E M C
C o m p o n e n t s
November 2015
Common Mode Filters
For automotive power line
ACM-V Series
ACM90V Type
ACM90V
(2/7)
E M C
C o m p o n e n t s
REMINDERS FOR USING THESE PRODUCTS
Before using these products, be sure to request the delivery specifications.
SAFETY REMINDERS
Please pay sufficient attention to the warnings for safe designing when using these products.
REMINDERS
The storage period is less than 12 months. Be sure to follow the storage conditions (Temperature: 5 to 40°C, Humidity: 10 to 75% RH
or less).
If the storage period elapses, the soldering of the terminal electrodes may deteriorate.
Do not use or store in locations where there are conditions such as gas corrosion (salt, acid, alkali, etc.).
Before soldering, be sure to preheat components.
The preheating temperature should be set so that the temperature difference between the solder temperature and chip temperature
does not exceed 150°C.
Soldering corrections after mounting should be within the range of the conditions determined in the specifications.
If overheated, a short circuit, performance deterioration, or lifespan shortening may occur.
When embedding a printed circuit board where a chip is mounted to a set, be sure that residual stress is not given to the chip due to
the overall distortion of the printed circuit board and partial distortion such as at screw tightening portions.
Self heating (temperature increase) occurs when the power is turned ON, so the tolerance should be sufficient for the set thermal
design.
Carefully lay out the coil for the circuit board design of the non-magnetic shield type.
A malfunction may occur due to magnetic interference.
Use a wrist band to discharge static electricity in your body through the grounding wire.
Do not expose the products to magnets or magnetic fields.
Do not use for a purpose outside of the contents regulated in the delivery specifications.
The products listed on this catalog are intended for use in general electronic equipment (AV equipment, telecommunications
equipment, home appliances, amusement equipment, computer equipment, personal equipment, office equipment, measurement
equipment, industrial robots) under a normal operation and use condition.
The products are not designed or warranted to meet the requirements of the applications listed below, whose performance and/or
quality require a more stringent level of safety or reliability, or whose failure, malfunction or trouble could cause serious damage to
society, person or property.
If you intend to use the products in the applications listed below or if you have special requirements exceeding the range or conditions
set forth in the each catalog, please contact us.
(1) Aerospace/Aviation equipment
(2) Transportation equipment (electric trains, ships, etc.)
(3) Medical equipment
(4) Power-generation control equipment
(5) Atomic energy-related equipment
(6) Seabed equipment
(7) Transportation control equipment
(8) Public information-processing equipment
(9) Military equipment
(10) Electric heating apparatus, burning equipment
(11) Disaster prevention/crime prevention equipment
(12) Safety equipment
(13) Other applications that are not considered general-purpose
applications
When designing your equipment even for general-purpose applications, you are kindly requested to take into consideration securing
protection circuit/device or providing backup circuits in your equipment.
20151120 / cmf_automotive_power_acm90v_en.fm
(3/7)
E M C
C o m p o n e n t s
Common Mode Filters
Product compatible with RoHS directive
Compatible with lead-free solders
AEC-Q200
Overview of ACM90V Type
FEATURES
Exclusive square type closed magnetic core designed as an exclusive core is used, so it can be small while maintaining the same
features.
Low profile design makes it optimal for surface mounting.
Excellent impedance characteristics, making it great for suppressing common mode noise.
Series includes large current products up to 8A, making them compatible with various DC power lines.
Covers a wide operating temperature range from –40 to +125°C.
APPLICATION
Common mode noise countermeasure for electronic controller DC power lines and power supply lines for car multi-media equipment
and various electronic devices.
