V o l t a g e
P r o t e c t i o n
D e v i c e s
February 2022
RoHS
REACH
SVHC-Free
Chip varistors
ESD/Voltage protection devices
AVR/SGNE series
AVRM/AVR-M
AVRL
AVRH
SGNE
: Standard Type
: Low Capacitance Type
: High reliability Type
: Low Clamp Type
Cl
Br
Pb
Halogen
Free
Lead
Free
(2/12)
Voltage Protection Devices
RoHS Directive Compliant Product
Compatible with lead-free solders
Chip varistors
Overview of the AVR/SGNE series
CHARACTERISTICS OF CHIP VARISTOR
Varistors are voltage dependent nonlinear resistive elements with
a resistance that decreases rapidly when the voltage is over the
constant value.
Varistors become zener diode of 2 serial connection and equivalent, and does not have polarity.
CURRENT vs. VOLTAGE CHARACTERISTICS
EQUIVALENT CIRCUIT OF CHIP VARISTORS
2 Zener Diodes
A capacitance content
CHIP VARISTORS FEATURE
IEC61000-4-2 LEVEL4 compliant.
Reliability characteristics evaluated based on AEC-Q200 condition. (Automotive products)
High ESD withstanding voltage
Small-sized products are available
125°C, 150°C Supported
Current(A)
10–1
10–2 Zener diode
/Vz:6.8V
Positive direction
10–3
Chip varistor
/V1mA:12V
10–4
10–5
–18 –14
–10
–6
–2
2
–10–5
6
10
14
18
–10–4
–10–3
Negative direction
Fig.1 Internal structure of multilayer chip varistors
–10–2
–10–1
①
Voltage(V)
THE EFFECT OF THE VARISTOR
Without varistor
A malfunction and failure of electronic equipment
ESD, Surge voltage
Power line
Signal line
IC
②
⑤
④
③
With Varistor
Suppress abnormal voltage by inserting varistor in a circuit
ESD, Surge voltage
Power line
Signal line
IC
No.
(1)
(2)
(3)
(4)
(5)
Name
Semiconductor ceramics
Internal electrode(Pd)
Ag
Terminal electrode Ni
Sn
Insert a varistor between
a line and ground
: Chip varistor
20220209 / vpd_varistors_avr_en.fm
(3/12)
Chip varistors
PART NUMBER CONSTRUCTION
AVRM
1608
C
LxW
dimensions
(mm)
0402
0.4x0.2
0603
0.6x0.3
1005
1.0x0.5
1608
1.6x0.8
2012 2.0×1.2
Series name
AVR-M
390
C General structure
10
1A
Series name
LxW
dimensions
(mm)
Maximum
continuous voltage
(V)
04
06
10
16
1A
1D
1E
AVRH
10
Series name
LxW
dimensions
(V)
1.0x0.5
SGNE
04
Series name
LxW
dimensions
W
L
T
B
R50
1R1
3R3
6R8
Varistor
voltage
Structure
code
C
General
structure
270=27×100
270
390
101
04
06
10
(pF)
270
(mm)
1005
Capacitance
C
General structure
Shape symbol (JIS)
0402
0603
1005
1608
2012
Capacitance
tolerance
K
M
N
T
AAB
Packaging style
Company
special symbol
T
B
Taping
Bulk
F
T
A
Capacitance
tolerance
(pF)
Packaging style
Company
special symbol
