ACH4518-471-TD01
ACH4518-471-TD01
    TDK(东电化)
    ACH4518-471-TD01
ACH4518-471-TD01 数据手册
3-teminal Filters For power line ACH series Type: ACH32C ACH3218 ACH4518 [1206 inch]* [1207 inch] [1807 inch] * Dimensions Code [EIA] Issue date: September 2011 • All specifications are subject to change without notice. • Conformity to RoHS Directive: This means that, in conformity with EU Directive 2002/95/EC, lead, cadmium, mercury, hexavalent chromium, and specific bromine-based flame retardants, PBB and PBDE, have not been used, except for exempted applications. (1/6) 3-terminal Filters For Power Line Conformity to RoHS Directive ACH Series ACH32C FEATURES • These T-type EMC filters comprise ferrite beads and chip capacitors and are engineered to handle high current levels. • The series offers even greater attenuation characteristics when used in a stable circuit on the ground. • The ACH series is ideal for high-density circuit design, since the series is vertically mounted and does not require much mounting space. • Because guarantee temperature range is –40 to +125°C, it is possible to use in strict environmental condition. • Available for reflow soldering. APPLICATIONS Home electronic equipment, (TVs, VCRs, CD players, DAT players, electric musical instruments, PCs, etc.), office automation equipment (computers, terminals, stand-alone word processors, fax machines, etc.), factory automation equipment (robots, numerical control devices, process controllers, etc.), automotive electronics (car navigation, ECU, etc.) PRODUCT IDENTIFICATION ACH 32C - 103 - T (1) (2) (3) (4) (5) (1) Series name (2) Dimensions 32C: 3216 type(3.2×1.6mm) (3) Capacitance 103: 10000pF (4) Packaging style T: ø180mm reel taping (5) TDK internal code TEMPERATURE RANGES Operating Storage(After mount) –40 to +125°C –40 to +125°C PACKAGING STYLE AND QUANTITIES Packaging style Taping Reel ø180mm Quantity 2000 pieces/reel SHAPES AND DIMENSIONS/CIRCUIT DIAGRAM RECOMMENDED SOLDERING CONDITIONS RECOMMENDED TEMPERATURE PROFILE FOR LEAD-FREE SOLDER 3.2 ± 0.2 2.1±0.2 1.6±0.2 3.0 Marking Peak 245˚C max. 3 1 Natural cooling 230˚C GND 2 1 3 180˚C 150˚C 60 to 120s 0.1 2 0.45 No polarity 1.7 Ferrite Time (s) GND terminal Terminal electrode 0.7 10 to 30s Dimensions in mm REFLOW PROFILE FOR SOLDER HEAT RESISTANCE Peak 260˚C max. RECOMMENDED PC BOARD PATTERN REFLOW SOLDERING Natural cooling 230˚C 180˚C 4.2 1.0 0.6 150˚C 1.0 2.6 40s max. 0.5 60 to 120s Land pattern Time (s) Dimensions in mm • Conformity to RoHS Directive: This means that, in conformity with EU Directive 2002/95/EC, lead, cadmium, mercury, hexavalent chromium, and specific bromine-based flame retardants, PBB and PBDE, have not been used, except for exempted applications. • Please contact our Sales office when your application is considered the following: The device’s failure or malfunction may directly endanger human life (e.g. application for automobile/aircraft/medical/nuclear power devices, etc.) • All specifications are subject to change without notice. 001-03 / 20110928 / e9611_ach (2/6) ELECTRICAL CHARACTERISTICS Part No. Rated voltage Edc(V)max. Rated current (A)max. Insulation resistance (MΩ )min. DC resistance (mΩ )max. ACH32C-100-T001 ACH32C-220-T001 ACH32C-470-T001 ACH32C-101-T001 ACH32C-331-T001 ACH32C-102-T001 ACH32C-222-T001 ACH32C-103-T001 ACH32C-333-T001 ACH32C-104-T001 50 50 50 50 50 50 50 50 50 50 6 6 6 6 6 6 6 6 6 6 100 100 100 100 100 100 100 100 100 100 2 2 2 2 2 2 2 2 2 2 Guaranteed attenuation (dB) –15 –15 –15 –20 –20 –25 –25 –25 –25 –25 Guaranteed frequency bandwidth (MHz) 2000 to 6000 1300 to 2500 650 to 2500 450 to 1300 200 to 800 100 to 