AVR-M1005C180MTAAB
AVR-M1005C180MTAAB
    TDK(东电化)
    特性:IEC61000-4-2 LEVEL4 compliant。 可靠性特性基于 AEC-Q200 条件评估(汽车产品)。 高 ESD 耐受电压。 有小型产品可供选择。 支持 85℃、125℃、1...
AVR-M1005C180MTAAB 数据手册
V o l t a g e P r o t e c t i o n D e v i c e s February 2024 Chip varistors ESD/Voltage protection devices AVR/SGNE series AVRM/AVR-M : Standard Type AVRL : Low Capacitance Type AVRH : High reliability Type SGNE : Low Clamp Type (2/20) Voltage Protection Devices REMINDERS FOR USING THESE PRODUCTS Before using these products, be sure to request the delivery specifications. SAFETY REMINDERS Please pay sufficient attention to the warnings for safe designing when using this products. REMINDERS ⃝Please pay careful attention to the precautions and follow safe designing practices when using these products. ⃝Please observe the following precautions in order to avoid problems with chip varistors such as characteristic degradation and element destruction Please store these products in an environment with a temperature of 5 to 40°C and humidity level of 20 to 70%RH, and use them within six months. Poor storage conditions may lead to the deterioration of the solderability of the edge electrodes, so please be careful to avoid contact with humidity, dew condensation, dust, toxic gas (hydrogen, hydrogen sulfide, sulfurous acid, chlorine, ammonia, etc.), direct sunlight, and so on. Please do not use products that have been dropped or detached when mounting. Please solder with the reflow soldering method, and not the flow (dip) soldering method. ⃝Please observe the following precautions to avoid problems with varistors such as characteristic degradation and element destruction, which ultimately lead to the generation of heat and smoke with the elements. Do not use in locations where the temperatures exceed the operating temperature range such as under direct sunlight or near sources of heat. Do not use in locations where there are high levels of humidity such as under direct exposure to weather and areas where steam is released. Do not use in locations such as dusty areas, high-saline environments, places where the atmosphere is contaminated with corrosive gas, etc. Avoid powerful vibrations, impact (such as by dropping), pressure, etc. that may lead to splitting in the products. Do not use with a voltage that exceeds the maximum allowable circuit voltage. When resin coating (including modular) a varistor, do not use a resin that will cause deterioration of the varistor. Be sure never to use resin that generates hydrogen as palladium is used for the inner electrode. Avoid attachment near combustible materials. ⃝Please contact our sales offices when considering the use of the products listed on this catalog for applications, whose performance and/or quality require a more stringent level of safety or reliability, or whose failure, malfunction or trouble could cause serious damage to society, person or property (\qspecific uses\q such as automobiles, airplanes,medical instruments, nuclear devices, etc.) as well as when considering the use for applications that exceed the range and conditions of this catalog. ⃝As range of catalog, conditions are transcended, or for damage that generated by was used in application specific, etc, accept no the responsibility, wish. ⃝Please take appropriate measures such as acquiring protective circuits and devices that meet the uses, applications, and conditions of the instruments and keeping backup circuits. Please be sure to request delivery specifications that provide further details on the features and specifications of the products for proper and safe use. Please note that the contents may change without any prior notice due to reasons such as upgrading. 