ACT1210G-800-2P-TL05
    TDK(东电化)
    FILTER_3.2X2.5MM_SM
    共模滤波器 FILTER_3.2X2.5MM_SM - -30%~+50% 70mA 2.4Ω 80μH@100KHz
ACT1210G-800-2P-TL05 数据手册
E M C C o m p o n e n t s Common mode filters Automotive signal line (for power train/safety) ACT series RoHS REACH SVHC-Free Cl Br Pb Halogen Free Lead Free AEC-Q200 ACT1210G type FEATURES Common mode filters for automotive Ethernet 1000BASE-T1, compatible with an operating temperature range of –40 to +125°C. This product is equivalent to the conventional product (ACT1210L-201) compatible with 100BASE-T1. This product achieves high S-parameter while realizing high reliability by metallizing terminals and laser welding using a proprietary method. Operating temperature range: –40 to +125°C OPEN ALLIANCE 1000BASE-T1 response Compliant with AEC-Q200 APPLICATION Ethernet system. PART NUMBER CONSTRUCTION ACT1210G - 800 - Inductance(typ.) (µH) Series • type name 2P - Number of lines TL 05 Packaging style Internal code CHARACTERISTICS SPECIFICATION TABLE Common mode inductance [100kHz] DC resistance Insulation resistance Rated current Rated voltage Part No. (µH) 80 ( )max. 2.4 (M )min. 10 (mA)max. 70 (V)max. 80 ACT1210G-800-2P-TL05 Tolerance +50/–30% Derating Rated current (mA) 80 60 40 20 0 0 25 50 75 Ambient temperature(°C) 100 125 Measurement equipment Measurement item Product No. Common mode inductance 4294A DC resistance 4338A Insulation resistance 4339A * Equivalent measurement equipment may be used. Manufacturer Keysight Technologies Keysight Technologies Keysight Technologies Please be sure to request delivery specifications that provide further details on the features and specifications of the products for proper and safe use. Please note that the contents may change without any prior notice due to reasons such as upgrading. (1/4) 20190924 cmf_automotive_signal_act1210g_en.fm E M C C o m p o n e n t s ACT1210G type Sdd21 Scc21 0 0 Sdd21 –10 OPEN ALLIANCE Scc21 (dB) Sdd21 (dB) –1 –2 –3 –4 –30 OPEN ALLIANCE –40 –5 10 100 Frequency (MHz) –10 –20 Sdd11 OPEN ALLIANCE Sdd22 –30 –40 100 Frequency (MHz) 1000 Ssd21, Ssd12 (dB) 0 –50 10 100 Frequency (MHz) 1000 Ssd21, Ssd12 0 –20 Scc21 –50 10 1000 Sdd11, Sdd22 Sdd11, Sdd22 (dB) –20 –40 –60 Ssd12 OPEN ALLIANCE Ssd21 –80 –100 10 100 Frequency (MHz) 1000 Measurement equipment Product No. Manufacturer E5071C Keysight Technologies * Equivalent measurement equipment may be used. Please be sure to request delivery specifications that provide further details on the features and specifications of the products for proper and safe use. Please note that the contents may change without any prior notice due to reasons such as upgrading. (2/4) 20190924 cmf_automotive_signal_act1210g_en.fm E M C C o m p o n e n t s ACT1210G type SHAPE & DIMENSIONS PACKAGING STYLE REEL DIMENSIONS 3.9max. 2.0±0.5 4 2 3 2 typ. 2.5max. ø100±1 2.5±0.2 1 1.0 0.6 0.6 ø13.0±0.2 3.2±0.2 0.5 4x 0.1 CZ 13.5±0.5 ø21.0±0.8 17.5±1 ø330±2 Dimensions in mm Dimensions in mm 2±0.05 4±0.1 2.0 B 4.1 5.5±0.05 1.6 0.4 1.5 +0.1 –0 12+0.3/–0.1 Sprocket hole 0.35±0.1 1.75±0.1 TAPE DIMENSIONS RECOMMENDED LAND PATTERN Dimensions in mm A K Cavity 4±0.1 CIRCUIT DIAGRAM 1 4 2 3 Dimensions in mm Type ACT1210G A 2.85±0.1 B 4.2±0.1 K 2.7±0.1 • No polarity PACKAGE QUANTITY Package quantity 6,000 pcs/reel RECOMMENDED REFLOW PROFILE Preheating Soldering Natural cooling Peak 245°C Temperature 230°C TEMPERATURE RANGE, INDIVIDUAL WEIGHT Operating temperature range –40 to +125°C Individual weight 0.075 g 230°C 180°C 5s 150°C 60 to 120s 40s max. Time Please be sure to request delivery specifications that provide further details on the features and specifications of the products for proper and safe use. Please note that the contents may change without any prior notice due to reasons such as upgrading. (3/4) 20190924 cmf_automotive_signal_act1210g_en.fm E M C C o m p o n e n t s REMINDERS FOR USING THESE PRODUCTS Before using these products, be sure to request the delivery