ACT1210L-101-2P-TL00 数据手册
E M C
C o m p o n e n t s
Common mode filters
Automotive signal line (for power train/safety)
ACT series
RoHS
REACH
SVHC-Free
Cl
Br
Pb
Halogen
Free
Lead
Free
AEC-Q200
ACT1210L-101 type
FEATURES
Common mode filters for automotive A2B (Audiobus), compatible with an operating temperature range of –40 to +125°C.
A2B for ACT1210L by unique method, maintenance and L high 100µH is a product which realized high Characterization of mode conversion characteristics Scd21.
Operating temperature range: –40 to +125°C (including self-temperature rise)
Compliant with AEC-Q200
APPLICATION
A2B system.
Circuit diagram (draft)
Application guides: Automotive (xEV), Car Infotainment
PART NUMBER CONSTRUCTION
ACT1210L
Series • type name
101
Inductance(typ.)
(µH)
2P
Number of lines
TL
00
Packaging style
Internal code
CHARACTERISTICS SPECIFICATION TABLE
Common mode inductance
[100kHz]
(µH)
Tolerance
100
+50/–30%
DC resistance
Insulation resistance
Rated current
Rated voltage
Part No.
( )max.
1.5
(M )min.
10
(mA)max.
150
(V)max.
80
Measurement equipment
Measurement item
Product No.
4294A
DC resistance
4338A
4339A
* Equivalent measurement equipment may be used.
Manufacturer
Keysight Technologies
Please be sure to request delivery specifications that provide further details on the features and specifications of the products for proper and safe use.
Please note that the contents may change without any prior notice due to reasons such as upgrading.
(1/4)
20181004
cmf_automotive_signal_act1210l-101_en.fm
E M C
C o m p o n e n t s
ACT1210L-101 type
IMPEDANCE VS. FREQUENCY CHARACTERISTICS
100000
101 Common mode
Impedance (Ω)
10000
1000
100
101 Differential mode
10
1
1
10
100
1000
Frequency (MHz)
Product No.
Manufacturer
4991A
(2/4)
20181004
E M C
C o m p o n e n t s
ACT1210L-101 type
SHAPE & DIMENSIONS
PACKAGING STYLE
REEL DIMENSIONS
3.9max.
2.0±0.5
4
2
3
2 typ.
2.5max.
ø100±1
2.5±0.2
1
1.0
0.6
0.5
ø13.0±0.2
13.5±0.5
ø21.0±0.8
4x
0.1 CZ
17.5±1
ø330±2
Dimensions in mm
Dimensions in mm
TAPE DIMENSIONS
Sprocket
hole
1.6
0.4
0.35±0.1
1.5 +0.1
–0
2±0.05
4±0.1
12+0.3/–0.1
RECOMMENDED LAND PATTERN
2.0
B
4.1
5.5±0.05
3.2±0.2
1.75±0.1
0.6
Dimensions in mm
A
K
Cavity
4±0.1
CIRCUIT DIAGRAM
1
4
2
3
Dimensions in mm
Type
ACT1210L-101
A
2.85±0.1
B
4.2±0.1
K
2.7±0.1
• No polarity
PACKAGE QUANTITY
Package quantity
6,000 pcs/reel
RECOMMENDED REFLOW PROFILE
Preheating
Soldering
Natural
cooling
Peak
245°C
Temperature
230°C
TEMPERATURE RANGE, INDIVIDUAL WEIGHT
Operating
Individual
temperature range
weight
–40 to +125°C
0.075 g
The storage temperature range is for after the assembly.
230°C
180°C
5s
150°C
60 to 120s
40s max.
Time
(3/4)
20181004
E M C
C o m p o n e n t s
REMINDERS FOR USING THESE PRODUCTS
Before using these products, be sure to request the delivery specifications.
SAFETY REMINDERS
Please pay sufficient attention to the warnings for safe designing when using this products.
REMINDERS
The storage period is less than 12 months. Be sure to follow the storage conditions (temperature: 5 to 40°C, humidity: 10 to 75% RH or
less).
If the storage period elapses, the soldering of the terminal electrodes may deteriorate.
Do not use or store in locations where there are conditions such as gas corrosion (salt, acid, alkali, etc.).
Before soldering, be sure to preheat components.
The preheating temperature should be set so that the temperature difference between the solder temperature and chip temperature
does not exceed 150°C.
Soldering corrections after mounting should be within the range of the conditions determined in the specifications.
If overheated, a short circuit, performance deterioration, or lifespan shortening may occur.
When embedding a printed circuit board where a chip is mounted to a set, be sure that residual stress is not given to the chip due to
the overall distortion of the printed circuit board and partial distortion such as at screw tightening portions.
Self heating (temperature increase) occurs when the power is turned ON, so the tolerance should be sufficient for the set thermal
design.
Carefully lay out the coil for the circuit board design of the non-magnetic shield type.
A malfunction may occur due to magnetic interference.
Use a wrist band to discharge static electricity in your body through the grounding wire.
Do not expose the products to magnets or magnetic fields.
Do not use for a purpose outside of the contents regulated in the delivery specifications.
The products listed on this catalog are intended for use in general electronic equipment (AV equipment, telecommunications equipment, home appliances, amusement equipment, computer equipment, personal equipment, office equipment, measurement equipment, industrial robots) under a normal operation and use condition.
The products are not designed or warranted to meet the requirements of the applications listed below, whose performance and/or quality require a more stringent level of safety or reliability, or whose failure, malfunction or trouble could cause serious damage to society,
person or property.
If you intend to use the products in the applications listed below or if you have special requirements exceeding the range or conditions
set forth in the each catalog, please contact us.
(1) Aerospace/aviation equipment
(2) Transportation equipment (electric trains, ships, etc.)
(3) Medical equipment
(4) Power-generation control equipment
(5) Atomic energy-related equipment
(6) Seabed equipment
(7) Transportation control equipment
(8) Public information-processing equipment
(9) Military equipment
(10) Electric heating apparatus, burning equipment
(11) Disaster prevention/crime prevention equipment
(12) Safety equipment
(13) Other applications that are not considered general-purpose
applications
When designing your equipment even for general-purpose applications, you are kindly requested to take into consideration securing protection circuit/device or providing backup circuits in your equipment.
(4/4)
20181004
ACT1210L-101-2P-TL00 价格&库存
很抱歉,暂时无法提供与“ACT1210L-101-2P-TL00”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+3.57390
- 10+2.93040
- 1200+2.90110
- 国内价格 香港价格
- 8+7.853358+1.02091
- 10+7.4158810+0.96404
- 25+7.0765625+0.91993
- 100+7.06218100+0.91806
- 250+7.04779250+0.91619
- 500+7.03256500+0.91421
- 1000+7.018181000+0.91234
- 3000+7.003793000+0.91047
- 6000+6.989416000+0.90860
- 国内价格 香港价格
- 1+15.427701+2.00530
- 10+13.0680010+1.69860
- 25+12.0978025+1.57250
- 100+9.29490100+1.20820
- 250+8.68410250+1.12880
- 500+8.24090500+1.07120
- 1000+7.725801000+1.00420
- 2500+7.474302500+0.97150
- 6000+7.294606000+0.94820
