ACM7060-301-2PL-TL01
    TDK(东电化)
    SMD,7x6mm
    共模电感 5A 10mΩ 300Ω CHOKE_7X6MM_SM
ACM7060-301-2PL-TL01 数据手册
E M C C o m p o n e n t s May 2016 ࢥಠఌ؉ධ ‫ݢ‬ኑღቂ ACMႼள ACM7060 ACM7060 [2824 inch]* * ‫װ‬໯‫ܗ܄ڞ‬బȃ JIS[EIA] ᄲ (2/7) E M C C o m p o n e n t s ໪ቂ᎙ሃ໳ჵ ኷໪ቂׁٛ൰෇ˈขႚ‫ࢆࣙࢭتࡒཱུכ‬༚ȃ ՗ภ᎙ሃ໳ჵ ໪ቂׁٛ൰໢ˈข᎙ሃ՗ภ໳ჵȃ ᎙ ሃ ֦‫܃‬໢ৱၓ 12 ࢋኟᇵ೗ˈ֦‫܃‬࿢਋ ˄ၫ‫ ޡ‬5 ȋ 40°CȂ໛‫ ޡ‬10 ȋ 75%RH ᇵ჉˅ˈᅍ‫ࠍڣ‬᎙ሃȃ ๩٫ࣰ֦‫܃‬໢ৱˈ‫ޤ‬Ꮚ‫ݢ‬সܿ૰उᄹਖ૰೙୔फ़ȃ ข႙኷න࿒ࡄ໥०੼ ˄ᆑȂ཰Ȃ৻݃˅჉໪ቂञ֦࣏ȃ ኷໦໚उਾ෇ˈขႚ‫כ‬੣ᄵኁ฽ȃ ኁ฽ၫ‫ޡ‬ቪउਾၫ‫ޡ‬ঽᄣ൥ၫ‫ܿޡ‬ၫ‫ُޡ‬ᇋ኷ 150°C ᇵ೗ȃ ՗Ꭷॄܿउਾᅃጸሥ኷ࣙࢆ༚ࣙ‫ܿށ‬࿢਋߭ၐ೗ȃ ๩ৠ฽ࣰ‫ޡ‬૰೙ܷ፛‫௸ޥ‬Ȃᄹ೙ਠ݈Ȃ༊ಛਂຬȃ ਖ՗Ꭷமᄣ൥ܿሠ༱‫௸ݢ‬ᏠᎧܸᎧ፜໢ˈข᎙ሃ‫؜‬ᇋሓሠ༱‫௸ݢ‬ጶ࿒‫ק‬ᄳড੟ࢿ‫݃ؠ‬ટ‫קؠ‬ᄳߑࢍᄣ൥໚ৠ໔቟ሥஉȃ Ꭷ፜ঐሓ࿳‫ߑݢ‬Ꮛၻߙ฽ ˄ၫ‫ޡ‬ຢ໐˅ˈሓۨ኷฽ົ৓ߴಅᅍௗ቏‫ࠍڣ‬቟‫ݓ‬ȃ ߾ۢൺ‫ב‬ᄲ኷ন֊ົ৓໢ᅍ᎙ሃി፜ღปȃ །ܸ‫ฺ࡞ۢݢ‬૰೙ঐܷ፛ႜ‫ވ‬Ꮾȃ ቈ቙เ࿒ྈ‫ݢ੻ܿܕ‬ঐ‫ܸۈ‬ਾ‫ݓ‬ღຢˈሓۨข໪ቂ߷੻‫ݢ‬ှ‫ܕ‬ȃ ข႙ਖׁٛ൰૦੧ۢ࿧ড‫ܕ‬቏ۢஉܿ႘࿒ȃ ข኷‫ࢆࣙࢭت‬༚ࣙ‫߭ܿށ‬ၐ೗໪ቂȃ ׁٛ൰಼௽፩৔ኵܿٛ൰໸ፑ኷࿳ቂ‫׭‬Ꮃቂဉሃሆຢ໪ቂ቙ᇜֈ‫ݢ‬Ꮚົֻ˄AV ົֻˈ࿳ᄪົֻˈয়‫ݢ‬ٛ൰ˈቨ୛ົֻˈ৓ི঩ົֻˈࢋ เົֻˈ֑࢞ົֻˈ৓‫ࢗˈֻົك‬ᇖ঩ධเ˅ˈ‫؃‬෩ࡘᇜֈ‫ݢ‬Ꮚົֻᇋ኷࿳٢ܿ‫غ‬Ꮾञ໪ቂߴߟ჉໪ቂȃ ޭ቙ᅍᇋࡴ‫ޡ‬՗ภᄹञ૰૦ᄹܿˈডጚົֻܿࢽጊˈႜ‫ވ‬ᏮˈከᎡ‫؜‬ட૰೙ঐࢍเܿໍಛˈເ࿒ঽ‫ا‬ٛ݃ዉ‫ڈ‬ཿࣷˈᇵঽ቏૰೙ٛໍಧ ‫຺ܐ‬ঐሯჳܿᇵ჉ቂဉ ˄ᇵ჉‫ ‘ څ‬࿅‫ށ‬ቂဉ ’˅፩ܿ໻ቂᄹˈᄹ೙ߙংˈ൰፣ˈׁ࢞ཌྷ‫؜‬ቧ֦ጽȃ ૴ॖኁ‫ށ‬኷ׁٛ൰಼௽ܿ߭ၐˈ࿢਋ፇိˈডጚ኷࿅‫ށ‬ቂဉ፩໪ቂ໢ˈข໳჏Ꮐᅲׁ࢞ཌྷყ࣋‫ؠ‬౤ȃׁ࢞ཌྷঐിठ૴ॖᅍชˈᇜඩᄒຟ ‫؜‬࿷቙ׁٛ൰಼௽፩ྈ৔ኵܿ໪ቂቂဉȃ (1) ऎૼˈऎ࿙ົֻ (2) ከ༕ົֻ ˄ප‫˅݃ؑۉˈٴݢˈٴ‬ (3) ᇞனົֻ (4) ߙ‫૿ݢ‬፟ົֻ (5) ज‫ވ‬உყ࣋ົֻȁȁ (6) ࣴ‫ֻົݒ‬ (7) ਦ࿳ࢗન૿፟ົֻ (8) ࢞ࢥᄹܿࡴ‫ޡ‬ᄪႩ‫ֻົ୲ۃ‬ (9) ૅቂົֻ (10) ‫ݢ‬฽ቂ൰ˈัຨົֻ (11) ߷ኳ߷ܼົֻ (12) ࢌ፯՗ภᎧ፜ (13) ඝྊ‫־‬ไ‫ށ‬ၓ࿅‫ށ‬ቂဉܿቂဉ ۨိˈޭ໪ቂׁٛ൰಼௽፩ྈ৔ኵٛ൰ܿົֻ੣ᄵົ৓໢ˈขฬ֦࠲ठࡘົֻܿ໪ቂቂဉঽᎫྙ֦ܿ॓ই௸ञᎧ፜ˈ‫ົ؃‬፜ֻቂই௸݃ȃ 20160519 / cmf_commercial_power_acm7060_zh.fm (3/7) E M C C o m p o n e n t s ࢥಠఌ؉ධ RoHSፑ௑ޭሥٛ൰ ႇ௲ཧ ႇලउਾޭሥ ‫ݢ‬ኑღቂ ACM7060ᄲ࡚ܿᇋ ࿅‫ݞ‬ ໻ቂ቙‫ݢܐ‬௚ܿ൥໮ࢥಠఌ؉ධȃ ȁႇజು፯ႼளૂਖᄳᎫ૿፟኷Ꮵᄆქ‫ˈޡ‬࿷໢નֻ਺ࡴܿࢥಠᏟૠˈ೙ࢮ‫࠰ܐ‬ਠ݈ወሕȃ ቈ቙ٛ൰ܿࡴ‫܄ڞޡ‬ᇓ‫૿־‬፟኷਺݈༽൶ˈሓۨ೙ࢮ໻ሥ‫ި؜‬ᄆᄲ෸஢फ़ܿ‫צ‬ᄔ໮ົֻܿࡴ౻‫ޡ‬फ़ฎ໷ȃ ቂဉ ቂ቙ሥޭྈ቏‫ݢ‬Ꮚົֻܿ‫ݢ‬ኑღወሕȃ ቂ቙ሥޭ‫׍‬৔ׁ‫ݢ‬೑ȂၭᏍ‫୲ۃ‬঩݃਺‫ܐ‬ᄲ‫ݢ‬Ꮚົֻܿ໻ിධღȂ‫ڗݢ‬ღܿወሕȃ ᄲखܿಛಚߴߟ ACM Ⴜளಚ‫څ‬ 7060 L×W×H ‫ߟ܄‬ (mm) 7060 7.0×6.0×3.5 - 301 Ꮯૠ (:) at 100MHz 301 300 - 2PL - ღ༮ 2PL 2ღ TL TL 01 ֡Ꭷᄳ໮ ࣏୲࠲ख ø330mm શ࿽ 01 ໪ቂၫ‫߭ޡ‬ၐȂ֡Ꭷ༮஢Ȃٛ൰፱஢ ၫ‫߭ޡ‬ၐ ୥ᄲ ACM7060 ࢗᏮၫ‫ޡ‬ ˄°C˅ –40 to +85 ֦‫܃‬ၫ‫ ޡ‬ ˄°C˅ –40 to +85 શ੿ ֡Ꭷ༮஢ ‫ࢋܠ‬፱஢ ˄mm˅ ø330 ˄ࢋ / શ˅ 1,500 ˄g˅ 0.35 ֦‫܃‬ၫ‫߭ޡ‬ၐ኷ন֊՗Ꭷॄმ໯ȃ RoHSፑ௑ޭሥٛ൰˖RoHSፑ௑ޭሥٛ൰ܿჱႿ೗๒‫ي‬૛ጝ୴ȃhttp://product.tdk.com/zh/environment/rohs/ ႇ௲ཧ˖ፑܿ໸Clࣽ஢‫ܸ؜‬900ppmȂ Brࣽ஢‫ܸ؜‬900ppmᇵঽ ClȂ Brܿठ৓ࣽ஢‫ܸ؜‬1500ppmȃ ၓம೙ࢮ࢑ৠጸฬȂ՗ภ‫ݓ‬໪ቂٛ൰ˈขႚ‫྆כ‬ถ೙੣ᇜ‫؞‬ฬไჱႿ࿅ᄹȂࣙࢆܿ‫ࢆࣙࢭت‬༚ȃ ৔ኵ೗๒૰೙ሓၓٛ൰࡙ட݃ኊሓ‫੶؜‬ኁࡻߑ࢑࡙ˈ༰‫؜‬ௐᄵ࿳ፃȃ 20160519 / cmf_commercial_power_acm7060_zh.fm (4/7) E M C C o m p o n e n t s ACM7060 ᄲ ထਃই௚उၫ‫ޡ‬ฑღဇ Preheating Soldering Natural cooling Peak T: Temperature T4 T3 T2 T3 t3 T1 t1 t2 t: Time Preheating Temp. T1 T2 150°C 180°C Time t1 60 to 120s Soldering Temp. Time T3 t2 