ACM1513-551-2PL-T
ACM1513-551-2PL-T
    TDK(东电化)
    ACM1513-551-2PL-T
ACM1513-551-2PL-T 数据手册
Issue Date: 2015/05/26 TDK Corporation MAGNETICS BD GM Toshihiro Kuroshima Comon-mode filter Product Discontinuation Notice First of all, we would like to thank you very much for your continuous cooperation with TDK and our products. This letter informs your company that TDK is planning to discontinue and stop production of the certain products we have been currently shipping to you. Due to product profitability or products elimination and unification, we had to decide to discontinue manufacturing the products listed below. This list not only shows cross-reference between your part number and our part number for each of end-of-life products, but also exhibits TDK part numbers of recommended alternative products wherever available. We deeply regret to inform you of this discontinuation. However, because of above reason, please let us ask you for considering replacement with TDK's alternative product wherever possible. If there is no TDK's alternative product available, then we have to ask you to kindly look into other sources in the market. Description Your product name Our product name Our substitute ACM1513-551-2PL ACM1513-551-2PL-TL ACM1513-551-2PL-TLHF ACM1513-551-2PL-T ACM1513-551-2PL-TL ACM1513-551-2PL-TLHF ACM1513-551-2PL-TL ACM1513-551-2PL-TL ACM1513-551-2PL-TLHF ZJY51R5-8PA-01 ZJY51R5-8PA-01 ACP3225-102-2P-TL000 Products Effected: Please refer to product name list. 1.Pls issue final order until below date. *Last Buy PO receive date : December 25, 2015 2. The end-products delivery date : June 30, 2016 . After receiving this letter, please send the acknowledgement to TDK local salesperson who is currently serving you. We apologize for any inconveniences raised by this discontinuation of products, but do hope we will have your kind understanding and your cooperation soon.Sincerely yours, Accept Company Department Name 1 Page 20 , Jul , 2010 TDK Common-mode filters MAGNETICS BUSINESS GROUP TDK-EPC CORPORATION Current item Item Product name Changes TDK-EPC Common-mode filter ACM1513-551-2PL-TLHF Rated current Rated voltage DC resistance Product Spec Replaceable item TDK-EPC Common-mode filter ACM1513-551-2PL-TL DC(A)max. DC(V)max. (mΩ)max. Operating temperature range(deg.C) 10 80 4 -25 to 85 Resin Rated current Rated voltage DC resistance DC(A)max. DC(V)max. (mΩ)max. Operating temperature range(deg.C) 10 80 4 -25 to 85 *Resin Cover Product structure Product name Cover Bobbin core Material Bobbin core Wire Solder Terminal Electrode No Change Wire *Solder Terminal Electrode *Halogen-Free Material L D C C L D C A C A B W B W A A Shapes and dimensions No Change T T E E unit : mm unit : mm L W T L W T 15.4±0.4 13.4±0.4 6.0max. 15.4±0.4 13.4±0.4 6.0max. A B C D E A B C D E 2.7±0.2 3.8±0.2 2.3±0.2 10.4 typ. 3.8 2.7±0.2 3.8±0.2 2.3±0.2 10.4 typ. 3.8 A A B B C Recommended footprint C D D unit : mm unit : mm A B C D A B C D 17.0 10.4 2.7 6.5 17.0 10.4 2.7 6.5 10000 10000 Differential-mode Common-mode Impedance(Ω) Frequency vs. Impedance characteristics (reference) Impedance(Ω) Differential-mode 1000 No Change 100 10 1 1000 Common-mode 100 No Change 10 1 1 10 100 Frequency(MHz) 1000 1 10 100 Frequency(MHz) 1000 Common Mode Filters Substitution Table WIRE WOUND EMC BUSINESS UNIT MAGNETICS BUSINESS GROUP TDK-EPC CORPORATION Status product Product name Product spec Substitute product Changes TDK Common-mode filter ZJY51R5-8PA-01 TDK Common-mode filter Product name ACP3225-102-2P-T000 change Rated voltage :DC50V max. Rated current :DC0.5A max. Rdc :0.07Ωtyp. Insulation resistance :100M ohm min. Common-mode Impedance :200ohm min. at 20 to 300MHz Operating temperature range :-25 to +85 deg.C Rated current , Rdc and Withstanding voltage are changed Rated voltage :DC60V max. Rated current :DC1.5A max. Rdc :0.10Ωmax. Insulation resistance :10M ohm min. Common-mode Impedance :750ohm min. at 100MHz Operating temperature range :-40 to +85 deg.C (0.65) (0.3) (0.9) (0.3) (9.0) T D K 0.5 min. 4.6 max. 2.54 min. ZJY51R5-8PA Shapes and dimension is changed 3.2±0.2 Shapes and dimension is changed (0.4) 1.9±0.1 0 to 15° 2.5±0.2 (7.62) (0.65) 7.0 max. All spec are changed (0.25) 23.5 max Shapes and dimension Changes Product name change コプラナリティ 0.1max. 単位:mm (0.5) 2.54+0.25/-0.25 10,000 Common-mode Impedance Impedance(Ohm) 1,000 Electrical characteristics 100 ZJY51R5-8PA-01 The frequency response is changed. ACP3225-102 10 1 1 10 100 1,000 Frequency(MHz) 10sec.max. Peak 260 degrees Solder flow recommendation profile Slow cooling 100 to 150 degrees 60 to 120sec. Peak 245 degrees centigrade Solder reflow recommendation profile 230 degrees centigrade Slow cooling 150 to 180 degrees centigrade 10 to 30 sec. max. 0.4 Foot print 0.75 0.4 60 to 120sec. 0.9 1.9 0.9
ACM1513-551-2PL-T 价格&库存
很抱歉,暂时无法提供与“ACM1513-551-2PL-T”相匹配的价格&库存,您可以联系我们找货
