R F
C o m p o n e n t s
February 2017
AEC-Q200 (–40 to 85°C) qualified component family
Multilayer Antenna (Dual Band type)
For 2400-2484MHz / 5150-5850MHz
ANT162442DT-2001AM2
1.6x0.8mm [EIA 0603]*
* Dimensions Code JIS[EIA]
RF Components
Multilayer Antenna
Conformity to RoHS Directive
ANT162442DT-2001AM2
SHAPES AND DIMENSIONS
[Top view]
0.40max.
0.80±0.10
1.60±0.10
(0.10)
0.20±0.10
(2)
(3)
(6)
(5)
(1)
(0.10)
0.63±0.10
[Bottom view]
(4)
0.25±0.10
0.215±0.10
Terminal functions
1 Radiator electrode for 2.4GHz ISM
2 Feed point
3 Feed point
4 Radiator electrode for 5.5GHz
5 Feed point
6 Feed point
*Terminal (2),(3),(5) and (6) :Connected in inner structure
Dimensions in mm
RECOMMENDED LAND PATTERN
SOLDER RESIST PATTERN
0.90
0.90
0.60
0.60
0.73
0.80
0.73
0.11
1.53
0.21
1.60
Dimensions in mm
Dimensions in mm
RoHS Directive Compliant Product: See the following for more details.https://product.tdk.com/info/en/environment/rohs/index.html
• All specifications are subject to change without notice.
• Before using these products, be sure to request the delivery specifications.
20170203 / rf_ant_ant162442dt-2001am2_summary_en.fm
RF Components
ANT162442DT-2001AM2
EVALUATION BOARD
ANT162442DT-2001AM2
Ft 2.4GHz
Ft 5.5GHz
PCB size : 50mm x 20mm x 1mm
Antenna area : 8 x 5 mm
Mt Common
Ft 2.4GHz
Ft 5.5GHz
Mt Common
Element Value
6.2pF
0.4pF
1.3nH( MLG1005S1N3C:TDK)
Measurement condition for Radiation Pattern
Z
Chip antenna
Er
θ
PCB
Eø
Eθ
Y
ø
X
RF Components
ANT162442DT-2001AM2
ELECTRICAL CHARACTERISTICS
Item
Frequency Range
(MHz)
Min.
Typ.
Max.
VSWR
2400 to 2484
5150 to 5850
1.54
1.58
Linear
5020
85
50 (Nominal)
3.0
3.0
Polarization
PCB size (mm)
Antenna keep-out area (mm)
Characteristic Impedance ()
・This is typical antenna performance with the standard PCB.
TEMPERATURE RANGE
Operating temperature
(°C)
–40 to +85
Storage temperature
(°C)
–40 to +85
FREQUENCY CHARACTERISTICS
11
10
–1
10
–2
9
–2
9
–3
8
–3
8
–4
7
–4
7
–5
6
–5
6
–6
5
–6
5
–7
4
–7
4
–8
3
–8
3
–9
2
–10
1
2.300 2.350 2.400 2.450 2.500 2.550 2.600
Frequency (GHz)
Efficiency(dB)
–1
Efficiency
Spec (VSWR)
VSWR
–9
–10
5.000
5.200
5.400
5.600
Frequency (GHz)
5.800
2
1
6.000
VSWR
5.5GHz BAND
VSWR
Efficiency(dB)
2.4GHz ISM BAND
Efficiency
Spec (VSWR)
VSWR
• Tested antenna has been soldered. Evaluation board size is 50x20x1 mm.