230°C 10 to 30s Peak Temp. T4 245°C Time t3 5s ၓம೙ࢮ࢑ৠጸฬȂ՗ภ‫ݓ‬໪ቂٛ൰ˈขႚ‫྆כ‬ถ೙੣ᇜ‫؞‬ฬไჱႿ࿅ᄹȂࣙࢆܿ‫ࢆࣙࢭت‬༚ȃ ৔ኵ೗๒૰೙ሓၓٛ൰࡙ட݃ኊሓ‫੶؜‬ኁࡻߑ࢑࡙ˈ༰‫؜‬ௐᄵ࿳ፃȃ 20160519 / cmf_commercial_power_acm7060_zh.fm (5/7) E M C C o m p o n e n t s ACM7060 ᄲ ᄳᎫቪ‫܄ڞ‬ 7.0±0.2 4 2 3 6.0±0.2 1 4.0typ. 1.5±0.2 3.5max. 1.5±0.2 1.5±0.2 1.5±0.2 1.5±0.2 Dimensions in mm ထਃउധ‫؝‬ટ ‫௸ݢ‬ဇ 9.0 1.5 4.0 1 4 2 3 3.0 • No polarity Dimensions in mm ၓம೙ࢮ࢑ৠጸฬȂ՗ภ‫ݓ‬໪ቂٛ൰ˈขႚ‫྆כ‬ถ೙੣ᇜ‫؞‬ฬไჱႿ࿅ᄹȂࣙࢆܿ‫ࢆࣙࢭت‬༚ȃ ৔ኵ೗๒૰೙ሓၓٛ൰࡙ட݃ኊሓ‫੶؜‬ኁࡻߑ࢑࡙ˈ༰‫؜‬ௐᄵ࿳ፃȃ 20160519 / cmf_commercial_power_acm7060_zh.fm (6/7) E M C C o m p o n e n t s ACM7060 ᄲ ‫ݢ‬න࿅‫ݞ‬ ࿅‫װࢆࣙݞ‬ ࢥಠᏟૠ [100MHz] (: ) min. 225 500 (: ) typ. 300 700 ፊ௚‫ݢ‬Ꮯ [1 line] (m: )max. 10 15 ߇‫ݢށ‬௚ ુኒ‫ݢ‬Ꮯ ߇‫ݢށ‬ᅼ ᄲख (A)max. 5 4 (M: )min. 10 10 (V)max. 80 80 ACM7060-301-2PL-TL01 ACM7060-701-2PL-TL01 ɐ‫ك‬஢ົֻ ‫ك‬஢ჵ಼ ࢥಠᏟૠ ፊ௚‫ݢ‬Ꮯ ુኒ‫ݢ‬Ꮯ ˆ቏໢໪ቂ࿷݃‫ك‬஢ົֻȃ ᄲख 4991A 4338A 4339A ٦ຟ Keysight Technologies Keysight Technologies Keysight Technologies Ꮯૠ൮ఋ࿅ᄹ 10000 701 Differential mode Impedance (Ω) 1000 301 Common mode 701 Common mode 100 301 Differential mode 10 1 1 10 100 1000 Frequency (MHz) ɐ‫ك‬஢ົֻ ᄲख 4991A ˆ቏໢໪ቂ࿷݃‫ك‬஢ົֻȃ ٦ຟ Keysight Technologies ၓம೙ࢮ࢑ৠጸฬȂ՗ภ‫ݓ‬໪ቂٛ൰ˈขႚ‫྆כ‬ถ೙੣ᇜ‫؞‬ฬไჱႿ࿅ᄹȂࣙࢆܿ‫ࢆࣙࢭت‬༚ȃ ৔ኵ೗๒૰೙ሓၓٛ൰࡙ட݃ኊሓ‫੶؜‬ኁࡻߑ࢑࡙ˈ༰‫؜‬ௐᄵ࿳ፃȃ 20160519 / cmf_commercial_power_acm7060_zh.fm (7/7) E M C C o m p o n e n t s ACM7060 ᄲ ֡Ꭷᄳ໮ શ࿽‫܄ڞ‬ 2.0±0.5 E A W1 W2 ø330±2 16.4+2/–0 20.4 typ. N 100±1 E 2 typ. N ୥ᄲ ACM7060 1.0 ø13.0±0.2 W1 ø21.0±0.8 W2 A Dimensions in mm ‫܄ڞܕף‬ t P0 B W F P2 E øD0 K P1 A Dimensions in mm ୥ᄲ ACM7060 A 6.6±0.1 B 7.6±0.1 øD0 1.5+0.1/0 E 1.75±0.1 F 7.5±0.1 P0 4.0±0.1 P1 8.0±0.1 P2 2.0±0.1 W 16.0±0.3 K 3.6±0.1 t 0.4±0.05 500 to 560min. 160min. Drawing direction Taping 440min. Dimensions in mm ၓம೙ࢮ࢑ৠጸฬȂ՗ภ‫ݓ‬໪ቂٛ൰ˈขႚ‫྆כ‬ถ೙੣ᇜ‫؞‬ฬไჱႿ࿅ᄹȂࣙࢆܿ‫ࢆࣙࢭت‬༚ȃ ৔ኵ೗๒૰೙ሓၓٛ൰࡙ட݃ኊሓ‫੶؜‬ኁࡻߑ࢑࡙ˈ༰‫؜‬ௐᄵ࿳ፃȃ 20160519 / cmf_commercial_power_acm7060_zh.fm
物料型号为ACM7060-301-2PL-TL01,是一款无卤素、无铅焊接对应的共模滤波器,适用于大电流的片式共模滤波器。
器件简介包括其特点,如适用于大电流、小型化、低高度设计,以及用途,主要用于电子设备的电源线噪音抑制。
引脚分配未在文档中明确说明,但通常这类器件为无极性设计。
参数特性包括共模阻抗、直流电阻、额定电流、绝缘电阻和额定电压。
具体数值为共模阻抗300Ω、直流电阻10mΩ、额定电流5A、绝缘电阻10MΩ、额定电压80V。
功能详解涉及其在电子设备中抑制电源线噪音的作用,以及在不同频率下的阻抗特性。
应用信息包括用于笔记本电脑、文字处理机等较大型电子设备的适配器线、电池线的噪音抑制。
封装信息为尺寸7.0×6.0×3.5mm,卷径330mm,包装数为每卷1500个,单个重量0.35g。
此外,还提供了推荐回流焊温度曲线图和形状与尺寸图。
ACM7060-301-2PL-TL01 价格&库存
很抱歉,暂时无法提供与“ACM7060-301-2PL-TL01”相匹配的价格&库存,您可以联系我们找货
  • 1+6.02910
  • 10+4.91040
  • 300+3.79170
  • 600+3.21750
  • 1500+3.04920
库存:1831
  • 1500+7.170761500+0.90240
  • 3000+6.762913000+0.85107
  • 4500+6.535444500+0.82245
  • 7500+6.342627500+0.79818
库存:93589
