E M C
C o m p o n e n t s
July 2013
Common Mode Filters
For high-speed differential signal line, general signal line
ACM series
ACM2012
ACM2520
[0805 inch]*
[1008 inch]
* Dimensions Code JIS[EIA]
(2/11)
E M C
C o m p o n e n t s
REMINDERS FOR USING THESE PRODUCTS
Before using these products, be sure to request the delivery specifications.
SAFETY REMINDERS
Please pay sufficient attention to the warnings for safe designing when using these products.
REMINDERS
The storage period is less than 6 months. Be sure to follow the storage conditions (Temperature: 5 to 40°C, Humidity: 10 to 75% RH or
less).
If the storage period elapses, the soldering of the terminal electrodes may deteriorate.
Do not use or store in locations where there are conditions such as gas corrosion (salt, acid, alkali, etc.).
Before soldering, be sure to preheat components.
The preheating temperature should be set so that the temperature difference between the solder temperature and chip temperature
does not exceed 150°C.
Soldering corrections after mounting should be within the range of the conditions determined in the specifications.
If overheated, a short circuit, performance deterioration, or lifespan shortening may occur.
When embedding a printed circuit board where a chip is mounted to a set, be sure that residual stress is not given to the chip due to
the overall distortion of the printed circuit board and partial distortion such as at screw tightening portions.
Self heating (temperature increase) occurs when the power is turned ON, so the tolerance should be sufficient for the set thermal
design.
Carefully lay out the coil for the circuit board design of the non-magnetic shield type.
A malfunction may occur due to magnetic interference.
Use a wrist band to discharge static electricity in your body through the grounding wire.
Do not expose the products to magnets or magnetic fields.
Do not use for a purpose outside of the contents regulated in the delivery specifications.
The products listed on this catalog are intended for use in general electronic equipment (AV equipment, telecommunications
equipment, home appliances, amusement equipment, computer equipment, personal equipment, office equipment, measurement
equipment, industrial robots) under a normal operation and use condition.
The products are not designed or warranted to meet the requirements of the applications listed below, whose performance and/or
quality require a more stringent level of safety or reliability, or whose failure, malfunction or trouble could cause serious damage to
society, person or property.
If you intend to use the products in the applications listed below or if you have special requirements exceeding the range or conditions
set forth in the each catalog, please contact us.
(1) Aerospace/Aviation equipment
(2) Transportation equipment (cars, electric trains, ships, etc.)
(3) Medical equipment
(4) Power-generation control equipment
(5) Atomic energy-related equipment
(6) Seabed equipment
(7) Transportation control equipment
(8) Public information-processing equipment
(9) Military equipment
(10) Electric heating apparatus, burning equipment
(11) Disaster prevention/crime prevention equipment
(12) Safety equipment
(13) Other applications that are not considered general-purpose
applications
When designing your equipment even for general-purpose applications, you are kindly requested to take into consideration securing
protection circuit/device or providing backup circuits in your equipment.
001-01 / 20130723 / e9712_acm.fm
(3/11)
E M C
C o m p o n e n t s
Common Mode Filters
Product compatible with RoHS directive
Compatible with lead-free solders
Overview of the ACM Series
FEATURES
Downsized wound type chip common mode filter that maintains required common mode filter characteristics.
Impedance for common mode noise can clear 1000: [100MHz], and has excellent EMC suppression.
Differential mode impedance is suppressed, so there is virtually no affect on high speed signals.
There is a two-line type and a three-line type, so they can be used for various circuits and noise.
APPLICATION
Common mode noise countermeasure for high-speed differential signals where influence to the signal is a concern.
USB line for PCs and peripheral devices.
IEEE1394 lines and ETHERNET lines for PCs, STBs, etc.
LCD panel LVDS and Panel Link lines.
PART NUMBER CONSTRUCTION
ACM
Series name
2012
L×W×H Dimensions
(mm)
2012
2.0×1.2×1.3
2520
2.5×2.0×1.2
900
Impedance
(:) at 100MHz
900
90
201
200
102
1000
2P
T
Number of lines
2P
3P
2 lines
3 lines
Packaging style
T
TL
002
Internal code
ø180mm reel
ø330mm reel
OPERATING TEMPERATURE RANGE, PACKAGE QUANTITY, PRODUCT WEIGHT
Type
Temperature range
Operating
Storage
temperature
temperature
(°C)
(°C)
ACM2012
–40 to +85
–40 to +85
ACM2520
–40 to +85
–40 to +85
Reel diameter
Package quantity
Individual weight
(mm)
ø180
ø330
ø180
ø330
(pieces/reel)
2,000
10,000
2,000
10,000
(mg)
10
25
The Storage temperature range is for after the circuit board is mounted.
RoHS Directive Compliant Product: See the following for more details related to RoHS Directive compliant products. http://www.tdk.co.jp/rohs/
• All specifications are subject to change without notice.
(4/11)
E M C
C o m p o n e n t s
RECOMMENDED REFLOW PROFILE
Preheating
Soldering
Natural
cooling
Peak
T: Temperature
T4
T3
T2
T3
t3
T1
t1
t2
t: Time
Preheating
Temp.
T1
T2
150°C
180°C
Time
t1
60 to 120s
Soldering
Temp.
Time
T3
t2
230°C
10 to 30s
Peak
Temp.
T4
245°C
Time
t3
5s
(5/11)
E M C
C o m p o n e n t s
ACM series
ACM2012 Type
SHAPE & DIMENSIONS
0.5
0.3
0.05
1.2±0.2
0.3
1.3max.
