ACM4520-901-2P-T000. 数据手册
E M C
C o m p o n e n t s
December 2015
Common Mode Filters
For power line
ACM Series
ACM4520 Type
ACM4520
[1808 inch]*
* Dimensions Code JIS[EIA]
(2/7)
E M C
C o m p o n e n t s
REMINDERS FOR USING THESE PRODUCTS
Before using these products, be sure to request the delivery specifications.
SAFETY REMINDERS
Please pay sufficient attention to the warnings for safe designing when using these products.
REMINDERS
The storage period is less than 12 months. Be sure to follow the storage conditions (Temperature: 5 to 40°C, Humidity: 10 to 75% RH
or less).
If the storage period elapses, the soldering of the terminal electrodes may deteriorate.
Do not use or store in locations where there are conditions such as gas corrosion (salt, acid, alkali, etc.).
Before soldering, be sure to preheat components.
The preheating temperature should be set so that the temperature difference between the solder temperature and chip temperature
does not exceed 150°C.
Soldering corrections after mounting should be within the range of the conditions determined in the specifications.
If overheated, a short circuit, performance deterioration, or lifespan shortening may occur.
When embedding a printed circuit board where a chip is mounted to a set, be sure that residual stress is not given to the chip due to
the overall distortion of the printed circuit board and partial distortion such as at screw tightening portions.
Self heating (temperature increase) occurs when the power is turned ON, so the tolerance should be sufficient for the set thermal
design.
Carefully lay out the coil for the circuit board design of the non-magnetic shield type.
A malfunction may occur due to magnetic interference.
Use a wrist band to discharge static electricity in your body through the grounding wire.
Do not expose the products to magnets or magnetic fields.
Do not use for a purpose outside of the contents regulated in the delivery specifications.
The products listed on this catalog are intended for use in general electronic equipment (AV equipment, telecommunications
equipment, home appliances, amusement equipment, computer equipment, personal equipment, office equipment, measurement
equipment, industrial robots) under a normal operation and use condition.
The products are not designed or warranted to meet the requirements of the applications listed below, whose performance and/or
quality require a more stringent level of safety or reliability, or whose failure, malfunction or trouble could cause serious damage to
society, person or property.
If you intend to use the products in the applications listed below or if you have special requirements exceeding the range or conditions
set forth in the each catalog, please contact us.
(1) Aerospace/Aviation equipment
(2) Transportation equipment (cars, electric trains, ships, etc.)
(3) Medical equipment
(4) Power-generation control equipment
(5) Atomic energy-related equipment
(6) Seabed equipment
(7) Transportation control equipment
(8) Public information-processing equipment
(9) Military equipment
(10) Electric heating apparatus, burning equipment
(11) Disaster prevention/crime prevention equipment
(12) Safety equipment
(13) Other applications that are not considered general-purpose
applications
When designing your equipment even for general-purpose applications, you are kindly requested to take into consideration securing
protection circuit/device or providing backup circuits in your equipment.
20151227 / cmf_commercial_power_acm4520_en.fm
(3/7)
E M C
C o m p o n e n t s
Common Mode Filters
Product compatible with RoHS directive
Halogen-free
Compatible with lead-free solders
For power line
Overview of ACM4520 Type
FEATURES
Chip common mode filter for large current applications.
For each series, there is excellent common mode impedance and noise suppression in a compact case.
Low profile and small size makes it optimal for surface mounting.
APPLICATION
Power line noise countermeasure for electronic equipment (DVCs, DVD cams, DSCs, etc.).
PART NUMBER CONSTRUCTION
ACM
Series name
4520
L×W×H Dimensions
(mm)
4520
4.7×4.5×2.0
231
Impedance
(:) at 100MHz
231
230
2P
Number of lines
2P
2 lines
T
T
000
Packaging style
Internal code
ø180mm reel
000
OPERATING TEMPERATURE RANGE, PACKAGE QUANTITY, PRODUCT WEIGHT
Temperature range
Operating
Storage
temperature
temperature
(°C)
(°C)
ACM4520
–40 to +85
–40 to +85
The Storage temperature range is for after the circuit board is mounted.
