ATB2012E-20011-T06
ATB2012E-20011-T06
    TDK(东电化)
    FILTER-4P_2X1.2MM_SM
    RF 平衡-不平衡变压器 13.56MHz 20 / 20 欧姆 0805(2012 公制)
ATB2012E-20011-T06 数据手册
R F C o m p o n e n t s Balun transformers Wound SMD ATB series RoHS REACH SVHC-Free Cl Br Pb Halogen Free Lead Free ATB2012 type FEATURES The ATB2012 case size is L2.0×W1.2. The case size is smaller than conventional Baluns. Low insertion loss and good balance parameters. APPLICATION TV and mobile device tuners (DVB-T/H, ISDB-T, etc.) STB / tuner power divider PART NUMBER CONSTRUCTION ATB Series name 2012 L x W dimensions (mm) 2012 2.0×1.2 - 500 Input impedance () 500 50 750 75 - 11 Impedance ratio 11 1:1 T T 000 Packaging style Internal code ø180mm reel CHARACTERISTICS SPECIFICATION TABLE Frequency range (MHz) 40 to 860 50 to 1200 UB/B Impedance ( ) 50/50 75/75 Insertion loss (dB) typ. max. 1.0 0.8 2.5 1.2 DC resistance ( )max. 1.0 0.7 Rated current (mA) 200 280 Rated voltage (V) 20 20 Insulation resistance (M )min. 10 10 Part No. ATB2012-50011-T000 ATB2012-75011-T000 Measurement equipment Measurement item Product No. DC resistance 4338A Insulation resistance 4339A Insertion loss E5071B Return loss E5071B Amplitude imbalance E5071B Phase balance E5071B * Equivalent measurement equipment may be used. Manufacturer Keysight Technologies Keysight Technologies Keysight Technologies Keysight Technologies Keysight Technologies Keysight Technologies Please be sure to request delivery specifications that provide further details on the features and specifications of the products for proper and safe use. Please note that the contents may change without any prior notice due to reasons such as upgrading. (1/4) 20211130 rf_balun_atb2012_en.fm R F C o m p o n e n t s ATB2012 type FREQUENCY CHARACTERISTICS ATB2012-50011-T000 INSERTION LOSS RETURN LOSS 0 5 1.0 Return loss (dB) Insertion loss (dB) 0.0 2.0 3.0 4.0 5.0 6.0 20 25 35 0 100 200 300 400 500 600 700 800 900 1000 Frequency (MHz) 0 100 200 300 400 500 600 700 800 900 1000 Frequency (MHz) PHASE BALANCE Phase balance (deg.) 5.0 Amplitude imbalance (dB) 15 30 AMPLITUDE IMBALANCE 4.0 3.0 2.0 1.0 0 10 0 100 200 300 400 500 600 700 800 900 1000 Frequency (MHz) 185 184 183 182 181 180 179 178 177 176 175 0 100 200 300 400 500 600 700 800 900 1000 Frequency (MHz) ATB2012-75011-T000 0 0.5 1 1.5 2 2.5 3 3.5 4 RETURN LOSS Return loss (dB) Insertion loss (dB) INSERTION LOSS 0 200 400 600 800 Frequency (MHz) 1000 1200 10 9 8 7 6 5 4 3 2 1 0 0 200 400 600 800 Frequency (MHz) 0 200 400 600 800 Frequency (MHz) 1000 1200 PHASE BALANCE Phase balance (deg.) Amplitude imbalance (dB) AMPLITUDE IMBALANCE 0 5 10 15 20 25 30 35 40 1000 1200 200 180 160 140 120 100 80 60 40 20 0 0 200 400 600 800 Frequency (MHz) 1000 1200 Please be sure to request delivery specifications that provide further details on the features and specifications of the products for proper and safe use. Please note that the contents may change without any prior notice due to reasons such as upgrading. (2/4) 20211130 rf_balun_atb2012_en.fm R F C o m p o n e n t s ATB2012 type PACKAGING STYLE SHAPE & DIMENSIONS REEL DIMENSIONS 2.0±0.2 4 2 3 2.0±0.5 (0.4) 60 +1 –0 1.2±0.1 1.2±0.2 1 (1.2) (0.4) (0.35) (0.5) (0.35) (0.4) 9 +1 –0 ø13.0±0.2 (ø21) 13±1.4 ø180+0/–3 Dimensions in mm Dimensions in mm TAPE DIMENSIONS 1.2 Sprocket hole ø1.5 +0.1 –0 2±0.1 4±0.1 B 8±0.2 0.8 0.4 0.25±0.05 1.75±0.1 2.7 3.5±0.1 RECOMMENDED LAND PATTERN Dimensions in mm ø1 +0.2 –0 4±0.1 A K CIRCUIT DIAGRAM Cavity Dimensions in mm ATB2012-50011-T000 Unbalanced Port 50Ω 1 4 (25Ω) (25Ω) 2 Type ATB2012 Balanced Port 50Ω A (1.4) B (2.25) K (1.4) 3 500 to 560min. ATB2012-75011-T00 Unbalanced Port 75Ω 1 4 160min. (37.5Ω) (37.5Ω) 2 Taping 440min. Balanced Port 75Ω 3 Drawing direction RECOMMENDED REFLOW PROFILE Preheating Soldering Natural cooling Peak Temperature 230°C 180°C 5s max. 150°C 60 to 120s PACKAGE QUANTITY Package quantity 245°C 230°C Dimensions in mm 2000 pcs/reel TEMPERATURE RANGE, INDIVIDUAL WEIGHT Operating Storage temperature range temperature range –40 to +85°C –40 to +85°C  The storage temperature range is for after the