ACM12V-701-2PL
ACM12V-701-2PL
    TDK(东电化)
ACM12V-701-2PL 数据手册
E M C C o m p o n e n t s Common mode filters/Chokes Automotive power line (for power train/safety) ACM-V series ACM12V type ■FEATURES ⃝Exclusive square type closed magnetic core designed as an exclusive core is used, so it can be small while maintaining the same features. ⃝Low profile design makes it optimal for surface mounting. ⃝Excellent impedance characteristics, making it great for suppressing common mode noise. ⃝It can handle up to a maximum of 16A, including temperature derating. ⃝Operating temperature range: -40 to +125°C (Does not include self-heating.) -40 to +150°C if self-heating is included. ⃝Compliant with AEC-Q200 ■APPLICATION ⃝Measures against common mode noise in power lines for various DC power lines, multimedia devices, and various electronic devices, including automotive power trains and safety applications. ■PART NUMBER CONSTRUCTION ACM 12V - Series name L×W×H dimensions 12.0×11.0×6.0 mm 701 - Impedance (Ω) at 100MHz 2PL - Number of lines TL 00 Packaging style Internal code ■CHARACTERISTICS SPECIFICATION TABLE Common mode impedance [at 100MHz] DC resistance Rated current Operating environment temperature -40~85°C (Ω)min. (Ω)typ. (mΩ)max. (A)max. 240 350 2.9 16.0 500 700 6 13.0 1200 1700 12 7.0 * Please refer to the derating curve for the rated current. 105°C (A)max. 14.0 11.0 6.0 125°C (A)max. 10.0 8.0 4.8 Rated voltage Insulation Part No. resistance (V)max. 80 80 80 (MΩ)min. 10 10 10 ACM12V-351-2PL-TL00 ACM12V-701-2PL-TL00 ACM12V-172-2PL-TL00 Derating 20 Rated current (A) 16 ACM12V-351 12 ACM12V-701 8 ACM12V-172 4 0 –40 65 85 Temperature (°C) 105 125 Measurement equipment Measurement item Product No. * Common mode impedance 4991B DC resistance RM3545 Insulation resistance 4339B * Equivalent measurement equipment may be used. Manufacturer Keysight Technologies HIOKI E.E. CORPORATION Keysight Technologies Please be sure to request delivery specifications that provide further details on the features and specifications of the products for proper and safe use. (1/4) Please note that the contents may change without any prior notice due to reasons such as upgrading. 20250414 cmf_automotive_power_acm12v_en E M C C o m p o n e n t s ACM12V type ■IMPEDANCE VS. FREQUENCY CHARACTERISTICS 10000 172 Differential mode 701 Differential mode 172 Common mode 1000 Impedance (Ω) 701 Common mode 351 Common mode 100 351 Differential mode 10 1 1 10 100 1000 Frequency (MHz) Measurement equipment Product No. * Manufacturer 4991B Keysight Technologies * Equivalent measurement equipment may be used. ■TEMPERATURE RANGE, INDIVIDUAL WEIGHT Operating temperature range * Storage temperature range ** Individual weight –40 to +125 °C –40 to +125 °C 2.3 g * The operating temperature range of this product does not include self-heating. If self-heating is included, the product can be used at -40 to +150°C. For use at 125°C, please use within the current range shown in the table on page (1/4) of this catalog. **The storage temperature range is for after the assembly. Please be sure to request delivery specifications that provide further details on the features and specifications of the products for proper and safe use. (2/4) Please note that the contents may change without any prior notice due to reasons such as upgrading. 20250414 cmf_automotive_power_acm12v_en E M C C o m p o n e n t s ACM12V type ■SHAPE & DIMENSIONS ■PACKAGING STYLE □REEL DIMENSIONS 12.0±0.3 2.0±0.5 4 2 3 11.0±0.3 1 2.3±0.2 ø100±1 (7.4) 6.0max. 2.3±0.2 2.7±0.2 2.7±0.2 2.5±0.2 Dimensions in mm ø13.0±0.2 16.4+2.0/-0 (ø21) 22.4 max. ø330±2 ■RECOMMENDED LAND PATTERN Dimensions in mm 14.0 Sprocket hole 2±0.1 24±0.3 4±0.1 1.75±0.1 7.9 2.5 ø1.55±0.05 0.5±0.05 B Dimensions in mm ■CIRCUIT DIAGRAM 1 4 2 3 11.5±0.1 □TAPE DIMENSIONS 7.4 K 16±0.1 A Dimensions in mm Type A B K ACM12V (13.2) (13.5) (6.4) • No polarity 500 to 560min. 160min. ■RECOMMENDED REFLOW PROFILE Preheating Soldering Dimensions in mm Natural cooling □PACKAGE QUANTITY 245°C Temperature 440min. Drawing direction Peak 230°C Taping Package quantity 500 pcs/reel 230°C 180°C 5s max. 150°C 60 to 120s 10 to 30s Time Please be sure to request delivery specifications that provide further details on the features and specifications of the products for proper and safe use. (3/4) Please note that the contents may change without any prior notice due to reasons such as upgrading. 