20240206 / vpd_varistors_avr_en (3/20) Voltage Protection Devices Chip varistors RoHS Directive Compliant Product Compatible with lead-free solders   Overview of the AVR/SGNE series ■CHARACTERISTICS OF CHIP VARISTOR Varistors are voltage dependent nonlinear resistive elements with a resistance that decreases rapidly when the voltage is over the constant value. Varistors become zener diode of 2 serial connection and equivalent, and does not have polarity. □current vs. voltage characteristics ■EQUIVALENT CIRCUIT OF CHIP VARISTORS 2 Zener Diodes A capacitance content ■CHIP VARISTORS FEATURE ⃝IEC61000-4-2 LEVEL4 compliant. ⃝Reliability characteristics evaluated based on AEC-Q200 condition. (Automotive products) ⃝High ESD withstanding voltage ⃝Small-sized products are available Current(A) 10–1 10–2 Zener diode Positive direction 10–3 /Vz:6.8V Chip varistor /V1mA:12V 10–4 10–5 –18 –14 –10 –6 –2 2 –10–5 6 10 14 18 ⃝85℃,125℃,150℃ Supported –10–4 –10–3 Negative direction Fig.1 Internal structure of multilayer chip varistors –10–2 –10–1 ① Voltage(V) □the effect of the varistor Without varistor A malfunction and failure of electronic equipment ESD, Surge voltage Power line Signal line IC ② With Varistor ⑤ ④ ③ Suppress abnormal voltage by inserting varistor in a circuit ESD, Surge voltage No. (1) Power line Signal line IC (2) (3) (4) (5) Name Semiconductor ceramics Internal electrode(Pd) Ag Terminal electrode Ni Sn Insert a varistor between a line and ground : Chip varistor Please be sure to request delivery specifications that provide further details on the features and specifications of the products for proper and safe use. Please note that the contents may change without any prior notice due to reasons such as upgrading. 20240206 / vpd_varistors_avr_en (4/20) Voltage Protection Devices Chip varistors RoHS Directive Compliant Product Compatible with lead-free solders   Overview of the AVR/SGNE series ■PART NUMBER CONSTRUCTION □AVRM series AVRM 1608 C 390 K T 271 N Series name LxW dimensions (mm) Structure code Varistor voltage (V) Varistor voltage tolerance (%) Packaging style Capacitance (pF) Capacitance tolerance (%) 271=27x101 221 220 271 270 K M N AVRM series 0402 0603 1005 1608 2012 0.4x0.2 C General structure 390=39x100 0.6x0.3 6R8 6.8 1.0x0.5 270 27 1.6x0.8 390 39 2.0x1.2 K M N ±10 ±20 ±30 T Taping ±10 ±20 ±30 □AVR-M series AVR-M 1608 C 270 M T AAB Series name LxW dimensions (mm) Structure code Varistor voltage (V) Varistor voltage tolerance (%) Packaging style Company special symbol AVR-M series 0603 1005 1608 2012 0.6x0.3 C General structure 270=27x100 1.0x0.5 G Conductive paste compatible 080 8 1.6x0.8 120 12 2.0x1.2 270 27 K M N ±10 ±20 ±30 T Taping □AVRL series AVRL 10 1D 3R3 F T A Series name LxW dimensions (mm) Maximum continuous voltage (V) Capacitance (pF) Capacitance tolerance (pF) Packaging style Company special symbol AVRL series L=Low cap 04 06 10 16 0.4x0.2 0.6x0.3 1.0x0.5 1.6x0.8 1A 1D 1E 10 20 25 R50 1R1 3R3 6R8 0.5 1.1 3.3 6.8 F G N ±1 ±2 ±0.3 T Taping Please be sure to request delivery specifications that provide further details on the features and specifications of the products for proper and safe use. Please note that the contents may change without any prior notice due to reasons such as upgrading. 