R F
C o m p o n e n t s
Balun transformers
Wound SMD
ATB series
RoHS
REACH
SVHC-Free
Cl
Br
Pb
Halogen
Free
Lead
Free
ATB2012 type
FEATURES
The ATB2012 case size is L2.0×W1.2.
The case size is smaller than conventional Baluns.
Low insertion loss and good balance parameters.
APPLICATION
TV and mobile device tuners (DVB-T/H, ISDB-T, etc.)
STB / tuner power divider
PART NUMBER CONSTRUCTION
ATB
Series name
2012
L x W dimensions
(mm)
2012
2.0×1.2
500
Input impedance
500
50
750
75
11
Impedance ratio
11
1:1
T
T
000
Packaging style
Internal code
ø180mm reel
CHARACTERISTICS SPECIFICATION TABLE
Frequency
range
(MHz)
40 to 860
50 to 1200
UB/B
Impedance
50/50
75/75
Insertion loss (dB)
typ.
max.
1.0
0.8
2.5
1.2
DC
resistance
( )max.
1.0
0.7
Rated
current
(mA)
200
280
Rated
voltage
(V)
Insulation
resistance
(M )min.
10
10
Part No.
ATB2012-50011-T000
ATB2012-75011-T000
Measurement equipment
Measurement item
Product No.
DC resistance
4338A
Insulation resistance
4339A
Insertion loss
E5071B
Return loss
E5071B
Amplitude imbalance
E5071B
Phase balance
E5071B
* Equivalent measurement equipment may be used.
Manufacturer
Keysight Technologies
Please be sure to request delivery specifications that provide further details on the features and specifications of the products for proper and safe use.
Please note that the contents may change without any prior notice due to reasons such as upgrading.
(1/4)
20211130
rf_balun_atb2012_en.fm
R F
C o m p o n e n t s
ATB2012 type
FREQUENCY CHARACTERISTICS
ATB2012-50011-T000
INSERTION LOSS
RETURN LOSS
1.0
Return loss (dB)
Insertion loss (dB)
0.0
2.0
3.0
4.0
5.0
6.0
35
0 100 200 300 400 500 600 700 800 900 1000
Frequency (MHz)
Frequency (MHz)
PHASE BALANCE
Phase balance (deg.)
5.0
Amplitude imbalance (dB)
15
30
AMPLITUDE IMBALANCE
4.0
3.0
2.0
1.0
Frequency (MHz)
185
184
183
182
181
180
179
178
177
176
175
Frequency (MHz)
ATB2012-75011-T000
1
1.5
2
2.5
3
3.5
4
RETURN LOSS
Return loss (dB)
Insertion loss (dB)
INSERTION LOSS
400
600
800
Frequency (MHz)
1000
1200
10
9
8
7
6
5
4
3
2
1
400
600
800
Frequency (MHz)
400
600
800
Frequency (MHz)
1000
1200
PHASE BALANCE
AMPLITUDE IMBALANCE
10
15
30
35
40
1000
1200
200
180
160
140
120
100
80
60
40
400
600
800
Frequency (MHz)
1000
1200
(2/4)
20211130
R F
C o m p o n e n t s
ATB2012 type
PACKAGING STYLE
SHAPE & DIMENSIONS
REEL DIMENSIONS
2.0±0.2
4
2
3
2.0±0.5
(0.4)
60 +1
–0
1.2±0.1
1.2±0.2
1
(1.2)
(0.4)
(0.35) (0.5) (0.35)
(0.4)
9 +1
–0
ø13.0±0.2
(ø21)
13±1.4
ø180+0/–3
Dimensions in mm
Dimensions in mm
TAPE DIMENSIONS
1.2
Sprocket
hole
ø1.5 +0.1
–0
2±0.1
4±0.1
B
8±0.2
0.8
0.4
0.25±0.05
1.75±0.1
2.7
3.5±0.1
RECOMMENDED LAND PATTERN
Dimensions in mm
ø1 +0.2
–0
4±0.1
A
K
CIRCUIT DIAGRAM
Cavity
Dimensions in mm
ATB2012-50011-T000
Unbalanced Port
50Ω
1
4
(25Ω)
(25Ω)
2
Type
ATB2012
Balanced Port
50Ω
A
(1.4)
B
(2.25)
K
(1.4)
3
500 to 560min.
