ADL3225VT-4R7M-TL000 数据手册
I N D U C T O R S
Inductors for decoupling circuits
Wound ferrite
ADL-VF series (for automotive)
ADL3225VF type
■FEATURES
⃝Small size and thin form factor (mounting area 3.2 x 2.5 mm, height 2.5mm max.)
⃝Achieving broadband impedance characteristics and good DC superimposition characteristics as the result of an original
coiled wiring design and original structure
⃝Operating temperature range: -55 to +155°C(including self-heating)
⃝Compliant with AEC-Q200
■APPLICATION
⃝Inductor for use with separate signal and power lines in in-vehicle PoC (Power Over Coax)
■PART NUMBER CONSTRUCTION
ADL
3225
VF
Series
name
L×W×H dimensions
3.2×2.5×2.5 mm
Characteristic type
R49
M
Inductance
(μH)
Inductance
tolerance
TL
000
Packaging style
Internal code
■CHARACTERISTICS SPECIFICATION TABLE
L
L measuring
frequency
DC resistance
Isat
Itemp
Part No.
(mA)typ.
(mA)typ.
(μH)
Tolerance
(kHz)
(Ω)max.
25°C
105°C
125°C
0.49 ±20%
100
0.11
2000
1600
1250
ADL3225VF-R49M-TL000
* Isat. : Current value at -30% inductance change (relative to nominal value) in DC superposition.
Itemp. 105℃: Current value at 50℃ self-heating when a product is mounted on the board for self-heating measurement.
Itemp. 125℃: Current value at 30℃ self-heating when a product is mounted on the board for self-heating measurement.
Measurement equipment
Measurement item
Product No. *
Inductance
E4990A
DC resistance
4338A
* Equivalent measurement equipment may be used.
Manufacturer
Keysight Technologies
Please be sure to request delivery specifications that provide further details on the features and specifications of the products for proper and safe use.
Please note that the contents may change without any prior notice due to reasons such as upgrading.
(1/5)
20241203
inductor_automotive_decoupling_adl3225vf_en
I N D U C T O R S
ADL3225VF type
■IMPEDANCE VS. FREQUENCY CHARACTERISTICS
10000
Impedance(Ω)
1000
100
10
R49M
1
1
10
100
1000
Frequency(MHz)
(2/5)
20241203
I N D U C T O R S
ADL3225VF type
■SHAPE & DIMENSIONS
3.9max.
2.5max.
2.5±0.2
3.2±0.2
4x
0.1 CZ
3.2±0.2
Dimensions in mm
■RECOMMENDED LAND PATTERN
4
4
2
2
3
No directionality
1.6
1
0.4
Pin#1
Signal line &
resist pattern
Signal line &
resist pattern
3
2.0
4.1
Dimensions in mm
(3/5)
20241203
I N D U C T O R S
ADL3225VF type
■RECOMMENDED REFLOW PROFILE
Preheating
■TEMPERATURE RANGE, INDIVIDUAL WEIGHT
Soldering
Natural
cooling
Peak
Operating
temperature range *
Storage
temperature range
Individual
weight
-55 to +155 °C
-55 to +155 °C
* Operating temperature range includes self-heating.
0.080 g
245°C
Temperature
230°C
230°C
180°C
5s max.
150°C
60 to 120s
10 to 30s
Time
■PACKAGING STYLE
Sprocket
hole
ø13+0.3/-0.2
2.0±0.05
4.0±0.1
12+0.3/-0.1
+0.1
1.5 –0
B
ø100+1.0/-1.5
0.4±0.1
1.75±0.1
(2)
2.0±0.5
5.5±0.05
□TAPE DIMENSIONS
□REEL DIMENSIONS
A
K
4.0±0.1
Cavity
Dimensions in mm
13.5±0.5
Type
A
B
K
ADL3225VF
(2.85)
(4.2)
(2.7)
(ø21)
Blank
160min.
ø330+2.0/-2.5
Products
Blank
400 to 500
Dimensions in mm
Start
End
Drawing direction
Dimensions in mm
□PACKAGE QUANTITY
Package quantity
6000 pcs/reel
(4/5)
20241203
I N D U C T O R S
REMINDERS FOR USING THESE PRODUCTS
Before using these products, be sure to request the delivery specifications.
SAFETY REMINDERS
Please pay sufficient attention to the warnings for safe designing when using this products
REMINDERS
⃝The storage period is within 12 months. Be sure to follow the storage conditions (temperature: 5 to 40°C, humidity: 10 to 75%
RH or less).
