ACT1210E-241-2P-TL00
    TDK(东电化)
    水平式,4 PC 板
    240 µH 2 线路共模扼流圈 表面贴装型 70mA DCR 4.1 欧姆
ACT1210E-241-2P-TL00 数据手册
E M C C o m p o n e n t s Common mode filters Automotive signal line (for power train/safety) ACT series RoHS REACH SVHC-Free Cl Br Pb Halogen Free Lead Free AEC-Q200 ACT1210E type FEATURES Common mode filters for automotive Ethernet 10BASE-T1S, compatible with an operating temperature range of –40 to +125°C. This product achieves high S-parameter while realizing high reliability by metallizing terminals and laser welding using a proprietary method. Operating temperature range: –40 to +125°C Compliant with AEC-Q200 APPLICATION For Ethernet 10BASE-T1S system (10BASE-T1S) PART NUMBER CONSTRUCTION ACT1210E - 241 - Inductance(typ.) (µH) Series • type name 2P - Number of lines TL 00 Packaging style Internal code CHARACTERISTICS SPECIFICATION TABLE Common mode inductance [100kHz]at 25°C (µH) Tolerance 240 +50%/–20% DC resistance at 25°C ( )max. 4.1 Insulation resistance at 25°C (M )min. 10 Rated current at 25°C (mA)max. 70 Rated voltage at 25°C (V)max. 80 Part No. ACT1210E-241-2P-TL00 Rated current temperature characteristics (Derating) 90 80 ACT1210E-241 Rated current (mA) 70 60 50 40 30 20 10 0 25 45 65 85 Ambient temperature(°C) 105 125 Measurement equipment Measurement item Product No. Common mode inductance 4294A DC resistance 4338A Insulation resistance 4339A * Equivalent measurement equipment may be used. Manufacturer Keysight Technologies Keysight Technologies Keysight Technologies Please be sure to request delivery specifications that provide further details on the features and specifications of the products for proper and safe use. Please note that the contents may change without any prior notice due to reasons such as upgrading. (1/4) 20221027 cmf_automotive_signal_act1210e_en.fm E M C C o m p o n e n t s ACT1210E type Sdd21 Scc21 0 0 ACT1210E-241 –10 Scc21 (dB) Sdd21 (dB) –1 –2 –3 –4 –20 ACT1210E-241 –30 –40 –50 –5 0.1 1 10 Frequency (MHz) 100 –60 0.1 1000 1 10 Frequency (MHz) 100 1000 Sdd11,Sdd22 0 0 ACT1210E-241 (Zd=50Ω) –5 –10 –10 Sdd22 (dB) Sdd11 (dB) ACT1210E-241 (Zd=50Ω) –5 –15 –20 –25 –15 –20 –25 ACT1210E-241 (Zd=100Ω) –30 –35 0.1 1 10 Frequency (MHz) 100 –30 –35 0.1 1000 ACT1210E-241 (Zd=100Ω) 1 10 Frequency (MHz) 100 1000 0 0 –20 –20 Ssd12 (dB) Ssd21 (dB) Ssd21, Ssd12 ACT1210E-241 –40 –60 –80 –40 ACT1210E-241 –60 –80 –100 0.1 1 10 Frequency (MHz) 100 1000 –100 0.1 1 10 Frequency (MHz) 100 1000 Measurement equipment Product No. Manufacturer E5071C Keysight Technologies * Equivalent measurement equipment may be used. Please be sure to request delivery specifications that provide further details on the features and specifications of the products for proper and safe use. Please note that the contents may change without any prior notice due to reasons such as upgrading. (2/4) 20221027 cmf_automotive_signal_act1210e_en.fm E M C C o m p o n e n t s ACT1210E type PACKAGING STYLE SHAPE & DIMENSIONS REEL DIMENSIONS 3.9max. (2) 2.0±0.5 4 2 3 2.5max. ø100+1.0/-1.5 2.5±0.2 1 (0.6) (0.5) ø13.0+0.3/-0.2 13.5±0.5 (ø21) 4x 0.1 CZ ø330+2.0/-2.5 Dimensions in mm Dimensions in mm TAPE DIMENSIONS 1.5 +0.1 –0 2±0.05 4±0.1 12+0.3/–0.1 Sprocket hole 0.4±0.1 1.6 0.4 RECOMMENDED LAND PATTERN 2.0 B 4.1 Dimensions in mm A K Cavity 4±0.1 CIRCUIT DIAGRAM 1 4 2 3 5.5±0.05 3.2±0.2 1.75±0.1 (0.6) Dimensions in mm Type ACT1210E A (2.85) B (4.2) K (2.7) • No polarity PACKAGE QUANTITY Package quantity 6,000 pcs/reel RECOMMENDED REFLOW PROFILE Soldering Preheating Natural cooling Peak 245°C Temperature 230°C TEMPERATURE RANGE, INDIVIDUAL WEIGHT Operating temperature range –40 to +125°C Individual weight 0.075 g 230°C 180°C 5s max. 150°C 10 to 30s 60 to 120s Time Please be sure to request delivery specifications that provide further details on the features and specifications of the products for proper and safe use. Please note that the contents may change without any prior notice due to reasons such as upgrading. (3/4) 20221027 cmf_automotive_signal_act1210e_en.fm E M C C o m p o n e n t s REMINDERS FOR USING THESE PRODUCTS Before using these products, be sure to request the delivery specifications. SAFETY REMINDERS Please pay sufficient attention to the warnings for safe designing when using this products. REMINDERS The storage period is within 12 months. Be sure to follow the storage conditions (temperature: 5 to 40°C, humidity: 10 to 75% RH or less). If the storage period elapses, the soldering of the terminal electrodes may deteriorate. Do not use or store in