Common Mode Filters
For high-speed differential signal line/general signal line
ACM series
Type:
ACM2012
ACM2520
ACM3225
ACM4532
[0805 inch]*
[1008 inch]
[1210 inch]
[1812 inch]
* Dimensions Code [EIA]
Issue date:
September 2011
• All specifications are subject to change without notice.
• Conformity to RoHS Directive: This means that, in conformity with EU Directive 2002/95/EC, lead, cadmium, mercury, hexavalent chromium, and specific
bromine-based flame retardants, PBB and PBDE, have not been used, except for exempted applications.
(1/5)
Common Mode Filters
For High-speed Differential Signal Line / General Signal Line
ACM Series ACM2012, 2520, 3225, 4532
FEATURES
• Although greatly miniaturized, this wire-wound chip-type filter
maintains the characteristics needed for a common mode filter.
Common mode impedance is 1000Ω [at 100MHz], so this filter is
greatly effective in supporting noise.
• Almost no affect upon even high speed signals since differential
mode impedance is kept low.
• This series includes both 2-line and 3-line types. They are used
for various types of circuits and noise.
APPLICATIONS
• Used for radiation noise suppression for any electronic devices.
• Used to counter common mode noise affecting signals within
high-speed lines.
• USB line for personal computers and peripheral equipment.
• IEEE1394 line for personal computers, DVC, STB, etc.
• LVDS, panel link line for liquid crystal display panels.
ACM
(1)
–25 to +85°C
–25 to +85°C
Type
ACM2012
ACM2520
Taping
ACM3225
ACM4532
Reel
ø180mm
ø330mm
ø180mm
ø330mm
ø180mm
ø330mm
ø180mm
ø330mm
(6)
(1) Series name
(2) Dimensions L×W
2012: 2.0×1.2mm
(3) Impedance[at 100MHz]
900: 90Ω
(4) Number of line
2P: 2-line
3P: 3-line
(5) Packaging style
T: ø180mm reel taping
TL: ø330mm reel taping
(6) TDK internal code
Peak 245˚C max.
PACKAGING STYLE AND QUANTITIES
Packaging style
2012 - 900 - 2P - T
(2)
(3)
(4)
(5)
RECOMMENDED SOLDERING CONDITIONS
RECOMMENDED TEMPERATURE PROFILE
FOR LEAD-FREE SOLDER
TEMPERATURE RANGES
Operating
Storage(After mount)
PRODUCT IDENTIFICATION
Quantity
2000 pieces/reel
10000 pieces/reel
2000 pieces/reel
10000 pieces/reel
1000 pieces/reel
5000 pieces/reel
500 pieces/reel
2000 pieces/reel
Natural
cooling
230˚C
180˚C
150˚C
60 to 120s
10 to 30s
Time (s)
REFLOW PROFILE FOR SOLDER HEAT RESISTANCE
Peak 260˚C max.
Natural
cooling
230˚C
180˚C
150˚C
60 to 120s
40s max.
Time (s)
001-03 / 20110928 / e9712_acm.fm
(2/5)
SHAPES AND DIMENSIONS/CIRCUIT DIAGRAMS/RECOMMENDED PC BOARD PATTERNS
2-LINE TYPE
ACM2012-2P
1.2±0.2
2.0±0.2
3
0.8
4
2
Termination
0.4
0.5
0.75 1.1 0.75
0.3
Dimensions in mm
0.4
ACM3225-2P
1
4
3
2
0.7
0.40
0.35
1.5
1.5
Dimensions in mm
ACM4532-102-3P
6
5
4
1
2
3
6
5
4
1
6
2
5
3
4
4.5±0.2
1
0.7
0.8
1.6
0.45
1
4.3
0.35
0.3
4
5
6
Electrode
Ferrite
1.3=P0.65×2
Wires
Insulation
resin
2.3max.
0.85
1.2±0.1
Terminal
electrode
6
5
4
1
2
3
1.2
2.0±0.2
1.6
Dimensions in mm
Ferrite
0.45
0.7
1.5
2.5±0.2
1.3=P0.65×2
3
0.8
3-LINE TYPE
ACM2520-3P
3
2
1
Insulation
resin
0.7
1.30
1.3
Ferrite
0.8
4
3
1
2
2.3max.