F
G
N
±1
±2
±0.3
±10
±20
±30
T
B
Taping
Bulk
150
N
A
8
Varistor
voltage
tolerance
Packaging
style
Capacitance
Capacitance
tolerance
ESD voltage
amount
IEC61000-4-2
(kV)
Operating
temperature
limit
(°C)
K
Varistor
voltage
(V)
080=8×100
080
8
270
27
L
0.40±0.02
0.60±0.03
1.00±0.05
1.60±0.10
2.00±0.20
Capacitance
T
(pF)
±10
080
Structure
code
N
K
27
39
100
C
(mm)
0.4x0.2
0.6x0.3
1.0×0.5
0.5
1.1
3.3
6.8
271
(pF)
271=27×101
221
220
271
270
Taping
Bulk
Varistor voltage
tolerance
K
±10
M
±20
N
±30
3R3
10
C
T
B
M
Varistor
voltage
(V)
270=27×100
080
8
120
12
270
27
General structure
Conductive paste compatible
AVRL
0.4x0.2
0.6x0.3
1.0×0.5
1.6×0.8
Packaging style
270
Structure code
C
G
T
Varistor voltage
tolerance
K
±10
M
±20
N
±30
C
LxW
dimensions
(mm)
0603
0.6x0.3
1005
1.0x0.5
1608
1.6x0.8
2012 2.0×1.2
Series name
Varistor
voltage
(V)
390=39×100
6R8
6.8
270
27
390
39
Structure code
1608
K
T
Taping
B
Bulk
M
Varistor
voltage
tolerance
K
±10
W
0.20±0.02
0.30±0.03
0.50±0.05
0.80±0.10
1.25±0.20
150=15×100
K
±10%
A
25
4R7
150
500
M
N
Y
±20%
±30%
±0.13pF
E
8
4.7
15
50
8
150
T
150
N
25
Packaging
style
Capacitance
Capacitance
tolerance
ESD clamping voltage
Average voltage
(IEC61000-4-2, 8kV)
T
B
T
0.20±0.02
0.30±0.03
0.50±0.05
0.80±0.10
0.70±0.20
Taping
Bulk
(pF)
150=15×100
6R8
4.7
150
15
N
Y
±30%
±0.13pF
B
0.07min.
0.1min.
0.1min.
0.2min.
0.2min.
Please be sure to request delivery specifications that provide further details on the features and specifications of the products for proper and safe use.
Please note that the contents may change without any prior notice due to reasons such as upgrading.
(4/12)
Chip varistors
TERMINOLOGY
Item
Varistor voltage
(Breakdown voltage)
Unit
V1mA
(V)
Maximum continuous voltage
Vdc
(V)
Clamping voltage
Maximum energy
Maximum peak current
Capacitance
1
Vcl
(V)
E
(Joule)
Ip
(A)
C
(pF)
Chip varistor-terminal voltage when DC1mA was flowed
DC voltage that is continuously applied between chip varistor terminals
Terminal chip varistors leakage current-value: 50µA max.
Voltage appearing across the varistor when a pulse current (8/20µs?1) of specified peak value is
applied.
Voltage between terminal chip varistors of the Specified peak current value of the impulse current (8/
20µs1) is applied
When applied specified peak impulse current-value current (10/1000µs2) once, maximum energy that
electrical property of chip varistors be not deteriorated
When applied impulse current (8/20µs1) once, maximum current that electrical property of chip varistors be not deteriorated
