AVR-M1005C080MTABB
AVR-M1005C080MTABB
    TDK(东电化)
AVR-M1005C080MTABB 数据手册
V o l t a g e P r o t e c t i o n D e v i c e s September 2014 Chip Varistors Countermeasure for surge voltage and static electricity AVRseries AVRM0402/AVRL0402 AVRM0603/AVRL0603 AVRM1005/AVRL1005 AVRM1608/AVRL1608 AVRM2012 0402 [01005 inch]* 0603 [0201 inch] 1005 [0402 inch] 1608 [0603 inch] 2012 [0805 inch] * Dimensions Code JIS[EIA] (2/26) Voltage Protection Devices REMINDERS FOR USING THESE PRODUCTS Before using these products, be sure to request the delivery specifications. SAFETY REMINDERS Please pay sufficient attention to the warnings for safe designing when using these products. REMINDERS Please observe the following precautions in order to avoid problems with chip varistors such as characteristic degradation and element destruction. Please store these products in an environment with a temperature of 5 to 40°C and humidity level of 20 to 70%RH, and use them within six months. Poor storage conditions may lead to the deterioration of the solderability of the edge electrodes, so please be careful to avoid contact with humidity, dew condensation, dust, toxic gas (hydrogen, hydrogen sulfide, sulfurous acid, chlorine, ammonia, etc.), direct sunlight, and so on. Please do not use products that have been dropped or detached when mounting. Please solder with the reflow soldering method, and not the flow (dip) soldering method. Please observe the following precautions to avoid problems with varistors such as characteristic degradation and element destruction, which ultimately lead to the generation of heat and smoke with the elements. Do not use in locations where the temperatures exceed the operating temperature range such as under direct sunlight or near sources of heat. Do not use in locations where there are high levels of humidity such as under direct exposure to weather and areas where steam is released. Do not use in locations such as dusty areas, high-saline environments, places where the atmosphere is contaminated with corrosive gas, etc. Avoid powerful vibrations, impact (such as by dropping), pressure, etc. that may lead to splitting in the products. Do not use with a voltage that exceeds the maximum allowable circuit voltage. When resin coating (including modular) a varistor, do not use a resin that will cause deterioration of the varistor. Be sure never to use resin that generates hydrogen as palladium is used for the inner electrode. Avoid attachment near combustible materials. Please contact our sales offices when considering the use of the products listed on this catalog for applications, whose performance and/or quality require a more stringent level of safety or reliability, or whose failure, malfunction or trouble could cause serious damage to society, person or property ('specific uses' such as automobiles, airplanes, medical instruments, nuclear devices, etc.) as well as when considering the use for applications that exceed the range and conditions of this catalog. Please also contact us when using these products for automotive applications. Please note that we are not responsible for any damages or losses incurred resulting from the use of these products that exceeds the range and conditions of this catalog or specific uses. Please take appropriate measures such as acquiring protective circuits and devices that meet the uses, applications, and conditions of the instruments and keeping backup circuits. 