ACM2012H-900-2P-T
ACM2012H-900-2P-T
    TDK(东电化)
    IND_2X1.2MM_SM
    固定电感器 2.00 x 1.20mm IND_2X1.2MM_SM
ACM2012H-900-2P-T 数据手册
E M C C o m p o n e n t s July 2013 Common Mode Filters For ultra high-speed differential signal line (HDMI, DVI, DisplayPort, USB3.0, etc.) ACM-D/-H series ACM2012D ACM2012H [0805 inch]* [0805 inch] * Dimensions Code JIS[EIA] (2/9) E M C C o m p o n e n t s REMINDERS FOR USING THESE PRODUCTS Before using these products, be sure to request the delivery specifications. SAFETY REMINDERS Please pay sufficient attention to the warnings for safe designing when using these products. REMINDERS The storage period is less than 6 months. Be sure to follow the storage conditions (Temperature: 5 to 40°C, Humidity: 10 to 75% RH or less). If the storage period elapses, the soldering of the terminal electrodes may deteriorate. Do not use or store in locations where there are conditions such as gas corrosion (salt, acid, alkali, etc.). Before soldering, be sure to preheat components. The preheating temperature should be set so that the temperature difference between the solder temperature and chip temperature does not exceed 150°C. Soldering corrections after mounting should be within the range of the conditions determined in the specifications. If overheated, a short circuit, performance deterioration, or lifespan shortening may occur. When embedding a printed circuit board where a chip is mounted to a set, be sure that residual stress is not given to the chip due to the overall distortion of the printed circuit board and partial distortion such as at screw tightening portions. Self heating (temperature increase) occurs when the power is turned ON, so the tolerance should be sufficient for the set thermal design. Carefully lay out the coil for the circuit board design of the non-magnetic shield type. A malfunction may occur due to magnetic interference. Use a wrist band to discharge static electricity in your body through the grounding wire. Do not expose the products to magnets or magnetic fields. Do not use for a purpose outside of the contents regulated in the delivery specifications. The products listed on this catalog are intended for use in general electronic equipment (AV equipment, telecommunications equipment, home appliances, amusement equipment, computer equipment, personal equipment, office equipment, measurement equipment, industrial robots) under a normal operation and use condition. The products are not designed or warranted to meet the requirements of the applications listed below, whose performance and/or quality require a more stringent level of safety or reliability, or whose failure, malfunction or trouble could cause serious damage to society, person or property. If you intend to use the products in the applications listed below or if you have special requirements exceeding the range or conditions set forth in the each catalog, please contact us. (1) Aerospace/Aviation equipment (2) Transportation equipment (cars, electric trains, ships, etc.) (3) Medical equipment (4) Power-generation control equipment (5) Atomic energy-related equipment (6) Seabed equipment (7) Transportation control equipment (8) Public information-processing equipment (9) Military equipment (10) Electric heating apparatus, burning equipment (11) Disaster prevention/crime prevention equipment (12) Safety equipment (13) Other applications that are not considered general-purpose applications When designing your equipment even for general-purpose applications, you are kindly requested to take into consideration securing protection circuit/device or providing backup circuits in your equipment. 001-01 / 20130723 / e9712_acm_dh.fm (3/9) E M C C o m p o n e n t s Common Mode Filters Product compatible with RoHS directive Compatible with lead-free solders For ultra high-speed differential signal line (HDMI, DVI, DisplayPort, USB3.0, etc.) Overview of the ACM-D/-H Series FEATURES Broadband common mode filter that was developed for Gbps-level high-speed differential signal interfaces such as DVI and HDMITM. Differential mode cutoff frequency is 3.5GHz for ACM2012D and 6.0GHz for ACM2012H, so they do not negatively influence high-speed differential signals. Characteristics impedance is matched for 100:, which is set for many differential interfaces, and can suppress unnecessary reflection components. APPLICATION EMI measure for HDMITM, which is an interface for digital video devices: ACM2012H is ideal for senders (Sources) such as Digital TVs, DVD recorders, and liquid crystal projectors, while ACM2012D is ideal for receivers (Sink). EMI measure for high-speed differential signal interfaces for digital video signal interfaces such as DVI, Display port, and Serial ATA used for PCs, etc. PART NUMBER CONSTRUCTION ACM 2012 - Series name L×W×H Dimensions (mm) 2.0×1.2×1.2 2012 2.0×1.2×1.3 D - Product internal code D H 900 - Impedance (:)at 100MHz 900 90 2P - Number of lines 2P 2 lines T 00 Packaging style Internal code T TL ø180mm reel ø330mm reel OPERATING TEMPERATURE RANGE, PACKAGE QUANTITY, PRODUCT WEIGHT Type Temperature range Operating Storage temperature temperature (°C) (°C) ACM2012D –40 to +85 –40 to +85 ACM2012H –40 to +85 –40 to +85 Reel diameter Package quantity Individual weight (mm) ø180 ø330 ø180 ø330 (pieces/reel) 2,000 10,000 2,000 10,000 (mg) 10 10 The Storage temperature range is for after the circuit board is mounted. RoHS Directive Compliant Product: See the following for more details related to RoHS Directive compliant products. http://www.tdk.co.jp/rohs/ Halogen-free: Indicates that Cl content is less than 900ppm, Br content is less than 900ppm, and that the total Cl and Br content is less than 1500ppm. • All specifications are subject to change without notice. 001-01 / 20130723 / e9712_acm_dh.fm (4/9) E M C C o m p o n e n t s Overview of the ACM-D/-H Series RECOMMENDED REFLOW PROFILE Preheating Soldering Natural cooling Peak T: Temperature T4 T3 T2 T3 t3 T1 t1 t2 t: Time Preheating Temp. T1 T2 150°C 180°C Time t1 60 to 120s Soldering Temp. Time T3 t2 230°C 10 to 30s Peak Temp. T4 245°C Time t3 5s max. • All specifications are subject to change without notice. 001-01 / 20130723 / e9712_acm_dh.fm (5/9) E M C C o m p o n e n t s ACM-D/-H series ACM2012D Type SHAPE & DIMENSIONS 0.5 0.3 0.05 1.2±0.2 0.3 1.3max. 2.0±0.2 0.4 1.2 Dimensions in mm 0.4 0.4 1 4 2 3 0.4 0.75 1.1 0.75 CIRCUIT DIAGRAM 0.4 RECOMMENDED LAND PATTERN • No polarity Dimensions in mm • All specifications are subject to change without notice. 001-01 / 20130723 / e9712_acm_dh.fm (6/9) E M C C o m p o n e n t s ACM-D/-H series ACM2012D Type ELECTRICAL CHARACTERISTICS CHARACTERISTICS SPECIFICATION TABLE Common mode impedance (: ) [at 100MHz] min. typ. 65 90 DC resistance (: )max. [1 line] 0.30 Insulation Rated current Rated voltage resistance (mA)max. (V)max. (M: )min. Cutoff frequency (GHz)typ. Characteristic impedance (: )typ. Part No. 300 3.5 100 ACM2012D-900-2P-T00 20 ○ Measurement equipment Measurement item Product No. Common mode impedance 4991A DC resistance 4338A Insulation resistance 4339A * Equivalent measurement equipment may be used. 10 Manufacturer Agilent Technologies Agilent Technologies Agilent Technologies IMPEDANCE VS. FREQUENCY CHARACTERISTICS 10000 Impedance (Ω) 1000 100 900 Common mode 900 Differential mode 10 1 1 10 100 Frequency (MHz) 1000 10000 ○ Measurement equipment Product No. Manufacturer 4991A Agilent Technologies * Equivalent measurement equipment may be used. • All specifications are subject to change without notice. 001-01 / 20130723 / e9712_acm_dh.fm (7/9) E M C C o m p o n e n t s ACM-D/-H series ACM2012H Type SHAPE & DIMENSIONS 0.35 0.5 1.2±0.2 0.35 0.4 1.2±0.1 2.0±0.2 0.4 1.2 Dimensions in mm 0.4 0.4 0.4 0.4 RECOMMENDED LAND PATTERN 0.75 1.1 0.75 CIRCUIT DIAGRAM 1 4 2 3 • No polarity Dimensions in mm • All specifications are subject to change without notice. 001-01 / 20130723 / e9712_acm_dh.fm (8/9) E M C C o m p o n e n t s ACM-D/-H series ACM2012H Type ELECTRICAL CHARACTERISTICS CHARACTERISTICS SPECIFICATION TABLE Common mode impedance (: ) [at 100MHz] min. typ. 65 90 DC resistance (: )max. [1 line] Insulation Rated current Rated voltage resistance (mA)max. (V)max. (M: )min. Cutoff frequency (GHz)typ. Characteristic impedance (: )typ. Part No. 0.30 300 6 100 ACM2012H-900-2P-T00 20 ○ Measurement equipment Measurement item Product No. Common mode impedance 4991A DC resistance 4338A Insulation resistance 4339A * Equivalent measurement equipment may be used. 10 Manufacturer Agilent Technologies Agilent Technologies Agilent Technologies IMPEDANCE VS. FREQUENCY CHARACTERISTICS 10000 Impedance (Ω) 1000 100 900 Common mode 900 Differential mode 10 1 1 10 100 Frequency (MHz) 1000 10000 ○ Measurement equipment Product No. Manufacturer 4991A Agilent Technologies * Equivalent measurement equipment may be used. • All specifications are subject to change without notice. 001-01 / 20130723 / e9712_acm_dh.fm (9/9) E M C C o m p o n e n t s ACM-D/-H series Packaging style REEL DIMENSIONS 2.0±0.5 E Type ACM2012D W1 9.5±0.5 9+1/–0 9.5±0.5 9+1/–0 W2 13.5±1 13±1 13.5±1 13±1 N 100±1 60+1/–0 100±1 60+1–0 E 2 typ. 2 typ. 2 typ. 2 typ. N ACM2012H A ø330±2 ø180±3 ø330±2 ø180±3 1.0 ø13.0±0.2 W1 ø21.0±0.8 W2 A Dimensions in mm TAPE DIMENSIONS P2 P0 W B F E øD0 K P1 A Dimensions in mm Type ACM2012D ACM2012H A 1.4±0.1 1.4±0.1 B 2.25±0.1 2.25±0.1 øD0 1.5+0.1/0 1.5+0.1/0 E 1.75±0.1 1.75±0.1 F 3.5±0.1 3.5±0.1 P0 4.0±0.1 4.0±0.1 P1 4.0±0.1 4.0±0.1 P2 2.0±0.1 2.0±0.1 W 8.0±0.2 8.0±0.2 K 1.4±0.1 1.4±0.1 t 0.25±0.05 0.25±0.05 500 to 560min. 160min. Taping 440min. Drawing direction Dimensions in mm • All specifications are subject to change without notice. 001-01 / 20130723 / e9712_acm_dh.fm
ACM2012H-900-2P-T 价格&库存
很抱歉,暂时无法提供与“ACM2012H-900-2P-T”相匹配的价格&库存,您可以联系我们找货
