ANT162442DT-2001A2
ANT162442DT-2001A2
    TDK(东电化)
    SMD-6P,1.6x0.8mm
ANT162442DT-2001A2 数据手册
R F C o m p o n e n t s September 2016 Multilayer Antenna (Dual Band type) For 2400-2484MHz / 5150-5850MHz ANT162442DT-2001A2 1.6x0.8mm [EIA 0603]* * Dimensions Code JIS[EIA] RF Components Multilayer Antenna Conformity to RoHS Directive For 2400-2484MHz / 5150-5850MHz ANT162442DT-2001A2 SHAPES AND DIMENSIONS [Top view] 0.40max. 0.80±0.10 1.60±0.10 (0.1) 0.20±0.10 (2) (3) (6) (5) (1) Terminal functions 1 Radiator electrode for 2.4GHz ISM 2 Feed point 3 Feed point 4 Radiator electrode for 5.5GHz 5 Feed point 6 Feed point (0.1) 0.63±0.10 [Bottom view] (4) 0.25±0.10 0.215±0.10 Dimensions in mm SOLDER RESIST PATTERN 1.60 1.53 0.90 0.90 0.60 0.60 0.11 0.73 0.80 0.73 0.21 RECOMMENDED LAND PATTERN Dimensions in mm Dimensions in mm RoHS Directive Compliant Product: See the following for more details.https://product.tdk.com/info/en/environment/rohs/index.html • All specifications are subject to change without notice. • Before using these products, be sure to request the delivery specifications. 20160926 / rf_ant_ant162442dt-2001a2_summary RF Components ANT162442DT-2001A2 EVALUATION BOARD ANT162442DT-2001A2 Ft 2.4GHz Ft 5.5GHz PCB size : 50mm x 20mm x 1mm Antenna area : 8 x 5 mm Mt Common Ft 2.4GHz Ft 5.5GHz Mt Common Component P/N 6.2pF 0.4pF 1.3nH( MLG1005S1N3C:TDK) Measurement condition for Radiation Pattern Z Chip antenna Er θ PCB Eø Eθ Y ø X • All specifications are subject to change without notice. • Before using these products, be sure to request the delivery specifications. 20160926 / rf_ant_ant162442dt-2001a2_summary RF Components ANT162442DT-2001A2 ELECTRICAL CHARACTERISTICS Item Frequency Range (MHz) Min. Typ. Max. VSWR 2400 to 2484 5150 to 5850 — — 1.54 1.58 Linear 5020 85 50 (Nominal) 3.0 3.0 Polarization PCB size (mm) Antenna keep-out area (mm) Characteristic Impedance () ・This is typical antenna performance with the standard PCB. TEMPERATURE RANGE Operating temperature (°C) –40 to +85 Storage temperature (°C) –40 to +85 FREQUENCY CHARACTERISTICS 11 0 11 10 –1 10 –2 9 –2 9 –3 8 –3 8 –4 7 –4 7 –5 6 –5 6 –6 5 –6 5 –7 4 –7 4 –8 3 –8 3 –9 2 –10 1 2.300 2.350 2.400 2.450 2.500 2.550 2.600 Frequency (GHz) Efficiency(dB) 0 –1 Efficiency VSWR –9 –10 5.000 5.200 5.400 5.600 Frequency (GHz) 5.800 2 1 6.000 VSWR 5.5GHz WLAN BAND VSWR Efficiency(dB) 2.4GHz WLAN BAND Efficiency VSWR • Tested antenna has been soldered. Evaluation board size is 50x20x1 mm. • All specifications are subject to change without notice. • Before using these products, be sure to request the delivery specifications. 20160926 / rf_ant_ant162442dt-2001a2_summary RF Components ANT162442DT-2001A2 RADIATION PATTERNS 2.4GHz ISM BAND 0° 10 (dBi) 315° Y 270° 270° 0 –10 –20 –30 –40 90° X Z 270° 90° 135° 225° 0° 0° 10 (dBi) 315° 45° 180° Horizontal polarization Frequency(GHz) 2.400 2.442 –16.5 –16.6 Average(dBi) –12.0 –13.5 Maximum(dBi) –30.1 –27.6 Minimum(dBi) 2.400GHz 2.442GHz 2.485GHz 2.485 –16.4 –12.7 –28.7 270° 270° 0 –10 –20 –30 –40 45° 90° 135° 225° 180° Vertical polarization Frequency(GHz) 2.400 2.442 0.6 0.7 Average(dBi) 2.0 2.1 Maximum(dBi) –1.4 –1.4 Minimum(dBi) 2.400GHz 2.442GHz 2.485GHz 2.485 0.4 1.9 –2.2 0° 10 (dBi) 0° 10 (dBi) 315° 0 –10 –20 –30 –40 315° 45° 270° 90° 0 –10 –20 –30 –40 45° 90° 90° Y 0° Z X 135° 225° 180° Horizontal polarization Frequency(GHz) 2.400 2.442 –2.3 –2.1 Average(dBi) 1.9 2.1 Maximum(dBi) –17.1 –19.0 Minimum(dBi) 2.400GHz 2.442GHz 2.485GHz 2.485 –2.4 2.0 –20.4 180° Vertical polarization Frequency(GHz) 2.400 2.442 –14.4 –14.7 Average(dBi) –12.8 –13.4 Maximum(dBi) –17.1 –16.7 Minimum(dBi) 0° 10 (dBi) 315° Z 90° Y 270° X 270° 0° 225° 0 –10 –20 –30 –40 135° 225° 2.400GHz 2.442GHz 2.485GHz 2.485 –14.8 –13.4 –18.0 0° 10 (dBi) 315° 45° 270° 90° 135° 180° Horizontal polarization Frequency(GHz) 2.400 2.442 –2.3 –2.2 Average(dBi) 0.7 0.8 Maximum(dBi) –30.4 –36.7 Minimum(dBi) 2.400GHz 2.442GHz 2.485GHz 2.485 –2.5 0.5 –31.2 225° 0 –10 –20 –30 –40 45° 90° 135° 180° Vertical polarization Frequency(GHz) 2.400 2.442 –12.3 –12.3 Average(dBi) –8.1 –7.9 Maximum(dBi) –28.7 –31.6 Minimum(dBi) 2.400GHz 2.442GHz 2.485GHz 2.485 –12.4 –8.0 –34.6 • Tested antenna has been soldered. Evaluation board size is 50x20x1 mm. • All specifications are subject to change without notice. • Before using these products, be sure to request the delivery specifications. 20160926 / rf_ant_ant162442dt-2001a2_summary RF Components ANT162442DT-2001A2 RADIATION PATTERNS 5.5GHZ BAND 0° 10 (dBi) 315° Y 270° 270° 0 –10 –20 –30 –40 90° X Z 270° 90° 135° 225° 0° 0° 10 (dBi) 315° 45° 180° Horizontal polarization Frequency(GHz) 5.150 5.500 –13.0 –12.2 Average(dBi) –7.5 –6.6 Maximum(dBi) –32.5 –26.8 Minimum(dBi) 5.150GHz 5.500GHz 5.850GHz 5.850 –13.6 –6.7 –36.3 270° 270° 0 –10 –20 –30 –40 45° 90° 135° 225° 180° Vertical polarization Frequency(GHz) 5.150 5.500 –1.4 –0.2 Average(dBi) 0.6 1.5 Maximum(dBi) –5.5 –3.1 Minimum(dBi) 5.150GHz 5.500GHz 5.850GHz 5.850 –0.1 1.7 –4.7 0° 10 (dBi) 0° 10 (dBi) 315° 0 –10 –20 –30 –40 315° 45° 270° 90° 0 –10 –2 –30 –40 45° 90° 90° Y 0° Z X 135° 225° 180° Horizontal polarization Frequency(GHz) 5.150 5.500 –2.5 –2.1 Average(dBi) 1.0 1.1 Maximum(dBi) –29.0 –23.9 Minimum(dBi) 5.150GHz 5.500GHz 5.850GHz 5.850 –2.7 0.4 –19.0 180° Vertical polarization Frequency(GHz) 5.150 5.500 –19.2 –18.2 Average(dBi) –13.5 –13.5 Maximum(dBi) –34.6 –42.6 Minimum(dBi) 0° 10 (dBi) 315° Z 90° Y 270° X 270° 0° 225° 0 –10 –20 –30 –40 135° 225° 5.150GHz 5.500GHz 5.850GHz 5.850 –19.2 –14.9 –38.9 0° 10 (dBi) 315° 45° 270° 90° 135° 180° Horizontal polarization Frequency(GHz) 5.150 5.500 –4.5 –3.5 Average(dBi) 0.4 1.4 Maximum(dBi) –29.1 –29.7 Minimum(dBi) 5.150GHz 5.500GHz 5.850GHz 5.850 –2.8 2.3 –40.7 225° 0 –10 –20 –30 –40 45° 90° 135° 180° Vertical polarization Frequency(GHz) 5.150 5.500 –2.9 –2.2 Average(dBi) –0.7 0.2 Maximum(dBi) –15.2 –20.3 Minimum(dBi) 5.150GHz 5.500GHz 5.850GHz 5.850 –3.2 –1.2 –19.8 •Tested antenna has been soldered. Evaluation board size is 50x20x1 mm. • All specifications are subject to change without notice. • Before using these products, be sure to request the delivery specifications. 20160926 / rf_ant_ant162442dt-2001a2_summary RF Components RECOMMENDED REFLOW PROFILE Preheating Soldering Peak T4 T: Temperature 3°C/sec or lower 6°C/sec or lower T3 T2 T3 t3 T1 t1 t2 t: Time Preheating Temp. T1 150°C T2 200°C Time t1 60 to 120sec Soldering Critical zone (T3 to T4) Temp. Time T3 t2 217°C 60 to 120sec t3 : Time within 5°C of actual peak temperature The maximum number of reflow is 3. • All specifications are subject to change without notice. • Before using these products, be sure to request the delivery specifications. Peak Temp. T4 240 to 260°C Time t3 30sec max. RF Components ANT162442DT-2001A2 PACKAGING STYLE REEL DIMENSIONS ø60–0.0 +1.0 2.0±0.5 9.0 +1.0 –0.0 ø13±0.2 ø21±0.8 13.0±1.0 +0 ø180 –1.5 Dimensions in mm TAPE DIMENSIONS Material of carrier the tape: PS G H t C B D E J K F A Dimensions in mm A B 0.97±0.05 1.8±0.05 C 8.0±0.2 D E 3.5±0.05 1.75±0.1 F 4.0±0.1 G 2.0±0.05 H J K t 4.0±0.1 1.5+0.1/-0 0.55max. 0.25±0.05 PACKAGE QUANTITY Standardpackage quantity (pieces/reel) 4,000 • All specifications are subject to change without notice. • Before using these products, be sure to request the delivery specifications. 