E M C
C o m p o n e n t s
Common mode filters
Automobile ultra high-speed differential signal line (for infotainment)
ACM-H series
Pb
RoHS
REACH
SVHC-Free
Lead
Free
AEC-Q200
ACM2012H-T03 type
FEATURES
Highly reliable with a temperature range of –40 to +105°C.
Common mode EMI measure: Possible to suppress waveform common mode EMI without straining the waveform.
Operating temperature range: –40 to +105°C
Compliant with AEC-Q200
APPLICATION
Radiated noise suppression for car multimedia interfaces (MOST, HDMI, IDB-1394, etc.).
Portable PC and PC interfaces (USB, IEEE1394)
DVC, CD/DVD-ROM, etc.
Application guides: Car Infotainment
PART NUMBER CONSTRUCTION
ACM
2012
H
Series
name
L×W×H dimensions
2.0×1.2×1.2 mm
Product
internal code
900
Impedance
()at 100MHz
2P
Number of lines
T
03
Packaging style
Internal code
CHARACTERISTICS SPECIFICATION TABLE
Common mode
impedance
DC resistance
[at 100MHz]
( )min. ( )typ.
65
90
[1 line]
( )max.
0.30
Rated current Rated voltage Insulation
resistance
Cutoff
frequency
Characteristic
impedance
(mA)max.
300
(GHz)typ.
5
( )typ.
100
(V)max.
50
(M )min.
10
Part No.
ACM2012H-900-2P-T03
Measurement equipment
Measurement item
Product No.
Common mode impedance
4991A
DC resistance
4338A
Insulation resistance
4339A
* Equivalent measurement equipment may be used.
Manufacturer
Keysight Technologies
Please be sure to request delivery specifications that provide further details on the features and specifications of the products for proper and safe use.
Please note that the contents may change without any prior notice due to reasons such as upgrading.
(1/4)
20210506
cmf_automotive_signal_acm2012h-t03_en.fm
E M C
C o m p o n e n t s
ACM2012H-T03 type
IMPEDANCE VS. FREQUENCY CHARACTERISTICS
10000
Impedance (Ω)
1000
100
900 Common mode
900 Differential mode
10
1
1
10
100
Frequency (MHz)
1000
10000
Product No.
Manufacturer
4991A
(2/4)
20210506
E M C
C o m p o n e n t s
ACM2012H-T03 type
SHAPE & DIMENSIONS
PACKAGING STYLE
REEL DIMENSIONS
2.0±0.2
4
2
3
2.0±0.5
(0.4)
1.2±0.1
60 +1
–0
1.2±0.2
1
(1.2)
(0.4)
(0.35) (0.5) (0.35)
Dimensions in mm
ø13.0±0.2
9+1/–0
(ø21)
13±1.4
ø180 +0
–3
RECOMMENDED LAND PATTERN
0.4
Dimensions in mm
ø1.5 +0.1
–0
2±0.1
4±0.1
0.75
1.1
8±0.2
0.75
Sprocket
hole
0.25±0.05
1.75±0.1
0.4
0.4
TAPE DIMENSIONS
B
Dimensions in mm
K
CIRCUIT DIAGRAM
3.5±0.1
(0.4)
ø1 +0.2
–0
4±0.1
A
Cavity
Dimensions in mm
1
4
2
3
Type
ACM2012H-T03
• No polarity
Soldering
B
(2.25)
K
(1.4)
500 to 560min.
RECOMMENDED REFLOW PROFILE
Preheating
A
(1.4)
160min.
Taping
440min.
Natural
cooling
Peak
Drawing direction
245°C
Dimensions in mm
Temperature
230°C
230°C
PACKAGE QUANTITY
Package quantity
180°C
2,000 pcs/reel
5s max.
150°C
TEMPERATURE RANGE, INDIVIDUAL WEIGHT
60 to 120s
10 to 30s
Time
Operating
Storage
temperature range
temperature range
–40 to +105 °C
–40 to +105 °C
The storage temperature range is for after the assembly.
Individual
weight
10 mg
(3/4)
20210506
E M C
C o m p o n e n t s
REMINDERS FOR USING THESE PRODUCTS
Before using these products, be sure to request the delivery specifications.
SAFETY REMINDERS
Please pay sufficient attention to the warnings for safe designing when using this products.
REMINDERS
The storage period is less than 6 months. Be sure to follow the storage conditions (temperature: 5 to 40°C, humidity: 10 to 75% RH or
less).
If the storage period elapses, the soldering of the terminal electrodes may deteriorate.
Do not use or store in locations where there are conditions such as gas corrosion (salt, acid, alkali, etc.).
Before soldering, be sure to preheat components.
The preheating temperature should be set so that the temperature difference between the solder temperature and chip temperature
does not exceed 150°C.
Soldering corrections after mounting should be within the range of the conditions determined in the specifications.
If overheated, a short circuit, performance deterioration, or lifespan shortening may occur.
When embedding a printed circuit board where a chip is mounted to a set, be sure that residual stress is not given to the chip due to
the overall distortion of the printed circuit board and partial distortion such as at screw tightening portions.
Self heating (temperature increase) occurs when the power is turned ON, so the tolerance should be sufficient for the set thermal
design.
Carefully lay out the coil for the circuit board design of the non-magnetic shield type.
A malfunction may occur due to magnetic interference.
Use a wrist band to discharge static electricity in your body through the grounding wire.
Do not expose the products to magnets or magnetic fields.
Do not use for a purpose outside of the contents regulated in the delivery specifications.
The products listed on this catalog are intended for use in general electronic equipment (AV equipment, telecommunications equipment, home appliances, amusement equipment, computer equipment, personal equipment, office equipment, measurement equipment, industrial robots) under a normal operation and use condition.
The products are not designed or warranted to meet the requirements of the applications listed below, whose performance and/or quality require a more stringent level of safety or reliability, or whose failure, malfunction or trouble could cause serious damage to society,
person or property.
If you intend to use the products in the applications listed below or if you have special requirements exceeding the range or conditions
set forth in the each catalog, please contact us.
(1) Aerospace/aviation equipment
(2) Transportation equipment (cars, electric trains, ships, etc.)
(3) Medical equipment
(4) Power-generation control equipment
(5) Atomic energy-related equipment
(6) Seabed equipment
(7) Transportation control equipment
(8) Public information-processing equipment
(9) Military equipment
(10) Electric heating apparatus, burning equipment
(11) Disaster prevention/crime prevention equipment
(12) Safety equipment
(13) Other applications that are not considered general-purpose
applications
When designing your equipment even for general-purpose applications, you are kindly requested to take into consideration securing protection circuit/device or providing backup circuits in your equipment.
(4/4)
20210506
ACM2012H-900-2P-T03 价格&库存
很抱歉,暂时无法提供与“ACM2012H-900-2P-T03”相匹配的价格&库存,您可以联系我们找货
