R F
C o m p o n e n t s
September 2016
Multilayer Antenna
For 902-930MHz
ANT160920ST-1204A1
1.6x0.8mm [EIA 0603]*
* Dimensions Code JIS[EIA]
RF Components
Multilayer Antenna
Conformity to RoHS Directive
For 902-930MHz
ANT160920ST-1204A1
SHAPES AND DIMENSIONS
[Top view]
0.40max.
0.80±0.10
1.60±0.10
(0.1)
0.20±0.10
(2)
(3)
(6)
(5)
(1)
(0.1)
0.63±0.10
[Bottom view]
(4)
0.25±0.10
0.215±0.10
Terminal functions
1 Radiator electrode
2 Dummy pad
3 Dummy pad
4 Feed point
5 Dummy pad
6 Dummy pad
Dimensions in mm
RECOMMENDED LAND PATTERN
SOLDER RESIST PATTERN
1.53
0.90
0.90
0.60
0.60
0.11
0.73
0.80
0.73
0.21
1.60
Dimensions in mm
Dimensions in mm
RoHS Directive Compliant Product: See the following for more details.https://product.tdk.com/info/en/environment/rohs/index.html
• All specifications are subject to change without notice.
• Before using these products, be sure to request the delivery specifications.
20160926 / rf_ant_ant160920st-1204a1_summary
RF Components
ANT160920ST-1204A1
EVALUATION BOARD
Mt
PCB size : 100mm x 20mm x 1mm
Antenna area : 20 x 10 mm
Component P/N
2.4nH(MLG1005S2N4:TDK)
1.5nH(MLG1005S1N5:TDK)
12nH(MLG1005S12N:TDK)
Ft-1
Ft-2
Mt
Ft-1 Ft-2
ANT160920ST-1204A1
Measurement condition for Radiation Pattern
Z
Er
Chip antenna
θ
Eø
Eθ
Y
ø
PCB
X
RF Components
ANT160920ST-1204A1
ELECTRICAL CHARACTERISTICS
Item
VSWR
Polarization
PCB size (mm)
Antenna keep-out area (mm)
Characteristic Impedance ()
Frequency Range
(MHz)
Min.
Typ.
Max.
902 to 930
1.60
Linear
10020
2010
50 (Nominal)
3.0
・This is typical antenna performance with the standard PCB.
TEMPERATURE RANGE
Operating temperature
(°C)
–40 to +85
Storage temperature
(°C)
–40 to +85
FREQUENCY CHARACTERISTICS
–1
10
–2
9
–3
8
–4
7
–5
6
–6
5
–7
4
–8
3
–9
–10
0.850
0.900
0.950
Frequency (GHz)
2
1
1.000
VSWR
Efficiency(dB)
EFFICIENCY AND VSWR
Efficiency
VSWR
• Tested antenna has been soldered. Evaluation board size is 100x20x1 mm.
RF Components
ANT160920ST-1204A1
RADIATION PATTERNS
Sub-GHz BAND
315°
270°
Y
270˚
90˚
X
Z
0°
10 (dBi)
–10
–20
–30
–40
–50
90°
135°
225°
180°
Horizontal polarization
Frequency(GHz) 0.902 0.916
–9.7
–9.4
Average(dBi)
–3.4
–3.0
Maximum(dBi)
–29.1 –25.5
Minimum(dBi)
0˚
315°
270°
270°
315°
45°
0°
10 (dBi)
–10
–20
–30
–40
–50
270°
0.902GHz
0.916GHz
0.930GHz
0.930
–9.6
–3.5
–23.6
45°
90°
135°
225°
180°
Vertical polarization
–1.4
–1.5
Average(dBi)
0.3
0.3
Maximum(dBi)
–3.5
–2.8
Minimum(dBi)
315°
45°
90°
0°
10 (dBi)
–10
–20
–30
–40
–50
270°
0°
10 (dBi)
–10
–20
–30
–40
–50
0.902GHz
0.916GHz
0.930GHz
0.930
–1.4
0.4
–2.5
45°
90°
90°
Y
0°
Z
X
135°
225°
180°
–3.9
–3.8
Average(dBi)
0.5
0.1
Maximum(dBi)
–13.7 –13.9
Minimum(dBi)
315°
Z
90˚
Y
270˚
X
270°
0˚
225°
0°
10 (dBi)
–10
–20
–30
–40
–50
0.902GHz
0.916GHz
0.930GHz
0.930
–3.8
0.0
–14.1
180°
–17.8 –17.1
Average(dBi)
–11.2
–9.8
Maximum(dBi)
–39.0 –32.8
Minimum(dBi)
315°
45°
270°
90°
135°
180°
–4.2
–4.5
Average(dBi)
–0.9
–1.0
Maximum(dBi)
–30.8 –41.5
Minimum(dBi)
0.902GHz
0.916GHz
0.930GHz
0.930
–4.6
–1.2
–36.0
135°
225°
225°
0°
10 (dBi)
–10
–20
–30
–40
–50
0.902GHz
0.916GHz
0.930GHz
0.930
–18.0
–11.5
–39.2
45°
90°
135°
180°
–12.4 –12.5
Average(dBi)
–9.8 –10.6
Maximum(dBi)
–16.9 –16.4
Minimum(dBi)
0.902GHz
0.916GHz
0.930GHz
0.930
–12.5
–10.5
–15.6
• Tested antenna has been soldered. Evaluation board size is 100x20x1mm.