Oscillator frequency 1kHz or 1MHz, capacitance between chip varistor-terminal in oscillator voltage
1Vrms
2
8/20µs test waveform
100%
90%
10/1000µs test waveform
100%
90%
Current
Current
Description
50%
8µs
50%
10µs
20µs
1000µs
Time
Time
(5/12)
Chip varistors
AVR/SGNE series Product characteristics list
PRODUCT CHARACTERISTICS LIST
Item
V (1mA)
C1kHz
*C1MHz
Vdc
AVRL041E1R1NTA
AVRM0402C120MT330N
AVRM0402C6R8NT101N
SGNE04C080MT150N25
AVRL061E1R1NTA
AVRL061FR50ETA
AVRM0603C080MT101N
AVRM0603C120MT101N
AVRM0603C120MT150N
AVR-M0603C120MTAAB
AVRM0603C200MT150N
AVRM0603C6R8NT101N
AVRM0603C6R8NT331N
SGNE06C080MT150N25
SGNE06C270MT6R8G60
AVRL101A1R1NTA
AVRL101E1R1NTB
AVRL101D3R3FTA
AVRL101D6R8GTA
AVR-M1005C080MTAAB
AVR-M1005C080MTABB
AVR-M1005C080MTACB
AVR-M1005C080MTADB
AVR-M1005C120MTAAB
AVR-M1005C120MTACC
AVR-M1005C180MTAAB
AVRM1005C270KT101N
AVR-M1005C270MTAAB
AVR-M1005C270MTABB
AVRM1005C6R8NT101N
AVRM1005C6R8NT331N
SGNE10C080MT150N28
AVRH10C270KT150NA8
AVRH10C270KT350NA8
AVRH10C390KT500NA8
AVRH10C101KT4R7FA8
AVRH10C101KT1R1NE8
AVRH10C221KT1R5YA8
AVRL161A1R1NTA
AVRL161A1R1NTB
AVRL161D3R3FTA
AVRL161D6R8GTA
AVR-M1608C080MTAAB
AVR-M1608C120MT2AB
AVR-M1608C120MT6AB
AVR-M1608C180MT6AB
AVR-M1608C220KT2AB
AVR-M1608C220KT6AB
AVR-M1608C270MTABB
AVR-M1608C270MTAAB
AVR-M1608C270KTACB
AVRM1608C270KT800M
AVR-M1608C270KT2AB
AVRM1608C270KT221M
AVR-M1608C270KT6AB
AVR-M1608G270KT6AB
AVRM1608C390KT271N
AVRM1608C560KT101M
AVRM1608C720KT750M
AVR-M2012C120MT6AB
AVR-M2012C220KT6AB
AVRM2012C330KT801N
AVR-M2012C390KT6AB
AVRM2012C560KT251M
AVRM2012C720KT201M
(V)
39(31.2 to 46.8)
12(9.6 to 14.4)
6.8(4.76 to 8.84)
8(6.4 to 9.6)
39(35.0 to 43.0)
140(112 to 168)
8(6.4 to 9.6)
12(9.6 to 14.4)
12.8(10.0 to 15.6)
12(9.6 to 14.4)
20(16 to 24)
6.8(4.76 to 8.84)
6.8(4.76 to 8.84)
8(6.4 to 9.6)
27(21.6 to 32.4)
90(79.6 to 110.4)
39(31.2 to 46.8)
27(21.6 to 32.4)
27(21.6 to 32.4)
8(6.4 to 9.6)
8(6.4 to 9.6)
8(6.4 to 9.6)
8(6.4 to 9.6)
12(9.6 to 14.4)
12(9.6 to 14.4)
18(14.4 to 21.6)
27(24.0 to 30.0)
27(21.6 to 32.4)
27(21.6 to 32.4)
6.8(4.76 to 8.84)
6.8(4.76 to 8.84)
8(6.4 to 9.6)
27(24.0 to 30.0)
27(24.0 to 30.0)
39(35.0 to 43.0)
100(90 to 110)
110(100 to 120)
220 (198 to 242)
90(79.6 to 110.4)
39(31.2 to 46.8)
27(21.6 to 32.4)
27(21.6 to 32.4)
8(6.4 to 9.6)
12(9.6 to 14.4)
12(9.6 to 14.4)
18(14.4 to 21.6)
22(19.8 to 24.2)
22(19.8 to 24.2)
27(21.6 to 32.4)
27(21.6 to 32.4)
27(24.0 to 30.0)
27(24.0 to 30.0)
27(24.0 to 30.0)