20250414 cmf_automotive_power_acm12v_en E M C C o m p o n e n t s REMINDERS FOR USING THESE PRODUCTS Before using these products, be sure to request the delivery specifications. SAFETY REMINDERS Please pay sufficient attention to the warnings for safe designing when using this products REMINDERS ⃝The storage period is within 12 months. Be sure to follow the storage conditions (temperature: 5 to 40°C, humidity: 10 to 75% RH or less). If the storage period elapses, the soldering of the terminal electrodes may deteriorate. ⃝Do not use or store in locations where there are conditions such as gas corrosion (salt, acid, alkali, etc.). ⃝Soldering corrections after mounting should be within the range of the conditions determined in the specifications. If overheated, a short circuit, performance deterioration, or lifespan shortening may occur. ⃝When embedding a printed circuit board where a chip is mounted to a set, be sure that residual stress is not given to the chip due to the overall distortion of the printed circuit board and partial distortion such as at screw tightening portions. ⃝Self heating (temperature increase) occurs when the power is turned ON, so the tolerance should be sufficient for the set thermal design. ⃝Carefully lay out the coil for the circuit board design of the non-magnetic shield type. A malfunction may occur due to magnetic interference. ⃝Use a wrist band to discharge static electricity in your body through the grounding wire. ⃝Do not expose the products to magnets or magnetic fields. ⃝Do not use for a purpose outside of the contents regulated in the delivery specifications. ⃝The products described in this catalog are intended to be installed in automobiles or automotive electronic equipment (AV equipment, telecommunications equipment, home appliances, amusement equipment, computer equipment, personal equipment, office equipment, measurement equipment, industrial robots) and to be used in automobiles (including the case where the said automotive product is mounted in a vehicle) or standard applications as general electronic equipment in automotive applications or standard applications as general electronic equipment in automotive applications in accordance with the scope and conditions described in this specification, while the said automotive or general electronic equipment including the said product is intended to be used in the usual operation and usage methods, respectively. Other than automotive or automotive products are not designed or warranted to meet the requirements of the applications listed below, whose performance and/or quality requires a more stringent level of safety or reliability, or whose failure, malfunction or defect could cause serious damage to society, person or property. Please understand that we are not responsible for any damage or liability caused by use of the products in any of the applications below or for any other use exceeding the range or conditions set forth in this specification sheet. If you intend to use the products in the applications listed below or if you have special requirements exceeding the range or conditions set forth in this specification, please contact us. (1) Aerospace/aviation equipment (2) Transportation equipment (electric trains, ships, etc.) (3) Medical equipment (4) Power-generation control equipment (5) Atomic energy-related equipment (6) Seabed equipment (7) Transportation control equipment (8) Public information-processing equipment (9) Military equipment (10) Electric heating apparatus, burning equipment (11) Disaster prevention/crime prevention equipment (12) Safety equipment (13) Other applications that are not considered general-purpose applications When designing your equipment even for general-purpose applications, you are kindly requested to take into consideration securing protection circuit/device or providing backup circuits in your equipment. Please be sure to request delivery specifications that provide further details on the features and specifications of the products for proper and safe use. (4/4) Please note that the contents may change without any prior notice due to reasons such as upgrading. 20250414 cmf_automotive_power_acm12v_en
ACM12V-701-2PL 价格&库存
很抱歉,暂时无法提供与“ACM12V-701-2PL”相匹配的价格&库存,您可以联系我们找货
