ACM4520-901-2P-TL000
    TDK(东电化)
    FILTER_4.5X4.5MM_SM
    CMC 900 OHM 2A 2 LN SMD
ACM4520-901-2P-TL000 数据手册
E M C C o m p o n e n t s Common mode filters For power line ACM series RoHS REACH SVHC-Free Cl Br Pb Halogen Free Lead Free ACM4520 type FEATURES Chip common mode filter for large current applications.  For each series, there is excellent common mode impedance and noise suppression in a compact case. Low profile and small size makes it optimal for surface mounting. Operating temperature range: –40 to +85°C APPLICATION Power line noise countermeasure for electronic equipment (DVCs, DVD cams, DSCs, etc.). PART NUMBER CONSTRUCTION ACM 4520 Series name L×W×H dimensions 4.7×4.5×2.0 mm - 231 - Impedance () at 100MHz 2P - Number of lines T 000 Packaging style Internal code CHARACTERISTICS SPECIFICATION TABLE Common mode impedance [at 100MHz] ( )min. 180 300 650 1000 ( )typ. 230 420 900 1400 DC resistance Rated current [1 line] ( )max. 0.05 0.055 0.06 0.08 (A)max.60°C 3.0 2.8 2.3 1.7 (A)max.85°C 2.6 2.4 2.0 1.5 Rated voltage Insulation resistance (V)max. 50 50 50 50 (M )min. 10 10 10 10 Part No. ACM4520-231-2P-T000 ACM4520-421-2P-T000 ACM4520-901-2P-T000 ACM4520-142-2P-T000 Measurement equipment Measurement item Product No. Common mode impedance 4991A DC resistance 4338A Insulation resistance 4339A * Equivalent measurement equipment may be used. Manufacturer Keysight Technologies Keysight Technologies Keysight Technologies Please be sure to request delivery specifications that provide further details on the features and specifications of the products for proper and safe use. Please note that the contents may change without any prior notice due to reasons such as upgrading. (1/4) 20191021 cmf_commercial_power_acm4520_en.fm E M C C o m p o n e n t s ACM4520 type IMPEDANCE VS. FREQUENCY CHARACTERISTICS 10000 142 Common mode 1000 Impedance (Ω) 901 Common mode 421 Common mode 421 Differential mode 100 231 Differential mode 901 Differential mode 1 142 Differential mode 231 Common mode 10 1 10 100 1000 Frequency (MHz) Measurement equipment Product No. Manufacturer 4991A Keysight Technologies * Equivalent measurement equipment may be used. Please be sure to request delivery specifications that provide further details on the features and specifications of the products for proper and safe use. Please note that the contents may change without any prior notice due to reasons such as upgrading. (2/4) 20191021 cmf_commercial_power_acm4520_en.fm E M C C o m p o n e n t s ACM4520 type SHAPE & DIMENSIONS PACKAGING STYLE REEL DIMENSIONS 4.7±0.2 4.5 2.0±0.5 4 2 3 0.65 60 +1 –0 4.5±0.2 1 2 typ. 0.65 2.0max. Ferrite Wire 1.0 0.75 0.75 2.0 ø13.0±0.2 13±0.3 ø21.0±0.8 Dimensions in mm 17±1.4 ø180±3 Dimensions in mm RECOMMENDED LAND PATTERN 1.55 +0.1 –0 2.0±0.05 4.0±0.1 Sprocket hole B 12.0±0.2 2.0 0.3±0.1 Dimensions in mm K Cavity A 8.0±0.1 CIRCUIT DIAGRAM 1 4 2 3 5.5±0.05 TAPE DIMENSIONS 1.25 1.75±0.1 3.5 0.95 1.05 0.95 1.25 Dimensions in mm Type ACM4520 A 4.75±0.1 B 5.05±0.1 K 2.05±0.05 • No polarity 500 to 560min. 160min. Taping 440min. RECOMMENDED REFLOW PROFILE Preheating Soldering Natural cooling Drawing direction Peak Dimensions in mm 245°C Temperature 230°C 230°C PACKAGE QUANTITY Package quantity 800 pcs/reel 180°C 5s 150°C 60 to 120s 10 to 30s TEMPERATURE RANGE, INDIVIDUAL WEIGHT Operating Storage temperature range temperature range –40 to +85 °C –40 to +85 °C  The storage temperature range is for after the assembly. Individual weight 0.144 g Time Please be sure to request delivery specifications that provide further details on the features and specifications of the products for proper and safe use. Please note that the contents may change without any prior notice due to reasons such as upgrading. (3/4) 20191021 cmf_commercial_power_acm4520_en.fm E M C C o m p o n e n t s REMINDERS FOR USING THESE PRODUCTS Before using these products, be sure to request the delivery specifications. SAFETY REMINDERS Please pay sufficient attention to the warnings for safe designing when using this products. REMINDERS The storage period is within 12 months. Be sure to follow the storage conditions (temperature: 5 to 40°C, humidity: 10 to 75% RH or less). If the storage period elapses, the soldering of the terminal electrodes may deteriorate. Do not use or store in locations where there are conditions such as gas corrosion (salt, acid, alkali, etc.). Before soldering, be sure to preheat components. The preheating temperature should be set so that the temperature difference between the solder temperature and chip temperature does not exceed 150°C. Soldering corrections after mounting should be within the range of the conditions determined in the specifications. If overheated, a short circuit, performance deterioration, or lifespan shortening may occur. When embedding a printed circuit board where a chip is mounted to a set, be sure that residual stress is not given to the chip due to the overall distortion of the printed circuit board and partial distortion such as at screw tightening portions. Self heating (temperature increase) occurs when the power is turned ON, so the tolerance should be sufficient for the set thermal design. Carefully lay out the coil for the circuit board design of the non-magnetic shield type. A malfunction may occur due to magnetic interference. Use a wrist band to discharge static electricity in your body through the grounding wire. Do not expose the products to magnets or magnetic fields. Do not use for a purpose outside of the contents regulated in the delivery specifications. The products listed on this catalog are intended for use in general electronic equipment (AV equipment, telecommunications equipment, home appliances, amusement equipment, computer equipment, personal equipment, office equipment, measurement equipment, industrial robots) under a normal operation and use condition. The products are not designed or warranted to meet the requirements of the applications listed below, whose performance and/or quality require a more stringent level of safety or reliability, or whose failure, malfunction or trouble could cause serious damage to society, person or property. If you intend to use the products in the applications listed below or if you have special requirements exceeding the range or conditions set forth in the each catalog, please contact us. (1) Aerospace/aviation equipment (2) Transportation equipment (cars, electric trains, ships, etc.) (3) Medical equipment (4) Power-generation control equipment (5) Atomic energy-related equipment   (6) Seabed equipment (7) Transportation control equipment (8) Public information-processing equipment (9) Military equipment (10) Electric heating apparatus, burning equipment (11) Disaster prevention/crime prevention equipment (12) Safety equipment (13) Other applications that are not considered general-purpose applications When designing your equipment even for general-purpose applications, you are kindly requested to take into consideration securing protection circuit/device or providing backup circuits in your equipment. Please be sure to request delivery specifications that provide further details on the features and specifications of the products for proper and safe use. Please note that the contents may change without any prior notice due to reasons such as upgrading. (4/4) 20191021 cmf_commercial_power_acm4520_en.fm
ACM4520-901-2P-TL000 价格&库存
很抱歉,暂时无法提供与“ACM4520-901-2P-TL000”相匹配的价格&库存,您可以联系我们找货
  • 2500+3.773102500+0.48840