20240206 / vpd_varistors_avr_en (5/20) Voltage Protection Devices Chip varistors RoHS Directive Compliant Product Compatible with lead-free solders   Overview of the AVR/SGNE series ■PART NUMBER CONSTRUCTION □SGNE series SGNE 04 C 080 M T Series name LxW dimensions (mm) Structure code Varistor voltage (V) Varistor voltage tolerance (%) Packaging style Low Clamp series 04 0.4x0.2 06 0.6x0.3 10 1.0x0.5 C General structure 080=8x100 080 8 270 27 150 N 25 Capacitance (pF) Capacitance tolerance ESD clamping voltageAverage voltage(IEC61000-4-2, 8kV) 150=15x100 6R8 6.8 150 15 N G M ±20 T Taping ±30% ±2.0pF Please be sure to request delivery specifications that provide further details on the features and specifications of the products for proper and safe use. Please note that the contents may change without any prior notice due to reasons such as upgrading. 20240206 / vpd_varistors_avr_en (6/20) Voltage Protection Devices Chip varistors RoHS Directive Compliant Product Compatible with lead-free solders   Overview of the AVR/SGNE series ■PART NUMBER CONSTRUCTION □AVRH series AVRH 10 C 270 K T Series name LxW dimensions (mm) Structure code Varistor voltage (V) Varistor voltage tolerance (%) Packaging style AVRH series H=High Reliability 10 1.0x0.5 C General structure 270=27x100 270 27 390 39 101 100 150 N A 8 Capacitance (pF) Capacitance tolerance ESD voltage tolerance IEC61000-4-2 (kV) Operating temperature limit (°C) 150=15x100 4R7 4.7 150 15 500 50 K M N Y ±10% ±20% ±30% Special A E 25 8 8 K Y ±10 Special T Taping 150 □AVRH series(array) AVRH 16 A2 C 270 K T Series name LxW dimensions (mm) Type Structure code Varistor voltage (V) Varistor voltage tolerance (%) Packaging style AVRH series H=High Reliability 16 1.6x0.8 A2 2in1 Array C General structure 270=27x100 270 27 200 N A 8 Capacitance (pF) Capacitance tolerance ESD voltage tolerance IEC61000-4-2 (kV) Operating temperature limit (°C) 200=20x100 200 20 N ±30% A 25 8 K ±10 T Taping 150 Please be sure to request delivery specifications that provide further details on the features and specifications of the products for proper and safe use. Please note that the contents may change without any prior notice due to reasons such as upgrading. 20240206 / vpd_varistors_avr_en (7/20) Voltage Protection Devices Chip varistors RoHS Directive Compliant Product Compatible with lead-free solders   Overview of the AVR/SGNE series ■TERMINOLOGY Item Unit Description Varistor voltage(Breakdown voltage) V1mA(V) Chip varistor-terminal voltage when DC1mA was flowed Maximum continuous voltage Vdc(V) Clamping voltage Vcl(V) Maximum energy E(Joule) Maximum peak current Ip(A) Capacitance C(pF) Capacitance Difference ΔC(pF) *1 8/20μs test waveform *2 10/1000μs test waveform 100% 90% Current 100% 90% Current DC voltage that is continuously applied between chip varistor terminalsTerminal chip varistors leakage current-value: 50μA max.Voltage appearing across the varistor when a pulse current (8/ 20μs*1) of specified peak value is applied. Voltage between terminal chip varistors of the Specified peak current value of the impulse current (8/20μs*1) is applied When applied specified peak impulse current-value current (10/1000μs*2) once, maximum energy that electrical property of chip varistors be not deteriorated When applied impulse current (8/20μs*1) once, maximum current that electrical property of chip varistors be not deteriorated Oscillator frequency 1kHz or 1MHz, capacitance between chip varistor-terminal in oscillator voltage 1Vrms Measure the capacitance of each Ch at an oscillator frequency of 1 MHz and an oscillator voltage of 1 V, The absolute value of the difference of the capacitance values obtained 50% 50% 10μs 8μs 20μs 1000μs Time Time Please be sure to request delivery specifications that provide further details on the features and specifications of the products for proper and safe use. Please note that the contents may change without any prior notice due to reasons such as upgrading. 