RF Components
RECOMMENDED REFLOW PROFILE
Preheating
Soldering
Peak
T4
T: Temperature
3°C/sec
or lower
6°C/sec
or lower
T3
T2
T3
t3
T1
t1
t2
t: Time
Preheating
Temp.
T1
150°C
T2
200°C
Time
t1
60 to 120sec
Soldering
Critical zone (T3 to T4)
Temp.
Time
T3
t2
217°C
60 to 120sec
t3
: Time within 5°C of actual peak temperature
The maximum number of reflow is 3.
Peak
Temp.
T4
240 to 260°C
Time
t3
30sec max.
RF Components
ANT160920ST-1204A1
PACKAGING STYLE
REEL DIMENSIONS
ø60–0.0
+1.0
2.0±0.5
9.0 +1.0
–0.0
ø13±0.2
ø21±0.8
13.0±1.0
+0
ø180 –1.5
Dimensions in mm
TAPE DIMENSIONS
Material of carrier the tape: PS
G
H
t
C
B
D
E
J
K
F
A
Dimensions in mm
A
B
0.97±0.05 1.8±0.05
C
8.0±0.2
D
E
3.5±0.05 1.75±0.1
F
4.0±0.1
G
2.0±0.05
H
J
K
t
4.0±0.1 1.5+0.1/-0 0.55max. 0.25±0.05
PACKAGE QUANTITY
Standardpackage quantity
(pieces/reel)
4,000
RF Components
REMINDERS FOR USING THESE PRODUCTS
SAFETY REMINDERS
Please pay sufficient attention to the warnings for safe designing when using these products.
REMINDERS
The products listed on this catalog are intended for use in general electronic equipment (AV equipment, telecommunications equipment,
home appliances, amusement equipment, computer equipment, personal equipment, office equipment, measurement equipment,
industrial robots) under a normal operation and use condition.
The products are not designed or warranted to meet the requirements of the applications listed below, whose performance and/or quality
require a more stringent level of safety or reliability, or whose failure, malfunction or trouble could cause serious damage to society, person
or property.
Please understand that we are not responsible for any damage or liability caused by use of the products in any of the applications below
or for any other use exceeding the range or conditions set forth in this catalog.
(1) Aerospace/Aviation equipment
(2) Transportation equipment (cars, electric trains, ships, etc.)
(3) Medical equipment
(4) Power-generation control equipment
(5) Atomic energy-related equipment
(6) Seabed equipment
(7) Transportation control equipment
(8) Public information-processing equipment
(9) Military equipment
(10) Electric heating apparatus, burning equipment
(11) Disaster prevention/crime prevention equipment
(12) Safety equipment
(13) Other applications that are not considered general-purpose
applications
When using this product in general-purpose applications, you are kindly requested to take into consideration securing protection circuit/
equipment or providing backup circuits, etc., to ensure higher safety.
很抱歉,暂时无法提供与“ANT160920ST-1204A1”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 4000+1.920344000+0.24871
- 8000+1.872128000+0.24246
- 12000+1.8479712000+0.23933
- 20000+1.8212020000+0.23587
- 28000+1.8055628000+0.23384
- 40000+1.7905240000+0.23189
- 国内价格 香港价格
- 1+4.505381+0.58350
- 10+3.1783210+0.41163
- 25+2.8356125+0.36724
- 100+2.46323100+0.31902
- 250+2.28557250+0.29601
- 500+2.17858500+0.28215
- 1000+2.090381000+0.27073
- 国内价格
- 1+2.47320
- 10+2.40840
- 30+2.36520
- 100+2.33280