Reel diameter
Package quantity
Individual weight
(mm)
ø180
(pieces/reel)
800
(g)
0.144
Type
RoHS Directive Compliant Product: See the following for more details related to RoHS Directive compliant products. http://product.tdk.com/en/environment/rohs/
Halogen-free: Indicates that Cl content is less than 900ppm, Br content is less than 900ppm, and that the total Cl and Br content is less than 1500ppm.
Please be sure to request delivery specifications that provide further details on the features and specifications of the products for proper and safe use.
Please note that the contents may change without any prior notice due to reasons such as upgrading.
(4/7)
E M C
C o m p o n e n t s
ACM4520 Type
RECOMMENDED REFLOW PROFILE
Preheating
Soldering
Natural
cooling
Peak
T: Temperature
T4
T3
T2
T3
t3
T1
t1
t2
t: Time
Preheating
Temp.
T1
T2
150°C
180°C
Time
t1
60 to 120s
Soldering
Temp.
Time
T3
t2
230°C
10 to 30s
Peak
Temp.
T4
245°C
Time
t3
5s
(5/7)
E M C
C o m p o n e n t s
ACM4520 Type
SHAPE & DIMENSIONS
4.7±0.2
4.5
4
2
3
4.5±0.2
1
0.65
0.65
2.0max.
Ferrite
Wire
0.75
0.75
2.0
Dimensions in mm
RECOMMENDED LAND PATTERN
3.5
1.25
2.0
0.95 1.05 0.95
1.25
CIRCUIT DIAGRAM
1
4
2
3
• No polarity
Dimensions in mm
(6/7)
E M C
C o m p o n e n t s
ACM4520 Type
ELECTRICAL CHARACTERISTICS
CHARACTERISTICS SPECIFICATION TABLE
Common mode
impedance
DC resistance
Rated current
[at 100MHz]
(: )min.
(: )typ.
180
230
300
420
650
900
1000
1400
[1 line]
(: )max.
0.05
0.055
0.06
0.08
(A)max.60°C
3.0
2.8
2.3
1.7
○ Measurement equipment
Measurement item
Product No.
Common mode impedance
4991A
DC resistance
4338A
Insulation resistance
4339A
* Equivalent measurement equipment may be used.
(A)max.85°C
2.6
2.4
2.0
1.5
Rated voltage
Insulation
resistance
(V)max.
50
50
50
50
(M: )min.
10
10
10
10
Part No.
ACM4520-231-2P-T000
ACM4520-421-2P-T000
ACM4520-901-2P-T000
ACM4520-142-2P-T000
Manufacturer
Keysight Technologies
IMPEDANCE VS. FREQUENCY CHARACTERISTICS
10000
142 Common mode
1000
Impedance (Ω)
901 Common mode
421 Common mode
421 Differential mode
100
231 Differential mode
901 Differential mode
231 Common mode
10
1
142 Differential mode
1
10
100
1000
Frequency (MHz)
Product No.
Manufacturer
4991A
(7/7)
E M C
C o m p o n e n t s
ACM4520 Type
PACKAGING STYLE
REEL DIMENSIONS
2.0±0.5
E
A
ø180±3
W1
13±0.3
W2
17±1.4
N
60+1/–0
E
2 typ.
N
Type
ACM4520
1.0
ø13.0±0.2
W1
ø21.0±0.8
W2
A
Dimensions in mm
TAPE DIMENSIONS
t
P0
B
W
F
P2
E
øD0
A
K
P1
Dimensions in mm
Type
ACM4520
A
4.75±0.1
B
5.05±0.1
øD0
1.55+0.1/0
E
1.75±0.1
F
5.5±0.05
P0
4.0±0.1
P1
8.0±0.1
P2
2.0±0.05
W
12.0±0.2
K
2.05±0.05
t
0.3±0.1
500 to 560min.
160min.
Drawing direction
Taping
440min.
Dimensions in mm
ACM4520-901-2P-T000. 价格&库存
很抱歉,暂时无法提供与“ACM4520-901-2P-T000.”相匹配的价格&库存,您可以联系我们找货
