ACM4520-901-2P
ACM4520-901-2P
    TDK(东电化)
    ACM4520-901-2P - Common Mode Filters(SMD) For Power Line - TDK Electronics
ACM4520-901-2P 数据手册
(1/2) Common Mode Filters(SMD) For Power Line ACM Series ACM4520 Type FEATURES • Several large current products are prepared to correspond to the various applications. • Low profile and compact shape, it is suited for surface mounting. • It shows high common-mode impedance despite of its compact shape. APPLICATIONS Radiation noise suppression for power line (DVC, DVD cam, DSC, etc.) TEMPERATURE RANGE Operating –40 to +85°C Conformity to RoHS Directive PRODUCT IDENTIFICATION ACM (1) 4520 - 901 - 2P - T - 000 (2) (3) (4) (5) (6) PACKAGING STYLE AND QUANTITIES Packaging style Taping Reel ø180mm ø330mm Quantity 800 pieces/reel 2500 pieces/reel (1) Series name (2) Dimensions W× T 4520: 4.5× 2.0mm (3) Impedance [at 100MHz] 901: 900Ω 142: 1400Ω (4) Numbers of lines 2P: 2-line (5) Packaging style T: ø180mm reel taping TL: ø330mm reel taping B: Bulk (6) TDK internal code SHAPES AND DIMENSIONS 4.7±0.2 4.5 CIRCUIT DIAGRAM 1 4 3 • No polarity 4.5±0.2 1 4 0.75 2 2.0 RECOMMENDED PC BOARD PATTERN 1.25 3.5 1.25 2 3 0.75 Ferrite 0.95 1.05 0.95 2.0max. 2.0 Wire Dimensions in mm Terminal 0.65 0.65 Dimensions in mm • Conformity to RoHS Directive: This means that, in conformity with EU Directive 2002/95/EC, lead, cadmium, mercury, hexavalent chromium, and specific bromine-based flame retardants, PBB and PBDE, have not been used, except for exempted applications. • All specifications are subject to change without notice. 001-02 / 20070111 / e9713_acm4520.fm (2/2) ELECTRICAL CHARACTERISTICS Part No. ACM4520-901-2P ACM4520-142-2P Common mode impedance (Ω)[at 100MHz] min. typ. 650 900 1000 1400 DC resistance (Ω)max. [1 line] 0.06 0.08 Rated current Idc (A)max. 2.0 1.5 Rated voltage Edc (V)max. 50 50 Insulation resistance (MΩ )min. 10 10 TYPICAL ELECTRICAL CHARACTERISTICS IMPEDANCE vs. FREQUENCY CHARACTERISTICS ACM4520-901-2P 10000 ACM4520-142-2P 10000 1000 Impedance (Ω) 1000 Impedance (Ω) 100 Common mode 100 Common mode 10 Differential mode 10 Differential mode 1 1 10 Frequency (MHz) 100 1000 1 1 10 Frequency (MHz) 100 1000 • All specifications are subject to change without notice. 001-02 / 20070111 / e9713_acm4520.fm
ACM4520-901-2P
1. 物料型号: - ACM4520-901-2P:阻抗为900Ω,DC电阻最大0.06Ω,最大额定电流2.0A,最大额定电压50V。 - ACM4520-142-2P:阻抗为1400Ω,DC电阻最大0.08Ω,最大额定电流1.5A,最大额定电压50V。
2. 器件简介: - ACM系列共模滤波器,专为各种应用准备了几个大电流产品,适合表面贴装,具有低轮廓和紧凑的形状,尽管形状紧凑,但具有较高的共模阻抗。
3. 引脚分配: - 2P:表示2线配置。
4. 参数特性: - 共模阻抗:ACM4520-901-2P为650至900Ω,ACM4520-142-2P为1000至1400Ω。 - DC电阻:ACM4520-901-2P最大0.06Ω,ACM4520-142-2P最大0.08Ω。 - 额定电流:ACM4520-901-2P最大2.0A,ACM4520-142-2P最大1.5A。 - 额定电压:两款产品均为最大50V。 - 绝缘电阻:最小10MΩ。
5. 功能详解: - 用于电源线的辐射噪声抑制(例如DVC、DVD摄像机、DSC等)。
6. 应用信息: - 用于电源线的辐射噪声抑制。
7. 封装信息: - 封装风格为卷轴包装,0180mm卷轴每卷800件,0330mm卷轴每卷2500件。
ACM4520-901-2P 价格&库存
很抱歉,暂时无法提供与“ACM4520-901-2P”相匹配的价格&库存,您可以联系我们找货
ACM4520V-901-2P-T00
库存:10
ACM4520-901-2P-T000
  • 1+5.2767
  • 10+4.4451
  • 160+4.40065
  • 320+4.31264
  • 800+4.18326
库存:2859
ACM4520-421-2P-T000
  • 1+4.9104
  • 10+3.9699
  • 160+3.0393
  • 320+2.7621
  • 800+2.6235
库存:782
ACM4520V-231-2P-T00
  • 1+5.7134
  • 10+4.7138
  • 30+4.2238
库存:88
ACM4520-231-2P-T000
  • 1+5.27294
  • 10+4.28304
  • 160+3.29314
  • 320+2.99911
  • 800+2.84229
库存:780
ACM4520-142-2P-T000
  • 1+5.2866
  • 10+4.4451
  • 160+3.3462
  • 320+3.1878
  • 800+3.0987
库存:501
ACM4520V-142-2P-T00
  • 1+8.28976
  • 10+6.60716
  • 160+4.98821
  • 320+4.505
  • 800+4.21344
库存:641