PART NUMBER CONSTRUCTION
ACM
Series name
90V
L×W×H Dimensions
(mm)
90V
9.0×7.0×4.5
701
Impedance
(:) at 100MHz
701
700
2PL
Number of lines
2PL
2 lines
TL
TL
00
Packaging style
Internal code
ø330mm reel
00
OPERATING TEMPERATURE RANGE, PACKAGE QUANTITY, PRODUCT WEIGHT
Temperature range
Operating
Storage
Type
temperature
temperature
(°C)
(°C)
ACM90V
–40 to +125
–40 to +125
The Storage temperature range is for after the circuit board is mounted.
Reel diameter
Package quantity
Individual weight
(mm)
ø330
(pieces/reel)
800
(g)
0.82
RoHS Directive Compliant Product: See the following for more details related to RoHS Directive compliant products. http://product.tdk.com/en/environment/rohs/
Please be sure to request delivery specifications that provide further details on the features and specifications of the products for proper and safe use.
Please note that the contents may change without any prior notice due to reasons such as upgrading.
(4/7)
E M C
C o m p o n e n t s
ACM90V Type
RECOMMENDED REFLOW PROFILE
Preheating
Soldering
Natural
cooling
Peak
T: Temperature
T4
T3
T2
T3
t3
T1
t1
t2
t: Time
Preheating
Temp.
T1
T2
150°C
180°C
Time
t1
60 to 120s
Soldering
Temp.
Time
T3
t2
230°C
10 to 30s
Peak
Temp.
T4
245°C
Time
t3
5s
(5/7)
E M C
C o m p o n e n t s
ACM90V Type
SHAPE & DIMENSIONS
9.0±0.2
4
2
3
7.0±0.2
1
6.0typ.
1.5±0.2
4.5max.
1.5±0.2
1.5±0.2
1.5±0.2
2.0±0.2
Dimensions in mm
RECOMMENDED LAND PATTERN
CIRCUIT DIAGRAM
11.0
1.5
6.0
1
4
2
3
3.5
• No polarity
Dimensions in mm
(6/7)
E M C
C o m p o n e n t s
ACM90V Type
ELECTRICAL CHARACTERISTICS
CHARACTERISTICS SPECIFICATION TABLE
Common mode impedance
DC resistance
Rated current
Rated voltage
Insulation
resistance
[at 100MHz]
(: )min.
500
(m: )max.
10
(A)max.
5.0
(V)max.
80
(M: )min.
10
(: )typ.
700
○ Measurement equipment
Measurement item
Product No.
4991A
DC resistance
4338A
Insulation resistance
4339A
* Equivalent measurement equipment may be used.
Part No.
ACM90V-701-2PL-TL00
Manufacturer
Agilent Technologies
IMPEDANCE VS. FREQUENCY CHARACTERISTICS
10000
1000
Impedance (Ω)
701 Common mode
701 Differential mode
100
10
1
1
10
100
1000
Frequency (MHz)
Product No.
Manufacturer
4991A
(7/7)
E M C
C o m p o n e n t s
ACM90V Type
PACKAGING STYLE
REEL DIMENSIONS
2.0±0.5
E
A
W1
W2
ø330±2 16.4+2/–0 20.4 typ.
N
100±1
E
2 typ.
N
Type
ACM90V
1.0
ø13.0±0.2
W1
ø21.0±0.8
W2
A
Dimensions in mm
TAPE DIMENSIONS
P0
t
B
W
F
P2
E
øD0
K
P1
A
Dimensions in mm
Type
ACM90V
A
8.6±0.1
B
9.6±0.1
øD0
1.5+0.1/0
E
1.75±0.1
F
7.5±0.1
P0
4.0±0.1
P1
12.0±0.1
P2
2.0±0.1
W
16.0±0.3
K
4.6±0.1
t
0.4±0.05
500 to 560min.
160min.
Drawing direction
Taping
L
Type
ACM90V
L
440min.
Dimensions in mm
ACM90V-701-2PL-TL00 价格&库存
很抱歉,暂时无法提供与“ACM90V-701-2PL-TL00”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+8.90820
- 10+7.44800
- 30+6.64440
- 100+5.73300