27(24.0 to 30.0)
27(24.0 to 30.0)
27(24.0 to 30.0)
39(35.0 to 43.0)
56(50.4 to 61.6)
72(64.8 to 79.2)
12(9.6 to 14.4)
22(19.8 to 24.2)
33(29.7 to 36.3)
39(35.0 to 43.0)
56(50.4 to 61.6)
72(64.8 to 79.2)
(pF)
1.1(0.8 to 1.4)*
33(23.1 to 42.9)
100(70 to 130)
15(10.5 to 19.5)
1.1(0.8 to 1.4)*
0.5(0.3 to 0.7)*
100(70 to 130)
100(70 to 130)
15(10.5 to 19.5)
33(23.1 to 42.9)
15(10.5 to 19.5)*
100(70 to 130)
330(231 to 429)
15(10.5 to 19.5)
6.8(4.8 to 8.8)*
1.1(0.8 to 1.4)*
1.1(0.8 to 1.4)*
3.3(2.3 to 4.3)*
6.8(4.8 to 8.8)*
650(520 to 780)
100(55 to 145)
33(14 to 52)
480(384 to 576)
130(104 to 156)
460(276 to 644)*
120(72 to 168)*
100(70 to 130)
40(30 to 48)
15(10.5 to 19.5)
100(70 to 130)
330(231 to 429)
15(10.5 to 19.5)
15(10.5 to 19.5)
35(24.5 to 45.5)
50(35 to 65)
4.7(3.7 to 5.7)*
1.1(0.8 to 1.4)*
1.5(1.37 to 1.63)*
1.1(0.8 to 1.4)*
1.1(0.8 to 1.4)*
3.3(2.3 to 4.3)*
6.8(4.8 to 8.8)*
650(520 to 780)
400(320 to 480)
1050(840 to 1260)
600(480 to 720)
210(147 to 273)
560(392 to 728)
15(10.5 to 19.5)
30(21 to 39)
60(42 to 78)
80(64 to 96)
160(112 to 208)
220(176 to 264)
430(301 to 559)
430(301 to 559)
270(189 to 351)
100(80 to 120)
75(60 to 90)
1000(550 to 1450)
800(560 to 1040)
800(560 to 1040)
430(387 to 483)
250(200 to 300)
200(160 to 240)
DC (V)
25
5.5
3.5
5.5
25
30
5.5
5.5
5.5
7.5
12
3.5
3.5
5.5
15
10
25
5.5
5.5
5.5
7.5
7.5
11
19
15
15
3.5
3.5
5.5
19
19
28
70
70
70
10
10
7.5
7.5
11
16
16
17
17
19
19
19
19
19
19
28
40
53
7.5
16
24
28
40
53
Clamping
voltage
8/20µs
Vcl (V)
20(1A)
15(1A)
21(1A)
17(1A)
20(1A)
35(1A)
23(1A)
40(1A)
14(1A)
14(1A)
21(1A)
54(1A)
62(0.5A)
58(1A)
14(1A)
15(1A)
19(1A)
14(1A)
20(1A)
21(1A)
30(1A)
44(1A)
47(1A)
49(1A)
14(1A)
15(1A)
21V(1A)
52(2A)
52(2A)
72(2A)
190(1A)
190 (0.3A)
400 (0.5A)
62(0.5A)
58(1A)
15(2A)
20(2A)
20(2A)
30(2A)
37(2A)
34(2A)
52(2A)
52(2A)
54(2A)
53(2A)
42(2A)
52(2A)
42(2A)
42(2A)
69(2A)
113(2A)
135(2A)
20(5A)
38(5A)
59(5A)
62(5A)
113(5A)
142(5A)
Maximum
energy
10/1000µs
E (J)
0.005
0.01
0.005
0.01
0.01
0.003
0.01
0.01
0.01
0.02
0.005
0.005
0.01
0.01
0.04
0.02
0.01
0.04
0.05
0.01
0.06
0.06
0.04
0.05
0.02
0.008
0.01
0.02
0.02
0.02
0.03
0.01
0.01
0.01
0.01
0.09
0.06
0.09
0.10
0.03
0.10
0.05
0.05
0.05
0.02
0.10
0.10
0.10
0.10
0.10
0.10
0.10
0.20
0.30
0.50
0.30
0.30
0.30
Maximum
peak current
8/20µs
Ip (A)
1
4
1
4
5
1
1
1
10
16
1
1
0.5
1
25
3
1
25
10
24
16
4
47
1
10
24
19
2
8
15
1
0.3
0.5
0.5
1
30
15
50
30
10
30
2
2
10
28
48
48
78
60
40
60
100
240
100
150
100
Operating
temperature
range
(°C)
–40 to +85
–40 to +85