20240206 / vpd_varistors_avr_en (8/20) Voltage Protection Devices Chip varistors RoHS Directive Compliant Product Compatible with lead-free solders   AVR/SGNE series 0402 type ■SHAPE & DIMENSIONS ■RECOMMENDED LAND PATTERN 0.2±0.02 0.18 to 0.20 0.4±0.02 0.15 to 0.21 0.2 Nom. 0.15 to 0.21 Dimensions in mm 0.2±0.02 0.07min. Electrode material Internal:Pd External:Ag/Ni/Sn Dimensions in mm ■PRODUCT CHARACTERISTICS LIST Item V1mA C Vdc Vcl E Ip AVRM0402C6R8NT101N AVRM0402C120MT330N AVRL041E1R1NTA SGNE04C080MT150N25 (V) 6.8(4.76 to 8.84) 12(9.6 to 14.4) 39(31.2 to 46.8) 8(6.4 to 9.6) 1kHz/1MHz* (pF) 100(70 to 130) 33(23.1 to 43.9) 1.1(0.8 to 1.4)* 15(10.5 to 19.5)* DC (V) 3.5 5.5 25 5.5 10/1000μs (J) 0.01 0.005 0.005 8/20μs (A) 4 1 1 8/20μs (V) 15(1A) 20(1A) 20(1A) Operating temperature range (°C) -40 to 85 -40 to 85 -40 to 85 -40 to 85 ESD voltage tolerance AEC-Q200 IEC61000-4-2 (kV) 8 8 4 8 V1mA: Varistor voltage, C:Capacitance, Vdc:Maximum allowable circuit voltage, Vcl:Clamping voltage, E:Energy capacity, Ip:Surge current Please be sure to request delivery specifications that provide further details on the features and specifications of the products for proper and safe use. Please note that the contents may change without any prior notice due to reasons such as upgrading. 20240206 / vpd_varistors_avr_en (9/20) Voltage Protection Devices Chip varistors RoHS Directive Compliant Product Compatible with lead-free solders   AVR/SGNE series 0603 type ■SHAPE & DIMENSIONS ■RECOMMENDED LAND PATTERN 0.3±0.03 0.25 to 0.35 0.6±0.03 0.2 to 0.3 0.25 to 0.35 0.2 to 0.3 Dimensions in mm 0.3±0.03 0.1min Electrode material Internal:Pd External:Ag/Ni/Sn Dimensions in mm ■PRODUCT CHARACTERISTICS LIST Item V1mA C Vdc Vcl E Ip AVRM0603C6R8NT101N AVRM0603C6R8NT331N AVRM0603C080MT101N AVRM0603C120MT150N AVR-M0603C120MTAAB AVRM0603C120MT101N AVRM0603C200MT150N AVRL061FR50ETA AVRL061E1R1NTA SGNE06C080MT150N25 SGNE06C270MT6R8G60 (V) 6.8(4.76 to 8.84) 6.8(4.76 to 8.84) 8(6.4 to 9.6) 12(10 to 15.6) 12(9.6 to 14.4) 12(10 to 15.6) 20(16 to 24) 140(112 to 168) 39(31.2 to 46.8) 8(6.4 to 9.6) 27(21.6 to 32.4) 1kHz/1MHz* (pF) 100(70 to 130) 330(231 to 429) 100(70 to 130) 15(10.5 to 19.5) 33(25 to 41) 100(70 to 130) 15(10.5 to 19.5) 0.5(0.3 to 0.7)* 1.1(0.8 to 1.4)* 15(10.5 to 19.5)* 6.8(4.8 to 8.8) DC (V) 3.5 3.5 5.5 5.5 7.5 5.5 12 30 25 5.5 15 10/1000μs (J) 0.01 0.02 0.01 0.003 0.01 0.01 0.01 0.005 0.005 8/20μs (A) 10 16 4 1 1 5 1 1 1 8/20μs (V) 14(1A) 14(1A) 17(1A) 35(1A) 23(1A) 20(1A) 40(1A) 21(1A) 54(1A) Operating temperature range (°C) -40 to 85 -40 to 85 -40 to 85 -40 to 85 -40 to 85 -40 to 85 -40 to 85 -40 to 85 -40 to 85 -40 to 85 -40 to 85 ESD voltage tolerance AEC-Q200 IEC61000-4-2 (kV) 8 8 8 8 8 8 8 4 4 8 8 V1mA: Varistor voltage, C:Capacitance, Vdc:Maximum allowable circuit voltage, Vcl:Clamping voltage, E:Energy capacity, Ip:Surge current Please be sure to request delivery specifications that provide further details on the features and specifications of the products for proper and safe use. Please note that the contents may change without any prior notice due to reasons such as upgrading. 