I N D U C T O R S
Inductors for power circuits
Wound metal
BCL series (for automotive)
RoHS
REACH
SVHC-Free
Cl
Br
Pb
Halogen
Free
Lead
Free
AEC-Q200
BCL322515RT-D type
FEATURES
The adoption of the new method has resulted in a high inductance that could not be achieved with conventional metallic materials.
Due to the properties of metallic materials, they are more able to handle larger currents than ferrite materials.
The use of high-µ materials has made it possible to achieve low Rdc in metal products.
The coil is fully encapsulated with a magnetic material to minimize leakage flux.
Supports rated voltage of 40V.
Operating temperature range: –55 to +155°C (including self-temperature rise)
Compliant with AEC-Q200.
APPLICATION
ADAS - Level5 for Camera
PART NUMBER CONSTRUCTION
BCL
322515
RT
Series name
LxWxH dimensions
3.2x2.5x1.5 mm
Internal code
470
M
Inductance
(µH)
Inductance
tolerance
D
Internal code
CHARACTERISTICS SPECIFICATION TABLE
L
Measuring
frequency
DC resistance
Rated current
Isat
(µH)
Tolerance
(MHz)
( )max.
( )typ.
(A)max.
(A)typ.
4.7
±20%
1
0.16
0.13
1.71
2.14
6.8
±20%
1
0.21
0.19
1.43
1.79
10
±20%
1
0.32
0.28
1.20
1.51
15
±20%
1
0.48
0.41
0.98
1.23
22
±20%
1
0.71
0.61
0.80
1.00
33
±20%
1
1.11
0.97
0.68
0.85
47
±20%
1
1.40
1.22
0.57
0.72
Rated current: smaller value of either Isat or Itemp.
Isat: When based on the inductance change rate (30% below the nominal value)
Itemp: When based on the temperature increase (temperature increase of 40°C by self heating)
Part No.
Itemp
(A)typ.
2.08
1.79
1.50
1.19
0.96
0.75
0.67
BCL322515RT-4R7M-D
BCL322515RT-6R8M-D
BCL322515RT-100M-D
BCL322515RT-150M-D
BCL322515RT-220M-D
BCL322515RT-330M-D
BCL322515RT-470M-D
Measurement equipment
Measurement item
Product No.
L
E4990A
DC resistance
AX-114N
* Equivalent measurement equipment may be used.
Manufacturer
Keysight Technologies
ADEX
Please be sure to request delivery specifications that provide further details on the features and specifications of the products for proper and safe use.
Please note that the contents may change without any prior notice due to reasons such as upgrading.
(1/4)
20211117
inductor_automotive_power_bcl322515rt-d_en.fm
I N D U C T O R S
BCL322515RT-D type
L FREQUENCY CHARACTERISTICS
1000
470M
330M
220M
100
Inductance(µH)
150M
100M
6R8M
4R7M
10
1
0.1
0.1
1
10
100
Frequency(MHz)
Product No.
Manufacturer
E4990A
L VS. DC BIAS CHARACTERISTICS
60
50
Inductance(µH)
40
30
470M
330M
220M
150M
10
100M
6R8M
4R7M
1
1.5
2
2.5
DC current(A)
Product No.
Manufacturer
6500B
KUWAKI ELECTRONICS
(2/4)
20211117
I N D U C T O R S
BCL322515RT-D type
SHAPE & DIMENSIONS
PACKAGING STYLE
REEL DIMENSIONS
0.5
2.5±0.2
2.5±0.2
2.0±0.5
(0.8)
(1.6)
(0.8)
1.5max.
ø60
3.2±0.2
1.0
Dimensions in mm
ø13.0±0.5
9
ø21.0±0.8
13
ø180
Dimensions in mm
Sprocket
hole
1.55±0.05
2±0.1
4±0.1
B
8±0.1
2.5
0.3±0.05
1.75±0.1
(3.5)
TAPE DIMENSIONS
RECOMMENDED LAND PATTERN
1.0
1.6
A
K
1.0
Cavity
4±0.1
Dimensions in mm
Dimensions in mm
Type
BCL322515RT-D
RECOMMENDED REFLOW PROFILE
Soldering
2000 pcs/reel
TEMPERATURE RANGE, INDIVIDUAL WEIGHT
245°C
Temperature
K
1.65±0.1
Natural
cooling
Peak
230°C
B
(3.5)
PACKAGE QUANTITY
Package quantity
Preheating
A
(2.8)
230°C
Operating
Storage
Individual
temperature range
temperature range
weight
–55 to +155 °C
–55 to +155 °C
0.067 g
Operating temperature range includes self-temperature rise.