If the storage period elapses, the soldering of the terminal electrodes may deteriorate.
⃝Do not use or store in locations where there are conditions such as gas corrosion (salt, acid, alkali, etc.).
⃝Soldering corrections after mounting should be within the range of the conditions determined in the specifications.
If overheated, a short circuit, performance deterioration, or lifespan shortening may occur.
⃝When embedding a printed circuit board where a chip is mounted to a set, be sure that residual stress is not given to the chip
due to the overall distortion of the printed circuit board and partial distortion such as at screw tightening portions.
⃝Self heating (temperature increase) occurs when the power is turned ON, so the tolerance should be sufficient for the set
thermal design.
⃝Carefully lay out the coil for the circuit board design of the non-magnetic shield type.
A malfunction may occur due to magnetic interference.
⃝Use a wrist band to discharge static electricity in your body through the grounding wire.
⃝Do not expose the products to magnets or magnetic fields.
⃝Do not use products that have received any excessive mechanical shock such as by being dropped.
⃝The performance of the product may deteriorate or at the worst case open if coating materials are used, thus please assess the
situation beforehand by tak-ing this factor into consideration.
⃝Due to the application of mechanical stress after mounting and handling such as contact, disconnection may occur.
⃝Do not use for a purpose outside of the contents regulated in the delivery specifications.
⃝The products listed on this specification sheet (the “Products”) are intended for incorporation into automobile and/or equipment
to be installed in automobile on the grounds that (i) the Products are used in accordance with the conditions and scope stated
in this specification sheet and (ii) said automobile and/or equipment involving the Products are used under a normal operation
and use condition.
Except for said incorporation into automobile and/or equipment installed in automobile, the Products are not designed or
warranted to meet the requirements of the applications listed below, whose performance and/or quality require a more stringent
level of safety or reliability, or whose failure, malfunction or trouble could cause serious damage to society, person or property.
Please understand that we are not responsible for any damage or liability caused by use of the Products in any of the applications
listed below or for any other use exceeding the range or conditions set forth in this specification sheet.
If you intend to use the Products beyond the condition and scope of this specification sheet or in any of the applications listed
below, please contact with our sales office.
We will separately discuss with you applicable specification suitable for your intended use.
(1) Aerospace/aviation equipment
(2) Transportation equipment (electric trains, ships, etc.)
(3) Medical equipment
(4) Power-generation control equipment
(5) Atomic energy-related equipment
(6) Seabed equipment
(7) Transportation control equipment
(8) Public information-processing equipment
(9) Military equipment
(10) Electric heating apparatus, burning equipment
(11) Disaster prevention/crime prevention equipment
(12) Safety equipment
(13) Other applications that are not considered general-purpose
applications
When designing your equipment even for general-purpose applications, you are kindly requested to take into consideration
securing protection circuit/device or providing backup circuits in your equipment.
In addition, although the products listed in this specification are intended for use in automotive applications as described above,
they are not prohibited to use in general electronic equipment, whose performance and/or quality doesn’t require a more stringent
level of safety or reliability, or whose failure, malfunction or defect could not cause serious damage to society, person or property.
Therefore, the description of this caution will be applied, when the products are used in general electronic equipment under a
normal operation and usage conditions.
(5/5)
20241203
ADL3225VT-4R7M-TL000 价格&库存
很抱歉,暂时无法提供与“ADL3225VT-4R7M-TL000”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+3.49800
- 100+2.79400
- 500+2.54100
- 1500+2.39800
- 3000+2.27700
- 6000+2.17800
- 国内价格
- 1+3.99790
- 10+3.42850
- 30+3.05980
- 100+2.81440
- 500+2.53780
- 1000+2.40840
- 国内价格
- 1+4.71960
- 10+3.82320
- 30+3.38040
- 100+2.93760
- 500+2.67840
- 1000+2.53800
- 国内价格 香港价格
- 6000+5.162926000+0.66989
- 12000+5.0671812000+0.65747
- 国内价格 香港价格
- 1+11.104161+1.44076
- 10+9.1380210+1.18565
- 25+8.4566425+1.09725
- 50+7.9734750+1.03455
- 100+7.51705100+0.97533
- 250+6.95410250+0.90229
- 500+6.55736500+0.85082
- 1000+6.202231000+0.80474
