ADL2012-1R5M
ADL2012-1R5M
    TDK(东电化)
    高频电感 1.5μH ±20% 210mΩ 620mA 1.65mm 2.20 x 1.25mm 0805
ADL2012-1R5M 数据手册
I N D U C T O R S Inductors for decoupling circuits Wound ferrite ADL series (for automotive) RoHS REACH SVHC-Free Cl Br Pb Halogen Free Lead Free AEC-Q200 ADL2012 type FEATURES Small size and thin form factor (mounting area 2.2x1.25mm, height 1.75mm max.) Achieving broadband impedance characteristics and good DC superimposition characteristics as the result of an original coiled wiring design and original structure Ensuring consistent high quality and reliability as the result of a completely automated manufacturing process Operating temperature range: –40 to +125°C (including self-temperature rise) Compliant with AEC-Q200 APPLICATION Inductor for use with separate signal and power lines in in-vehicle PoC (Power Over Coax) PART NUMBER CONSTRUCTION ADL 2012 Series name L×W dimensions 2.2x1.25 mm - 1R5 M Inductance (µH) Inductance tolerance - T 01 Packaging style Internal code CHARACTERISTICS SPECIFICATION TABLE L (µH) Tolerance L measuring frequency DC resistance Self-resonant frequency (MHz) ( )max. (MHz)typ. Rated current Isat (mA)typ. Part No. Itemp (mA)typ. 85deg.C 880 105deg.C 1.5 ±20% 1 0.21 450 1200 620 ADL2012-1R5M-T01  Rated current: smaller value of either Isat or Itemp. Isat: when based on the inductance change rate (30% below the initial L value) Itemp: When based on the temperature increase (temperature increase due to self heating : 40°C at ambient temperature of 85°C, 20°C at ambient temperature of 105°C, ) Measurement equipment Measurement item Product No. Inductance E4991A DC resistance 4338A * Equivalent measurement equipment may be used. Manufacturer Keysight Technologies Keysight Technologies Please be sure to request delivery specifications that provide further details on the features and specifications of the products for proper and safe use. Please note that the contents may change without any prior notice due to reasons such as upgrading. (1/4) 20210823 inductor_automotive_decoupling_adl2012_en.fm I N D U C T O R S ADL2012 type IMPEDANCE VS. FREQUENCY CHARACTERISTICS 10000 Impedance(Ω) 1000 100 10 1 1 10 100 1000 1000 Frequency(MHz) DERATING 1000 900 800 Rated Current (mA) 700 600 500 400 300 200 100 0 0 25 50 75 Temperature(°C) 100 125 Please be sure to request delivery specifications that provide further details on the features and specifications of the products for proper and safe use. Please note that the contents may change without any prior notice due to reasons such as upgrading. 150 (2/4) 20210823 inductor_automotive_decoupling_adl2012_en.fm I N D U C T O R S ADL2012 type SHAPE & DIMENSIONS PACKAGING STYLE REEL DIMENSIONS 2.20±0.10 1.25±0.20 60+1/–0 (0.35) 1.65±0.10 2.0±0.5 ø13.0±0.2 9+1/–0 (ø21) (0.43) 13±1.4 ø180+0/–3 Dimensions in mm Dimensions in mm 1.5 +0.1 –0 2.0±0.1 4.0±0.1 1.5 B 8.0+0.3/-0.1 RECOMMENDED LAND PATTERN 4.0±0.1 A K 3.5±0.1 Sprocket hole 0.25±0.05 1.75±0.1 TAPE DIMENSIONS Cavity Dimensions in mm 1.1 1.0 1.1 Type ADL2012 Dimensions in mm A (1.55) B (2.4) K (1.9) 500 to 560min. RECOMMENDED REFLOW PROFILE Preheating Soldering 160min. Taping 440min. Natural cooling Peak Drawing direction T: Temperature 245°C 230°C Dimensions in mm 230°C PACKAGE QUANTITY Package quantity 2,000 pcs/reel 180°C 5s max. 150°C 90 to 120s 40s TEMPERATURE RANGE, INDIVIDUAL WEIGHT Operating Storage Individual temperature range temperature range weight –40 to +125 °C –40 to +125 °C 18 mg  Operating temperature range includes self-temperature rise. t: Time Please be sure to request delivery specifications that provide further details on the features and specifications of the products for proper and safe use. Please note that the contents may change without any prior notice due to reasons such as upgrading. (3/4) 20210823 inductor_automotive_decoupling_adl2012_en.fm I N D U C T O R S REMINDERS FOR USING THESE PRODUCTS Before using these products, be sure to request the delivery specifications. SAFETY REMINDERS Please pay sufficient attention to the warnings for safe designing when using this products. REMINDERS The storage period is within 