / e9611_ach.fm (7/9) E M C C o m p o n e n t s ACH series ACH3218 Type SHAPE & DIMENSIONS 2.5± 0.25 3.2± 0.3 0.45 1.8± 0.2 0.6 Dimensions in mm RECOMMENDED LAND PATTERN CIRCUIT DIAGRAM 3 1.94 1 GND 2 • No polarity 1.4 0.6 2.2 1.4 Dimensions in mm • All specifications are subject to change without notice. 001-01 / 20130722 / e9611_ach.fm (8/9) E M C C o m p o n e n t s ACH series ACH3218 Type ELECTRICAL CHARACTERISTICS CHARACTERISTICS SPECIFICATION TABLE Insertion loss 25dB frequency range (MHz) 11 to 55 17 to 60 22 to 75 30 to 85 37 to 90 45 to 105 60 to 115 80 to 140 95 to 150 120 to 180 130 to 210 170 to 250 205 to 280 265 to 340 340 to 420 420 to 500 500 to 600 600 to 700 Rated voltage (V)max. Rated current (A)max. 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 1.5 1.5 1.5 1.5 1.5 1.5 1.5 1.5 1.5 1.5 1.5 1.5 1.5 1.5 1.5 1.5 1.5 1.5 DC resistance (: )max. [Terminal No.1 to 3] 0.06 0.06 0.06 0.06 0.06 0.06 0.06 0.06 0.06 0.06 0.06 0.06 0.06 0.06 0.06 0.06 0.06 0.06 Insulation resistance (M: )min. [Terminal No.1 to 2/No.2 to 3] 1000 1000 1000 1000 1000 1000 1000 1000 1000 1000 1000 1000 1000 1000 1000 1000 1000 1000 Part No. ACH3218-223-T□□□ ACH3218-103-T□□□ ACH3218-682-T□□□ ACH3218-472-T□□□ ACH3218-332-T□□□ ACH3218-222-T□□□ ACH3218-152-T□□□ ACH3218-102-T□□□ ACH3218-681-T□□□ ACH3218-471-T□□□ ACH3218-331-T□□□ ACH3218-221-T□□□ ACH3218-151-T□□□ ACH3218-101-T□□□ ACH3218-680-T□□□ ACH3218-470-T□□□ ACH3218-330-T□□□ ACH3218-220-T□□□ INSERTION LOSS VS. FREQUENCY CHARACTERISTICS 0 Insertion loss (dB) 10 332 20 102 222 30 330 220 40 152 223 50 470 680 1 3 10 103 221 151 101 471 331 472 682 30 Frequency (MHz) 681 100 300 1000 • All specifications are subject to change without notice. 001-01 / 20130722 / e9611_ach.fm (9/9) E M C C o m p o n e n t s ACH series Packaging style REEL DIMENSIONS 2.0±0.5 W1 W2 9±0.3 13+1.4 13.0±0.3 17.0±0.4 ø60min. Type ACH32C ACH3218 1.0 ø13±0.2 W1 ø21±0.8 W2 +0 ø180 –3 Dimensions in mm B F 4.0±0.1 8.0±0.3 2.0±0.05 1.5 +0.1 0 1.75±0.1 TAPE DIMENSIONS 4.0±0.1 A K Dimensions in mm Type ACH32C ACH3218 A 1.9±0.1 2.2±0.1 B 3.5±0.1 3.7±0.05 F 3.5±0.05 5.5±0.05 W 8.0±0.2 12.0±0.3 K 2.3±0.1 3.15max. 500 to 560min. 160min. Taping 440min. ACH32C TYPE Drawing direction 40 to 80 Dimensions in mm Taping 200min. ACH3218 TYPE Drawing direction 300min. Dimensions in mm • All specifications are subject to change without notice. 001-01 / 20130722 / e9611_ach.fm
ACH32C-333-T 价格&库存
很抱歉,暂时无法提供与“ACH32C-333-T”相匹配的价格&库存,您可以联系我们找货