20240206 / vpd_varistors_avr_en (10/20) Voltage Protection Devices Chip varistors RoHS Directive Compliant Product Compatible with lead-free solders   AVR/SGNE series 1005 type ■SHAPE & DIMENSIONS ■RECOMMENDED LAND PATTERN 0.5±0.05 0.4 to 0.6 1±0.05 0.35 to 0.45 0.3 to 0.5 0.35 to 0.45 Dimensions in mm 0.5±0.05 0.1 min. Electrode material Internal:Pd External:Ag/Ni/Sn Dimensions in mm ■PRODUCT CHARACTERISTICS LIST Item V1mA C Vdc Vcl E Ip AVRM1005C6R8NT101N AVRM1005C6R8NT331N AVR-M1005C080MTAAB AVR-M1005C080MTABB AVR-M1005C080MTACB AVR-M1005C080MTADB AVR-M1005C120MTAAB AVR-M1005C120MTACC AVR-M1005C180MTAAB AVRM1005C270KT101N AVR-M1005C270MTAAB AVR-M1005C270MTABB AVRL101A1R1NTA AVRL101E1R1NTB AVRL101D3R3FTA AVRL101D6R8GTA SGNE10C080MT150N28 (V) 6.8(4.76 to 8.84) 6.8(4.76 to 8.84) 8(6.4 to 9.6) 8(6.4 to 9.6) 8(6.4 to 9.6) 8(6.4 to 9.6) 12(9.6 to 14.4) 12(9.6 to 14.4) 18(14.4 to 21.6) 27(24 to 30) 27(21.6 to 32.4) 27(21.6 to 32.4) 90(79.6 to 110.4) 39(31.2 to 46.8) 27(21.6 to 32.4) 27(21.6 to 32.4) 8(6.4 to 9.6) 1kHz/1MHz* (pF) 100(70 to 130) 330(231 to 429) 650(520 to 780) 100(55 to 145) 33(14 to 52) 480(384 to 576) 130(104 to 156) 460(276 to 644)* 120(72 to 168)* 100(70 to 130) 40(24 to 42) 15(10.5 to 19.5) 1.1(0.8 to 1.4)* 1.1(0.8 to 1.4)* 3.3(2.3 to 4.3)* 6.8(4.8 to 8.8)* 15(10.5 to 19.5) DC (V) 3.5 3.5 5.5 5.5 5.5 5.5 7.5 7.5 11 19 15 15 10 25 20 20 5.5 10/1000μs (J) 0.02 0.008 0.04 0.02 0.01 0.04 0.05 0.01 0.06 0.06 0.06 0.05 0.01 0.01 0.01 8/20μs (A) 10 24 25 3 1 25 10 24 16 4 4 1 0.5 1 19 8/20μs (V) 14(1A) 15(1A) 14(1A) 15(1A) 19(1A) 14(1A) 20(1A) 21(1A) 30(1A) 44(1A) 47(1A) 49(1A) 62(0.5A) 58(1A) 21(1A) Operating temperature range (°C) -40 to 85 -40 to 85 -40 to 85 -40 to 85 -40 to 85 -40 to 85 -40 to 85 -40 to 85 -40 to 85 -40 to 85 -40 to 85 -40 to 85 -40 to 85 -40 to 85 -40 to 125 -40 to 125 -40 to 85 ESD voltage tolerance IEC61000-4-2 (kV) 8 8 8 8 8 8 8 8 8 8 8 8 8 4 8 8 8 AEC-Q200 ✓ ✓ V1mA: Varistor voltage, C:Capacitance, Vdc:Maximum allowable circuit voltage, Vcl:Clamping voltage, E:Energy capacity, Ip:Surge current Please be sure to request delivery specifications that provide further details on the features and specifications of the products for proper and safe use. Please note that the contents may change without any prior notice due to reasons such as upgrading. 20240206 / vpd_varistors_avr_en (11/20) Voltage Protection Devices Chip varistors RoHS Directive Compliant Product Compatible with lead-free solders   AVRH series 1005 type ■SHAPE & DIMENSIONS ■RECOMMENDED LAND PATTERN 0.5±0.05 0.4 to 0.6 1±0.05 0.35 to 0.45 0.3 to 0.5 0.35 to 0.45 Dimensions in mm 0.5±0.05 0.1 min. Electrode material Internal:Pd External:Ag/Ni/Sn Dimensions in mm ■PRODUCT CHARACTERISTICS LIST Item V1mA C Vdc Vcl E Ip AVRH10C220YT201MA8 AVRH10C270KT150NA8 AVRH10C270KT350NA8 AVRH10C390KT500NA8 AVRH10C101KT4R7FA8 AVRH10C101KT4R7YA8 AVRH10C101KT1R1NE8 AVRH10C101KT1R2YE8 AVRH10C221KT1R5YA8 (V) 22(19 to 26) 27(24 to 30) 27(24 to 30) 39(35 to 43) 100(90 to 110) 115(103.5 to 126.5) 110(100 to 120) 110(100 to 120) 220(198 to 242) 1kHz/1MHz* (pF) 200(160 to 240) 15(10.5 to 19.5) 35(24.5 to 45.5) 50(35 to 65) 4.7(3.7 to 5.7) 4.7(4.13 to 5.27)* 1.1(0.8 to 1.4)* 1.23(1.10 to 1.36)* 1.5(1.37 to 1.63)* DC (V) 16 19 19 28 70 70 70 70 70 10/1000μs (J) 0.07 0.02 0.02 0.06 0.03 0.03 0.007 0.007 0.007 8/20μs (A) 40 2 8 15 1 1 0.3 0.3 0.5 8/20μs (V) 40(2A) 52(2A) 52(2A) 72(2A) 190(1A) 212(1A) 187(0.3A) 187(0.3A) 400(0.5A) Operating temperature range (°C) -55 to 150 -55 to 150 -55 to 150 -55 to 150 -55 to 150 -55 to 150 -55 to 150 -55 to 150 -55 to 150 ESD voltage tolerance IEC61000-4-2 (kV) 25 25 25 25 25 25 8 8 25 AEC-Q200 ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ V1mA: Varistor voltage, C:Capacitance, Vdc:Maximum allowable circuit voltage, Vcl:Clamping voltage, E:Energy capacity, Ip:Surge current Please be sure to request delivery specifications that provide further details on the features and specifications of the products for proper and safe use. Please note that the contents may change without any prior notice due to reasons such as upgrading. 