12 months. Be sure to follow the storage conditions (temperature: 5 to 40°C, humidity: 10 to 75% RH or less). If the storage period elapses, the soldering of the terminal electrodes may deteriorate. Do not use or store in locations where there are conditions such as gas corrosion (salt, acid, alkali, etc.). Before soldering, be sure to preheat components. The preheating temperature should be set so that the temperature difference between the solder temperature and chip temperature does not exceed 150°C. Soldering corrections after mounting should be within the range of the conditions determined in the specifications. If overheated, a short circuit, performance deterioration, or lifespan shortening may occur. When embedding a printed circuit board where a chip is mounted to a set, be sure that residual stress is not given to the chip due to the overall distortion of the printed circuit board and partial distortion such as at screw tightening portions. Self heating (temperature increase) occurs when the power is turned ON, so the tolerance should be sufficient for the set thermal design. Carefully lay out the coil for the circuit board design of the non-magnetic shield type. A malfunction may occur due to magnetic interference. Use a wrist band to discharge static electricity in your body through the grounding wire. Do not expose the products to magnets or magnetic fields. Do not use for a purpose outside of the contents regulated in the delivery specifications. The products described in this catalog are intended to be installed in automobiles or automotive electronic equipment (AV equipment, telecommunications equipment, home appliances, amusement equipment, computer equipment, personal equipment, office equipment, measurement equipment, industrial robots) and to be used in automobiles (including the case where the said automotive product is mounted in a vehicle) or standard applications as general electronic equipment in automotive applications or standard applications as general electronic equipment in automotive applications in accordance with the scope and conditions described in this specification, while the said automotive or general electronic equipment including the said product is intended to be used in the usual operation and usage methods, respectively. Other than automotive or automotive products are not designed or warranted to meet the requirements of the applications listed below, whose performance and/or quality requires a more stringent level of safety or reliability, or whose failure, malfunction or defect could cause serious damage to society, person or property. Please understand that we are not responsible for any damage or liability caused by use of the products in any of the applications below or for any other use exceeding the range or conditions set forth in this specification sheet. If you intend to use the products in the applications listed below or if you have special requirements exceeding the range or conditions set forth in this specification, please contact us. (1) Aerospace/aviation equipment (2) Transportation equipment (electric trains, ships, etc.) (3) Medical equipment (4) Power-generation control equipment (5) Atomic energy-related equipment   (6) Seabed equipment (7) Transportation control equipment (8) Public information-processing equipment (9) Military equipment (10) Electric heating apparatus, burning equipment (11) Disaster prevention/crime prevention equipment (12) Safety equipment (13) Other applications that are not considered general-purpose applications When designing your equipment even for general-purpose applications, you are kindly requested to take into consideration securing protection circuit/device or providing backup circuits in your equipment. Please be sure to request delivery specifications that provide further details on the features and specifications of the products for proper and safe use. Please note that the contents may change without any prior notice due to reasons such as upgrading. (4/4) 20210823 inductor_automotive_decoupling_adl2012_en.fm
ADL2012-1R5M 价格&库存
很抱歉,暂时无法提供与“ADL2012-1R5M”相匹配的价格&库存,您可以联系我们找货