350 55 to 300 30 to 200 10 to 300 3.5 to 200 TYPICAL ELECTRICAL CHARACTERISTICS ATTENUATION vs. FREQUENCY CHARACTERISTICS (Glass epoxy coated double side mounting PCB) 0 0 102 –20 –10 Attenuation (dB) Attenuation (dB) –10 103 –30 –40 104 –50 –60 –30 333 –40 –50 –60 –70 –70 –80 1 10 0 100 Frequency (MHz) 1000 331 –10 –80 1 10000 10 100 Frequency (MHz) 1000 10000 1000 10000 0 100 –10 –20 Attenuation (dB) Attenuation (dB) 222 –20 –30 –40 –50 –60 –70 –20 220 470 101 –30 –40 –50 –60 –70 –80 1 10 100 Frequency (MHz) 1000 10000 –80 1 10 100 Frequency (MHz) CIRCUIT DIAGRAM S.G. ACH-C Series L.M. 50Ω 50Ω • All specifications are subject to change without notice. 001-03 / 20110928 / e9611_ach (3/6) 3-terminal Filters For Power Line Conformity to RoHS Directive ACH Series ACH3218, ACH4518 FEATURES • The ACH series consists of products with superior attenuation characteristics, in which the T-type filter circuit is magnetically shielded with ferrite. • The series offers even greater attenuation characteristics when used in a stable circuit on the ground. • The ACH series is ideal for high-density circuit design, since the series is vertically mounted and does not require much mounting space. • Available for reflow soldering. • It is a product conforming to RoHS directive. PRODUCT IDENTIFICATION ACH 3218 - 223 - T D (1) (2) (3) (4) (5) (1) Series name (2) Dimensions (3) Type (4) Packaging style (5) TDK internal code TEMPERATURE RANGES Operating Storage(After mount) –40 to +125°C –40 to +125°C PACKAGING STYLE AND QUANTITIES Packaging style Taping HANDLING AND PRECAUTIONS • Before soldering, be sure to preheat components. The preheating temperature should be set so that the temperature difference between the solder temperature and product temperature does not exceed 150°C. • After mounting components onto the printed circuit board, do not apply stress through board bending or mishandling. • The inductance value may change due to magnetic saturation if the current exceeds the rated maximum. • Do not expose the inductors to stray magnetic fields. • Avoid static electricity discharge during handling. • When hand soldering, apply the soldering iron to the printed circuit board only. Temperature of the iron tip should not exceed 350°C. Soldering time should not exceed 3 seconds. Quantity 1000 pieces/reel • Conformity to RoHS Directive: This means that, in conformity with EU Directive 2002/95/EC, lead, cadmium, mercury, hexavalent chromium, and specific bromine-based flame retardants, PBB and PBDE, have not been used, except for exempted applications. • Please contact our Sales office when your application is considered the following: The device’s failure or malfunction may directly endanger human life (e.g. application for automobile/aircraft/medical/nuclear power devices, etc.) • All specifications are subject to change without notice. 001-03 / 20110928 / e9611_ach (4/6) ACH3218 TYPE SHAPES AND DIMENSIONS/CIRCUIT DIAGRAM RECOMMENDED PC BOARD PATTERN REFLOW SOLDERING Terminal electrode 1 3 2 0.6 3 1 1.94 2.5±0.25 3.2 ± 0.3 Insulation resin GND 2 No polarity 0.45 1.8±0.2 Ferrite Dimensions in mm GND terminal 1.4 0.6 2.2 Resist Land pattern 1.4 Dimensions in mm • Dimension without tolerance is reference value. ELECTRICAL CHARACTERISTICS Part No. 25dB attenuation frequency range (MHz) ACH3218-223 ACH3218-103 ACH3218-682 ACH3218-472 ACH3218-332 ACH3218-222 ACH3218-152 ACH3218-102 ACH3218-681 ACH3218-471 ACH3218-331 ACH3218-221 ACH3218-151 ACH3218-101 ACH3218-680 ACH3218-470 ACH3218-330 ACH3218-220 11 to 55 17 to 60 22 to 75 30 to 85 37 to 90 45 to 105 60 to 115 80 to 140 95 to 150 120 to 180 130 to 210 170 to 250 205 to 280 265 to 340 340 to 420 420 to 500 500 to 600 600 to 700 Rated voltage Edc (V)max. 