RF Components
ANT162442DT-2001AM2
RADIATION PATTERNS
2.4GHz ISM BAND
0°
10 (dBi)
315°
Y
270°
270°
90°
X
Z
–10
–20
–30
–40
0°
10 (dBi)
315°
45°
270°
90°
135°
2.400GHz
2.442GHz
180°
2.485GHz
Horizontal polarization
Frequency(GHz) 2.400 2.442 2.485
–16.54 –16.59 –16.37
Average(dBi)
Maximum(dBi) –12.01 –13.47 –12.72
–30.09 –27.57 –28.66
Minimum(dBi)
225°
0°
270°
270°
–10
–20
–30
–40
45°
90°
135°
225°
180°
Vertical polarization
0.57
0.67
Average(dBi)
2.02
2.13
Maximum(dBi)
–1.35 –1.43
Minimum(dBi)
0°
10 (dBi)
315°
–10
–20
–30
–40
2.400GHz
2.442GHz
2.485GHz
2.485
0.35
1.90
–2.16
0°
10 (dBi)
315°
45°
270°
90°
–10
–20
–30
–40
45°
90°
90°
Y
0°
Z
X
135°
225°
180°
–2.27 –2.13 –2.37
Average(dBi)
1.94
2.08
1.96
Maximum(dBi)
–17.08 –18.95 –20.38
Minimum(dBi)
2.400GHz
2.442GHz
2.485GHz
2.400GHz
2.442GHz
180°
2.485GHz
–14.44 –14.68 –14.79
Average(dBi)
Maximum(dBi) –12.83 –13.39 –13.42
–17.10 –16.69 –18.01
Minimum(dBi)
0°
10 (dBi)
315°
270°
Z
90°
Y
270°
X
0°
–10
–20
–30
–40
135°
225°
0°
10 (dBi)
315°
45°
90°
135°
2.400GHz
2.442GHz
180°
2.485GHz
–2.32 –2.22 –2.51
Average(dBi)
0.69
0.81
0.54
Maximum(dBi)
–30.39 –36.66 –31.21
Minimum(dBi)
225°
270°
–10
–20
–30
–40
45°
90°
135°
2.400GHz
2.442GHz
180°
2.485GHz
–12.31 –12.26 –12.40
Average(dBi)
–8.06 –7.88 –7.97
Maximum(dBi)
–28.70 –31.60 –34.56
Minimum(dBi)
225°
RF Components
ANT162442DT-2001AM2
RADIATION PATTERNS
5.5GHz BAND
0°
10 (dBi)
315°
Y
270°
270°
90°
X
Z
–10
–20
–30
–40
0°
10 (dBi)
315°
45°
270°
90°
135°
5.150GHz
5.500GHz
180°
5.850GHz
Frequency(GHz) 5.150 5.500 5.850
–12.97 –12.16 –13.58
Average(dBi)
–7.48 –6.62 –6.72
Maximum(dBi)
–32.51 –26.84 –36.34
Minimum(dBi)
225°
0°
270°
270°
–10
–20
–30
–40
45°
90°
135°
225°
180°
–1.43 –0.20
Average(dBi)
0.62
1.47
Maximum(dBi)
–5.45 –3.08
Minimum(dBi)
0°
10 (dBi)
315°
–10
–20
–30
–40
5.150GHz
5.500GHz
5.850GHz
5.850
–0.08
1.73
–4.67
0°
10 (dBi)
315°
45°
270°
90°
–10
–20
–30
–40
45°
90°
90°
Y
0°
Z
X
135°
225°
180°
–2.51 –2.08 –2.65
Average(dBi)
1.01
1.13
0.37
Maximum(dBi)
–28.98 –23.90 –18.97
Minimum(dBi)
5.150GHz
5.500GHz
5.850GHz
5.150GHz
5.500GHz
180°
5.850GHz
–19.15 –18.18 –19.20
Average(dBi)
Maximum(dBi) –13.54 –13.50 –14.93
–34.57 –42.62 –38.87
Minimum(dBi)
0°
10 (dBi)
315°
270°
Z
90°
Y
270°
X
0°
–10
–20
–30
–40
135°
225°
0°
10 (dBi)
315°
45°
90°
135°
5.150GHz
5.500GHz
180°
5.850GHz
–4.50 –3.50 –2.84
Average(dBi)
0.42
1.37
2.30
Maximum(dBi)
–29.11 –29.74 –40.66
Minimum(dBi)
225°
270°
–10
–20
–30
–40
45°
90°
135°
5.150GHz
5.500GHz
180°
5.850GHz
–2.89 –2.23 –3.18
Average(dBi)
–0.68
0.24 –1.24
Maximum(dBi)
–15.19 –20.29 –19.75
Minimum(dBi)
225°
•Tested antenna has been soldered. Evaluation board size is 50x20x1 mm.