20140922 / vpd_varistors_avr_en.fm (3/26) Voltage Protection Devices Chip Varistors Product compatible with RoHS directive Compatible with lead-free solders Countermeasure for surge voltage and static electricity Overview of the AVR Series CHARACTERISTICS OF CHIP VARISTOR Varistors are voltage dependent nonlinear resistive elements with a resistance that decreases rapidly when the voltage is over the constant value. Varistor is equivalent with Zener diode of two series connection. Therefore, do not have polarity. CURRENT vs. VOLTAGE CHARACTERISTICS EQUIVALENT CIRCUIT 2 Zener Diodes Current(A) 10–1 10–2 Zener diode /Vz:6.8V Positive direction 10–3 Chip varistor /V1mA:12V 10–4 A capacitance content 10–5 –18 –14 –10 –6 –2 2 –10–5 6 10 14 18 –10–4 –10–3 Negative direction –10–2 –10–1 Voltage(V) THE EFFECT OF THE VARISTOR Without Varistor A malfunction and failure of electronic equipment ESD, Surge voltage ESD, Surge voltage Power line Signal line With Varistor Suppress abnormal voltage by inserting varistor in a circuit IC Power line Signal line IC Insert a varistor between a line and ground : Chip varistor RoHS Directive Compliant Product: See the following for more details related to RoHS Directive compliant products. http://product.tdk.com/en/environment/rohs/ • All specifications are subject to change without notice. 20140922 / vpd_varistors_avr_en.fm (4/26) Voltage Protection Devices Overview of the AVR Series MEASURING CIRCUIT Sample IC Test board USB2.0 board on PC Test set : Chip varistor Without Varistor With Varistor AVRL101A3R3FTA (3.3pF) AVRL101A6R8GTA (6.8pF) MERITS OF REPLACEMENT FROM ZENER DIODE (1) Reduction in the Number of Parts Production examples Zener diode+capacitor Chip varistor Example of replacement at audio terminal Audio connector Audio/out Audio AMP Audio/out Audio AMP Audio connector : Chip varistor Insulation resistance of tested circuit(Ω) (2) Improved Electrostatic Absorption Capability Compare data of chip varistor and zener diode about IC protection ESD measurements of CMOS-ICs with AVR-type varistors and zener diodes 10–7 AVR-M1608C120MT6AB 10–6 10–5 With Zener Diode 10–4 10–3 0 2 4 6 8 10 ESD voltage(kV) 12 14 CMOS: D74HC04C ESD generator : Noise Laboratory Co.,Ltd., ESS -630A 200pF-0Ω method model equipment Contact type discharge ESD applied point: Vcc-ground • All specifications are subject to change without notice. 20140922 / vpd_varistors_avr_en.fm (5/26) Voltage Protection Devices Overview of the AVR Series FEATURES No polarity, due to symmetrical current-voltage characteristics. Equivalent to anode common type Zener diode. Excellent electrostatic absorption capability. Response is as good or better than Zener diode.Keeps symmetrical current-voltage characteristics even after electrostatic absorption. Adopted the inner electrodes lamination structure. • Wide range of varistor voltages are available in series (6.8 to 90V). • Low capacitance items are available in series (from 1.1pF). • World’s smallest 0402-, 0603-, 1005-, 1608-, 2012-chip size are available in series. Excellent mount reliability. Good for Pb-free soldering.Adopted (Ni/Sn) electroplating. Achieved good solderability and solder heat