The products in this catalog are not recommended for new design
E M C
C o m p o n e n t s
Common mode filters
For ultra high-speed differential signal line (HDMI, DVI, DisplayPort, USB3.0, etc.)
ACM-H series
RoHS
REACH
SVHC-Free
Cl
Br
Pb
Halogen
Free
Lead
Free
ACM2012H-T05 type
FEATURES
Broadband common mode filter that was developed for Gbps-level high-speed differential signal interfaces such as DVI and HDMITM.
Differential mode cutoff frequency of 90 is 5GHz, so they do not negatively influence high-speed differential signals.
Characteristics impedance of 90 is matched for 100, which is set for many differential interfaces, and can suppress unnecessary
reflection components.
It does not adversely affect the transmission signal of the LAN and suppresses unnecessary common mode noise.
Operating temperature range: –40 to +85°C
APPLICATION
EMI measure for high-speed differential signal interfaces for digital video signal interfaces such as HDMITM, DVI, Display port, and Serial
ATA used for PCs, etc.
This product is suitable for anti-EMI measures with pulse ALT4532 series in high-speed LAN interfaces such as Multi-Gigabit Ethernet
and 10G Ethernet.
PART NUMBER CONSTRUCTION
ACM
2012
H
Series name
L×W×H dimensions
2.0×1.2×1.2 mm
Product
internal code
900
Impedance
()at 100MHz
2P
Number of lines
T
05
Packaging style
Internal code
CHARACTERISTICS SPECIFICATION TABLE
Common mode
impedance
[at 100MHz]
( )min.
65
280
( )typ.
90
380
DC resistance Rated current
[1 line]
( )max.
0.30
0.50
(mA)max.
300
300
Rated voltage Insulation
resistance
Cutoff
frequency
Characteristic
impedance
(V)max.
(GHz)typ.
5
( )typ.
100
(M )min.
10
10
Part No.
ACM2012H-900-2P-T05
ACM2012H-381-2P-T05
Measurement equipment
Measurement item
Product No.
Common mode impedance
4991A
DC resistance
4338A
Insulation resistance
4339A
* Equivalent measurement equipment may be used.
Manufacturer
Keysight Technologies
Please be sure to request delivery specifications that provide further details on the features and specifications of the products for proper and safe use.
Please note that the contents may change without any prior notice due to reasons such as upgrading.
(1/4)
20220113
cmf_commercial_signal_acm2012h-t05_en.fm
E M C
C o m p o n e n t s
ACM2012H-T05 type
IMPEDANCE VS. FREQUENCY CHARACTERISTICS
10000
Impedance (Ω)
1000
381 Common mode
100
900 Differential mode
381 Differential mode
10
900 Common mode
1
1
10
100
Frequency (MHz)
1000
10000
Product No.
Manufacturer
4991A
(2/4)
20220113
E M C
C o m p o n e n t s
ACM2012H-T05 type
PACKAGING STYLE
SHAPE & DIMENSIONS
REEL DIMENSIONS
2.0±0.2
(0.4)
1.2±0.1
60+1/–0
1.2±0.2
2.0±0.5
(0.4)
(1.2)
(0.35) (0.5)
ø13.0±0.2
9+1/–0
(ø21)
13±1.4
ø180+0/–3
Dimensions in mm
Dimensions in mm
0.4
2±0.1
4±0.1
B
0.4
8±0.2
0.4
ø1.5 +0.1
–0
3.5±0.1
Sprocket
hole
0.25±0.05
1.75±0.1
TAPE DIMENSIONS
RECOMMENDED LAND PATTERN
0.75
0.75
1.2
Dimensions in mm
K
ø1 +0.2
–0
4±0.1
A
Cavity
Dimensions in mm
CIRCUIT DIAGRAM
1
4
2
3
Type
ACM2012H-T05
A
(1.4)
B
(2.25)
K
(1.4)
500 to 560min.
160min.
• No polarity
Taping
440min.