0.85
1.2±0.1
Terminal
electrode
0.45
1
2
3
3
3.2±0.2
1.6
0.45
4
1.1
2.0±0.2
1
2
1.4
2.5±0.2
1.4
ACM2520-2P
0.8
1.2
0.4
1.2
0.05
0.3
0.4
Termination
0.5 0.75 0.5
3.2±0.2
Wires
1
0.7
0.7
2.5 ±0.2
3
Ferrite
0.4
4
2
1.3max.
1
1.5
0.8
Dimensions in mm
1.8
2.3
1.8
Dimensions in mm
(3/5)
ELECTRICAL CHARACTERISTICS
Part No.
2-LINE
ACM2012-900-2P
ACM2012-121-2P
ACM2012-201-2P
ACM2012-361-2P
ACM2520-301-2P
ACM2520-451-2P
ACM2520-601-2P
ACM2520-102-2P
ACM3225-800-2P
ACM3225-161-2P
ACM3225-271-2P
ACM3225-102-2P
3-LINE
ACM2520-801-3P
ACM4532-102-3P
Impedance
(Ω )typ.[100MHz]
DC resistance
(Ω )max.[per 1 line]
Rated voltage
Edc(V)max.
Rated current
Idc(A)max.
90
120
200
360
300
450
600
1000
80
160
270
1000
0.19
0.22
0.25
0.5
0.35
0.4
0.45
0.9
0.15
0.2
0.3
0.5
50
50
50
50
0.37
0.35
0.22
0.4
0.35
0.3
0.2
0.4
0.35
0.3
0.2
800
1000
1.6
0.6
0.2
(4/5)
TYPICAL ELECTRICAL CHARACTERISTICS
IMPEDANCE vs. FREQUENCY CHARACTERISTICS
2-LINE
ACM2012-900-2P
ACM2012-121-2P
ACM2012-201-2P
ACM2012-361-2P
1000
1000
1000
1000
ACM2520-301-2P
Impedance(Ω)
1
1
1000
Common mode
ACM2520-451-2P
100
10
1000
Differential
mode
10
100
1000
Frequency(MHz)
ACM3225-800-2P
10
1
1
10
Differential
mode
ACM3225-161-2P
Common mode
100
1
1
10000
1000
1000
1000
Common mode
1000
100
10
1
1
Differential
mode
10
100
1000
Frequency(MHz)
10
1
1
Differential
mode
10
100
1000
Frequency(MHz)
Common mode
100
10
1
1
Differential
mode
10
100
1000
Frequency(MHz)
Impedance(Ω)
100 Common mode
Impedance(Ω)
10
Impedance(Ω)
Impedance(Ω)
Common mode
10
100
1000
Frequency(MHz)
ACM3225-102-2P
1000
100
Differential
mode
1
1
10
100
1000
Frequency(MHz)
ACM3225-271-2P
10000
Differential
mode
10
100
1000
Frequency(MHz)
1
1
Differential
mode
10
10000
10
10000
1000
10
100
1000
Frequency(MHz)
100
ACM2520-102-2P
10000
Common mode
Common mode
Differential
mode
10
100
1000
Frequency(MHz)
ACM2520-601-2P
100
1
1
100
Differential
mode
10
100
1000
Frequency(MHz)
10000
10000
1
1
10
Differential
mode
10
100
1000
Frequency(MHz)
Common mode
Impedance(Ω)
1
1
100
Common-mode
Impedance(Ω)
10
Impedance(Ω)
100
Common mode
Impedance(Ω)
10000
Impedance(Ω)
10000
Impedance(Ω)
10000
Impedance(Ω)
10000
Common mode
100
10
Differential mode
1
1
10
100
1000
Frequency(MHz)
MEASURING CIRCUITS
2-LINE
Common mode
HP4291A
Differential mode
HP4291A
(5/5)
3-LINE
ACM2520-801-3P
ACM4532-102-3P
10000
Impedance(Ω)
Impedance(Ω)
1000 Common mode
1000 Common mode
100
10
1
1
Differential
mode
10
100
1000
Frequency(MHz)
100
10
Differential mode
1
1
10
100
1000
Frequency(MHz)
MEASURING CIRCUITS
3-LINE
Common mode
HP4291A
Differential mode
HP4291A
很抱歉,暂时无法提供与“ACM3225-271-2P-T”相匹配的价格&库存,您可以联系我们找货