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 Rated current (A)max. DC resistance (Ω )max. [Terminal No.1 to 3] 1.5 1.5 1.5 1.5 1.5 1.5 1.5 1.5 1.5 1.5 1.5 1.5 1.5 1.5 1.5 1.5 1.5 1.5 0.06 0.06 0.06 0.06 0.06 0.06 0.06 0.06 0.06 0.06 0.06 0.06 0.06 0.06 0.06 0.06 0.06 0.06 TYPICAL ELECTRICAL CHARACTERISTICS ATTENUATION vs. FREQUENCY CHARACTERISTICS Insulation resistance (MΩ )min. [Terminal No.1 to 2/No.2 to 3] 1000 1000 1000 1000 1000 1000 1000 1000 1000 1000 1000 1000 1000 1000 1000 1000 1000 1000 MEASURING CIRCUIT 0 S.G. ACH Series L.M. 50Ω 3 10 68 47 33 2 2 2 3 10 3 20 50Ω 22 0 220 33 0 47 0 681 101 15 1 22 1 331 471 2 68 2 15 10 2 22 Attenuation (dB) 10 30 40 50 1 30 100 Frequency (MHz) 300 1000 • All specifications are subject to change without notice. 001-03 / 20110928 / e9611_ach (5/6) ACH4518 TYPE SHAPES AND DIMENSIONS/CIRCUIT DIAGRAM RECOMMENDED PC BOARD PATTERN REFLOW SOLDERING Terminal electrode 1 3 3 1 1.94 3.2±0.3 4.5±0.4 Insulation resin GND 2 2 1.0 No polarity 0.45 1.8±0.2 Ferrite Dimensions in mm GND terminal 1.75 • Dimension without tolerance is reference value. Resist Land pattern 1.0 3.5 1.75 Dimensions in mm ELECTRICAL CHARACTERISTICS Part No. 25dB attenuation frequency range (MHz) ACH4518-333 ACH4518-223 ACH4518-153 ACH4518-103 ACH4518-682 ACH4518-472 ACH4518-332 ACH4518-222 ACH4518-152 ACH4518-102 ACH4518-681 ACH4518-471 ACH4518-331 ACH4518-221 ACH4518-151 ACH4518-101 ACH4518-680 ACH4518-470 ACH4518-330 ACH4518-220 6 to 60 9 to 65 11 to 70 15 to 75 20 to 85 25 to 90 35 to 100 40 to 110 50 to 130 65 to 150 75 to 160 95 to 180 115 to 205 150 to 250 190 to 290 235 to 335 290 to 395 360 to 460 450 to 550 530 to 650 Rated voltage Edc (V)max. 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 50 TYPICAL ELECTRICAL CHARACTERISTICS ATTENUATION vs. FREQUENCY CHARACTERISTICS Rated current (A)max. DC resistance (Ω )max. [Terminal No.1 to 3] 2.0 2.0 2.0 2.0 2.0 2.0 2.0 2.0 2.0 2.0 2.0 2.0 2.0 2.0 2.0 2.0 2.0 2.0 2.0 2.0 0.06 0.06 0.06 0.06 0.06 0.06 0.06 0.06 0.06 0.06 0.06 0.06 0.06 0.06 0.06 0.06 0.06 0.06 0.06 0.06 Insulation resistance (MΩ )min. [Terminal No.1 to 2/No.2 to 3] 1000 1000 1000 1000 1000 1000 1000 1000 1000 1000 1000 1000 1000 1000 1000 1000 1000 1000 1000 1000 MEASURING CIRCUIT 0 S.G. ACH Series L.M. 50Ω 50Ω 0 22 0 330 680 47 22 15 10 68 47 33 22 3 3 3 2 2 2 2 33 3 20 1 101 151 31 3 22 1 1 68 47 2 2 15 10 Attenuation(dB) 10 30 40 50 60 1 3 10 30 100 Frequency (MHz) 300 1000 • All specifications are subject to change without notice. 001-03 / 20110928 / e9611_ach (6/6) PACKAGING STYLES REEL DIMENSIONS ø60±2.0 1.0 2.0±0.5 13.0±0.3 ø13±0.5 17.0±1.4 ø21±0.8 ø178±2.0 Dimensions in mm 1.5 +0.1 –0.0 Cavity 5.5±0.05 Sprocket hole B 12.0±0.3 0.3 to 0.4 1.75±0.1 TAPE DIMENSIONS T A 4.0±0.1 D C Dimensions in mm Type 321825 451832 A 2.2±0.2 2.2±0.2 40 to 80 B 3.7±0.2 5.2±0.2 Taping C 4.0±0.1 4.0±0.1 D 2.0±0.05 2.0±0.05 T 3.3max. 3.8max. 200min. Drawing direction 300min. Dimensions in mm • All specifications are subject to change without notice. 001-03 / 20110928 / e9611_ach
ACH4518-471-TD01
物料型号:ACH32C、ACH3218、ACH4518,尺寸代码遵循EIA标准。
器件简介:这些T型EMC滤波器由铁氧体珠和芯片电容器组成,设计用于处理高电流水平,提供优越的衰减特性,适用于高密度电路设计,并且可以在-40至+125°C的温度范围内工作。
引脚分配:文档提供了详细的尺寸和电路图,包括地线(GND)终端和无极性的端子电极。
参数特性:包括额定电压、最大额定电流、最小绝缘电阻、最大直流电阻、保证的衰减值、保证的频率带宽等。
功能详解:ACH系列适用于多种应用,如家用电器、办公自动化设备、工厂自动化设备和汽车电子设备。
应用信息:适用于需要电磁兼容性的多种电子设备,以减少电源线上的噪声。
封装信息:提供了不同型号的封装风格和数量,例如T型封装,每卷2000件。
ACH4518-471-TD01 价格&库存
很抱歉,暂时无法提供与“ACH4518-471-TD01”相匹配的价格&库存,您可以联系我们找货
ACH4518-471-TD01
    • 5+3.942975+0.51257
    库存:1