180°C
5s max.
150°C
60 to 120s
10 to 30s
Time
(3/4)
20211117
I N D U C T O R S
REMINDERS FOR USING THESE PRODUCTS
Before using these products, be sure to request the delivery specifications.
SAFETY REMINDERS
Please pay sufficient attention to the warnings for safe designing when using this products.
REMINDERS
The storage period is within 12 months. Be sure to follow the storage conditions (temperature: 5 to 40°C, humidity: 10 to 75% RH or
less).
If the storage period elapses, the soldering of the terminal electrodes may deteriorate.
Do not use or store in locations where there are conditions such as gas corrosion (salt, acid, alkali, etc.).
Storage conditions after mounting: –55°C to +155°C
Soldering corrections after mounting should be within the range of the conditions determined in the specifications.
If overheated, a short circuit, performance deterioration, or lifespan shortening may occur.
Do not use products that have received any excessive mechanical shock such as by being dropped.
When embedding a printed circuit board where a chip is mounted to a set, be sure that residual stress is not given to the chip due to
the overall distortion of the printed circuit board and partial distortion such as at screw tightening portions.
Self heating (temperature increase) occurs when the power is turned ON, so the tolerance should be sufficient for the set thermal
design.
Do not expose the products to magnets or magnetic fields.
The performance of the product may deteriorate if coating materials are used, thus please assess the situation beforehand by taking
this factor into consideration.
Do not use for a purpose outside of the contents regulated in the delivery specifications.
The products described in this catalog are intended to be installed in automobiles or automotive electronic equipment (AV equipment,
telecommunications equipment, home appliances, amusement equipment, computer equipment, personal equipment, office equipment, measurement equipment, industrial robots) and to be used in automobiles (including the case where the said automotive product
is mounted in a vehicle) or standard applications as general electronic equipment in automotive applications or standard applications
as general electronic equipment in automotive applications in accordance with the scope and conditions described in this specification,
while the said automotive or general electronic equipment including the said product is intended to be used in the usual operation and
usage methods, respectively. Other than automotive or automotive products are not designed or warranted to meet the requirements of
the applications listed below, whose performance and/or quality requires a more stringent level of safety or reliability, or whose failure,
malfunction or defect could cause serious damage to society, person or property.
Please understand that we are not responsible for any damage or liability caused by use of the products in any of the applications
below or for any other use exceeding the range or conditions set forth in this specification sheet.
If you intend to use the products in the applications listed below or if you have special requirements exceeding the range or conditions
set forth in this specification, please contact us.
(1) Aerospace/aviation equipment
(2) Transportation equipment (electric trains, ships, etc.)
(3) Medical equipment
(4) Power-generation control equipment
(5) Atomic energy-related equipment
(6) Seabed equipment
(7) Transportation control equipment
(8) Public information-processing equipment
(9) Military equipment
(10) Electric heating apparatus, burning equipment
(11) Disaster prevention/crime prevention equipment
(12) Safety equipment
(13) Other applications that are not considered general-purpose
applications
When designing your equipment even for general-purpose applications, you are kindly requested to take into consideration securing protection circuit/device or providing backup circuits in your equipment.
(4/4)
20211117
很抱歉,暂时无法提供与“BCL322515RT-4R7M-D”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+11.967601+1.55522
- 10+9.8347110+1.27805
- 25+9.0996325+1.18252
- 50+8.5788050+1.11484
- 100+8.08797100+1.05106
- 250+7.48310250+0.97245
- 500+7.05591500+0.91694
- 1000+6.729711000+0.87455
- 国内价格 香港价格
- 2000+6.095582000+0.79214
- 4000+5.749074000+0.74711
- 6000+5.555846000+0.72200
- 10000+5.4981310000+0.71450
- 国内价格
- 1+8.33760
- 10+8.15400
- 30+8.02440
- 国内价格 香港价格
- 2000+6.260752000+0.81360