assembly. Individual weight 12 mg 10 to 30s Time Please be sure to request delivery specifications that provide further details on the features and specifications of the products for proper and safe use. Please note that the contents may change without any prior notice due to reasons such as upgrading. (3/4) 20211130 rf_balun_atb2012_en.fm R F C o m p o n e n t s REMINDERS FOR USING THESE PRODUCTS Before using these products, be sure to request the delivery specifications. SAFETY REMINDERS Please pay sufficient attention to the warnings for safe designing when using this products. REMINDERS The storage period is within 6 months. Be sure to follow the storage conditions (temperature: 5 to 40°C, humidity: 10 to 75% RH or less). If the storage period elapses, the soldering of the terminal electrodes may deteriorate. Do not use or store in locations where there are conditions such as gas corrosion (salt, acid, alkali, etc.). Before soldering, be sure to preheat components. The preheating temperature should be set so that the temperature difference between the solder temperature and chip temperature does not exceed 150°C. Soldering corrections after mounting should be within the range of the conditions determined in the specifications. If overheated, a short circuit, performance deterioration, or lifespan shortening may occur. When embedding a printed circuit board where a chip is mounted to a set, be sure that residual stress is not given to the chip due to the overall distortion of the printed circuit board and partial distortion such as at screw tightening portions. Self heating (temperature increase) occurs when the power is turned ON, so the tolerance should be sufficient for the set thermal design. Carefully lay out the coil for the circuit board design of the non-magnetic shield type. A malfunction may occur due to magnetic interference. Use a wrist band to discharge static electricity in your body through the grounding wire. Do not expose the products to magnets or magnetic fields. Do not use for a purpose outside of the contents regulated in the delivery specifications. The products listed on this catalog are intended for use in general electronic equipment (AV equipment, telecommunications equipment, home appliances, amusement equipment, computer equipment, personal equipment, office equipment, measurement equipment, industrial robots) under a normal operation and use condition. The products are not designed or warranted to meet the requirements of the applications listed below, whose performance and/or quality require a more stringent level of safety or reliability, or whose failure, malfunction or trouble could cause serious damage to society, person or property. If you intend to use the products in the applications listed below or if you have special requirements exceeding the range or conditions set forth in the each catalog, please contact us. (1) Aerospace/aviation equipment (2) Transportation equipment (cars, electric trains, ships, etc.) (3) Medical equipment (4) Power-generation control equipment (5) Atomic energy-related equipment   (6) Seabed equipment (7) Transportation control equipment (8) Public information-processing equipment (9) Military equipment (10) Electric heating apparatus, burning equipment (11) Disaster prevention/crime prevention equipment (12) Safety equipment (13) Other applications that are not considered general-purpose applications When designing your equipment even for general-purpose applications, you are kindly requested to take into consideration securing protection circuit/device or providing backup circuits in your equipment. Please be sure to request delivery specifications that provide further details on the features and specifications of the products for proper and safe use. Please note that the contents may change without any prior notice due to reasons such as upgrading. (4/4) 20211130 rf_balun_atb2012_en.fm
ATB2012E-20011-T06 价格&库存
很抱歉,暂时无法提供与“ATB2012E-20011-T06”相匹配的价格&库存,您可以联系我们找货
ATB2012E-20011-T06
  • 1+3.943461+0.51193
  • 10+3.6151910+0.46931
  • 25+3.4787725+0.45160
  • 50+3.3798650+0.43876
库存:95