2.0±0.2
0.4
1.2
0.4
Dimensions in mm
CIRCUIT DIAGRAM
1
4
2
3
0.4
0.4
0.4
RECOMMENDED LAND PATTERN
• No polarity
0.75
1.1
0.75
Dimensions in mm
(6/11)
E M C
C o m p o n e n t s
ACM series ACM2012 Type
ELECTRICAL CHARACTERISTICS
CHARACTERISTICS SPECIFICATION TABLE
Impedance
(: ) [100MHz]
min.
typ.
65
90
90
120
150
200
270
360
DC resistance
(: )max.[per line]
Rated voltage
(V)max.
Rated current
(A)max.
Part No.
0.19
0.22
0.25
0.5
50
50
50
50
0.4
0.37
0.35
0.22
ACM2012-900-2P-T002
ACM2012-121-2P-T002
ACM2012-201-2P-T002
ACM2012-361-2P-T002
○ Measurement equipment
Measurement item
Product No.
Common mode impedance
4991A
DC resistance
4338A
Insulation resistance
4339A
* Equivalent measurement equipment may be used.
Manufacturer
Agilent Technologies
IMPEDANCE VS. FREQUENCY CHARACTERISTICS
10000
121 Common mode
1000
Impedance (Ω)
201 Common mode
361 Common mode
121 Differential mode
100
361 Differential mode
201 Differential mode
900 Common mode
10
1
900 Differential mode
1
10
100
1000
Frequency (MHz)
Product No.
Manufacturer
4991A
(7/11)
E M C
C o m p o n e n t s
ACM series
ACM2520-2P Type
SHAPE & DIMENSIONS
1.30
2.0±0.2
2.5±0.2
1.6
0.45
0.85
1.2±0.1
0.45
Dimensions in mm
0.40
1.3
0.8
1.5
0.8
CIRCUIT DIAGRAM
1
4
2
3
• No polarity
Dimensions in mm
(8/11)
E M C
C o m p o n e n t s
ACM series ACM2520-2P Type
Impedance
(: ) [100MHz]
min.
typ.
225
300
330
450
450
600
750
1000
DC resistance
(: )max.[per line]
Rated voltage
(V)max.
Rated current
(A)max.
Part No.
0.35
0.4
0.45
0.9
0.35
0.3
0.2
ACM2520-301-2P-T002
ACM2520-451-2P-T002
ACM2520-601-2P-T002
ACM2520-102-2P-T002
Measurement item
Product No.
4991A
DC resistance
4338A
4339A
Manufacturer
10000
601 Common mode
451 Common mode
Impedance (Ω)
1000
451 Differential mode
601 Differential mode
102 Common mode
100
301 Common mode
102 Differential mode
301 Differential mode
10
1
1
10
100
1000
Frequency (MHz)
Product No.
Manufacturer
4991A
(9/11)
E M C
C o m p o n e n t s
ACM series
ACM2520-3P Type
SHAPE & DIMENSIONS
3
4
2
5
1
6
1.6
0.45
0.85
1.2±0.1
0.45
2.0±0.2
1.3=P0.65×2
2.5±0.2
Dimensions in mm
CIRCUIT DIAGRAM
1
6
2
5
3
4
0.35
1.3=P0.65×2
• No polarity
0.8
1.5
0.8
Dimensions in mm
(10/11)
E M C
C o m p o n e n t s
ACM series ACM2520-3P Type
Impedance
(: ) [100MHz]
min.
typ.
600
800
DC resistance
(: )max.[per line]
Rated voltage
(V)max.
Rated current
(A)max.
Part No.
1.6
ACM2520-801-3P-T002
Measurement item
Product No.
4991A
DC resistance
4338A
4339A
Manufacturer
10000
Impedance (Ω)
1000
801 Common mode
100
801 Differential mode
10
1
1
10
100
1000
Frequency (MHz)
Product No.
Manufacturer
4991A
(11/11)
E M C
C o m p o n e n t s
ACM series
Packaging style
REEL DIMENSIONS
2.0±0.5
E
Type
ACM2012
W1
9.5±0.5
9+1/–0
9.5±0.5
9+1/–0
W2
13.5±1
13±1
13.5±1
13±1
N
100±1
60+1/–0
100±1
60+1–0
E
2 typ.
2 typ.
2 typ.
2 typ.
N
ACM2520
A
ø330±2
ø180±3
ø330±2
ø180±3
1.0
ø13.0±0.2
W1
ø21.0±0.8
W2
A
Dimensions in mm
TAPE DIMENSIONS
P2
t
P0
W
B
F
E
øD0
A
K
P1
Dimensions in mm
Type
ACM2012
ACM2520
A
1.4±0.1
2.4±0.1
B
2.25±0.1
2.9±0.1
øD0
1.5+0.1/0
1.5+0.1/0
E
1.75±0.1
1.75±0.1
F
3.5±0.1
3.5±0.1
P0
4.0±0.1
4.0±0.1
P1
4.0±0.1
4.0±0.1
P2
2.0±0.1
2.0±0.1
W
8.0±0.2
8.0±0.2
K
1.4±0.1
1.45±0.1
t
0.25±0.05
0.25±0.05
500 to 560min.
160min.
Taping
440min.
Drawing direction
Dimensions in mm
很抱歉,暂时无法提供与“ACM2012-900-2P-T”相匹配的价格&库存,您可以联系我们找货
