E M C
C o m p o n e n t s
Common mode filters
Automotive signal line (for power train/safety)
ACT series
Pb
RoHS
REACH
SVHC-Free
Lead
Free
AEC-Q200
ACT45B type
FEATURES
Compatible with an operating temperature range of –40 to +150°C, so can be used for vehicle devices requiring compatibility with high
temperatures.
When mounting, the terminal and winding tape splicing part do not fuse.
Operating temperature range: –40 to +150°C
Compliant with AEC-Q200
APPLICATION
CAN-BUS, FAXs, modems, ISDNs, etc.
Application guides: Automotive (xEV), Car Infotainment
PART NUMBER CONSTRUCTION
ACT45B
Series • type name
110
Inductance(typ.)
(µH)
2P
Number of lines
TL
003
Packaging style
Internal code
CHARACTERISTICS SPECIFICATION TABLE
Common mode
impedance
[10MHz]
( )min. ( )typ.
300
600
500
1200
1000
2800
2000
5800
Common mode
inductance
[100kHz]
(µH)+50/–30%
11
22
51
100
Stray
inductance
[100kHz]
(µH)typ.
0.05
0.08
0.15
0.20
DC
resistance
Rated
current
Insulation
resistance
Rated
voltage
( )max.
0.6
1.0
1.0
2.0
(A)max.
0.25
0.2
0.2
0.15
(M )min.
10
10
10
10
(V)max.
50
50
50
50
Part No.
ACT45B-110-2P-TL003
ACT45B-220-2P-TL003
ACT45B-510-2P-TL003
ACT45B-101-2P-TL003
Measurement equipment
Measurement item
Product No.
Common mode impedance
4991A
Common mode inductance
4294A
DC resistance
4338A
Insulation resistance
4339A
* Equivalent measurement equipment may be used.
Manufacturer
Keysight Technologies
Please be sure to request delivery specifications that provide further details on the features and specifications of the products for proper and safe use.
Please note that the contents may change without any prior notice due to reasons such as upgrading.
(1/4)
20181015
cmf_automotive_signal_act45b_en.fm
E M C
C o m p o n e n t s
ACT45B type
IMPEDANCE VS. FREQUENCY CHARACTERISTICS
100000
510 Common mode
101 Common mode
10000
Impedance (Ω)
220 Common mode
1000
510 Differential mode
110 Common mode
101 Differential mode
100
220 Differential mode
110 Differential mode
10
1
10
100
1000
Frequency (MHz)
Product No.
Manufacturer
4991A
(2/4)
20181015
E M C
C o m p o n e n t s
ACT45B type
SHAPE & DIMENSIONS
PACKAGING STYLE
REEL DIMENSIONS
4.5±0.2
4
2
3
2.0±0.5
2 typ.
Marking
2.8±0.2
ø100±1
3.2±0.2
1
1.0
0.65±0.1
0.7±0.1
Dimensions in mm
ø13.0±0.2
13.5±0.5
ø21.0±0.8
17.5±1
ø330±2
RECOMMENDED LAND PATTERN
Dimensions in mm
1.55±0.05
2.0±0.05
4.0±0.1
Sprocket
hole
5.5±0.05
0.3±0.05
1.75±0.1
3.4
1.6
TAPE DIMENSIONS
3.2
B
12.0±0.2
5.9
Dimensions in mm
K
8.0±0.1
CIRCUIT DIAGRAM
1
4
2
3
Cavity
A
Dimensions in mm
Type
ACT45B
A
3.6±0.1
B
4.9±0.1
K
3.05±0.1
• No polarity
Blank
160min.
Products
Blank
400 to 500
RECOMMENDED REFLOW PROFILE
Start
Preheating
Soldering
End
Natural
cooling
Drawing direction
Peak
Dimensions in mm
245°C
Temperature
230°C
230°C
PACKAGE QUANTITY
Package quantity
2,500 pcs/reel
180°C
5s
150°C
60 to 120s
40s max.
TEMPERATURE RANGE, INDIVIDUAL WEIGHT
Operating
Storage
temperature range
temperature range
–40 to +150 °C
–40 to +150 °C
The storage temperature range is for after the assembly.
Individual
weight
0.14 g
Time
(3/4)
20181015
E M C
C o m p o n e n t s
REMINDERS FOR USING THESE PRODUCTS
Before using these products, be sure to request the delivery specifications.
SAFETY REMINDERS
Please pay sufficient attention to the warnings for safe designing when using this products.
REMINDERS
The storage period is less than 12 months. Be sure to follow the storage conditions (temperature: 5 to 40°C, humidity: 10 to 75% RH or
less).
If the storage period elapses, the soldering of the terminal electrodes may deteriorate.
Do not use or store in locations where there are conditions such as gas corrosion (salt, acid, alkali, etc.).
Before soldering, be sure to preheat components.
The preheating temperature should be set so that the temperature difference between the solder temperature and chip temperature
does not exceed 150°C.
Soldering corrections after mounting should be within the range of the conditions determined in the specifications.
If overheated, a short circuit, performance deterioration, or lifespan shortening may occur.
When embedding a printed circuit board where a chip is mounted to a set, be sure that residual stress is not given to the chip due to
the overall distortion of the printed circuit board and partial distortion such as at screw tightening portions.
Self heating (temperature increase) occurs when the power is turned ON, so the tolerance should be sufficient for the set thermal
design.
Carefully lay out the coil for the circuit board design of the non-magnetic shield type.
A malfunction may occur due to magnetic interference.
Use a wrist band to discharge static electricity in your body through the grounding wire.
Do not expose the products to magnets or magnetic fields.
Do not use for a purpose outside of the contents regulated in the delivery specifications.
The products listed on this catalog are intended for use in general electronic equipment (AV equipment, telecommunications equipment, home appliances, amusement equipment, computer equipment, personal equipment, office equipment, measurement equipment, industrial robots) under a normal operation and use condition.
The products are not designed or warranted to meet the requirements of the applications listed below, whose performance and/or quality require a more stringent level of safety or reliability, or whose failure, malfunction or trouble could cause serious damage to society,
person or property.
If you intend to use the products in the applications listed below or if you have special requirements exceeding the range or conditions
set forth in the each catalog, please contact us.
(1) Aerospace/aviation equipment
(2) Transportation equipment (electric trains, ships, etc.)
(3) Medical equipment
(4) Power-generation control equipment
(5) Atomic energy-related equipment
(6) Seabed equipment
(7) Transportation control equipment
(8) Public information-processing equipment
(9) Military equipment
(10) Electric heating apparatus, burning equipment
(11) Disaster prevention/crime prevention equipment
(12) Safety equipment
(13) Other applications that are not considered general-purpose
applications
When designing your equipment even for general-purpose applications, you are kindly requested to take into consideration securing protection circuit/device or providing backup circuits in your equipment.
(4/4)
20181015
ACT45B-510-2P-TL003 价格&库存
很抱歉,暂时无法提供与“ACT45B-510-2P-TL003”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 5+2.52840
- 50+1.75420
- 500+1.52880
- 1000+1.47000
- 2500+1.43080
- 25000+1.41649
