BEPC-25B-1111G
BEPC-25B-1111G
    TDK(东电化)
    BEPC-25B-1111G - Ferrite Cores For Power Supply and Signal Transformer EPC Cores - TDK Electronics
BEPC-25B-1111G 数据手册
EPC-13_TDK.pdf Ferrite Cores For Power Supply and Signal Transformer EPC Cores CORE SHAPES AND DIMENSIONS/CHARACTERISTICS C EPC Series C1 A Fig.1 C2 D U.S.PAT.4,760,366 EP.PAT.245,083(DE,FR,GB,NL) KS.UM50,836 TW.UM39,406 JP.PENDING C2 C1 A D C Type Fig.2 Fig. 3 1 1 1 1 2 1 4 1 C1 A Fig.3 D A Fig.4 ELECTRICAL CHARACTERISTICS WITHOUT AIR GAP Part No. PC44EPC10-Z PC50EPC10-Z H5C3EPC10-Z PC44EPC13-Z PC50EPC13-Z H5C3EPC13-Z PC44EPC17-Z PC50EPC17-Z PC44EPC19-Z PC50EPC19-Z PC44EPC25-Z PC50EPC25-Z PC44EPC25B-Z PC50EPC25B-Z PC44EPC27-Z PC50EPC27-Z PC44EPC27N-Z ∗ C2 C1 D EPC10 EPC13 EPC17 EPC19 EPC25 EPC25B EPC27 EPC27N EPC30 Dimensions (mm) A C 10.2±0.2 3.4±0.1 13.25±0.3 4.6±0.15 17.6±0.4 6±0.15 19.1±0.4 6±0.15 25.1±0.5 8±0.2 25.1±0.5 6.5±0.2 27.1±0.5 8±0.2 27±0.4 5.1±0.1 30.1±0.5 8±0.2 C1 5±0.1 5.6±0.15 7.7±0.15 8.5±0.15 11.5±0.2 13.8±0.2 13±0.3 13.85±0.15 15±0.3 C2 1.9±0.1 2.05±0.1 2.8±0.1 2.5±0.1 4±0.1 2.5±0.15 4±0.1 2.2±0.1 4±0.1 D 4.05±0.1 6.6±0.2 8.55±0.2 9.75±0.2 12.5±0.2 11.4±0.15 16±0.2 13±0.1 17.5±0.2 Ae (mm2) 9.39 12.5 22.8 22.7 46.4 33.3 54.6 33 61 le (mm) 17.8 30.6 40.2 46.1 59.2 46.2 73.1 55.9 81.6 Weight (g) 1.1 2.1 4.5 5.3 13 11 18 10 23 C2 C C WITHOUT AIR GAP Calculated output power∗(W) 5.4[100kHz] 13[500kHz] Part No. PC44EPC30-Z PC50EPC30-Z ∗ AL-value (nH/N2) 1000±25% [1kHz, 0.5mA, 100Ts] 660±25% [1kHz, 0.5mA, 100Ts] 2660min. [10kHz, 10mV, 100Ts] 870±25% [1kHz, 0.5mA, 100Ts] 560±25% [1kHz, 0.5mA, 100Ts] 2450min. [10kHz, 10mV, 100Ts] 1150±25% [1kHz, 0.5mA, 100Ts] 740±25% [1kHz, 0.5mA, 100Ts] 940±25% [1kHz, 0.5mA, 100Ts] 680±25% [1kHz, 0.5mA, 100Ts] 1560±25% [1kHz, 0.5mA, 100Ts] 1080±25% [1kHz, 0.5mA, 100Ts] 1560±25% [1kHz, 0.5mA, 100Ts] 1080±25% [1kHz, 0.5mA, 100Ts] 1540±25% [1kHz, 0.5mA, 100Ts] 1030±25% [1kHz, 0.5mA, 100Ts] 1400±25% [1kHz, 0.5mA, 100Ts] AL-value (nH/N2) 1570±25% [1kHz, 0.5mA, 100Ts] 1060±25% [1kHz, 0.5mA, 100Ts] Calculated output power ∗(W) 85[100kHz] 180[500kHz] The values were obtained with forward converter mode. 8.6[100kHz] 19[500kHz] WITH AIR GAP Part No. PC44EPC10AXXX∗ PC50EPC10AXXX PC44EPC13AXXX PC50EPC13AXXX PC44EPC17AXXX PC50EPC17AXXX PC44EPC19AXXX PC50EPC19AXXX PC44EPC25AXXX PC50EPC25AXXX PC44EPC25BAXXX PC50EPC25BAXXX PC44EPC27AXXX PC50EPC27AXXX PC44EPC27NAXXX PC44EPC30AXXX PC50EPC30AXXX ∗ 20[100kHz] 35[500kHz] 27[100kHz] 55[500kHz] 63[100kHz] 127[500kHz] 45[100kHz] 87[500kHz] 80[100kHz] 161[500kHz] 43[100kHz] AL-value (nH/N2)[1kHz, 0.5mA, 100Ts] 40±7%, 63±10% 40±7%, 63±10% 40±4%, 63±5% 40±4%, 63±5% 80±4%, 125±5% 80±4%, 125±5% 80±4%, 125±5% 80±4%, 125±5% 125±5%, 200±7% 125±5%, 200±7% 80±5%, 125±7% 80±5%, 125±7% 125±5%, 200±7% 125±5%, 200±7% 80±5%, 125±7% 125±5%, 200±7% 125±5%, 200±7% XXX: AL-value The values were obtained with forward converter mode. Specifications which provide more details for the proper and safe use of the described product are available upon request. All specifications are subject to change without notice. Ferrite Cores For Power Supply and Signal Transformer EPC Cores BOBBINS SURFACE MOUNT TYPE H EPC Series Part No. BEPC-10-118GA BEPC-13-1110GA BEPC-17-119GA BEPC-19-1110GA BEPC-25B-1111G No. of lead terminal 8 10 9 10 11 W Dimensions (mm) W D 11 11.7 14.2 20.6 18.2 23.2 20.2 25.2 26.1 28.9 H 5.2 7.3 9.9 9.9 9.9 Clamp∗ FEPC-10-A FEPC-13-A FEPC-17-A FEPC-19-A FEPC-25B-A DROP-IN TYPE Part No. BEPC-19-1110SA BEPC-25B-1111S D D No. of pin terminal 10 11 W Dimensions (mm) W D 20.2 26.2 26 37.9 H H 9.8 9.5 Clamp∗ FEPC-19-A FEPC-25B-A LEAD-THROUGH TYPE Part No. D No. of pin terminal W BEPC-13-1110CPH 10 BEPC-17-1110CPH 10 BEPC-19-1111CPH 11 BEPC-25-1111CPH 11 BEPC-27-1111CPH 11 BEPC-27N-1114CPH 14 BEPC-30-1112CPH 12 ∗ Clamp material: Stainless steel • Material: FR phenol, UL Grade: 94V-0, Pin material: Steel wire (Solder plated) Dimensions (mm) W D 13.9 14.8 18.2 19.1 20 21.5 26.1 27 28.1 34 29 36.5 31.1 37 H H 7.7 12.1 12.1 16.2 16.2 9 16.2 Clamp∗ FEPC-13-A FEPC-17-A FEPC-19-A FEPC-25-A FEPC-27-A FEPC-27-A FEPC-30-A 132 980706 Specifications which provide more details for the proper and safe use of the described product are available upon request. All specifications are subject to change without notice.
BEPC-25B-1111G 价格&库存
很抱歉,暂时无法提供与“BEPC-25B-1111G”相匹配的价格&库存,您可以联系我们找货