RECOMMENDED REFLOW PROFILE
Drawing direction
Preheating
Soldering
Natural
cooling
Dimensions in mm
Peak
245°C
Temperature
230°C
230°C
5s max.
60 to 120s
Package quantity
2000 pcs/reel
TEMPERATURE RANGE, INDIVIDUAL WEIGHT
180°C
150°C
PACKAGE QUANTITY
10 to 30s
Operating
Storage
temperature range
temperature range
–40 to +85 °C
–40 to +85 °C
The storage temperature range is for after the assembly.
Individual
weight
10 mg
Time
(3/4)
20220113
E M C
C o m p o n e n t s
REMINDERS FOR USING THESE PRODUCTS
Before using these products, be sure to request the delivery specifications.
SAFETY REMINDERS
Please pay sufficient attention to the warnings for safe designing when using this products.
REMINDERS
The storage period is within 6 months. Be sure to follow the storage conditions (temperature: 5 to 40°C, humidity: 10 to 75% RH or
less).
If the storage period elapses, the soldering of the terminal electrodes may deteriorate.
Do not use or store in locations where there are conditions such as gas corrosion (salt, acid, alkali, etc.).
Before soldering, be sure to preheat components.
The preheating temperature should be set so that the temperature difference between the solder temperature and chip temperature
does not exceed 150°C.
Soldering corrections after mounting should be within the range of the conditions determined in the specifications.
If overheated, a short circuit, performance deterioration, or lifespan shortening may occur.
When embedding a printed circuit board where a chip is mounted to a set, be sure that residual stress is not given to the chip due to
the overall distortion of the printed circuit board and partial distortion such as at screw tightening portions.
Self heating (temperature increase) occurs when the power is turned ON, so the tolerance should be sufficient for the set thermal
design.
Carefully lay out the coil for the circuit board design of the non-magnetic shield type.
A malfunction may occur due to magnetic interference.
Use a wrist band to discharge static electricity in your body through the grounding wire.
Do not expose the products to magnets or magnetic fields.
Do not use for a purpose outside of the contents regulated in the delivery specifications.
The products listed on this catalog are intended for use in general electronic equipment (AV equipment, telecommunications equipment, home appliances, amusement equipment, computer equipment, personal equipment, office equipment, measurement equipment, industrial robots) under a normal operation and use condition.
The products are not designed or warranted to meet the requirements of the applications listed below, whose performance and/or quality require a more stringent level of safety or reliability, or whose failure, malfunction or trouble could cause serious damage to society,
person or property.
If you intend to use the products in the applications listed below or if you have special requirements exceeding the range or conditions
set forth in the each catalog, please contact us.
(1) Aerospace/aviation equipment
(2) Transportation equipment (cars, electric trains, ships, etc.)
(3) Medical equipment
(4) Power-generation control equipment
(5) Atomic energy-related equipment
(6) Seabed equipment
(7) Transportation control equipment
(8) Public information-processing equipment
(9) Military equipment
(10) Electric heating apparatus, burning equipment
(11) Disaster prevention/crime prevention equipment
(12) Safety equipment
(13) Other applications that are not considered general-purpose
applications
When designing your equipment even for general-purpose applications, you are kindly requested to take into consideration securing protection circuit/device or providing backup circuits in your equipment.
(4/4)
20220113
ACM2012H-381-2P-T05 价格&库存
很抱歉,暂时无法提供与“ACM2012H-381-2P-T05”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+3.593401+0.46410
- 10+2.9705010+0.38370
- 25+2.6232025+0.33880
- 100+2.28780100+0.29550
- 500+2.15600500+0.27850
- 1000+1.988301000+0.25680
- 2000+1.916502000+0.24750
- 4000+1.808704000+0.23360
- 国内价格 香港价格
- 1+3.961331+0.51138
- 10+3.2279510+0.41670
- 25+2.9866325+0.38555
- 50+2.8146950+0.36336
- 100+2.65334100+0.34253
- 250+2.45487250+0.31691
- 500+2.31462500+0.29880
- 1000+2.182291000+0.28172