20240206 / vpd_varistors_avr_en (12/20) Voltage Protection Devices Chip varistors RoHS Directive Compliant Product Compatible with lead-free solders   AVR series 1608 type ■SHAPE & DIMENSIONS ■RECOMMENDED LAND PATTERN 0.8±0.1 0.6 to 0.8 1.6±0.1 0.6 to 0.8 0.6 to 0.8 0.6 to 0.8 Dimensions in mm 0.8±0.1 0.2 min. Electrode material Internal:Pd, Pd/Ag External:Ag/Ni/Sn Dimensions in mm ■PRODUCT CHARACTERISTICS LIST Item V1mA C Vdc Vcl E Ip AVR-M1608C080MTAAB AVR-M1608C120MT2AB AVR-M1608C120MT6AB AVR-M1608C180MT6AB AVR-M1608C220KT2AB AVR-M1608C220KT6AB AVR-M1608C270MTABB AVR-M1608C270MTAAB AVR-M1608C270KTACB AVRM1608C270KT800M AVR-M1608C270KT2AB AVRM1608C270KT221M AVR-M1608C270KT6AB AVR-M1608G270KT6AB AVRM1608C390KT271N AVRM1608C560KT101M AVRM1608C720KT750M AVRL161A1R1NTA AVRL161A1R1NTB AVRL161D3R3FTA AVRL161D6R8GTA (V) 8(6.4 to 9.6) 12(9.6 to 14.4) 12(9.6 to 14.4) 18(14.4 to 21.6) 22(19.8 to 24.2) 22(19.8 to 24.2) 27(21.6 to 32.4) 27(21.6 to 32.4) 27(24 to 30) 27(24 to 30) 27(24 to 30) 27(24 to 30) 27(24 to 30) 27(24 to 30) 39(35 to 43) 56(50.4 to 61.6) 72(64.8 to 79.2) 90(79.6 to 110.4) 39(31.2 to 46.8) 27(21.6 to 32.4) 27(21.6 to 32.4) 1kHz/1MHz* (pF) 650(520 to 780) 400(320 to 480) 1050(840 to 1260) 600(480 to 720) 210(168 to 252) 560(448 to 672) 15(11 to 20) 30(21 to 39) 60(42 to 78) 80(64 to 96) 160(128 to 192) 220(176 to 264) 430(344 to 516) 430(344 to 516) 270(216 to 324) 100(80 to 120) 75(60 to 90) 1.1(0.8 to 1.4)* 1.1(0.8 to 1.4)* 3.3(2.3 to 4.3)* 6.8(4.8 to 8.8)* DC (V) 5.5 7.5 7.5 11 16 16 17 17 19 19 19 19 19 19 28 40 53 10 10 20 20 10/1000μs (J) 0.09 0.06 0.09 0.1 0.03 0.1 0.05 0.05 0.05 0.02 0.1 0.1 0.1 0.1 0.1 0.3 0.1 0.01 0.01 8/20μs (A) 30 15 50 30 10 30 2 2 10 28 20 56 48 48 78 60 40 0.5 1 8/20μs (V) 15(2A) 20(2A) 20(2A) 30(2A) 37(2A) 34(2A) 52(2A) 52(2A) 54(2A) 53(2A) 42(2A) 52(2A) 42(2A) 42(2A) 69(2A) 113(2A) 135(2A) 62(0.5A) 58(1A) Operating temperature range (°C) -40 to 85 -40 to 85 -40 to 125 -40 to 85 -40 to 125 -40 to 125 -55 to 150 -55 to 150 -55 to 150 -55 to 150 -55 to 150 -55 to 150 -55 to 150 -55 to 150 -55 to 150 -55 to 150 -55 to 150 -40 to 85 -40 to 85 -40 to 125 -40 to 125 ESD voltage tolerance IEC61000-4-2 (kV) 8 8 8 8 25 25 25 25 25 25 25 25 25 25 25 25 25 8 4 8 8 AEC-Q200 ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ V1mA: Varistor voltage, C:Capacitance, Vdc:Maximum allowable circuit voltage, Vcl:Clamping voltage, E:Energy capacity, Ip:Surge current Please be sure to request delivery specifications that provide further details on the features and specifications of the products for proper and safe use. Please note that the contents may change without any prior notice due to reasons such as upgrading. 20240206 / vpd_varistors_avr_en (13/20) Voltage Protection Devices Chip varistors RoHS Directive Compliant Product Compatible with lead-free solders   AVRH series(array) 1608 type ■SHAPE & DIMENSIONS ■RECOMMENDED LAND PATTERN 1.60±0.2 0.40 0.60 0.80±0.15 0.40 0.40 0.60±0.1 0.45±0.10 Electrode material Internal:Pd External:Ag/Ni/Sn 0.60 1.00 Dimensions in mm 0.25±0.10 Dimensions in mm ■PRODUCT CHARACTERISTICS LIST Item V1mA C Vdc Vcl E Ip ΔC AVRH16A2C270KT200NA8 (V) 27(24 to 30) 1kHz/1MHz* (pF) 20(14 to 26) DC (V) 19 10/1000μs (J) 0.04 8/20μs (A) 4 1MHz (pF) (°C) 1.0 -55 to 150 8/20μs (V) 60(2A) Operating temperature range ESD voltage tolerance IEC61000-4-2 (kV) 25 AEC-Q200 ✓ V1mA: Varistor voltage, C:Capacitance, Vdc:Maximum allowable circuit voltage, Vcl:Clamping voltage, E:Energy capacity, Ip:Surge current Please be sure to request delivery specifications that provide further details on the features and specifications of the products for proper and safe use. Please note that the contents may change without any prior notice due to reasons such as upgrading. 