resistance. Can replace a Zener diode + capacitor combination. Reduced footprint and total mounting cost. APPLICATION Electrostatic absorption Pulse noise absorption APPLICATION EXAMPLES Consumer product Mobile phone Digital video camera Digital camera PDA Note PC DVD-ROM, CD-ROM CD/MD/MP3 player Game machine In-car equipment Application Data terminal LCD panel Touch panel Button and switch unit Battery terminal Audio-Video input-output terminal Microphone/receiver unit Controller unit CAN-BUS ECU Connector Air conditioner panel Car audio Car navigation SMART PHONE AUDIO, VIDEO To LCD driver Monitor OUT Video1 in Video2 in Video3 in Video5 in Microphone/Receiver Digi LCD panel Video Video Video Video L L/MONO L/MONO L/MONO L/MONO Button Data terminal Audio : Chip varistor USB2.0 Audio Audio Audio Audio R VDD USB cable USB IC D– D+ : Chip varistor USB connector F.G. : Chip varistor • All specifications are subject to change without notice. 20140922 / vpd_varistors_avr_en.fm (6/26) Voltage Protection Devices Overview of the AVR Series PART NUMBER CONSTRUCTION AVRM 1005 C Series name L×W Dimensions (mm) Structure code 0402 0603 1005 1608 2012 0.4×0.2 0.6×0.3 1.0×0.5 1.6×0.8 2.0×1.2 6R8 N Varistor voltage (V) 6R8 6.8 270 27 Varistor voltage tolerance (%) K ±10 M ±20 N ±30 T 101 N Packaging style Capacitance or TDK internal code Capacitance tolerance (%) M ±20 N ±30 T B Taping Bulk When the capacitance is not included in the part number, the capacitance tolerance is also not described. AVRL 10 Series name L×W Dimensions (mm) 04 06 10 16 1A Maximum continuous voltage (Vdc) 1A 10 1C 16 1E 25 0.4×0.2 0.6×0.3 1.0×0.5 1.6×0.8 3R3 F Capacitance tolerance (pF) D ±0.5 F ±1 G ±2 N ±0.3 Capacitance (pF) 1R1 2R2 3R3 6R8 1.1 2.2 3.3 6.8 T A Packaging style Varistor voltage or TDK internal code T Taping OPERATING TEMPERATURE RANGE, PACKAGE QUANTITY, PRODUCT WEIGHT Temperature range Package quantity Operating Storage Type temperature temperature (pieces/reel) (°C) (°C) AVRM0402 –40 to +85 –40 to +85 20,000 AVRL0402 –40 to +85 –40 to +85 20,000 AVRM0603 –40 to +85 –40 to +85 15,000 AVRL0603 –40 to +85 –40 to +85 15,000 AVRM1005 –40 to +125 –40 to +125 10,000 AVRL1005 –40 to +85 –40 to +85 10,000 AVRM1608 –40 to +125 –40 to +125 4,000 AVRL1608 –40 to +85 –40 to +85 4,000 AVRM2012 –40 to +125 –40 to +125 2,000 Operating temperature range includes self-temperature rise. The Storage temperature range is for after the circuit board is mounted. Individual weight (mg)typ. 0.1 0.1 0.2 0.2 1.2 1.2 5 5 12 OPERATIONAL VOLTAGE RANGES AVRM0402/AVRL0402 types 25 AVRM0603/AVRL0603 types 25 19 AVRM1005/AVRL1005 types AVRM1608/AVRL1608 types 28 AVRM2012 type 28 0 5 10 15 20 Circuit voltage(V) 25 30 • All specifications are subject to change without notice. 20140922 / vpd_varistors_avr_en.fm (7/26) Voltage Protection Devices Overview of the AVR Series TERMINOLOGY Item Varistor voltage (Breakdown voltage) Maximum continuous voltage (Rated voltage) Clamping voltage Maximum energy Maximum peak current Capacitance Insulation resistance 1 Unit V1mA (V) Vdc (V) Vcl (V) E (Joule) Ip (A) C (pF) Rdc (M: ) Terminology Voltage measured across the varistor when DC1mA is applied. Maximum DC voltage that can be applied continuously. Varistor leakage current: 50μA max. (Within the range of maximum allowable circuit