RF Components
ANT162442DT-2001AM2
PACKAGING STYLE
REEL DIMENSIONS
ø60–0.0
+1.0
2.0±0.5
9.0 +1.0
–0.0
ø13±0.2
ø21±0.8
13.0±1.0
+0
ø180 –1.5
Dimensions in mm
TAPE DIMENSIONS
Material of carrier tape: PS
G
H
t
C
B
D
E
J
K
F
A
Dimensions in mm
A
B
0.97±0.05 1.8±0.05
C
8.0±0.2
D
E
3.5±0.05 1.75±0.1
F
4.0±0.1
G
2.0±0.05
H
J
K
t
4.0±0.1 1.5+0.1/-0 0.55max. 0.25±0.05
PACKAGE QUANTITY
Standard package quantity
(pieces/reel)
4,000
RF Components
ANT162442DT-2001AM2
RECOMMENDED REFLOW PROFILE
Preheating
Soldering
Peak
T4
T: Temperature
3°C/sec
or lower
6°C/sec
or lower
T3
T2
T3
t3
T1
t1
t2
t: Time
Preheating
Temp.
T1
150°C
T2
200°C
Time
t1
60 to 120sec
Soldering
Critical zone (T3 to T4)
Temp.
Time
T3
t2
217°C
60 to 120sec
Peak
Temp.
T4
240 to 260°C
Time
t3
30sec max.
t3
: Time within 5°C of actual peak temperature
The maximum number of reflow is 3.
RF Components
REMINDERS FOR USING THESE PRODUCTS
SAFETY REMINDERS
Please pay sufficient attention to the warnings for safe designing when using these products.
REMINDERS
The products listed on this catalog are intended for use in general electronic equipment (AV equipment, telecommunications equipment,
home appliances, amusement equipment, computer equipment, personal equipment, office equipment, measurement equipment,
industrial robots) under a normal operation and use condition.
The products are not designed or warranted to meet the requirements of the applications listed below, whose performance and/or quality
require a more stringent level of safety or reliability, or whose failure, malfunction or trouble could cause serious damage to society, person
or property.
Please understand that we are not responsible for any damage or liability caused by use of the products in any of the applications below
or for any other use exceeding the range or conditions set forth in this catalog.
(1) Aerospace/Aviation equipment
(2) Transportation equipment (cars, electric trains, ships, etc.)
(3) Medical equipment
(4) Power-generation control equipment
(5) Atomic energy-related equipment
(6) Seabed equipment
(7) Transportation control equipment
(8) Public information-processing equipment
(9) Military equipment
(10) Electric heating apparatus, burning equipment
(11) Disaster prevention/crime prevention equipment
(12) Safety equipment
(13) Other applications that are not considered general-purpose
applications
When using this product in general-purpose applications, you are kindly requested to take into consideration securing protection circuit/
equipment or providing backup circuits, etc., to ensure higher safety.
ANT162442DT-2001AM2 价格&库存
很抱歉,暂时无法提供与“ANT162442DT-2001AM2”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+10.489151+1.30145
- 10+6.5575410+0.81364
- 25+5.5204725+0.68496
- 100+4.34255100+0.53881
- 250+3.76483250+0.46713
- 500+3.41129500+0.42326
- 1000+3.116571000+0.38669
- 国内价格 香港价格
- 4000+2.667384000+0.33096
- 8000+2.497878000+0.30993
- 12000+2.4123612000+0.29932
- 20000+2.3170720000+0.28750
- 28000+2.2610928000+0.28055