specifications. SAFETY REMINDERS Please pay sufficient attention to the warnings for safe designing when using this products. REMINDERS The storage period is within 12 months. Be sure to follow the storage conditions (temperature: 5 to 40°C, humidity: 10 to 75% RH or less). If the storage period elapses, the soldering of the terminal electrodes may deteriorate. Do not use or store in locations where there are conditions such as gas corrosion (salt, acid, alkali, etc.). Before soldering, be sure to preheat components. The preheating temperature should be set so that the temperature difference between the solder temperature and chip temperature does not exceed 150°C. Soldering corrections after mounting should be within the range of the conditions determined in the specifications. If overheated, a short circuit, performance deterioration, or lifespan shortening may occur. When embedding a printed circuit board where a chip is mounted to a set, be sure that residual stress is not given to the chip due to the overall distortion of the printed circuit board and partial distortion such as at screw tightening portions. Self heating (temperature increase) occurs when the power is turned ON, so the tolerance should be sufficient for the set thermal design. Carefully lay out the coil for the circuit board design of the non-magnetic shield type. A malfunction may occur due to magnetic interference. Use a wrist band to discharge static electricity in your body through the grounding wire. Do not expose the products to magnets or magnetic fields. Do not use for a purpose outside of the contents regulated in the delivery specifications. The products listed on this catalog are intended for use in general electronic equipment (AV equipment, telecommunications equipment, home appliances, amusement equipment, computer equipment, personal equipment, office equipment, measurement equipment, industrial robots) under a normal operation and use condition. The products are not designed or warranted to meet the requirements of the applications listed below, whose performance and/or quality require a more stringent level of safety or reliability, or whose failure, malfunction or trouble could cause serious damage to society, person or property. If you intend to use the products in the applications listed below or if you have special requirements exceeding the range or conditions set forth in the each catalog, please contact us. (1) Aerospace/aviation equipment (2) Transportation equipment (electric trains, ships, etc.) (3) Medical equipment (4) Power-generation control equipment (5) Atomic energy-related equipment   (6) Seabed equipment (7) Transportation control equipment (8) Public information-processing equipment (9) Military equipment (10) Electric heating apparatus, burning equipment (11) Disaster prevention/crime prevention equipment (12) Safety equipment (13) Other applications that are not considered general-purpose applications When designing your equipment even for general-purpose applications, you are kindly requested to take into consideration securing protection circuit/device or providing backup circuits in your equipment. Please be sure to request delivery specifications that provide further details on the features and specifications of the products for proper and safe use. Please note that the contents may change without any prior notice due to reasons such as upgrading. (4/4) 20190924 cmf_automotive_signal_act1210g_en.fm
ACT1210G-800-2P-TL05 价格&库存
很抱歉,暂时无法提供与“ACT1210G-800-2P-TL05”相匹配的价格&库存,您可以联系我们找货
  • 1+16.076041+2.08950
  • 10+13.2342010+1.72013
  • 25+12.2451025+1.59157
  • 50+11.5440350+1.50045
  • 100+10.88413100+1.41467
  • 250+10.06943250+1.30878
  • 500+9.49515500+1.23414
  • 1000+9.491201000+1.23363
库存:19890
  • 77+10.8943077+1.41600
  • 100+10.72028100+1.39338
  • 250+7.95111250+1.03345
  • 500+7.81993500+1.01640
  • 1000+7.689601000+0.99946
库存:2786
  • 1+7.35412
  • 10+6.18988
  • 30+5.54954
库存:58
库存:2786