voltage) Voltage appearing across the varistor when a pulse current (8/20μs 1) of specified peak value is applied. Maximum energy that can be absorbed without deteriorating varistor characteristics when an impulse current (10/1000μs 2) is applied once. Maximum current that can be withstood without deteriorating varistor characteristics when an impulse current (8/20μs 1) is applied once. Capacitance measured at 1kHz (or 1MHz) of oscillator frequency and 1Vrms of oscillator voltage. Insulation resistance appearing across the varistor when specified voltage is applied. 8/20μs test waveform Current 100% 90% 50% 8μs 20μs Time 2 10/1000μs test waveform Energy 100% 90% 50% 10μs 1000μs Time • All specifications are subject to change without notice. 20140922 / vpd_varistors_avr_en.fm (8/26) Voltage Protection Devices Overview of the AVR Series RECOMMENDED REFLOW PROFILE Preheating Soldering Natural cooling Peak T: Temperature T4 T3 T2 T3 t3 T1 t1 t2 t: Time Preheating Temp. T1 T2 150°C 180°C Time t1 120s max. Soldering Temp. Time T3 t2 230°C 40s max. Peak Temp. T4 260°C max. Time t3 5s • All specifications are subject to change without notice. 20140922 / vpd_varistors_avr_en.fm (9/26) Voltage Protection Devices AVR series AVRM0402/AVRL0402 Types SHAPE & DIMENSIONS INTERNAL STRUCTURE 0.4±0.02 0.2±0.02 Inner electrode Varistor body (Palladium) (Zinc Oxide: ZnO semiconductor ceramics) Sn plating Ag termination underlayer Ni plating 0.2±0.02 0.07 min. Dimensions in mm CIRCUITS DIAGRAM 0.18 to 0.2 RECOMMENDED LAND PATTERN 0.15 to 0.2 0.2 0.15 to 0.2 • All specifications are subject to change without notice. 20140922 / vpd_varistors_avr_en.fm (10/26) Voltage Protection Devices AVR series AVRM0402/AVRL0402 Types ELECTRICAL CHARACTERISTICS CHARACTERISTICS SPECIFICATION TABLE AVRM0402 Varistor voltage (Breakdown voltage) Part No. AVRM0402C6R8NT101N AVRM0402C120MT330N V1mA(V) [DC1mA] 6.8 (4.76 to 8.84) 12 (9.6 to 14.4) Maximum continuous Clamping voltage voltage (Rated voltage) Vdc(V) Vcl(V) [8/20μs] max. 3.5 15[1A] 5.5 20[1A] Maximum energy Maximum Capacitance peak current E(Joule) [10/1000μs] max. 0.01 0.005 Ip(A) [8/20μs] max. 4 1 C(pF) [1kHz, 1Vrms] typ. 100 (70 to 130) 33 (23.1 to 43.9) AVRL0402 Varistor voltage Part No. AVRL041E1R1NTA V1mA(V) [DC1mA] typ. 39 Maximum continuous voltage (Rated voltage) Vdc(V) max. Capacitance Insulation resistance C(pF) [1MHz, 1Vrms] 25 1.1[0.8 to 1.4] Rdc(M:) [3Vrms] min. 10 • All specifications are subject to change without notice. 20140922 / vpd_varistors_avr_en.fm (11/26) Voltage Protection Devices AVR series AVRM0402/AVRL0402 Types ELECTRICAL CHARACTERISTICS CURRENT vs. VOLTAGE CHARACTERISTICS 100 10–1 100000 10000 V1mA=12V V1mA=6.8V V1mA=39V Impeadance(Ω) 10–2 Current(A) IMPEDANCE vs. FREQUENCY CHARACTERISTICS 1000000 10–3 10–4 1.1pF 100 33pF 10–5 10 10–6 1 10–7 0 10 20 30 Voltage(V) 40 0.1 50 TRANSMISSION CHARACTERISTICS 100pF 1 10 100 Frequency(MHz) 1000 10000 CAPACITANCE vs. FREQUENCY CHARACTERISTICS 10 1000 1.1pF 0 100 –20 33pF 100pF –30 Capacitance(pF) –10 Insertion loss(dB) 1000 100pF 33pF 10 –40 1.1pF 1 –50 –60 1 10 100 Frequency(MHz) 1000 10000 0.1 1 10 100 Frequency(MHz) 1000 10000 • All specifications are subject to change without notice. 