locations where there are conditions such as gas corrosion (salt, acid, alkali, etc.). Soldering corrections after mounting should be within the range of the conditions determined in the specifications. If overheated, a short circuit, performance deterioration, or lifespan shortening may occur. When embedding a printed circuit board where a chip is mounted to a set, be sure that residual stress is not given to the chip due to the overall distortion of the printed circuit board and partial distortion such as at screw tightening portions. Self heating (temperature increase) occurs when the power is turned ON, so the tolerance should be sufficient for the set thermal design. Carefully lay out the coil for the circuit board design of the non-magnetic shield type. A malfunction may occur due to magnetic interference. Use a wrist band to discharge static electricity in your body through the grounding wire. Do not expose the products to magnets or magnetic fields. Do not use products that have received any excessive mechanical shock such as by being dropped. The performance of the product may deteriorate or at the worst case open if coating materials are used, thus please assess the situation beforehand by tak-ing this factor into consideration. Due to the application of mechanical stress after mounting and handling such as contact, disconnection may occur. Do not use for a purpose outside of the contents regulated in the delivery specifications. The products listed on this specification sheet (the “Products”) are intended for incorporation into automobile and/or equipment to be installed in automobile on the grounds that (i) the Products are used in accordance with the conditions and scope stated in this specification sheet and (ii) said automobile and/or equipment involving the Products are used under a normal operation and use condition. Except for said incorporation into automobile and/or equipment installed in automobile, the Products are not designed or warranted to meet the requirements of the applications listed below, whose performance and/or quality require a more stringent level of safety or reliability, or whose failure, malfunction or trouble could cause serious damage to society, person or property. Please understand that we are not responsible for any damage or liability caused by use of the Products in any of the applications listed below or for any other use exceeding the range or conditions set forth in this specification sheet. If you intend to use the Products beyond the condition and scope of this specification sheet or in any of the applications listed below, please contact with our sales office. We will separately discuss with you applicable specification suitable for your intended use: 1) Aerospace/Aviation equipment, 2) Transportation equipment (e.g. train, ship), 3) Medical equipment which directly endanger human life, 4) Power-generation control equipment, 5) Atomic energy-related equipment, 6) Seabed equipment, 7) Transportation control equipment (e.g. train, ship), 8) Public information-processing equipment, 9) Military equipment, 10) Electric heating apparatus / burning equipment, 11) Disaster prevention/crime prevention equipment, 12) Safety equipment, or 13) Other applications that are not considered general-purpose applications. When designing your equipment involving the Products, you are kindly requested to take into consideration securing protection circuit/equipment or providing backup circuits, etc. in your equipment, to ensure higher safety. As stated above, the Products are intended for incorporation into automobile and/or equipment to be installed in automobile, however, it is not prohibited to use the Products for general electronic equipment which is not required the same high level or reliability as automobile, or which is unlikely to damage its users’ life, body and property or to cause extensive impact on society. Accordingly, all description in this specification sheet is applied if the Products are incorporated into general electronic equipment which is used for normal application under a normal operation and use condition. Please be sure to request delivery specifications that provide further details on the features and specifications of the products for proper and safe use. Please note that the contents may change without any prior notice due to reasons such as upgrading. (4/4) 20221027 cmf_automotive_signal_act1210e_en.fm
ACT1210E-241-2P-TL00 价格&库存
很抱歉,暂时无法提供与“ACT1210E-241-2P-TL00”相匹配的价格&库存,您可以联系我们找货
    库存:6000