–40 to +85
–40 to +85
–40 to +85
–40 to +85
–40 to +85
–40 to +85
–40 to +85
–40 to +85
–40 to +85
–40 to +85
–40 to +85
–40 to +85
–40 to +85
–40 to +85
–40 to +85
–40 to +125
–40 to +125
–40 to +85
–40 to +85
–40 to +85
–40 to +85
–40 to +85
–40 to +85
–40 to +85
–40 to +85
–40 to +85
–40 to +85
–40 to +85
–40 to +85
–40 to +85
–55 to +150
–55 to +150
–55 to +150
–55 to +150
–55 to +150
–55 to +150
–40 to +85
–40 to +85
–40 to +125
–40 to +125
–40 to +85
–40 to +85
–40 to +85
–40 to +85
–40 to +125
–40 to +125
–55 to +150
–55 to +150
–55 to +150
–55 to +150
–55 to +150
–55 to +150
–55 to +150
–55 to +150
–55 to +150
–55 to +150
–55 to +150
–40 to +85
–40 to +125
–55 to +150
–55 to +150
–55 to +150
–55 to +150
IEC61000-4-2
(Contact)
150pF/330
4kV (Level2)
8kV (Level4)
8kV (Level4)
8kV (Level4)
4kV (Level2)
4kV (Level2)
8kV (Level4)
8kV (Level4)
8kV (Level4)
8kV (Level4)
8kV (Level4)
8kV (Level4)
8kV (Level4)
8kV (Level4)
8kV (Level4)
8kV (Level4)
4kV (Level2)
8kV (Level4)
8kV (Level4)
8kV (Level4)
8kV (Level4)
8kV (Level4)
8kV (Level4)
8kV (Level4)
8kV (Level4)
8kV (Level4)
8kV (Level4)
8kV (Level4)
8kV (Level4)
8kV (Level4)
8kV (Level4)
8kV (Level4)
25kV
25kV
25kV
25kV
8kV (Level4)
25kV
8kV (Level4)
4kV (Level2)
8kV (Level4)
8kV (Level4)
8kV (Level4)
8kV (Level4)
8kV (Level4)
8kV (Level4)
25kV
25kV
25kV
25kV
25kV
25kV
25kV
25kV
25kV
25kV
25kV
25kV
25kV
8kV (Level4)
25kV
25kV
25kV
25kV
25kV
AEC-Q200
(6/12)
Chip varistors
AVR/SGNE series
Electrostatic absorption characteristics
DISCHARGE VOLTAGE WAVEFORM (EXAMPLE)
1800
1600
1400
1200
1000
800
600
400
200
–200
–50
WAVEFORM AT VARISTOR INSTALLATION
Without Varistor
Voltage(V)
Voltage(V)
WITHOUT VARISTOR, WAVEFORM AT VARISTOR INSTALLATION
AVRH10C270KT150NA8
AVR-M1608C270KT6AB
AVR-M1608C220KT6AB
100
150
Time(ns)
200
250
300
180
160
140
120
100
80
60
40
–20
–50
AVRH10C270KT150NA8
AVR-M1608C270KT6AB
AVR-M1608C220KT6AB
100
150
Time(ns)
200
250
300
Test conditions
150pF/330 (IEC61000-4-2)
Contact discharge, Charged voltage 8kV
TEST CIRCUIT DIAGRAM
Discharge gun
Test
sample
60dB attenuator
ESD
simulator
50Ω
Oscilloscope
I/O impedance: 50Ω
Shield
Discharge
Point
SMA
Connector
PCB
ESD Simulator
Chip
Varistor
Coaxial
Cable
Attenuator(60dB)
50Ω
Oscilloscope
50Ω
(7/12)
Chip varistors
Attention on a circuit board design
Board design
When attached to chip varistors, amount of silver used (fillet size)
has direct impact on chip varistors after mounting. Thus, sufficient
consideration is necessary.