20140922 / vpd_varistors_avr_en.fm (12/26) Voltage Protection Devices AVR series AVRM0603/AVRL0603 Types SHAPE & DIMENSIONS INTERNAL STRUCTURE 0.6±0.03 0.3±0.03 Inner electrode Varistor body (Palladium) (Zinc Oxide: ZnO semiconductor ceramics) Sn plating Ag termination underlayer Ni plating 0.3±0.03 0.1 min. Dimensions in mm CIRCUITS DIAGRAM 0.25 to 0.35 RECOMMENDED LAND PATTERN 0.2 to 0.3 0.25 to 0.35 0.2 to 0.3 • All specifications are subject to change without notice. 20140922 / vpd_varistors_avr_en.fm (13/26) Voltage Protection Devices AVR series AVRM0603/AVRL0603 Types ELECTRICAL CHARACTERISTICS CHARACTERISTICS SPECIFICATION TABLE AVRM0603 Varistor voltage (Breakdown voltage) Part No. AVRM0603C6R8NT331N AVRM0603C6R8NT101N AVRM0603C080MT101N AVRM0603C120MT101N AVR-M0603C120MTAAB AVRM0603C120MT150N AVRM0603C200MT150N V1mA(V) [DC1mA] 6.8 6.8 8 12.8 12 12.8 20 ( 4.76 to 8.84) ( 4.76 to 8.84) ( 6.4 to 9.6) (10 to 15.6) ( 9.6 to 14.4) (10 to 15.6) (16.0 to 24.0) Maximum continuous voltage (Rated voltage) Vdc(V) max. 3.5 3.5 5.5 5.5 7.5 5.5 12 Clamping voltage Maximum energy Maximum Capacitance peak current Vcl(V) [8/20μs] E(Joule) [10/1000μs] max. 0.02 0.01 0.01 0.01 0.01 0.003 0.01 Ip(A) [8/20μs] max. 16 10 4 5 1 1 1 14[1A] 14[1A] 17[1A] 20[1A] 23[1A] 35[1A] 40[1A] C(pF) [1kHz, 1Vrms] typ. 330 (231 to 429) 100 ( 70 to 130) 100 ( 70 to 130) 100 ( 70 to 130) 33 15 ( 10.5 to 19.5) 15 ( 10.5 to 19.5) [1MHz] AVRL0603 Varistor voltage Part No. AVRL061E1R1NTA V1mA(V) [DC1mA] typ. 39 Maximum continuous voltage (Rated voltage) Vdc(V) max. Capacitance Insulation resistance C(pF) [1MHz, 1Vrms] 25 1.1[0.8 to 1.4] Rdc(M:) [3Vrms] min. 10 • All specifications are subject to change without notice. 20140922 / vpd_varistors_avr_en.fm (14/26) Voltage Protection Devices AVR series AVRM0603/AVRL0603 Types ELECTRICAL CHARACTERISTICS CURRENT vs. VOLTAGE CHARACTERISTICS 100 10–1 100000 10000 10–2 Impeadance(Ω) V1mA=12V V1mA=6.8V Current(A) IMPEDANCE vs. FREQUENCY CHARACTERISTICS 1000000 V1mA=39V 10–3 10–4 100pF 10–6 1 0 10 20 30 Voltage(V) 40 0.1 50 1.1pF 100 10 TRANSMISSION CHARACTERISTICS 1 10 100 Frequency(MHz) 1000 10000 CAPACITANCE vs. FREQUENCY CHARACTERISTICS 10 1000 1.1pF 0 100 –20 15pF –30 33pF 100pF Capacitance(pF) –10 Insertion loss(dB) 33pF 10–5 10–7 15pF 1000 100pF 33pF 15pF 10 –40 1.1pF 1 –50 –60 1 10 100 Frequency(MHz) 1000 10000 0.1 1 10 100 Frequency(MHz) 1000 10000 • All specifications are subject to change without notice. 20140922 / vpd_varistors_avr_en.fm (15/26) Voltage Protection Devices AVR series AVRM1005/AVRL1005 Types SHAPE & DIMENSIONS INTERNAL STRUCTURE 1.0±0.05 0.5±0.05 Inner electrode Varistor body (Palladium) (Zinc Oxide: ZnO semiconductor ceramics) Sn plating Ag termination underlayer Ni plating 0.5±0.05 0.1 min. Dimensions in mm CIRCUITS DIAGRAM 0.4 to 0.6 RECOMMENDED LAND PATTERN 0.35 to 0.45 0.3 to 0.5 0.35 to 0.45 • All specifications are subject to change without notice. 