ALD Series
LED Backlighting DC-DC Converters
Features
u Two to Five Strings
u 12VDC Input
u Analog or Resistive Dimming
u Low Profile
u Off the shelf solution
Key Market Segments & Applications
Specifications
Model
Number of LED Strings
DC Input
Input Current Max.(norm./inhib.)
Output Current (each string)
Dimming Frequency
Analog Dim. (Dark to Light) Vbr
Analog Dim. (Dark to Light) Rbr
PWM Dimming
Remote On/Off (Vrmt)
Maximum Output Voltage
Overvoltage Alarm
Operating Temperature
Storage Temperature
Maximum Humidity
(1)
Cooling
Input to Output Isolation
Vibration
Shock
Weight (Typ)
Size (LxWxH)
Warranty
VDC
A
mA
Hz
VDC
kΩ
VDC
VDC
VDC
VDC
°C
°C
%RH
g
mm
Yr
ALD-214012PJ111
2
ALD-310012PJ125
ALD-414012PJ126
ALD-514012PJ134
3
4
5
10.8 - 13.2VDC
1.2 / 0.001A
1.5 / 0.001A
2.0 / 0.001A
2.5 / 0.001A
140mA
100mA
140mA
140mA
200Hz
225Hz
200Hz
200Hz
2.5V to 0V
0V to 4V (Vbr2)
2.5V to 0V
2.5V to 0V
50 - 0kΩ
0 - 10kΩ
50 - 0kΩ
50 - 0kΩ
2.5V to 0V
0 to 2.5V
2.5V to 0V
2.5V to 0V
OFF: 0V - 0.4V, ON: 2.5V - Vin
44V
38V
44V
44V
Approximately 5V if any one string is open
-30 to +85°C
-40 to +85°C
95%RH (Storage or Operating)
Convection
None
588m/s2 (60G) 11ms Half-sine wave once each axis X,Y,Z,-X,-Y,-Z total 6 times
5~10Hz Amplitude 10mm 10~200Hz Accelerated Velocity 21.6m/s2(2.2G)
9g
9g
22g
22g
85 x 21.5 x 5mm
85 x 21.5 x 5.5mm
100 x 50 x 5.2mm
100 x 50 x 5.2mm
One Year
Note: See Installation Manual for full details, test methods of parameters and application notes
(1) non condensing
1-800-526-2324 • www.us.tdk-lambda.com/lp/
7
ALD Series
Outline Drawing
ALD-214012PJ111
any parts and pattering inhibit area except GND pattern.
TOP View
CP3:Freq.
Check Pad
(ii)
(i)
NTH 2-! φ3.5
21.5
8
13.5±0.3
8
85
77±0.3
(1.0)
(1.1)
(1.0)
8
8
(iii)
(71.3)
4.0 ± 0.4
SIDE View
85. 0± 0.5
4.0 ± 0.4
2- φ3.5 ± 0.2
77. 0± 0.4
(4)
1
(ii)
(4) 13.5 ± 0.4
1
CN2
example (refer to *1-1 Marking)
Product Name,Lot No.,name of origin
CN1
BOTTOM View
ALD214012PJ111
8Z01 JAPAN
21.5 ± 0.5
4.0 typ.
5.2 max.
ALD-310012PJ125 TOP View
CP6
(8)
(8)
(iii)
(i)
any
partsscrew
and pattering
area
GND above
pattern.
When LED driver is fixing, please
confirm
head and inhibit
plate form
is except
located within
hatching
area include any tolerances. Please insulate it with the case such as sheet metals.
Tolerance is ±0.5mm unless otherwise specified.
Qty.
Remark
1
JST
8
corresponding connector
5.5Max.
Item/Material
SM08B-SRSS-TB(LF)(SN)
(i)
ALD-414012PJ126
No. & Part Description
ALD-514012PJ134
(i) SIDE
InputView
Connector: CN1
Unit in mm
Mass:9g(max)
TOP View
SHR-08V-S-B
8
Output Connector: CN3
SM06B-SRSS-TB(LF)(SN)
1
JST
(iii)
Print Cicuit Board: PCB
FR-4
1
UL94V-0 t=1.0mm
8
(ii)
SHR-06V-S-B
Tolerance is ±0.5mm
unless otherwise
specified.
Unit in mm
Mass:22g max.
(1)
*CN2 is not installed.
anyNo.
parts
and pattering
inhibit area
Product Name, Lot
name
of origin
except GND pattern.
50
42±0.3
BOTTOM View
8
ALD310012PJ125
9401 JAPAN
(iii)
(2.0)
(2.0)
(13.4)
92±0.3
When LED driver is fixing, please confirm
100screw head and plate form is located within
above hatching area include any tolerances.
(iii)
(i)
(ii)
Unit in mm
Mass:9g max
(ii)
No.
NTH 4-! φ3.5
(37.0)
Tolerance is ± 0.5mm unless otherwise specified.
Part Description
Item/Material
Print Circuit Board: PCB
FR-4
Input Connector: CN1
53261-0871
Output Connector: CN2
Qty.
Remark
=1.0 Information, please
ForUL94V-0
Additional
visit
us.tdk-lambda.com/lp/products/ald-series.htm
1
Molex
51021-0800
1
1
8
JST
SHR-06V-S-B
Revision A5: Nov 2011
很抱歉,暂时无法提供与“ALD-214012PJ111”相匹配的价格&库存,您可以联系我们找货
