ACM7060-701-2PL-TL
ACM7060-701-2PL-TL
    TDK(东电化)
    SMD,7x6mm
    固定电感器 7.00 x 6.00mm FILTER_7X6MM_SM
ACM7060-701-2PL-TL 数据手册
E M C C o m p o n e n t s Common mode filters For power line ACM series RoHS REACH SVHC-Free Cl Br Pb Halogen Free Lead Free ACM7060 type FEATURES Chip common mode filter for large current applications. For each series, there is excellent common mode impedance and noise suppression in a compact case. Compatible with high-density portable devices, which are always being made smaller and lighter, because the height has been reduced. Operating temperature range: –40 to +85°C APPLICATION Power line noise countermeasure for various electronic equipment. Noise countermeasure for adapter lines and battery lines or larger electronic equipment such as note PCs and word processors. PART NUMBER CONSTRUCTION ACM 7060 - Series name L×W×H dimensions 7.0×6.0×3.5 mm 301 - Impedance () at 100MHz 2PL Number of lines - TL 01 Packaging style Internal code CHARACTERISTICS SPECIFICATION TABLE Common mode impedance DC resistance Rated current Insulation resistance Rated voltage Part No. [100MHz] ( )min. 225 500 [1 line] (m )max. 10 15 (A)max. 5 4 (M )min. 10 10 (V)max. 80 80 ACM7060-301-2PL-TL01 ACM7060-701-2PL-TL01 ( )typ. 300 700 Measurement equipment Measurement item Product No. Common mode impedance 4991A DC resistance 4338A Insulation resistance 4339A * Equivalent measurement equipment may be used. Manufacturer Keysight Technologies Keysight Technologies Keysight Technologies Please be sure to request delivery specifications that provide further details on the features and specifications of the products for proper and safe use. Please note that the contents may change without any prior notice due to reasons such as upgrading. (1/4) 20181011 cmf_commercial_power_acm7060_en.fm E M C C o m p o n e n t s ACM7060 type IMPEDANCE VS. FREQUENCY CHARACTERISTICS 10000 701 Differential mode Impedance (Ω) 1000 301 Common mode 701 Common mode 100 301 Differential mode 10 1 1 10 100 1000 Frequency (MHz) Measurement equipment Product No. Manufacturer 4991A Keysight Technologies * Equivalent measurement equipment may be used. Please be sure to request delivery specifications that provide further details on the features and specifications of the products for proper and safe use. Please note that the contents may change without any prior notice due to reasons such as upgrading. (2/4) 20181011 cmf_commercial_power_acm7060_en.fm E M C C o m p o n e n t s ACM7060 type SHAPE & DIMENSIONS PACKAGING STYLE REEL DIMENSIONS 7.0±0.2 2.0±0.5 4 2 3 100±1 6.0±0.2 1 2 typ. 1.5±0.2 4.0typ. 1.5±0.2 3.5max. 1.0 ø13.0±0.2 1.5±0.2 16.4+2/–0 ø21.0±0.8 1.5±0.2 1.5±0.2 20.4 typ. ø330±2 Dimensions in mm Dimensions in mm RECOMMENDED LAND PATTERN 4.0±0.1 Sprocket hole 16.0±0.3 2.0±0.1 B 4.0 9.0 7.5±0.1 1.5 +0.1 0 0.4±0.05 1.75±0.1 4.5 1.5 TAPE DIMENSIONS Dimensions in mm Cavity K A CIRCUIT DIAGRAM 1 4 2 3 8.0±0.1 Dimensions in mm Type ACM7060 A 6.6±0.1 160min. Taping B 7.6±0.1 K 3.6±0.1 • No polarity 500 to 560min. RECOMMENDED REFLOW PROFILE Preheating Soldering 440min. Natural cooling Peak Drawing direction 245°C Temperature 230°C Dimensions in mm 230°C PACKAGE QUANTITY Package quantity 1500 pcs/reel 180°C 5s 150°C 60 to 120s 10 to 30s TEMPERATURE RANGE, INDIVIDUAL WEIGHT Operating Storage temperature range temperature range –40 to +85 °C –40 to +85 °C  The storage temperature range is for after the assembly. Individual weight 0.35 g Time Please be sure to request delivery specifications that provide further details on the features and specifications of the products for proper and safe use. Please note that the contents may change without any prior notice due to reasons such as upgrading. (3/4) 20181011 cmf_commercial_power_acm7060_en.fm E M C C o m p o n e n t s REMINDERS FOR USING THESE PRODUCTS Before using these products, be sure to request the delivery specifications. SAFETY REMINDERS Please pay sufficient attention to the warnings for safe designing when using this products. REMINDERS The storage period is less than 12 months. Be sure to follow the storage conditions (temperature: 5 to 40°C, humidity: 10 to 75% RH or less). If the storage period elapses, the soldering of the terminal electrodes may deteriorate. Do not use or store in locations where there are conditions such as gas corrosion (salt, acid, alkali, etc.). Before soldering, be sure to preheat components. The preheating temperature should be set so that the temperature difference between the solder temperature and chip temperature does not exceed 150°C. Soldering corrections after mounting should be within the range of the conditions determined in the specifications. If overheated, a short circuit, performance deterioration, or lifespan shortening may occur. When embedding a printed circuit board where a chip is mounted to a set, be sure that residual stress is not given to the chip due to the overall distortion of the printed circuit board and partial distortion such as at screw tightening portions. Self heating (temperature increase) occurs when the power is turned ON, so the tolerance should be sufficient for the set thermal design. Carefully lay out the coil for the circuit board design of the non-magnetic shield type. A malfunction may occur due to magnetic interference. Use a wrist band to discharge static electricity in your body through the grounding wire. Do not expose the products to magnets or magnetic fields. Do not use for a purpose outside of the contents regulated in the delivery specifications. The products listed on this catalog are intended for use in general electronic equipment (AV equipment, telecommunications equipment, home appliances, amusement equipment, computer equipment, personal equipment, office equipment, measurement equipment, industrial robots) under a normal operation and use condition. The products are not designed or warranted to meet the requirements of the applications listed below, whose performance and/or quality require a more stringent level of safety or reliability, or whose failure, malfunction or trouble could cause serious damage to society, person or property. If you intend to use the products in the applications listed below or if you have special requirements exceeding the range or conditions set forth in the each catalog, please contact us. (1) Aerospace/aviation equipment (2) Transportation equipment (cars, electric trains, ships, etc.) (3) Medical equipment (4) Power-generation control equipment (5) Atomic energy-related equipment   (6) Seabed equipment (7) Transportation control equipment (8) Public information-processing equipment (9) Military equipment (10) Electric heating apparatus, burning equipment (11) Disaster prevention/crime prevention equipment (12) Safety equipment (13) Other applications that are not considered general-purpose applications When designing your equipment even for general-purpose applications, you are kindly requested to take into consideration securing protection circuit/device or providing backup circuits in your equipment. Please be sure to request delivery specifications that provide further details on the features and specifications of the products for proper and safe use. Please note that the contents may change without any prior notice due to reasons such as upgrading. (4/4) 20181011 cmf_commercial_power_acm7060_en.fm
ACM7060-701-2PL-TL 价格&库存
很抱歉,暂时无法提供与“ACM7060-701-2PL-TL”相匹配的价格&库存,您可以联系我们找货
