ACM1211-102-2PL-TL01 数据手册
E M C
C o m p o n e n t s
Common mode filters
For power line
ACM series
RoHS
REACH
SVHC-Free
Cl
Br
Pb
Halogen
Free
Lead
Free
ACM1211 type
FEATURES
Chip common mode filter for large current applications.
For each series, there is excellent common mode impedance and noise suppression in a compact case.
Compatible with high-density portable devices, which are always being made smaller and lighter, because the height has been
reduced.
Operating temperature range: –40 to +85°C
APPLICATION
Power line noise countermeasure for various electronic equipment.
Noise countermeasure for adapter lines and battery lines or larger electronic equipment such as note PCs and word processors.
PART NUMBER CONSTRUCTION
ACM
1211
Series name
L×W×H dimensions
12.0×11.0*6.0 mm
701
Impedance
() at 100MHz
2PL
Number of lines
TL
01
Packaging style
Internal code
CHARACTERISTICS SPECIFICATION TABLE
Common mode impedance
DC resistance
Rated current
Insulation
resistance
Rated voltage
Part No.
[100MHz]
( )min.
500
750
[1 line]
(m )max.
6
14
(A)max.
8
6
(M )min.
10
10
(V)max.
80
80
ACM1211-701-2PL-TL01
( )typ.
700
1000
Measurement equipment
Measurement item
Product No.
4991A
DC resistance
4338A
Insulation resistance
4339A
* Equivalent measurement equipment may be used.
Manufacturer
Keysight Technologies
Please be sure to request delivery specifications that provide further details on the features and specifications of the products for proper and safe use.
Please note that the contents may change without any prior notice due to reasons such as upgrading.
(1/4)
20181011
cmf_commercial_power_acm1211_en.fm
E M C
C o m p o n e n t s
ACM1211 type
IMPEDANCE VS. FREQUENCY CHARACTERISTICS
10000
102 Differential mode
Impedance (Ω)
701 Differential mode
102 Common mode
1000
701 Common mode
100
10
1
1
10
100
1000
Frequency (MHz)
Product No.
Manufacturer
4991A
(2/4)
20181011
E M C
C o m p o n e n t s
ACM1211 type
SHAPE & DIMENSIONS
PACKAGING STYLE
REEL DIMENSIONS
12.0±0.3
2.0±0.5
4
2
3
7.4typ.
2.3±0.2
6.0max.
2.3±0.2
100±1
11.0±0.3
1
2 typ.
1.0
2.7±0.2
2.7±0.2
ø13.0±0.2
2.5±0.2
24.4+2/–0
ø21.0±0.8
Dimensions in mm
28.4 typ.
ø330±2
Dimensions in mm
RECOMMENDED LAND PATTERN
2.0±0.1
Sprocket
hole
4.0±0.1
1.75±0.1
1.5 +0.1
0.5±0.05
24.0±0.3
7.4
B
14.0
Dimensions in mm
Cavity
K
A
CIRCUIT DIAGRAM
1
4
2
3
11.5±0.1
2.5
7.9
TAPE DIMENSIONS
16.0±0.1
Dimensions in mm
Type
ACM1211
A
11.5±0.1
160min.
Taping
B
12.5±0.1
K
6.4±0.1
• No polarity
500 to 560min.
RECOMMENDED REFLOW PROFILE
Preheating
Soldering
440min.
Natural
cooling
Drawing direction
Peak
245°C
Temperature
230°C
Dimensions in mm
230°C
PACKAGE QUANTITY
Package quantity
500 pcs/reel
180°C
5s
150°C
60 to 120s
10 to 30s
TEMPERATURE RANGE, INDIVIDUAL WEIGHT
Operating
Storage
temperature range
temperature range
–40 to +85 °C
–40 to +85 °C
The storage temperature range is for after the assembly.
Individual
weight
2.3 g
Time
(3/4)
20181011
E M C
C o m p o n e n t s
REMINDERS FOR USING THESE PRODUCTS
Before using these products, be sure to request the delivery specifications.
SAFETY REMINDERS
Please pay sufficient attention to the warnings for safe designing when using this products.
REMINDERS
The storage period is less than 12 months. Be sure to follow the storage conditions (temperature: 5 to 40°C, humidity: 10 to 75% RH or
less).
If the storage period elapses, the soldering of the terminal electrodes may deteriorate.
Do not use or store in locations where there are conditions such as gas corrosion (salt, acid, alkali, etc.).
Before soldering, be sure to preheat components.
The preheating temperature should be set so that the temperature difference between the solder temperature and chip temperature
does not exceed 150°C.
Soldering corrections after mounting should be within the range of the conditions determined in the specifications.
If overheated, a short circuit, performance deterioration, or lifespan shortening may occur.
When embedding a printed circuit board where a chip is mounted to a set, be sure that residual stress is not given to the chip due to
the overall distortion of the printed circuit board and partial distortion such as at screw tightening portions.
Self heating (temperature increase) occurs when the power is turned ON, so the tolerance should be sufficient for the set thermal
design.
Carefully lay out the coil for the circuit board design of the non-magnetic shield type.
A malfunction may occur due to magnetic interference.
Use a wrist band to discharge static electricity in your body through the grounding wire.
Do not expose the products to magnets or magnetic fields.
Do not use for a purpose outside of the contents regulated in the delivery specifications.
The products listed on this catalog are intended for use in general electronic equipment (AV equipment, telecommunications equipment, home appliances, amusement equipment, computer equipment, personal equipment, office equipment, measurement equipment, industrial robots) under a normal operation and use condition.
The products are not designed or warranted to meet the requirements of the applications listed below, whose performance and/or quality require a more stringent level of safety or reliability, or whose failure, malfunction or trouble could cause serious damage to society,
person or property.
If you intend to use the products in the applications listed below or if you have special requirements exceeding the range or conditions
set forth in the each catalog, please contact us.
(1) Aerospace/aviation equipment
(2) Transportation equipment (cars, electric trains, ships, etc.)
(3) Medical equipment
(4) Power-generation control equipment
(5) Atomic energy-related equipment
(6) Seabed equipment
(7) Transportation control equipment
(8) Public information-processing equipment
(9) Military equipment
(10) Electric heating apparatus, burning equipment
(11) Disaster prevention/crime prevention equipment
(12) Safety equipment
(13) Other applications that are not considered general-purpose
applications
When designing your equipment even for general-purpose applications, you are kindly requested to take into consideration securing protection circuit/device or providing backup circuits in your equipment.
(4/4)
20181011
ACM1211-102-2PL-TL01 价格&库存
很抱歉,暂时无法提供与“ACM1211-102-2PL-TL01”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+17.130901+2.12560
- 10+12.0114010+1.49040
- 100+9.73740100+1.20820
- 500+8.73450500+1.08380
- 1000+8.396401000+1.04180
- 2500+7.964902500+0.98830
- 5000+7.731605000+0.95930
- 10000+7.7200010000+0.95790
- 国内价格
- 1+6.74099
- 10+6.47350
- 100+5.83150
- 500+5.51050
