ACM2012H-900-2P-TL
ACM2012H-900-2P-TL
    TDK(东电化)
    ACM2012H-900-2P-TL - Common Mode Filters(SMD) For DVI / HDMI - TDK Electronics
ACM2012H-900-2P-TL 数据手册
(1/2) Common Mode Filters(SMD) For DVI / HDMI ACM-D/H Series ACM2012D/H Types FEATURES • These are a series of broadband common mode filters developed for high-speed differential signal interfaces, such as DVI and HDMI™. • The cutoff frequencies in differential mode for ACM2012D and ACM2012H are 3.5GHz and 6.0GHz respectively, so they do not interfere with high-speed differential signals. • The characteristic impedance is approximated to 100Ω conform, ing to the TDR standard for HDMI™. APPLICATIONS • For new HDMI™ interfaces used in digital video devices: ACM2012H is suited for use on the transmission side (Source) of digital TVs, DVD recorders and liquid crystal projectors. ACM2012D is suited for use on the receiving side (Sink). • For digital video signal interfaces DVI (UXGA) used in PCs and other devices/High-speed differential signal interfaces for USB 2.0, IEEE1394 and Serial-ATA. SHAPES AND DIMENSIONS 2.0±0.2 1 1.2±0.2 4 Conformity to RoHS Directive PRODUCT IDENTIFICATION ACM (1) 2012 (2) D - 900 - 2P - T (3) (4) (5) (6) (7) (1) Series name (2) Dimensions L× W 2012: 2.0× 1.2mm (3) Product identification number (D or H) (4) Impedance[at 100MHz] 900: 90Ω (5) Number of line 2P: 2-line (6) Packaging style T: ø180mm reel taping TL: ø330mm reel taping B: Bulk (7) TDK internal code TEMPERATURE RANGE Operating –25 to +85°C PACKAGING STYLE AND QUANTITIES Packaging style Taping Reel ø180mm ø330mm Quantity 2000 pieces/reel 10000 pieces/reel 2 1.2±0.1 3 CIRCUIT DIAGRAM 0.8 1 2 4 3 • No polarity 0.4 0.35 0.5 0.35 1.2 0.4 Dimensions in mm RECOMMENDED PC BOARD PATTERN 0.75 0.35 0.5 0.35 1.2 0.75 Dimensions in mm • HDMI™ is trademark of HDMI Licensing, LLC. • Conformity to RoHS Directive: This means that, in conformity with EU Directive 2002/95/EC, lead, cadmium, mercury, hexavalent chromium, and specific bromine-based flame retardants, PBB and PBDE, have not been used, except for exempted applications. • All specifications are subject to change without notice. 003-02 / 20070215 / e9712_acm_dh.fm (2/2) ELECTRICAL CHARACTERISTICS Part No. ACM2012D-900-2P ACM2012H-900-2P Impedance (Ω) [at 100MHz] 65min.(90typ.) 65min.(90typ.) DC resistance (Ω) [1 line] 0.30max. 0.30max. Rated current Idc (mA) 300max. 300max. Rated voltage Edc (V) 20max. 20max. Insulation resistance (MΩ) 10min. 10min. Cut-off frequency (GHz) 3.5typ. 6typ. Characteristic impedance (Ω) 100typ. 100typ. TYPICAL ELECTRICAL CHARACTERISTICS IMPEDANCE vs. FREQUENCY CHARACTERISTICS(REFERENCE) ACM2012D-900-2P ACM2012H-900-2P 10000 10000 1000 Impedance (Ω) 1000 Impedance (Ω) 100 Common mode 100 Common mode 10 Differential mode 10 Differential mode 1 1 10 100 Frequency (MHz) 1000 10000 1 1 10 100 Frequency (MHz) 1000 10000 INSERTION LOSS vs. FREQUENCY CHARACTERISTICS (REFERENCE) 0 1 2 Insertion loss(dB) CHARACTERISTIC IMPEDANCE MEASURED ACCORDING TO TDR(REFERENCE) 140 120 100 Impedance (Ω) 85Ω 80 60 40 20 ACM2012D-900 ACM2012H-900 0 0.5 1.0 1.5 2.0 2.5 100ps/div Common mode filter 115Ω 3 4 5 6 7 8 9 10 1 10 100 Frequency (MHz) ACM2012D-900 ACM2012H-900 1000 10000 0 • All specifications are subject to change without notice. 003-02 / 20070215 / e9712_acm_dh.fm
ACM2012H-900-2P-TL
1. 物料型号: - ACM2012D-900-2P 和 ACM2012H-900-2P,其中“ACM”是系列名称,“2012”表示尺寸(2.0 × 1.2 mm),“900”表示100MHz时的阻抗为90Ω,“2P”表示2线。
2. 器件简介: - 这些是为高速差分信号接口(如DVI和HDMI)开发的宽带共模滤波器系列。
3. 引脚分配: - 2P表示2线配置。
4. 参数特性: - ACM2012D和ACM2012H的差分模式截止频率分别为3.5GHz和6.0GHz,不会干扰高速差分信号。 - 特性阻抗接近100Ω,符合HDMI的TDR标准。
5. 功能详解: - ACM2012H适用于数字电视、DVD录像机和液晶投影仪等数字视频设备的HDMI接口的传输侧(源)。 - ACM2012D适用于接收侧(汇)。
6. 应用信息: - 用于DVI(UXGA)数字视频信号接口和高速差分信号接口,如USB 2.0、IEEE1394和Serial-ATA。
7. 封装信息: - 封装风格包括Taping(180mm卷轴)和330mm卷轴,分别包含2000和10000件。
ACM2012H-900-2P-TL 价格&库存
很抱歉,暂时无法提供与“ACM2012H-900-2P-TL”相匹配的价格&库存,您可以联系我们找货
ACM2012H-900-2P-T03
    • 5+2.86413
    • 50+2.42676
    • 400+2.07865
    • 800+2.0349
    • 2000+2.01455
    库存:1785
    ACM2012H-900-2P-T00
    • 10+1.70001
    • 100+1.55001
    • 500+1.40001
    • 1000+1.25001
    • 2000+1.15001
    • 4000+1.12001
    ACM2012H-900-2P-T05
    • 5+1.10564
    • 50+0.93296
    • 400+0.73755
    • 800+0.72649
    • 2000+0.67894
    库存:1471