20140922 / vpd_varistors_avr_en.fm (16/26) Voltage Protection Devices AVR series AVRM1005/AVRL1005 Types ELECTRICAL CHARACTERISTICS CHARACTERISTICS SPECIFICATION TABLE AVRM1005 Varistor voltage (Breakdown voltage) Part No. AVRM1005C6R8NT331N AVRM1005C6R8NT101N AVR-M1005C080MTAAB AVR-M1005C080MTADB AVR-M1005C080MTABB AVR-M1005C080MTACB AVR-M1005C120MTACC AVR-M1005C120MTAAB AVR-M1005C180MTAAB AVRM1005C270KT101N AVR-M1005C270MTAAB AVR-M1005C270MTABB V1mA(V) [DC1mA] 6.8 6.8 8 8 8 8 12 12 18 27 27 27 ( 4.76 to 8.84) ( 4.76 to 8.84) ( 6.4 to 9.6) ( 6.4 to 9.6) ( 6.4 to 9.6) ( 6.4 to 9.6) ( 9.6 to 14.4) ( 9.6 to 14.4) (14.4 to 21.6) (24 to 30) (21.6 to 32.4) (21.6 to 32.4) Maximum continuous Clamping voltage voltage (Rated voltage) Vdc(V) Vcl(V) [8/20μs] max. 3.5 15[1A] 3.5 14[1A] 5.5 14[1A] 5.5 14[1A] 5.5 15[1A] 5.5 19[1A] 7.5 21[1A] 7.5 20[1A] 11 30[1A] 19 44[1A] 15 47[1A] 15 49[1A] Maximum energy E(Joule) [10/1000μs] max. 0.008 0.02 0.04 0.04 0.02 0.01 0.01 0.05 0.06 0.06 0.06 0.05 Maximum peak current Ip(A) [8/20μs] max. 24 10 25 25 3 1 24 10 16 4 4 1 Capacitance C(pF) [1kHz, 1Vrms] typ. 330 (231 to 429) 100 ( 70 to 130) 650 480 100 33 460 [1MHz] 130 120 [1MHz] 100 ( 70 to 130) 40 15 AVRL1005 Varistor voltage Part No. AVRL101A1R1NTA AVRL101A1R1NTB AVRL101C2R2DTA AVRL101A3R3FTA AVRL101A6R8GTA V1mA(V) [DC1mA] typ. 90 39 90 27 27 Maximum continuous voltage (Rated voltage) Vdc(V) max. 10 10 16 10 10 Capacitance Insulation resistance C(pF) [1MHz, 1Vrms] Rdc(M:) [3Vrms] min. 10 10 10 10 10 1.1[0.8 to 1.4] 1.1[0.8 to 1.4] 2.2[1.7 to 2.7] 3.3[2.3 to 4.3] 6.8[4.8 to 8.8] • All specifications are subject to change without notice. 20140922 / vpd_varistors_avr_en.fm (17/26) Voltage Protection Devices AVR series AVRM1005/AVRL1005 Types ELECTRICAL CHARACTERISTICS CURRENT vs. VOLTAGE CHARACTERISTICS IMPEDANCE vs. FREQUENCY CHARACTERISTICS 1000000 100 100000 10–1 V1mA=8V V1mA=6.8V 10–3 V1mA=39V 10–4 1000 1.1pF 100 100pF 10–5 10 10–6 1 10–7 0 10 20 30 Voltage(V) 40 0.1 50 TRANSMISSION CHARACTERISTICS 650pF 1 10 100 Frequency(MHz) 1000 10000 CAPACITANCE vs. FREQUENCY CHARACTERISTICS 10 15pF 33pF 15pF 6.8pF 3.3pF 10000 V1mA=27V V1mA=12V Impeadance(Ω) Current(A) 10–2 6.8pF 3.3pF 1.1pF 10000 650pF 0 1000 650pF 100pF 100pF Capacitance(pF) Insertion loss(dB) –10 –20 33pF –30 100 33pF 15pF 6.8pF 10 3.3pF –40 1 1.1pF –50 –60 1 10 100 Frequency(MHz) 1000 10000 0.1 1 10 100 Frequency(MHz) 1000 10000 • All specifications are subject to change without notice. 20140922 / vpd_varistors_avr_en.fm (18/26) Voltage Protection Devices AVR series AVRM1608/AVRL1608 Types SHAPE & DIMENSIONS INTERNAL STRUCTURE 1.6±0.1 0.8±0.1 Inner electrode Varistor body (Palladium) (Zinc Oxide: ZnO semiconductor ceramics) Sn plating Ag termination underlayer Ni plating 0.8±0.1 0.2 min. Dimensions in mm CIRCUITS DIAGRAM 0.6 to 0.8 RECOMMENDED LAND PATTERN 0.6 to 0.8 0.6 to 0.8 0.6 to 0.8 • All specifications are subject to change without notice. 20140922 / vpd_varistors_avr_en.fm (19/26) Voltage Protection Devices AVR series AVRM1608/AVRL1608 Types ELECTRICAL CHARACTERISTICS CHARACTERISTICS SPECIFICATION TABLE AVRM1608 Varistor voltage (Breakdown voltage) Part No. AVR-M1608C080MTAAB AVR-M1608C120MT6AB AVR-M1608C120MT2AB AVR-M1608C180MT6AB AVR-M1608C220KT6AB AVR-M1608C220KT2AB AVR-M1608C270KT6AB AVR-M1608C270KT2AB AVR-M1608C270KTACB AVRM1608C270KT800M AVR-M1608C270MTAAB AVR-M1608C270MTABB AVRM1608C390KT271N V1mA(V) [DC1mA] 8 12 12 18 22 22 27 27 27 27 27 27 39 ( 6.4 to 9.6) ( 9.6 to 14.4) ( 9.6 to 14.4) (14.4 to 21.6) (19.8 to 24.2) (19.8 to 24.2) (24 to 30) (24 to 30) (24 to 30) (24 to 30) (21.6 to 32.4) (21.6 to 32.4) (35 to 43) Maximum continuous Clamping voltage voltage (Rated voltage) Vdc(V) Vcl(V) [8/20μs] max. 5.5 15[2A] 7.5 20[2A] 7.5 20[2A] 11 30[2A] 16 34[2A] 16 37[2A] 19 42[2A] 19 42[2A] 19 54[2A] 19 