20240206 / vpd_varistors_avr_en (14/20) Voltage Protection Devices Chip varistors RoHS Directive Compliant Product Compatible with lead-free solders   AVR series 2012 type ■SHAPE & DIMENSIONS ■RECOMMENDED LAND PATTERN 1.25±0.2 0.9 to 1.2 2±0.2 0.7 to 0.9 0.9 to 1.2 0.7 to 0.9 Dimensions in mm 1.0±0.2 0.2 min. Electrode material Internal:Pd External:Ag/Ni/Sn Dimensions in mm ■PRODUCT CHARACTERISTICS LIST Item V1mA C Vdc Vcl E Ip AVR-M2012C120MT6AB AVR-M2012C220KT6AB AVRM2012C330KT801N AVR-M2012C390KT6AB AVRM2012C560KT251M AVRM2012C720KT201M (V) 12(9.6 to 14.4) 22(19.8 to 24.2) 33(30 to 36) 39(35 to 43) 56(50.4 to 61.6) 72(64.8 to 79.2) 1kHz/1MHz* (pF) 1000(550 to 1450) 800(560 to 1040) 800(560 to 1040) 430(301 to 559) 250(200 to 300) 200(160 to 240) DC (V) 7.5 16 24 28 40 53 10/1000μs (J) 0.2 0.3 0.5 0.3 0.3 0.3 8/20μs (A) 60 100 240 100 150 100 8/20μs (V) 20(5A) 38(5A) 59(5A) 62(5A) 113(5A) 142(5A) Operating temperature range (°C) -40 to 85 -40 to 125 -55 to 150 -55 to 150 -55 to 150 -55 to 150 ESD voltage tolerance IEC61000-4-2 (kV) 8 25 25 25 25 25 AEC-Q200 ✓ ✓ ✓ ✓ ✓ V1mA: Varistor voltage, C:Capacitance, Vdc:Maximum allowable circuit voltage, Vcl:Clamping voltage, E:Energy capacity, Ip:Surge current Please be sure to request delivery specifications that provide further details on the features and specifications of the products for proper and safe use. Please note that the contents may change without any prior notice due to reasons such as upgrading. 20240206 / vpd_varistors_avr_en (15/20) Voltage Protection Devices Chip varistors RoHS Directive Compliant Product Compatible with lead-free solders   AVR/SGNE series Electrostatic absorption characteristics ■discharge voltage waveform (example) Voltage(V) □WITHOUT VARISTOR, WAVEFORM AT VARISTOR INSTALLATION 1800 1600 1400 1200 1000 800 600 400 200 0 –200 –50 Without Varistor AVRH10C270KT150NA8 AVR-M1608C270KT6AB AVR-M1608C220KT6AB 0 50 100 150 Time(ns) 200 250 300 Voltage(V) □WAVEFORM AT VARISTOR INSTALLATION 180 160 140 120 100 80 60 40 20 0 –20 –50 AVRH10C270KT150NA8 AVR-M1608C270KT6AB AVR-M1608C220KT6AB 0 50 100 150 Time(ns) 200 250 300 □Test conditions 150pF/330Ω (IEC61000-4-2) Contact discharge, Charged voltage 8kV □TEST CIRCUIT DIAGRAM Discharge gun Test sample 60dB attenuator ESD simulator 50Ω Oscilloscope I/O impedance: 50Ω Shield Discharge Point SMA Connector PCB ESD Simulator Chip Varistor Coaxial Cable Attenuator(60dB) 50Ω Oscilloscope 50Ω Please be sure to request delivery specifications that provide further details on the features and specifications of the products for proper and safe use. Please note that the contents may change without any prior notice due to reasons such as upgrading. 