ATB2012-75011-T00
Unbalanced Port
75Ω
1
4
160min.
(37.5Ω)
(37.5Ω)
2
Taping
440min.
Balanced Port
75Ω
3
Drawing direction
RECOMMENDED REFLOW PROFILE
Preheating
Soldering
Natural
cooling
Peak
Temperature
230°C
180°C
5s max.
150°C
60 to 120s
PACKAGE QUANTITY
Package quantity
245°C
230°C
Dimensions in mm
2000 pcs/reel
TEMPERATURE RANGE, INDIVIDUAL WEIGHT
Operating
Storage
temperature range
temperature range
–40 to +85°C
–40 to +85°C
The storage temperature range is for after the assembly.
Individual
weight
12 mg
10 to 30s
Time
(3/4)
20211130
R F
C o m p o n e n t s
REMINDERS FOR USING THESE PRODUCTS
Before using these products, be sure to request the delivery specifications.
SAFETY REMINDERS
Please pay sufficient attention to the warnings for safe designing when using this products.
REMINDERS
The storage period is within 6 months. Be sure to follow the storage conditions (temperature: 5 to 40°C, humidity: 10 to 75% RH or
less).
If the storage period elapses, the soldering of the terminal electrodes may deteriorate.
Do not use or store in locations where there are conditions such as gas corrosion (salt, acid, alkali, etc.).
Before soldering, be sure to preheat components.
The preheating temperature should be set so that the temperature difference between the solder temperature and chip temperature
does not exceed 150°C.
Soldering corrections after mounting should be within the range of the conditions determined in the specifications.
If overheated, a short circuit, performance deterioration, or lifespan shortening may occur.
When embedding a printed circuit board where a chip is mounted to a set, be sure that residual stress is not given to the chip due to
the overall distortion of the printed circuit board and partial distortion such as at screw tightening portions.
Self heating (temperature increase) occurs when the power is turned ON, so the tolerance should be sufficient for the set thermal
design.
Carefully lay out the coil for the circuit board design of the non-magnetic shield type.
A malfunction may occur due to magnetic interference.
Use a wrist band to discharge static electricity in your body through the grounding wire.
Do not expose the products to magnets or magnetic fields.
Do not use for a purpose outside of the contents regulated in the delivery specifications.
The products listed on this catalog are intended for use in general electronic equipment (AV equipment, telecommunications equipment, home appliances, amusement equipment, computer equipment, personal equipment, office equipment, measurement equipment, industrial robots) under a normal operation and use condition.
The products are not designed or warranted to meet the requirements of the applications listed below, whose performance and/or quality require a more stringent level of safety or reliability, or whose failure, malfunction or trouble could cause serious damage to society,
person or property.
If you intend to use the products in the applications listed below or if you have special requirements exceeding the range or conditions
set forth in the each catalog, please contact us.
(1) Aerospace/aviation equipment
(2) Transportation equipment (cars, electric trains, ships, etc.)
(3) Medical equipment
(4) Power-generation control equipment
(5) Atomic energy-related equipment
(6) Seabed equipment
(7) Transportation control equipment
(8) Public information-processing equipment
(9) Military equipment
(10) Electric heating apparatus, burning equipment
(11) Disaster prevention/crime prevention equipment
(12) Safety equipment
(13) Other applications that are not considered general-purpose
applications
When designing your equipment even for general-purpose applications, you are kindly requested to take into consideration securing protection circuit/device or providing backup circuits in your equipment.
(4/4)
20211130
ATB2012-75011-TL000 价格&库存
很抱歉,暂时无法提供与“ATB2012-75011-TL000”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+3.70440
- 200+1.47960
- 500+1.43640
- 1000+1.40400