Set of land dimensions
(1) As the stress rises in the chip varistors owing to the increase in
silver, breakage and cracks will occur. Cause including crack, as
caution on board land design, configure the shape and dimensions
so that the amount of silver is appropriate. If you installed 2 or
more parts in the Common Land, separated by a solder resist and
special land of each component.
C
B
(2) When peak levels panning-at soldering is excessive, by solder
contraction stress, mechanical-thermal stress causes a Yasuku
chip crack. In addition, when the peak level is underestimated, terminal electrode fixed strength is insufficient. This causes chip
dropouts and may affect circuit reliability. Representative example
of the panning of peak levels is shown in the following.
Recommended silver dose
Solder stress is increased,
and it is easy for a crack to
form.
Solder volume
overload
Most large serving amount
Minimum prime amount
Decent solder
volume
Fixed strength is weak, and
there is connection a problem and risk of loss.
Solder volume
deficit
A
Case and suggested protocol want to avoid
Dimensions shape
0402
0603
1005
1608
2012
Symbol
A
0.20 Nom.
0.25 to 0.35
0.30 to 0.50
0.60 to 0.80
0.90 to 1.20
B
0.15 to 0.21
0.20 to 0.30
0.35 to 0.45
0.60 to 0.80
0.70 to 0.90
C
0.18 to 0.20
0.25 to 0.35
0.40 to 0.60
0.60 to 0.80
0.90 to 1.20
Example
Improvement example
(land division)
Cases to avoid
Leads
Chip
Leads
Solder
Solder resist
Lead wire and land
of part discrete
doubles up
PCB
Chassis
Solder
(ground solder)
Solder resist
Arrangements in
the vicinity
L1
L2
L2>L1
Land
Arrangements of
chip component's
companion
Excess solder
Solder resist
Land
Missing solder
(8/12)
Chip varistors
Arrangements of components
(1) I was based on camber of substrate and suggested protocol of
chip varistors arrangement, as stress does not join to the utmost is
shown in following.
(2) In payment near by board, depending on mount position of chip
varistors, as mechanical stress varies, please refer to the following
diagram.
Substrate for flexural stress Substrate for flexural stress
Adverse events
Good example
E
D
Perforation
Perforation or slit
C
Perforation or slit
B
A
Direction of
surface solder
Slit
Solder the mountain fold as a Solder the mountain fold as a
top.
bottom. [Please review the
italicized portion, as I am
unsure what you mean to convey here.]
Perforation or slit
The order of A > B = C > D > E eases the stress.
Perforation or slit
Chip
arrangements
(direction)
Mounted vertically to the per- Mounted horizontally to the
foration and slit.
perforation and slit.
L1
Distance from
perforation
and slit
portion
L2
(L1
很抱歉,暂时无法提供与“AVR-M2012C220KT6AB”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+1.283201+0.16532
- 100+1.15821100+0.14922
- 300+0.79158300+0.10199
- 500+0.72492500+0.09340
- 1000+0.666601000+0.08588
- 4000+0.624934000+0.08052
- 5000+0.624935000+0.08052
- 国内价格 香港价格
- 2000+0.989412000+0.12747
- 4000+0.956394000+0.12322
- 6000+0.939846000+0.12109
- 10000+0.9215410000+0.11873
- 14000+0.9108314000+0.11735
- 20000+0.9005220000+0.11602
- 国内价格
- 1+0.34546
- 100+0.32243
- 300+0.29940
- 500+0.27637
- 2000+0.26485
- 5000+0.25794
- 国内价格
- 5+0.88860
- 50+0.69910
- 150+0.57630
- 500+0.51300
- 2000+0.46240
- 4000+0.43200