20240206 / vpd_varistors_avr_en (16/20) Voltage Protection Devices Chip varistors RoHS Directive Compliant Product Compatible with lead-free solders   Attention on a circuit board design ■Board design When attached to chip varistors, amount of silver used (fillet size) has direct impact on chip varistors after mounting. Thus, sufficient consideration is necessary. Set of land dimensions (1) As the stress rises in the chip varistors owing to the increase in silver, breakage and cracks will occur. Cause including crack, as caution on board land design, configure the shape and dimensions so that the amount of silver is appropriate. If you installed 2 or more parts in the Common Land, separated by a solder resist and special land of each component. (2) When peak levels panning-at soldering is excessive, by solder contraction stress, mechanical-thermal stress causes a Yasuku chip crack. In addition, when the peak level is underestimated, terminal electrode fixed strength is insufficient. This causes chip dropouts and may affect circuit reliability. Representative example of the panning of peak levels is shown in the following. Recommended silver dose Solder stress is increased, and it is easy for a crack to form. Solder volume overload Most large serving amount Minimum prime amount Decent solder volume Fixed strength is weak, and there is connection a problem and risk of loss. Solder volume deficit Recommended silver dose Example Improvement example (land division) Cases to avoid Leads Lead wire and land of part discrete doubles up Chip Leads Solder Solder resist PCB Chassis Arrangements in the vicinity Solder resist Solder (ground solder) L2 L1 L2>L1 Land Arrangements of chip component\qs companion Solder resist Excess solder Land Missing solder Please be sure to request delivery specifications that provide further details on the features and specifications of the products for proper and safe use. Please note that the contents may change without any prior notice due to reasons such as upgrading. 20240206 / vpd_varistors_avr_en (17/20) Voltage Protection Devices Chip varistors RoHS Directive Compliant Product Compatible with lead-free solders   Attention on a circuit board design Arrangements of components (1) I was based on camber of substrate and suggested protocol of chip varistors arrangement, as stress does not join to the utmost is shown in following. Substrate for flexural stressAdverse events Perforation or slit Substrate for flexural stress Good example (2) In payment near by board, depending on mount position of chip varistors, as mechanical stress varies, please refer to the following diagram. E D Perforation C Perforation or slit B A Direction of surface solder Slit Solder the mountain fold as a bottom. [Please review Solder the mountain fold as the italicized portion, as I a top. am unsure what you mean to convey here.] Perforation or slit The order of A > B = C > D > E eases the stress. Perforation or slit Chip arrangements (direction) Mounted vertically to the perforation and slit. L1 Distance from perforation and slit portion Mounted horizontally to the perforation and slit. L2 (L1
AVR-M1005C180MTAAB 价格&库存
很抱歉,暂时无法提供与“AVR-M1005C180MTAAB”相匹配的价格&库存,您可以联系我们找货
AVR-M1005C180MTAAB
  • 1+0.970751+0.12618
  • 10+0.6699310+0.08708
  • 25+0.5858725+0.07615
  • 100+0.49317100+0.06410
  • 250+0.44885250+0.05834
  • 500+0.42184500+0.05483
  • 1000+0.399711000+0.05196
  • 2500+0.376292500+0.04891
  • 5000+0.362205000+0.04708
库存:89
AVR-M1005C180MTAAB
  • 62+0.7477062+0.09719
  • 100+0.62869100+0.08172
  • 250+0.55797250+0.07253
  • 500+0.53888500+0.07004
  • 1000+0.484991000+0.06304
  • 2500+0.480502500+0.06246
  • 5000+0.348685000+0.04532
  • 10000+0.2911410000+0.03784
库存:10059
AVR-M1005C180MTAAB
  • 10000+0.3373610000+0.04385
  • 20000+0.3281620000+0.04266
  • 30000+0.3235530000+0.04206
  • 50000+0.3184550000+0.04139
  • 70000+0.3154770000+0.04101
  • 100000+0.31260100000+0.04063
库存:89
