SMT inductors
SIMID series, SIMID 1812-T
Series/Type:
B82432T
Date:
June 2019
a~í~=pÜÉÉí
¤TDK Electronics AG 2019. Reproduction, publication and dissemination of this publication, enclosures hereto
and the information contained therein without TDK Electronics’ prior express consent is prohibited.
SMT inductors, SIMID series
B82432T
SIMID 1812-T
Size 1812 (EIA) or 4532 (IEC)
Rated inductance 1 ... 1000 μH
Rated current 70 ... 1300 mA
Construction
■ Upright ferrite drum core
■ Laser-welded winding
■ Flame-retardant molding
Features
Temperature range up to +150 °C
High current handling capability
Qualified to AEC-Q200
Suitable for lead-free reflow soldering
as referenced in JEDEC J-STD 020D
■ RoHS-compatible
Applications
Filtering of supply voltages, coupling, decoupling
DC/DC converters
Automotive electronics (e.g. single-wire bus systems)
Telecommunications
Industrial electronics
Terminals
■ Base material CuSn6
■ Layer composition Cu, Ag, Sn (lead-free)1)
■ Electro-plated
Marking
■ Marking on component:
Manufacturer and letter “T”,
L value (in PH), tolerance of L value (coded),
date of manufacture (YWWD)
■ Minimum data on reel:
Manufacturer, ordering code, L value, quantity, date of packing
Delivery mode and packing unit
■ 12-mm blister tape, wound on 330-mm reel
■ Packing unit: 2500 pcs./reel
1) Ni-barrier-plated terminals on request (B82432T*50).
Please read Cautions and warnings and
Important notes at the end of this document.
2
06/19
B82432T
SIMID 1812-T
Dimensional drawing and layout recommendation
A
B
C
D
3.6
1.3
3.2
5.8
Dimensions in mm
Taping and packing
Blister tape
Reel
Dimensions in mm
3
06/19
B82432T
SIMID 1812-T
Technical data and measuring conditions
Rated inductance LR
Measured with impedance analyzer Agilent 4294A
or equivalent at frequency fL, 0.1 V, +20 °C
Q factor Qmin
or equivalent at frequency fQ, +20 °C
Rated temperature TR
+85 qC
Rated current IR
Maximum permissible DC with inductance decrease
'L/L0 d10% and temperature increase
of d 40 K at rated temperature
Self-resonance frequency fres,min
Measured with impedance analyzer Agilent 4294A / E4991A
or equivalent, +20 °C
DC resistance Rmax
Measured at +20 qC
Solderability (lead-free)
Sn95.5Ag3.8Cu0.7: +(245 r5) °C, (5 r0.3) s
Wetting of soldering area t90%
(based on IEC 60068-2-58)
Resistance to soldering heat
+260 qC, 40 s (as referenced in JEDEC J-STD 020D)
Climatic category
55/150/56 (to IEC 60068-1)
Storage conditions
Mounted: –55 °C … +150 °C
Packaged: –25 °C … +40 °C, d 75% RH
Weight
Approx. 130 mg
Characteristics and ordering codes
Tolerance
Ordering code 1)
fL ; fQ
IR
Rmax
fres,min
MHz
mA
MHz
10
7.96
1300
0.08
110
B82432T1102K000
1.2
10
7.96
1200
0.10
100
B82432T1122K000
1.5
10
7.96
1150
0.11
80
B82432T1152K000
1.8
10
7.96
1050
0.13
70
B82432T1182K000
2.2
10
7.96
1000
0.15
60
B82432T1222K000
2.7
10
7.96
950
0.17
55
B82432T1272K000
3.3
10
7.96
900
0.19
50
B82432T1332K000
3.9
10
7.96
850
0.20
45
B82432T1392K000
4.7
10
7.96
800
0.22
40
B82432T1472K000
5.6
10
7.96
750
0.26
38
B82432T1562K000
6.8
10
7.96
700
0.30
36
B82432T1682K000
8.2
10
7.96
670
0.33
30
B82432T1822K000
LR
Qmin
PH
1.0
r10%
K
1) For Ni-barrier-plated terminals replace the last two digits “00” by “50”.
4
06/19
B82432T
SIMID 1812-T
Tolerance
Ordering code 1)
fL ; fQ
IR
Rmax
fres,min
MHz
mA
MHz
10
2.52
650
0.35
25
B82432T1103K000
12
10
2.52
630
0.45
23
B82432T1123K000
15
10
2.52
600
0.50
B82432T1153K000
18
10
2.52
550
0.60
18
B82432T1183K000
22
10
2.52
450
0.70
15
B82432T1223K000
27
10
2.52
430
1.00
14
B82432T1273K000
33
10
2.52
400
1.20
13
B82432T1333K000
39
10
2.52
380
1.30
12
B82432T1393K000
47
10
2.52
350
1.35
11
B82432T1473K000
56
10
2.52
300
2.00
10
B82432T1563K000
68
10
2.52
250
2.50
8.0
B82432T1683K000
82
10
2.52
220
3.00
7.0
B82432T1823K000
100
200
3.50
6.5
B82432T1104K000
120
180
4.50
6.3
B82432T1124K000
150
160
6.00
6.1
B82432T1154K000
180
140
7.00
5.5
B82432T1184K000
220
130
7.50
4.5
B82432T1224K000
270
120
10.5
4.3
B82432T1274K000
330
120
11.0
4.1
B82432T1334K000
390
110
13.0
3.9
B82432T1394K000
470
100
15.0
3.5
B82432T1474K000
560
90
20.0
3.0
B82432T1564K000
680
80
23.0
2.6
B82432T1684K000
820
80
27.0
2.4
B82432T1824K000
1000
70
30.0
2.3
B82432T1105K000
LR
Qmin
PH
10
r10 %
K
Closer tolerances on request.
Higher currents possible at temperatures
很抱歉,暂时无法提供与“B82432-T1273-K”相匹配的价格&库存,您可以联系我们找货