53[2A] 17 52[2A] 17 52[2A] 28 69[2A] Maximum energy Maximum Capacitance peak current E(Joule) [10/1000μs] max. 0.09 0.09 0.06 0.1 0.1 0.03 0.1 0.1 0.05 0.02 0.05 0.05 0.1 Ip(A) [8/20μs] max. 30 50 15 30 30 10 48 20 10 28 2 2 78 C(pF) [1kHz, 1Vrms] typ. 650 1050 400 600 560 210 430 160 60 80 ( 64 to 96) 30 15 270 (189 to 351) AVRL1608 Varistor voltage Part No. AVRL161A1R1NTA AVRL161A1R1NTB AVRL161A3R3FTA AVRL161A6R8GTA V1mA(V) [DC1mA] typ. 90 39 27 27 Maximum continuous voltage (Rated voltage) Vdc(V) max. 10 10 10 10 Capacitance Insulation resistance C(pF) [1MHz, 1Vrms] Rdc(M:) [3Vrms] min. 10 10 10 10 1.1[0.8 to 1.4] 1.1[0.8 to 1.4] 3.3[2.3 to 4.3] 6.8[4.8 to 8.8] • All specifications are subject to change without notice. 20140922 / vpd_varistors_avr_en.fm (20/26) Voltage Protection Devices AVR series AVRM1608/AVRL1608 Types ELECTRICAL CHARACTERISTICS CURRENT vs. VOLTAGE CHARACTERISTICS IMPEDANCE vs. FREQUENCY CHARACTERISTICS 1000000 100 V1mA=18V 10–1 V1mA=12V 100000 V1mA=22V V1mA=8V Current(A) V1mA=27V V1mA=39V 10–3 10–4 1000 1.1pF 100 10–5 10 10–6 1 10–7 0 30pF 15pF 6.8pF 3.3pF 10000 Impeadance(Ω) 10–2 10 20 30 Voltage(V) 40 0.1 50 TRANSMISSION CHARACTERISTICS 1050pF 600pF 400pF 160pF 1 10 6.8pF 3.3pF 1.1pF 10000 10000 1050pF 0 600pF 400pF 160pF 1000 1050pF –20 600pF 400pF –30 Capacitance(pF) Insertion loss(dB) 1000 CAPACITANCE vs. FREQUENCY CHARACTERISTICS 10 –10 100 Frequency(MHz) 15pF 30pF 160pF 30pF 100 15pF 6.8pF 10 3.3pF –40 1.1pF 1 –50 –60 1 10 100 Frequency(MHz) 1000 10000 0.1 1 10 100 Frequency(MHz) 1000 10000 • All specifications are subject to change without notice. 20140922 / vpd_varistors_avr_en.fm (21/26) Voltage Protection Devices AVR series AVRM2012 Type SHAPE & DIMENSIONS INTERNAL STRUCTURE 2.0±0.2 1.25±0.2 Inner electrode Varistor body (Palladium) (Zinc Oxide: ZnO semiconductor ceramics) Sn plating Ag termination underlayer Ni plating 1.0±0.2 0.2 min. Dimensions in mm CIRCUITS DIAGRAM 0.9 to 1.2 RECOMMENDED LAND PATTERN 0.7 to 0.9 0.9 to 1.2 0.7 to 0.9 • All specifications are subject to change without notice. 20140922 / vpd_varistors_avr_en.fm (22/26) Voltage Protection Devices AVR series AVRM2012 Type ELECTRICAL CHARACTERISTICS CHARACTERISTICS SPECIFICATION TABLE Varistor voltage (Breakdown voltage) Part No. AVR-M2012C120MT6AB AVR-M2012C220KT6AB AVR-M2012C390KT6AB V1mA(V) [DC1mA] 12 22 39 ( 9.6 to 14.4) (19.8 to 24.2) (35 to 43) Maximum continuous Clamping voltage voltage (Rated voltage) Vdc(V) Vcl(V) [8/20μs] max. 7.5 20[5A] 16 38[5A] 28 62[5A] Maximum energy Maximum Capacitance peak current E(Joule) [10/1000μs] max. 0.2 0.3 0.3 Ip(A) [8/20μs] max. 60 100 100 C(pF) [1kHz, 1Vrms] typ. 1000 800 430 • All specifications are subject to change without notice. 20140922 / vpd_varistors_avr_en.fm (23/26) Voltage Protection Devices AVR series AVRM2012 Type ELECTRICAL CHARACTERISTICS CURRENT vs. VOLTAGE CHARACTERISTICS IMPEDANCE vs. FREQUENCY CHARACTERISTICS 1000 100 10–1 100 Impeadance(Ω) Current(A) 10–2 10–3 V1mA=12V V1mA=22V V1mA=39V 10–4 10–5 800pF 10 1000pF 430pF 1 10–6 10–7 0 10 20 30 Voltage(V) 40 0.1 50 TRANSMISSION CHARACTERISTICS 1 10 100 Frequency(MHz) 1000 10000 CAPACITANCE vs. FREQUENCY CHARACTERISTICS 10 10000 0 1000pF 800pF 1000pF 430pF Capacitance(pF) Insertion loss(dB) –10 –20 –30 800pF 430pF 1000 –40 –50 –60 1 10 100 Frequency(MHz) 1000 10000 100 1 10 100 Frequency(MHz) 1000 10000 • All specifications are subject to change without notice. 