20160926 / rf_ant_ant162442dt-2001a2_summary RF Components REMINDERS FOR USING THESE PRODUCTS Before using these products, be sure to request the delivery specifications. SAFETY REMINDERS Please pay sufficient attention to the warnings for safe designing when using these products. REMINDERS The products listed on this catalog are intended for use in general electronic equipment (AV equipment, telecommunications equipment, home appliances, amusement equipment, computer equipment, personal equipment, office equipment, measurement equipment, industrial robots) under a normal operation and use condition. The products are not designed or warranted to meet the requirements of the applications listed below, whose performance and/or quality require a more stringent level of safety or reliability, or whose failure, malfunction or trouble could cause serious damage to society, person or property. Please understand that we are not responsible for any damage or liability caused by use of the products in any of the applications below or for any other use exceeding the range or conditions set forth in this catalog. (1) Aerospace/Aviation equipment (2) Transportation equipment (cars, electric trains, ships, etc.) (3) Medical equipment (4) Power-generation control equipment (5) Atomic energy-related equipment (6) Seabed equipment (7) Transportation control equipment (8) Public information-processing equipment (9) Military equipment (10) Electric heating apparatus, burning equipment (11) Disaster prevention/crime prevention equipment (12) Safety equipment (13) Other applications that are not considered general-purpose applications When using this product in general-purpose applications, you are kindly requested to take into consideration securing protection circuit/ equipment or providing backup circuits, etc., to ensure higher safety. • All specifications are subject to change without notice. • Before using these products, be sure to request the delivery specifications. 20160926 / rf_ant_ant162442dt-2001a2_summary
ANT162442DT-2001A2
物料型号:ANT162442DT-2001A2
器件简介:这是一款多层天线,适用于2400-2484MHz和5150-5850MHz的双频段,尺寸为1.6x0.8mm,符合EIA 0603标准。
引脚分配: - 1号引脚:2.4GHz ISM的辐射电极 - 2号引脚:馈电点 - 3号引脚:馈电点 - 4号引脚:5.5GHz的辐射电极 - 5号和6号引脚:馈电点
参数特性: - 推荐焊盘图案和阻焊图案 - 符合RoHS指令的产品 - 电气特性包括在2400至2484MHz和5150至5850MHz的频率范围内的电压驻波比(VSWR)、极化方式、PCB尺寸、天线保持区域和特性阻抗 - 工作温度范围为-40至+85°C,存储温度范围同样为-40至+85°C
功能详解:文档提供了辐射模式的测量条件和辐射模式图,展示了在2.4GHz和5.5GHz频段下的天线效率和VSWR。
应用信息:适用于一般电子设备,如音视频设备、通信设备、家用电器、娱乐设备、计算机设备、个人设备、办公设备、测量设备和工业机器人。不适用于需要更高安全或可靠性级别的应用,如航空、汽车、医疗设备等。
封装信息:提供了推荐的回流焊接曲线和包装样式、卷径尺寸以及胶带尺寸。
ANT162442DT-2001A2 价格&库存
很抱歉,暂时无法提供与“ANT162442DT-2001A2”相匹配的价格&库存,您可以联系我们找货
ANT162442DT-2001A2
    • 5+1.57268
    • 50+1.27151
    • 150+1.14245
    • 500+0.98138
    • 2500+0.90964
    • 4000+0.86662
    库存:4890
    ANT162442DT-2001A2
    • 4000+2.058614000+0.26636
    • 8000+2.007558000+0.25976
    • 12000+1.9820012000+0.25645
    • 20000+1.9536720000+0.25278
    • 28000+1.9371128000+0.25064
    • 40000+1.9212040000+0.24858
    库存:35695
    ANT162442DT-2001A2
      • 1+2.35858
      • 10+2.10169
      • 100+1.90508
      • 1000+1.70508
      • 2000+1.48316
      • 4000+1.33150
      库存:3200