20140922 / vpd_varistors_avr_en.fm (24/26) Voltage Protection Devices AVR series Electrostatic discharge tests ELECTROSTATIC DISCHARGE TESTS (EXAMPLE) AVRL101A3R3FTA 20 20 0 0 ΔC1MHz/C1MHz(%) ΔV1mA/V1mA(%) AVR-M1005C080MTAAB –20 –40 –60 –80 –100 Init. 1 10 100 Number of Discharge(Times) –40 –60 –80 –100 Init. 1000 AVR-M1608C080MTAAB 20 20 0 0 –20 –40 –60 –80 –100 Init. 1 10 100 Number of Discharge(Times) 1000 AVRL161A3R3FTA ΔC1MHz/C1MHz(%) ΔV1mA/V1mA(%) –20 1 10 100 Number of Discharge(Times) –20 –40 –60 –80 –100 Init. 1000 1 10 100 Number of Discharge(Times) 1000 ○Test conditions 150pF, 330: contact discharge Charged voltage /8kV, 0.1s interval ○Measurement equipment 10MΩ High voltage DC power supply 330Ω Discharge gun Test sample 150pF ESD simulator ESD simulator • All specifications are subject to change without notice. 20140922 / vpd_varistors_avr_en.fm (25/26) Voltage Protection Devices AVR series Electrostatic absorption characteristics DISCHARGE VOLTAGE WAVEFORM (EXAMPLE) DISCHARGE CURRENT WAVEFORM 350 8 150pF, 330Ω, Contact discharge, Test level 1 Discharge current(A) 7 6 Open waveform 300 AVR-M1005C120MTAAB / V1mA:12V 250 Voltage(V) 5 4 3 2 200 AVR-M1005C080MTAAB / V1mA:8V 150 Zener diode /Vz:6.2V 100 50 1 0 –1 –50 0 50 100 150 Time(ns) 200 250 300 0 –50 –50 0 50 100 150 Time(ns) 200 250 300 ESD ABSORPTION CHARACTERISTICS COMPARISON OF VARIOUS ELEMENTS (EXAMPLE) Clamping voltage (V) 350 300 250 269V down 258V down 271V down 200 (voltage) 100 101V down 50 0 Open waveform 93V down 96V down AVR-M1005C080MTAAB AVR-M1005C120MTAAB Zener diode/Vz:6.2V Peak 316 45 58 47 Average 117 16 24 21 WAVEFORM PARAMETERS [IEC61000-4-2] Test level 1 2 3 4 Peak voltage:Peak voltage of standing up part Average voltage : Average voltage of 30 to 100ns Peak voltage 150 ESD Charge voltage (kV) 2 4 6 8 First peak current of discharge (A) 7.5 15 22.5 30 ESD (Electro Static Discharge) absorption characteristics of V1mA-8V is superior to Vz-6.2V Zener diode. Average voltage 30 (ns) MEASUREMENT EQUIPMENT 10MΩ Rise time (ns) 0.7 to 1.0 0.7 to 1.0 0.7 to 1.0 0.7 to 1.0 100 High voltage DC power supply 330Ω 150pF ESD simulator Discharge gun Test sample 60dB attenuator ESD simulator 50Ω Oscilloscope I/O impedance: 50Ω Frequency range: DC to 18GHz • All specifications are subject to change without notice. 20140922 / vpd_varistors_avr_en.fm (26/26) Voltage Protection Devices AVR series Packaging Style REEL DIMENSIONS ø60min. 2.0±0.5 1.0 8.4 +2.0 –0.0 ø13±0.2 ø21±0.8 14.4max. ø180±2.0 Dimensions in mm B 3.5±0.05 4.0±0.1 A P1 8.0±0.3 2.0±0.05 1.5 +0.1 0 1.75±0.1 TAPE DIMENSIONS K Dimensions in mm Type AVRM0402/AVRL0402 AVRM0603/AVRL0603 AVRM1005/AVRL1005 AVRM1608/AVRL1608 AVRM2012 160min. Taping A 0.26±0.04 0.38±0.05 0.65±0.1 1.1±0.2 1.6±0.2 B 0.46±0.04 0.68±0.05 1.15±0.1 1.9±0.2 2.3±0.2 P1 2.0±0.05 2.0±0.05 2.0±0.05 4.0±0.1 4.0±0.1 K 0.4max. 0.45max. 0.65max. 1.1max. 1.7max. 200min. Drawing direction 300min. Dimensions in mm • All specifications are subject to change without notice. 20140922 / vpd_varistors_avr_en.fm
AVR-M1005C080MTABB 价格&库存
很抱歉,暂时无法提供与“AVR-M1005C080MTABB”相匹配的价格&库存,您可以联系我们找货
AVR-M1005C080MTABB
  • 10000+0.3162510000+0.04091
  • 100000+0.29528100000+0.03820
AVR-M1005C080MTABB
